Visitor Agreement.
lol
Just amazing that otherwise "car nuts" would trust such a critical and SIMPLE procedure to someone who doesn't give a whit about your investment. Do you really pump your own gas!!??
No matter where I lived, no matter my economic station in life, I've always changed my own oil.
Sort of like brushing one's teeth....
I would appreciate feedback from anyone who has some useful knowledge to share with me on this matter. Thanks in advance.
Well, I am renting an apartment. My lease explicitly prohibit servicing cars on the parking lot.
I have one place that changes the oil and filter and does a complete lube job for $5.95, if you bring in your own oil and filter, and another place that does the same for $7.00. It just isn't worth it to do it myself to save only 6 or 7 bucks.
tom
This is not so important with newer cars, but was very useful while I drove an old Ford Taurus with 105-130K miles.
The Firestone mechanics found once a crack in the front half-axle, definitely a safety item. Couple of times found the joint cover was damaged on the axles. And other problems.
--- Bror Jace
Did you run your engine dry and then put some more oil in? Did you throw four quarts into an engine that already had four quarts in it?
If you mean, is it ok to put in an additional quart of oil if the level is at the bottom of the hashmark without changing the oil, then that's OK.
The moral of the story? Change your oil yourself. If you absolutely have to have it done, watch them like a hawk, because they'll screw you if you don't!
In gear oils though, a GL-5 should not be used where a GL-4 is specified, different additives and can injure some components
Mobil 1 brags about this on their bottles ... although I'm not sure I'd do the same if I were them.
--- Bror Jace
Why does putting ice cold oil into a hot engine not do any damage?
Combine that with the good info in the precceding post, and your reason should be clear.
dave
Spokane, I thought about its heat absorbing properties also, but didn't have confidence in that answer because of exactly what you mention: Its the job of the oil to remove heat. But I guess it is all relative, as you mention.
It has always scared me to be putting the cold oil right onto the cam. Now the cam doesn't have much meat relative to the block. But I guess the low conductivity you mention must be low enough!
Someone help us out here... what temperature range does the oil normally see?
We have a test for our paper (I work at a plant that makes automotive filter paper) where the paper is "cooked" in 400º F oil for 96 hours and then the paper is flex tested to check for brittleness. I know it's common for tests to be run under extreme conditions that the product would never actually see, just to accelerate the test and to have a big safety margin. So, maybe the oil wouldn't see 400º under normal conditions, but I'll bet 300+ is normal.
tom
Take Care
Ryan
--- Bror Jace
Think about the thin film of oil on the cylinder wall at the moment the fuel and air charge explodes to push the piston down. That tiny volume of oil must be at a rather high temperature. This must surely be the reason that a small amount of oil is "burning" as the engine runs, and you will eventually be able to detect that some oil has disappeared from the system.
http://www.unofficialbmw.com/all/misc/all_oilfaq.html
i know i've posted it in another topic, but these are real facts that may give some the answer they are looking for.
Once I brought my car in to have a flat fixed and have the oil and filter changed. I could have fixed the flat myself with one of those do it yourself expresso plug kits but figured why not have it done right seeing I needed an oil change anyway. So I left the car with the grease monkey and came back to pick it up at the end of the day. Charged me $12 for the flat repair and $23 for the oil change. The guy that worked on my car wrote up the bill. I paid the bill and headed home. Once home, I checked the dip stick to make sure he filled it up to the proper level. The stick had oil on it as black as coal---the oil obviously wasnt changed. I checked the tire repair and found that he had just inserted a plug like I could have done myself in 2 minutes instead of the proper inner patch. Well, I headed back and asked him why he didnt change the oil. He stated that he must have forgot. I said to him: "Yeah, but you didnt forget to charge me!" I also mentioned the improper flat repair and demanded a full refund which I received. Needless to say, I will not be heading back to that station for any future repair or maintenance work. Some unsuspecting customer would have driven the car for another 3,000 to 7,000 miles with dirty oil and a clogged filter. Dont think that would be too good for your engine.--Motto: Buyer Beware
Dealers and manufactrurers are sleazy, IMHO!!!!!!!!!!!!
As a matter of fact, BMW was reducing the servicing requirements on their cars years before service was rolled into the price. Brake fluid change intervals were doubled in the early nineties while coolant change intervals increased by 50%.
Now, while there is little doubt that BMW bumped up service intervals as they were assuming servicing costs, I fail to see anything "sleazy" about it. Does anyone have any evidence that the increased intervals are harmful? BMW ensured that oil and coolant were upgraded BEFORE any service intervals were increased.
In short, BMW effectively doubled the oil change interval TWO DECADES AGO- and doubled it again in 1999 with a switch to synthetic oil. Screwed? Right.
And i suppose you could pour in frozen oil from your garage, but if you're concerned, why not just put the 4 quarts on the fridge the night before?
BMW's oil changer intervals, are, i think ok. You have to recall:
1) Synthetic is assumed.
2) The have special high-density filters.
3) The engines hold a lot of oil.
4) The cooling system is pretty aggressive.
5) Suppsoedly the engine is tight enough that hardly any fuel or exhaust ever reaches the crankcase.
After 12,000 miles my oil still looks fine in my 328i. It always looked pretty dirty after 1,500 miles in my saurn.
dave
Who makes their oil for them??? Who even makes a 5W60, lots of additives in that one.
Plain ole arrogance. It also sounds like the we have a Bimmer dealer on board as feathers have been ruffled!
And yeah, that Peake reset tool nearly broke me... guess I'll be eating lunch meat for a couple of months;) BTW, I'm not a Bimmer dealer; I've just owned them since 1983...
