-June 2024 Special Lease Deals-
Nick
I hope this information is helpful to you. -----Greg
1. By using this oil, does it effect the vehicle passing emissions control?
2. Since this oil was developed for engines that are being revved high constantly (race track), will it cause deposits in the cylendar heads?
3. Will using a product not recommended by the manufacturer void the Honda Bumper-to-Bumper/Extended warranty?
I have recently purchased Honda Civic Ex 2004. It only has 200 mi on it. Couple of days ago, i accidentally left one of the internal light turned on for around 13-14 hours. Next day i tried to start it but it would not. in fact i was not even able to use key-less entry and had to use the key. My neighbour helped me jump start and i took it to a nearby pepboys for charging. I also asked them to check the conditon of battery (for which they also charged $$, so it was a professional check). They charged the battery but told me that battery was pretty weak and i should go to the dealer and have it replaced because obviously i still have warranty. I have 2 questions:
1.Is it possible that battery really became so dead that it needs to be replaced ? it was in a brand new car !!!
2. Obviously it was my fault that battery drained. would the warranty still be valid ?
nk
Note all cars brands have problems whether Kia or Lexus. Honda's are just known to be better than average but of course things go wrong.
Nick
The mechanic that did the diagnostic said she's worth saving. Mechanic and dealer say the cylinder head needs to go to the machine shop for pressure testing and honing. They're ballparking the job at $1,500. They also mentioned honing the valves "later on." Any thoughts anyone?
The dealer also says the radiator needs to be watched since its beginning to show signs of antifreeze leakage around the top. Mechanic says no big deal.
Has anyone had experience with this before?
Should I put the bucks into her?, Will she keep going (and for how long)? or should I sell her for parts and move on?
Changing them is simple enough, in fact AutoZone has a loaner sensor socket to aid in replacement. Warm up the engine and shut it off, disconnect the connector, remove old senor, install new one (be careful not to touch or damage lower shield or get any contaminants on it, for example the anti-size compound on the threads), tighten, but don't strip the threads, remove your back-up fuse from the eng compartment fuse block for a few minutes (you'll lose clock settings and radio presets/programming), reinstall the fuse and your done. This should do it providing of course the diagnostics didn't reveal a short on the harness between the ECU and sensor.
A battery in good shape will stand a draining and then charge right back up (says he who has left the lights on more than once).
I too have an 02 Civic EX auto and have noticed that I have a vibration in the tranny while slowing down in traffic, like the grade logic doesn't work properly. It also doesn't shift as smooth as it did when it was new. Shifts seem hard. I have 15,500 miles. Is that what you were experiencing? If not, what were your symptoms? What made Honda replace your tranny? Thanks
It's like the transmission gets mad that it has to upshift but then downshift quickly thereafter.
I have 5 months left on the warranty so I'm going to see what the dealer says. Other than the low speed shuddering, everything else is fine. We'll see.
When I first brought the car in the rep checked the cooling fan and it wasn't turning on. He checked the fuse box, all seemed fine, then he moved two fuses around and the cooling fan came on. The temp gauge was still moving up and down. The gauge never got all the way up to "H", just below it.
What does this mean? What other problem/s could this be?
I'm planning a long trip, any opinions about driving her on an approx 1000 mile round trip, if I decide to fix her?
Anything else I should be looking out for?
This is true for most work during under a warranty, not just in the auto industry. The warranty service company, whether it's the manufacturer or a 3rd party, usually has the right to use refurbished, reconditioned, or rebuilt parts or to replace the warranty'd item with a similar product. Read the fine print!
Is there a difference between a new transmission and a rebuilt one? Maybe. But you did get a warranty on the "new" transmission good for an additional 36,000 miles from the time it was installed. Smile and drive on down the road.
JM2C
My sister went outside this morning to start her 1999 Ford zx2 sport to defrost the windows due to the 20 degree temperatures we experienced here in Michigan. She got out of the car, closed the door and CRASH!!!! The rear window completely shattered. I've never heard of such a crazy thing before even with the cold temperatures. I don't know if it was a manufature defect of if something else happened along the way, I'm just glad no one was hurt. I couldn't believe that the shock of a door could cause such damage. I was just curious if anyone has ever heard of this happening or if it happened to them, and I think from now on I will be conducting periodic inspections on the glass of my Civic to make sure everything is Ok. I think it would be a good idea for others to follow suit. I was just passing this along to say it can happen if you weren't aware of it because I have never seen anything more bizzare happening to a vehicle before and I just thought people should be aware of it because I'm sure it's rare but now I know even the unthinkable can happen.
Have a great day.
Nick
"My concern is not the knocks and / or pings that I can hear, but rather the ones that I cannot hear. With a loaded vehicle under hard acceleration, or climbing a long hill, the engine is under "stress", and as such, it needs all the octane that it can get."
