Visitor Agreement.
Pat
I've seen quite a few Hondas running well with 250,000 plus miles on them. Make sure you have na inspection done first. It's also due for a timing belt.
Nobody actually "knows" if the car you're looking at will be a good investment. Does the current owner have maintenance records? How often was the oil changed? Has it ever been in a wreck?
If the car was well cared for and not driven excessively hard, chances are it should last well beyond 200,000 miles. Honda Civics are reliable, but they are not indestructible. There are no guarantees.
1. i am pretty capable in the garage. can i replace the oxygen sensor myself?
2. my mechanic recommended if i do i should use a honda part only, ($198). bosch part is $94. big diff in price. what about quality? should i pop for the honda unit or is the bosch a quality alternative?
3. once the sensor is replaced will the idle return to normal or will i have to have a mechanic address this?
4. will the check eng light turn off afer the sensor is replaced?
THANKS FOR ALL HELP. IT HAS BEEN AN EXPENSIVE MONTH SO ANY DOUGH I CAN SAVE HELPS.
I know there's a way to reset the CE light if you've got the right equipment, but simply disconnecting the neg. battery terminal for a couple minutes will do the same thing. Good luck.
I own a 1995 Civic Coupe (made in Canada, if that makes any difference) that overheats and my mechanic (after $640 of repairs!!!) cannot seem to find what causes it .
This is the story in short:
1) Changed water pump
2) Changed thermostat
3) New timing belt
4) No signs of coolant on the sparkplugs
5) No visible leaks anywhere - thoroughly checked by mechanic
6) No mixing of coolant and engine oil (in radiator or engine)
7) No white exhaust
8) After topping off the coolant the car starts to overheat within a day or two and seems like it looses some of its power, too. The only thing i can think of is a leak, but we have looked for hours to no avail...
Is it a good idea to use the store-sold radiator/leak sealant and if yes, then what is a good one to use?
Please, share any suggestions or ideas you may have
As far as I understand the manual recommends to change the timing belt at 105 000.
About the rest I will give you a recent example:
After changing my timing belt, water pump, thermostat, a few gaskets and seals that go with this + front breakpads and rotors and one of the axle outer boots my mechanic charged me $609,29 including tax. This was a week ago in San Diego - nation's 6th most expensive city, so adjust accordingly.
Hope this will help.
If it happens in traffic, it's possible the electric fan in front of the radiator isn't working.
You can also test for combustion gases in your radiator coolant.
I took the car to the mechanic who re-threaded the spark plug socket. When I asked what the original cause of the problem could have been, he said that whoever did the last tune up forced the spark plug in or tightened it too much.
My concern is that I drove the car today and the wire that sits over the spark plug came off. All of the other wires fit snug over the spark plug but the one that is giving me the probem is loose. I got new wires and at first it fit but when I pulled it out, it would not tighten anymore. I'm afraid that the diagnosis my mechanic gave me is wrong and I do not want to be taken for a ride.
Does anyone know what the problem may be? Should I just buy a new engine altogether?
Kudos to the nice folks at AutoZone for pulling CEL's gratis. Dealers will charge up to $50 to perform this same operation. Once AZ pulls the code; all you need do is look up the code on the 'net. Most CEL's are caused by either loose gas caps (screw those things on TIGHT) or bad 02 sensors.
my car has been overheating for some time now. I have to put water in it everytime i go somewhere....drive a couple of miles and it back up in the red.....I dont have any leaks ...we have checked. I just dont understand what the problem is...my fan is working...before i change my water pump...i was told to try the thermostat first...(least expensive)
so my question is ,.....is it difficult
If your Civic has been overheating for "some time" you may have a blown head gasket. Overheating an engine isn't a good thing to do once let alone every time you drive it.
Replacing a thermostat isn't hard and it can't hurt anything. Just don't put it in backwards and make sure you don't overtighten the tiny bolts that hold it in.
I posted this on the 06 Civic board, I thought it was the steering, You may find this helpful:
(if message doesn't show up just check that board)
Dan - and all with steering issues;
I have beeen reading every review and post I can find on the net about this issue and as I am reading roads tests the sensitive steering issue is mentioned in several articles. One states the car not being able to track straight. This may be why you mention a pulling sensation to the right and the poster before you stating the the same thing during a test drive.
I have not driven mine enough to pick up on that; just a lack of control and feeling like I have to steer all the time on something that that is so sensitive I feel nervous.
