Visitor Agreement.
good luck
THANX!!!
I asked the dealership and they told me you need a good flashlight to look in there. Unfortunately when I went there one evening to have fluids checked and show me what all i need to check, etc. they could not find a flashlight..
Anyways only have 1,500 miles on my '03 EX and will probably go to dealership on day off Friday to have them checked again. I want them to show me so I can find the easiest way to see it. I'm sure they know a trick or two.
g85
1990 Honda Civc LX won't start.
Engine turns over easily, everything sounds and smells normal, except - no ignition!
Spark plug spark is VERY weak and faint.
Problem began last week, I started it up briefly during some SUB-ZERO weather - to move the car a couple of feet. The car ran well for less than a minute, then I turned it off and it sat another few days until I tried to start it again 2-3 days later. Wouldn't start!
Ignition wires seem okay as they all checked out within the resistance parameters.
Fuel is fine because there's fuel in the cylinders, according to the damp/wet spark plugs.
The timing belt isn't broken - because the distributor/rotor is turning.
Checked the ignition ground wire at the thermostat housing. It has a good ground.
Did starter fluid and recharged battery. Cleaned, dried and re-gapped the spark plugs. Still won't start!
Replaced the original distributor with a SUPPOSEDLY GOOD but "used" distributor w/everything in it (the whole assembly) from a junk yard and swapped it out with the original - no change! Still a VERY faint spark and NO start.
I'll try is to replace the cap, rotor, and wires - when I can get to town ....
I read somewhere on the net where a bad ignition key switch could be the culpret. Is that possible, for it to turn the starter over but fail to connect the ignition/igniter-coil circuit properly? Don't have a manual yet.
Could the EFI relay have anything to do with this problem, in COLD weather?
Where is the main relay located and how does it relate to the ignition system?
ECU/ECM code 01 = oxygen content. Probably an old stored fault - not related to current problem (I hope).
Is there a 1990 Honda Civic LX ignition wiring diagram on the net. Anyone know of where I might find one?
Any help, ideas, or insight will be VERY MUCH appreciated. Thanks!
I have a 93 Civic DX Cpe with 165,000 miles. Over the last 4 months or so, I have noticed that the temperature of the heat has gradually decreased. On cold days, it is barely warm unless you turn it to RECIRC, then it warms up but fogs the windows.
Weird thing about it is that the warmer the outside air, the warmer the heat it blows out. But on cold days, it isn't very warm at all. The temp gauge is always the same and the car warms up quickly, but shows no signs of running hot.
Any ideas what could be wrong?
Scott
Or a clogged heater core. How's your coolant. When did you last change it if ever.
cobweber
We see alot of cap and rotors cause similar problems as yours, but if not then either a main fuel relay tw sensor or weak coil/igniter would be my next guesses..However if you traded the dist you probably used the igniter and coil from the swap so they would seem to be ok....good luck
How does the fuel relay come into play? The cylinders seem wet w/fuel enough, judging from the damp plugs.
It can't hurt to install a new cap and rotor. And if a new coil doesn't fix the problem, AutoZone will refund the purchase.
Do you know where the main fuel relay is in a 1990 Honda Civic LX?
What's a tw sensor? Where's that located?
Thanks!!!
Cob~
I like a reccommendation on whether to replace all four tires with the Dunlop's or replace only the rear ones with the Michelin MX4 if I can find them. Are Dunlop's quiter and better tires for this car than the Michelin MX4's. Does the performance and handling of this car degrades significantly by using 'S' rated tires than the 'H' rated tires, any input and opinions will be appreciated.
The tw is the computers signal for engine temp and if the signal says hot when car is cold or cold when hot the car will have a hard time starting if start at all. Sometimes you can diag this by disconnecting the connector at the tw(temperature water) then trying to start the car. This will cause a check engine light and put the car into back up mode..That test is not 100% true but works most of the time.
My first try would be the cap, rotor and coil combo. As this is the most common on civic. Good luck
Thanks for the replies. When the car is running at highway speed, the heat is roughly half the temp it used to be. Warm, but not hot like it used to be. The engine itself gets to temp quickly and doesn't budge. It is being cooled properly as far as I can tell. When going down the road, I moved the temp slide control to cool and the air gets cold as it should and when I move it to warm all the way right, it gets warmer but only as warm as it might get if you slid the temp to the middle or so.
The coolant was changed about 70,000 miles ago with Prestone and distilled water (50/50 mixture). Sounds like it is time to change it again, huh? Could weak coolant be to blame? And if it was, wouldn't I notice the car running a bit hotter??
Thanks -
Scott
As usual, Auburn's advice is excellent. The hot water control valve to the heater is suspect. On the firewall in the engine compartment below the master cylinder, find where the two hoses connect to the heater fittings. (The heater core is in the passenger compartment.) The heater inlet hose has a valve in it, very near the firewall. Verify that the cable is opening and closing the valve as you move the control slide on the dash panel. If it opens OK, and the coolant temperature at the radiator is up to normal, see if the two heater hoses are hot - they should both be almost as hot as the radiator inlet hose. (Do this with the valve wide open and the fan at medium speed.) If the hoses are hot, check the dampers in the heater system to see if a good flow of air is obtained at each outlet (floor, dash, and defrost) per the flow descriptions in the owner's manual for each selector button position. If air flows are good but the heater hoses were not hot to the touch, disconnect the hoses and check flow through the valve and heater core with a garden hose. If the flow through the heater core is restricted, a radiator shop may (or may not) be able to flush the heater core and restore its performance. Hopefully your problem is no more than a kinked hose or a defective valve but replacement of the heater core may be needed if the coolant quality has been neglected too long.
