2025 Ford Explorer Lease Deals, Incentives, Rebates, and Prices
2456789
  • cable23cable23 Member Posts: 55
    RWD or AWD?
    What lease term?
    Sorry about that! 36 month and AWD.
  • MichaellMichaell Moderator Posts: 268,688
    cable23 said:
    Hello Moderators.
    Thanks again for all the help and info.
    Apologies for the multiple asks below, but wanted to see what the rates are for each trim and if there is one that's better. Hoping you're able to provide numbers for both 7,500 miles and 10k miles for the following?
    Zip Code: 07054
    Active
    Line
    Platinum
    RWD or AWD?
    What lease term?
    5.13% APR
    61% and $500 incentive
    60%
    61%
    Thanks @Michaell! Appreciate the help.
  • Pup807Pup807 Member Posts: 2
    Hello! May I please have RV/MF/Incentives for 2025 Ford Explorer AWD ST Line and AWD Active? Zip 11730, 36 months, 12k/15k/20k miles?
    5.13% APR
    58%/57% residual for Active/STLine
    +2% for 12K
    -3% for 19.5K
    5.13% APR
    +2% for 12K
    -3% for 19.5K
    Thank you so much!
  • skabossskaboss Member Posts: 39
    edited November 2024
    Good evening. May I please get the info for the following vehicles for zip 61107...
    Explorer Platinum AWD 2.3L
    24/36 months - 12k/15k miles
    Explorer Platinum AWD V6
    24/36 months - 12K/15k miles
    Thank you in advance
    24/15 - 6.19% APR and 66% RV
    36/15 - 5.90% APR and 58% RV
    Either engine
    Either engine
    Thanks. What's the RV for 12K and does the APR stay the same for 12K?
    Either engine
    Add 1% for 24 months, 2% for 36 months.
    APR is the same
  • fgabrieladiazfgabrieladiaz Member Posts: 9
    Hello, can I please get the money factor, RV, and any incentives or rebates to
    2025 Ford Explore Active Base model
    12k miles / 36 months term
    Zipcode: 34743
    Zipcode: 34743
    RWD or AWD?
  • charlottesaudicharlottesaudi Member Posts: 39
    Hi, can I have the MF and the residual for ST AWD 36/12 in 06111. Thx
    5.13% APR
    60% residual
  • joshdubbyajoshdubbya Member Posts: 5
    May I please have the MF and Residual for a 2025 Explorer active and ST line AWD in 80104 for 12k and 15k.
  • Double_clutchDouble_clutch Member Posts: 5
    Hi, could I receive the residual/MF/incentives for a 2025
    Trims: Active, ST-Line
    Terms: 36mo/15 or 18K (if possible)
    Zip 07860
    TIA!
    What lease term?
    Zip 07860
    TIA!
    RWD or AWD?
    Zip 07860
    TIA!
    RWD or AWD?
    AWD
    Zip 07860
    TIA!
    RWD or AWD?
    AWD
    36/18
    5.13% APR
    Active - 56% RV and $500 incentive
    ST-Line - 55% RV and no incentive
  • BBMakBBMak Member Posts: 3
    May I please have RV/MF/Incentives for 2025 Ford Explorer AWD ST Line?
    Zip: 12303
    36/10.5
    Zip: 12303
    36/10.5
    5.13% APR and 59% RV
  • vickiejodvickiejod Member Posts: 39
    May I please obtain the MF and RV for the ST trim with 36/15k for 78736?
    Any incentives?
    Any incentives?
    RWD or AWD?
    RWD
    Any incentives?
    vickiejod said:
    RWD
    5.90% APR
    57% RV
  • lake171lake171 Member Posts: 10
    May I please obtain the MF and RV for the ST trim and Premium Line with 36/ 10k and 12k for 94121?
    RWD or AWD?
    AWD, sorry for missing that in the previous post. Thank you for your help!
  • BryanmbullBryanmbull Member Posts: 12
    Hi there, could I please get the RV, MF, and lease cash for a 2025 Ford Explorer ST-Line trim. AWD. 2.3L I-4 engine.
    36 mo / 12k miles. Zip 37122.
    Thank you in advance!
    Sorry, I need to clarify your trims.
    There is an ST trim and an ST-Line trim - which are you looking for?
    And, I don't see a Premium Line trim. Please check again, and clarify what you want.
    5.90% APR
    59% RV
  • ldjfmillerldjfmiller Member Posts: 2
    I would like to get the buy rate and any incentives for financing on a new 2025 Ford Explorer Platinum for zip code 34110.
    5.90% APR for 60 months
    +$1500 customer incentive
    OR
    $2500 customer incentive for cash
    5.90% APR
    59% RV
    One more question. Could you please. Check numbers on a Platinum trim instead? Same build same zip. Thank you!
    5.90% APR
    59% RV
    5.90% APR
    60% residual
    edited December 2024
    5.90% APR
    60% residual
    Hi! Revising this request to 36 mo / 15k miles. AWD. Zip 37122. MF, RV.
    2025 ST and 2025 ST-Line please. Thank you!!
    5.90% APR
    60% residual
    Subtract 2% from the residual
  • donnelly713donnelly713 Member Posts: 33
    2025 Ford Explorer Active AWD, residual and MF incentives for zip 36830
    36 and 48 month, 7.5k miles.
    Ty
    Ty
    5.90% APR and 62% residual
    7.08% APR and 55% residual
  • LightofasinglecandleLightofasinglecandle Member Posts: 2
    Hi! Can I get RV, MF, and incentives for 2025 ford explorer st RWD and AWD for zip 90048? 36 months, 7.5K miles. Thank you!
    5.13% APR
    RWD: 61% residual
    AWD: 62% residual
  • Hi again! Can I get RV, MF, and incentives for 2025 ford explorer platinum RWD and AWD for zip 90048? 36 months, 7.5K miles. Thank you!
    5.13% APR
    62% AWD
    61% RWD
  • ugafootballfanugafootballfan Member Posts: 7
    Trims: ST-Line/RWD
    Terms: 24 and 36mo/10k and 12k
    Zip 30040
    Is there a RCL to RCL 3k incentive?
    I am Z plan and i heard it was available.
    Holiday RCL Customer Cash $500 cash back
    Thank you for all you do!
    Trims: ST-Line/RWD
    Zip 30040
    24/12: 6.19% APR and 66% residual
    36/12: 5.90% APR and 58% residual
    No info on Z-plan. But, we don't see any of those incentives
    Thanks. Can you give me the 10K numbers on the 24 month.
    Add 1% to the residual for 10.5K/yr
  • rcm_ovorcm_ovo Member Posts: 10
    Hello, may I please have RV/MF/Incentives for 2025 Ford Explorer RWD ST Line and RWD active? Zip 91402
    36m/12k miles
    24m/12k miles
    36m/12k miles
    24m/12k miles
    24/12
    5.19% APR and 67% / 66% for Activ / ST-Line
    5.13% APR and 59% / 58%
