I start, drive, move and ride in new Civics every day. Probably an average of four a day?
I have NEVER had one fail to start or stall after it did start.
I have NEVER had one of my customers walk up to my desk and tell me that this was happening to a civic that I had sold them.
But...like anything, I'm sure there are isolated cases.
But love this car!
hope that helps, and maybe the honda mechanics should read their manuals, where the system is described in detail, and not run out and replace a perfectly fine alternator.
oh yeah, no other keys on the key chain, just the remote keyless entry, and preferrably on some kind of link that moves it farther from the key
let me know if it works.
Sorry to hear of so many problems. Once this is fixed, (and Honda will take care of it trust me) you'll have a great car for as many miles/years as you want to own it.
Two shops, including the dealer, says it's the dirty throttle body. So I have it cleaned. It's somewhat better but still hurts me to step on.
Anything more I should do ? Thanks
So, I dunno that your revs are a prob. I bet not. It sure is different than driving a vehicle redlined at 5.5K (and throwing rods at 6K), though.
Now after 2.5 weeks when I have my car back from them it looks fine on the outside. However when I drive it it immediately heats up! The temperature shoots up beyond the "H" mark even if the car has been driven for only 5 minutes. I called up the Honda body shop and they want me to bring it in!!! I tried to talk to them to tow it as the dealer's shop is some 30 miles from my home but they refuse!
I am extermely disappointed with the level of service I have been provided. The total repair bill was $3200 and if they can't get the car back in good shape after spending all this money then they should be ashamed of themselves.
I am thinking of complaining to American Honda. Is there anything else I can do? I have clearly been duped here. Honda is supposed to provide some sort of guarentee on their work???
Any help or pointers would be greatly appreciated
This morning the same roughness, but as I was traveling at highway speeds around 65mph, the engine temp was warming up to about the midpoint. I then let go of the gas to decelerate slightly to adjust for traffic and my engine light came on, nothing else. I took the next exit and when I came to a stop at the traffic light, my engine stalled and it wouldn't start anymore. it cranks fine, all the lights are on, the battery seems ok. I tried starting it for about 10 mins, waiting about 1 min before cranking it, it turns over, as if the engine is started so the cranking stops automatically, but it sounds as if there wasn't fuel to keep the engine running. After about 10 mins, it finally started and it ran fine, but the engine light stayed on.
So does anyone know what could be the cause of this light to come on? And after it comes on, does it stay on until a technician can inspect it and turn it off with special tools?
So instead of forking over $100 to the dealer to do a diagnostic test, I figured I'd reset the ECM myself, and if an O2 sensor or something was really wrong, the check engine light would come on again. I filled up my car with regular gasoline to dilute the stuff I put in. Then I took out the main battery fuse for about a minute to let it reset, then started up my car again and the check engine light stayed off (after its 2 second test). I had to dig up the Anti-theft radio code since the radio reset too.
Lesson from all of this, do not put anything in your gas tank that you aren't 100% sure of. I learned my lesson the hard way...it could have been a lot worse. Also supports my theory that most car problems are human caused rather than mechanical failures, as much as we'd like to deny it and blame it on someone else.
I spoke with Body Shop and they wanted me to drive there (some 30miles) even though the car was overheating within 5minutes. I drove the car for 2days from home to work and back (about2miles) and the car would reach "H" mark by the end of the trip.
Bodyshop towed the car from my work to their shop. They say that they found an air pocket in the coolant circulation system that they bled-off and now the car is driving without heating up.
However, I feel, that the engine has become noisier. I can hear the pistons or something moving each time I accelerate. Also, once I stepped on the brake and the whole car started shaking.
This is 3-4month old car and is covered by warranty so I am thinking of taking it to the Honda Service Shop even though I can not pin point what could be wrong. I'll let them figure out.
Any comments or suggestions?
Thanks for your help
DrDoMore
I have a problem with my Honda Civic and was wondering if anyone had any suggestions.
I bought this car new last January. Everything was fine for sometime. In October I took it on a 4-hour long trip on the highway. On my way back, it suddenly started making a whistiling noise and it continued to do so as soon as I went above 60 mph. Not knowing what it was, I freaked out and drove it home at 45mph. The next day, I took it to the dealer and he took a test run. The car didn't make any noise. The dealer told me they needed to hear the noise before doing anything else. We were not convinced and so tested it again on the highway for about 25 minutes. The car behaved just fine. We were quite relieved and took the dealer's explanation that it was caused by the road and wind conditions on that particular day. The car ran fine for a while. Last weekend we made a 3 hour trip on the highway. The whistling noise was back. It was very annoying. It continued continously for 2 and 1/2 hours during the trip. On our way back, we could drive about 40 miles before the noise started. This time it was intermittent. Once again we take it to the dealer and it does not make any noise. When we drive the car in the city it does not have the same noise problem.
Has anyone had a similar problem or have any suggestions about what it could be?
I replaced the washer pump on my 1999 Civic with a new one from Autozone. The pump looked exactly the same and installed very easily. The problem is that the fluid drains back into the tank when not in use. So it takes a few seconds to begin spraying out of the nozzles. My Honda dealer informed me that the Honda replacement pump has a one way valve to keep this from happening. The autozone pump cost 16.00 and a honda pump cost 40.00. The dealer did say however that I can purchase a small one way valve to install on my pump. I checked the local auto stores and no one carries this valve. Can someone please let me know where I can find this valve or any sggestions on how to go about fixing this? Any responses are appreciated.
regards,
Carrie ~Eternal Blue Pearl 2002 Honda Civic EX Sedan
Hope that helps you.
I have three questions:
1. The dealer said this service should have been done every 30k miles (it's never been done). I've always been told that if there is no ticking sound, everything is fine. What's the rule of thumb for civics on valve adjustments?
2. Does $80 sound right (I checked with 2 other dealers and they were right in that ballpark)? I have read posts on other cars where this adjustment was approx. $500.
3. Once the dealer takes off the valve cover, what is it likely that he could find damaged what are the tell tale signs I should have him show me to prove there is damage? The car runs really strong, so I'd be hard pressed to believe he'll find anything damaged?
I have some cars went over 180 k miles and never had any valve adjusted. I do change brake fluid tho.
Have you learned anything more about why yours is doing it?
is it possible to just "disconnect" the 2001-2003 Civic immobilizer at the dealer's service department ?
Or would this cause other warning lights to illuminate ?