Here is an excerpt from Canadian Car & Driver long term test on the hybrid version which decribes quite well what I am feeling. (sorry I don't know how to post links)
"All 2006 Civics feature electric power assist provided by a motor rather than a hydrolic system. We're finding this a bit too noticable. Especially as the temperature drops. At low temps the steering seems to pick a line and follow it, until you correct it whereupon it picks another line and follows it. Rarely will it just go straight and respond to the type of familiar and minute adjustments you make with a hydraulic system"
This concerns me that professional drivers are uncomfortable. How do I get used to a car that won't DRIVE STRAIGHT? I frankly don't think cold weather has anything to do with it.
Dan, is this similar to how you feel and maybe the car isn't out of alignment and made this way?
the dealers pulling your timing belt you can retard and advance the timing belt up to 3 teeth on the belt and the car will still run ...sounds like they did a bad job and are trying to pass the buck without having to do any extra work take it to a smog center to check the timing and they should be able to give you a print out of the degree of advance or retard that its at now and that will give you a little paper trail ...that should help...give it to the dealer and have them make it right
Later
944boy
Thanks for the info. I have done the idle speed timing check with the system jumper as explained in the Haynes manual. Warm and in park the idle speed is 740rpm and the timing is on the red middle timing mark. So at least this simple test says it is ok. Can the test you mentioned tell more than the timing check? We live in podunk and don't have pollution check requirements.
I actually have done two of these Civic timing belts with my son in the past. Well he is all grown up now and I am getting older. It was great bonding with him but it just wasn't worth it so I "took it in". Man do I wish I would have done it myself at this point.
I've done all my own oil changes and the pan was dry before the service. Well I am taking it back because it is obvious to me now that the crack shaft seal is leaking as the wetness is coming at the timing cover. They will have to take it all apart again so maybe they will find something.
The shop that did the service actually has a good reputation in my area. Foreign car specialists you know. I'm just having a bad experience. Do you think there is anything in their suggestion of replacing the engine mounts? It didn't vibrate like this before the service so I have a hard time thinking the mounts suddenly went bad.
Thanks again.
EJ
I have a honda civic 95, mileage 140k and expereincing a strange problem. I go for regular oil changes. The oil presuure gets low after every 200 miles, and I have to refill the oil. There are no leak spots where the car is parked, at home or in office, there is no smoke or smell that might give a hint of burning of oil. I took it to Jiffy Lubes and they suggested that the oil might be leaking from rear main seal or oil pan case gasket might need to be replaced. I donot have any idea what should I do. Pointers are welcome.
Visheetal
Am taking back to dealer on Monday - again....this car has had several nuisance problems, ex., air bag light on, door lock not working, replace air conditioner condenser (500.00) at 5,500 miles due to a "stone" that that pierced the "shield"(?), and now this.
Is there any recommendation as to what to ask for if the car is not "sick" when the mechanic looks at it? I don't want to pay for parts and labor that is not necessary or does not resolve the problem. The car has always been to the dealer for all services.
Thanks very much for your help.
The 2nd guy suggested that the valve heads might have gone wrong, he will have to look at it. The estimate cost of repairs is around $1000 - $1500. What should I do?
As for the car they said that I can drive it with no issues just keep on putting the oil.
Rgds
Vishal
It could be as simple as valve stem seals (little rubber seals that go around the stems of the valves---this generally does not require engine disassembly of any kind).
But the leakdown test will show you what is wearing out.
I've had this driver side suspension rattle for about a month now, and my mechanic claims everything checks out ok. Has anyone else had this problem? Any suggestions on what to investigate first would be greatly appreciated.
George
944boy
Engine sounds loud with tapping sounds all the time.
Squeaking intermittent under hood while driving.
After shifting from drive to reverse and vice versa there
is a strange sound for a couple of seconds . Kind of sounds like a power window going up or down.
The dealer says they can not do anything about the vibration unless they can hear it on the hoist. The
service manager has been out in the car and did hear this noise. Thinks it might be in the exhause system or heat
sheilds.
Does anyone else have these problems? Did the dealer fix it?
You're not alone whoever is reading this, but it has been very hard to remedy the problem, and no shop seems to claim to know anything about it. Good luck!
Did you figure out what the grinding and squeaking noise was? My wife drives a 99 model and about one week ago it intermittently started making a grinding/squeaking noise. Since then the noise is beginning to be more persistent. The noise seems to be coming from the front left wheel area. I removed both front wheels to inspect the rotors and brake pads, nothing obvious.
Any help?
Did you figure out what the grinding and squeaking noise was? My wife drives a 99 model and about one week ago it intermittently started making a grinding/squeaking noise. Since then the noise is only beginning to be more persistent. The noise seems to be coming from the front left wheel area. I removed both front wheels to inspect the rotors and brake pads, nothing obvious.
Any help?
Thanks for your help anyone who can answer!