1) my ignition switch went out 2 days after driving it on vacation
it would crank and try to turn over but it wouldn't do anything else I replaced the fuel pump
and it did nothing so i had it towed to my mechanic who determined it was the ignition switch ($300)
2) while driving to work one morning I pulled up to a stop sign and it went dead I tried to re crank it and it wouldn't stay lit if I held down the gas it would run but as soon as I let off it would die, I had it running for about 5 minutes before the tow truck arrived and almost tried driving it to the shop when it died again.
I feel stupid about this one, but it was cold and away from home , but it turned out to be a clogged carburetor ($160 including tow)[but I figure a can or 2 of carburetor cleaner at my mechanic so I feel like a dunce on that one]
but I think Honda has phased out carburetors by the 88-91 generation
I do have a question if anyone has any ideas
I've noticed recently that my 86 hatch tends to run warm if I'm in stop and go traffic. it cools back down to normal on the highway, but I have to cut the heater on to help cool it during traffic
I had replaced the thermostat about 4 or 5 years ago after it was running hot (turned out to be a disintegrated water pump) and I was wondering if that might be the culprit, it does have approx 80k with the second thermostat, but the whole situation reminds me of my first car an 87 sedan that did the same thing in stop and go traffic
i had a new cooling fan installed last year so i know that's not the problem this time any suggestions?
you can take 2 bolts and thread them into 2 holes in the drum to pry the drum off
2 other suggestions but be careful
I found out the hard way
1) be careful and release the emergency break thats what held one of mine on was the break was gripping the drum
2) its possible the shoes have dug a lip onto the drum that prevents it from being removed hence my first suggestion about threading 2 bolts to pry it off but it will destroy the pads and you will need the rotor machined id not replaced if its worn too badly
their is a self adjuster inside but its impossible to reach without the drum removed
I think most repair manuals show the procedure
good luck
I finally broke down and bought a 2000 civic lx
It was the least emotional car purchase I've ever made lol one of those utilitarian decisions
but I hate everything on the market ,hopefully someone will make something I like in the next few years and i may trade again then. I guess I got a good deal on it though I feel cramped (but I feel cramped in an accord too)
does anyone know if the seats from the 96-2000 civics can be swapped out with anything else that is more comfortable?
the power steering reminds me of my grandfathers ford ltd I guess I have been without a long time
I figured with the 2000 being the last year on that generation (plus the depreciation) that I would come out better than buying new , especially since I dont "like" either car too much
everything is so generic these days , i kind of wished i bought an accord but i figure this will end up the better deal in the short or long run
what kind of mileage does a 2000 automatic generally get ?
I only got 31.7 mpg of mostly highway mileage
but it also never had the 30k and 45k services (both of which are now caught up, with about 44500 currently)
but I thought it got from like 30-38 mpg
If not, it could be that the struts are leaking or plainly gone.
Do take it to Honda and have them point it out to you as the car is on the hoist.
Dinu
I don't think it's the key. I took the key off the chain and also tried my wife's key. The way I got it to start in the end was to floor the gas pedal and hold it there while I let it crank. It started within a few cranks doing that (that's the reason I don't think it's the key.) I've done this every time the car has trouble starting and it has worked every time.
I've told a friend of mine at work with a 2002 Civic LX with starting trouble about it and it's worked for her too.
while turning on bumpy surfaces. I never took it in for service on
that item. In 30k miles, the suspension never failed and it was very
quiet when driving straight. I just chalked it up to cheap parts.
Take it to a mechanic if you wish, but I'm betting they'll say "that's normal for this car". Good luck...
When you turn the key that starts the fuel pump at the first stop then the continued turning engages the starter. You just turn it all the way to start, right? I do too even though I know it takes longer. Just can't get used to the work around, which is.... Just turn the key to the first click, wait a second or two then start.
This, of course, is a trade off for an inexpensive car.
Greetings from sunny warm Miami.
v/r
Fig.
My question is does anyone else experience the ABS light coming on, the radio shutting off, the lights dimming, and the gauges dropping to zero all at the same time, when you apply the brake? This happens to me and then the next time I try to start the car, it won't budge. Sometimes none of this happens and the car won't start.
I love my car, but I want something that is reliable and will start every time for me.
I got my car in July and have been bringing to Honda since the middle of july for this problem (BIG INCONVIENCE).
NickD-- please e-mail me...
I don't know where in Ontario you are, but I can recommend Roadsport Honda at Kennedy/Ellesmere in Scarboro for good service (had a Civic before my Mazda). Unfortunately, I can't say the same about Sisley (Yonge/Steeles).
As far as reliability goes, the Civic is a fine car, but I do think people should do a little more research and not assume that just because it has an "H" on the hood it will be reliable, and anything else (see Nissan/Mazda is inferior).
Dinu
2001 Protege ES 53.000Kms and trouble-free
91 CRX Si 168,000
00 Hatch DX 48,875
1 bad head gasket.
86 Pontiac Fiero 2M6 136,000
3 exhaust manifolds (kept cracking)
4 alternators
3 turn signal stalks
1 E-brake cable
Sorry about your problems. Maybe you need to buy from the big3 for a while, get a dose of reality.
Maybe you should drive my car around for a week and see if you complain about it! The REALITY is Honda screwed up with A LOT of there NEW Civic's and Accord's.
I thought this was a site to find help with problems not to be ridiculed when someone says their HONDA SUCKS!
Just because one type of car has a problem doesn't mean the whole brand sucks or that even that particular model sucks. Especially when you have data to show that historically, whether new or old, the Civic is one of the most reliable cars built. Saying all new Hondas are bad is like saying that all people in Atlanta are fat because you saw one fat person at Baskin Robins and that happened to be the only place you went on your trip.