A higher octane fuel will not reduce the stress on your engine. All a higher octane rating will do is increase the combustion temperature of the fuel/air mixture. Unless you are experiencing premature ignition, which typically produces a pinging or knocking sound under acceleration, you don't really need premuim fuel. I doubt that using premium fuel will do any damage - but it is typically unnecessary and adds cost. Premium fuel, however, will not reduce the stress on your engine.
You can't see the inboard bolt, so I had to look at the new assembly and visualize its position behind the splash shield. My arms are small enough so that I could get my hand through one of the slots in the shield and access the bolt with a 1/4" ratchet and socket.
For the outboard bolt, I removed a philips head sheet metal screw that holds the right rear of the splash shield and was able to pull it away from the fender to access the bolt. I used a 10mm closed end wrench to loosen the bolt and fully removed it with a 10mm nut driver.
With all four bolts removed, I then had to remove one philips sheet metal screw from under the splash shield about 12-14 inches directly below where the inboard bolt was. Removal of the rear splash shield screw and this one was enough to loosen the lower part of the splash shield, but the top also had to be partially dismantled. This is easy since all you do is pop off some plastic retainers. The entire right side of the shield could now be pulled out and bent in order to manipulate the headlamp assembly out of the cavity.
It's a tight squeeze in there, so you have to be very careful in both removing the old housing and putting in the new one. I partially pulled it out and first took off the blinker electrical connector by pushing in and twisting. Now I could pull out the housing a little bit so I could get to the headlamp connector. This comes off by gently rocking it and simultaneously pulling it away from the housing.
I fully removed the housing by bending away the splash shield and first pulling out the inboard end of the housing, then carefully pulling the rest of it out of the fender area. Not an easy job, but I think any one of us can do it by setting aside a couple of hours and exercising patience.
Once the housing was on my garage floor, I pulled the headlamp bulb out of the old housing by removing the rubber boot and unsnapping the clip that holds the bulb. Easy enough to do with your fingers. No need to remove any blinker bulb since it is attached to the connector on the car. From here on, all reassembly was in reverse order. Just make sure you temporarily push in the splash shield before tightening the housing bolts so that you can see where it will be flush with the fender, splash shield, and the hood.
Thanks for all the hints, folks. This truly was a learning experience.
Big Al
Nick
If the cap is bad, the system can over heat and push coolant passed the cap and out the overflow.
I know......
The overflow is supposed to keep the coolant, but I have seen where the overflow tank has overflowed, then when the engine cooled, the level dropped to normal.
Something to think about.
BTW, with the crimped end bells on your modern radiator, don't assume it's not the radiator.
pressure test the pig today and see what you got. if this is a situation where you're driving an old car because you need the money elsewhere, it might be time to put in some stop-leak. worst it will do is roach the engine by plugging the galleys, and, hey! -- isn't that where a gasket fail would go?
I have a 1998 Civic EX Couple. I went to service center to have a wheel alignment for my EX Couple. After the service was done, I realized that the reception put Civic CX (instead of EX) on the work order. I am thinking whether the technican use the CX alignment (assume the information was different) information to do the alignment on my EX.
Does anyone know whether EX and CX have the same alignment information or not? If they were not the same, how much damage would it have? The reception at there said it should be the same. I am not sure. Is there any of you know the answer about this?
Thank you very much!!
Vince
This discussion will soon be combined with the "Honda Civic Owners: Problems & Solutions", which resides in the Honda Civic Owners Club. However, the combined topics will also appear here in M&R. If you are subscribed to this discussion, you will need to re-subscribe when the change takes place.
If you have any questions/concerns, please address them to me in email, karen@edmunds.com.
How did you find it? What does it say? Did the dealer fix it pro bono?
There's some kind of bulletin out by the NHTSA for civics on head gaskets dated 11/97. Honda doesn't admit it exists. Can't access it. Any suggestions?
My solution for my '94 accord (hasn't happened on my civic) is to clock the miles, and zero her out at each fillup. Has been working for about three years. Dealers say no problem.
Appreciate the info.
I had the fluid changed at 80k and again at 115k.
The manual says Dexron III or Honda ATF will work but recommends Honda. I'm sure the mechanic I used installed Dexron. I changed it at 115k and installed Honda ATF.
I didn't notice the problem until several months ago and I automatically changed the fluid myself. The fluid looked good when I drained it.
The shifting makes no difference if it's hot or cold. Also, I made a mistake, the problem is from 2nd to 3rd not 1st to 2nd. The only difference is shifting under a light or heavy throttle. It never drags out the shift under a heavy throttle when the vacuum is low. That's why I'm wondering if it's something related to the computer getting incorrect readings from sensors.
My only concern is it will get worse and then I'll be stuck. Other than that I would be happy to just drive it for another year or two and then trade it in.
looking at used 96-97 Civic Hatchbacks. outside of timing belt/mileage issues, what should i look out for when considering one of these cars?
thanks!
Vincent
