Visitor Agreement.
It sent Nasdaq (and Nvidia) on a nose dive.
This one’s for @roadburner:
https://www.instagram.com/reel/DFTkJVlJjiW/?igsh=M3NrdG1obTJpMWs5
No, I'm not joking.
I never understood hating someone you once liked enough to marry that you would rather give money to a lawyer instead of splitting it with your ex.
Because at some point it’s not about the money and it’s about “winning.” I used to work in that area and sometimes the lawyers themselves make it worse.
I did business with a guy who also owned a plumbing supply. His wife cheated on him with her tennis instructor. She left him for the tennis instructor and filed for divorce. Some 20 years + later she won’t marry the tennis instructor and continues to collect alimony.
Well, let’s see, it’s just before midnight so hurry up. I haven’t heard a good bedtime story in months.
After a couple of weeks of R&R, plus getting over a winter cold, the step daughter broke out the cans and brushes and painted my office today - the last full room that needed to be done.
So, fresh paint on the walls and trim, but no art has been re-hung yet. There is also a new bookcase that will need to be assembled so I can get my office put back together later this week.
Everything from the office is currently packed away in about a dozen various sized cardboard boxes, which I'll have to review/purge before they go back.
No painting here but we did redo my wife’s office for the start of her new job.
We gave my son the desk she was using (had a large hutch on top that she never really liked) and got a new sit/stand motorized unit. I bought a nice dual monitor stand that attaches to the desk and frees up room too. She then bought some new decor and I hung it all up. Came out really sharp.
Room also has a nice daybed for company if needed. She is very happy with it.
She didn't like it, especially when it involved kids she went to school with and/or families from town.
Plumbers came back out yesterday and cut another hole in the garage ceiling to get access to the shower plumbing to figure out where the leak was. Man was that bathroom laid out poorly in terms of access. But they found it. The fitting on the cold water line (that connects the PEX hose to the shower valve) had a hairline crack letting water leak out just a little. Apparently it was a bear to replace due to tight access but it is done. Now just need contractor back out to replace insulation and drywall that got wet or removed. Will be nice not having holes cut out in my ceiling.
Hopefully that is it for punch list items.
His comment was he would never put the plumbing on that wall. But he doesn’t get to design the house.
I take it that the leak was at the female solder fitting on the shower valve body inlet where an adapter was used to transition from solder to PEX tubing. If that’s the case the plumber didn’t use a shower valve that was manufactured with PEX male stubs that could be crimped to the PEX tubing. That’s just downright poor plumbing when you know you’re plumbing the house with PEX.
It wasn’t a leak at the connection. A tiny hairline crack in the fitting itself that he pointed out but I really didn’t see. Probably a manufacturing defect? But seemed to have nothing to do with installation and it was the correct component.
They did pressure test the whole system before the walls were closed up and all was fine. So likely was something that failed after some use.
But seems fixed now (and plumber said it was something he hadn’t seen before so pretty rare). And most importantly, I did not have to pay for it.
It can depend on the circumstances. One guy I know came home and found a note that said his wife left him to go with her new boyfriend....all the furniture was gone except for one arm chair and a case of beer. He was not feeling too friendly about it!
Was it the transition fitting from sweat copper to PEX? If so I’ve never had a bad copper fitting either but I have come across bad PEX crimp/cinch connections.
Solder, Pro Press, or Threaded Brass Fittings & Nipples are the way to go!
Yes, and sadly most houses, even very expensive ones get the Pex treatment.
The shutoff valves are metal but the supply are a rigid plastic.
I remember when PEX first became code acceptable in my area and plumbers laughed at it. Now, they use it all the time. A plumber we’ve used to do the heavy work like when concrete floors have to be opened up for installing new drain lines said he remembers when plumbers laughed at the use of ABS and PVC being used for that purpose. Now, that’s all they use today. Why use a material like cast iron that is prone to rusting when you can use plastic that will never rust? PEX was used in Europe for about 20 years before it became acceptable in the USA. There will always be changes in new technology/materials. So, when times change people need time to change too.
I doubt any of us want to go back to the days when doctors treated pain with aspirin and surgery was a real hit/miss proposition.
Yes, it is. I forget where I got it. Grainger maybe? I was going to relocate it to the new garage but just left it. It doesn’t get a whole lot of use where it is now but what can ya do?
BUT, good for places that freeze, like my garage!
It was copper when we moved in and when I turned on the valve in the basement, I found out they apparently left it on one winter and a crack of several feet developed. I replaced just that line with pex.
Pex and CPVC isn’t up to code in most instances in the city, right?
I think it is silver. Not sure what the technical name is but he left the old one so I will snap a picture of it later.
I don’t think anyone uses copper up here these days.
The auxiliary battery also went in his JEEP. It can't be reached without major work, they had to take off the fender to get at it....cost almost $500. Since then he got rid of the JEEP.
CPVC is only approved for A/C drains as far as I know. There are some instances you can use PEX for heating, but it is very limited applications. It is illegal for hot & cold water lines because the rats will chew right through. Even PVC pipe is only allowed to be used here for buildings 3 stories or less.
https://www.facebook.com/share/p/15FwuuSEyb/
We went there in 2017. Cool and creepy at the same time.
Extra long donut stops for 40 minutes while the car gets charged up.
I just saw this article. Are you seeing this happen?
https://www.cbc.ca/news/canada/montreal/quebec-snowbirds-selling-homes-florida-1.7440455?utm_source=firefox-newtab-en-us
Speaking of which, I passed a local convenience store which has multiple EV chargers and they were all occupied by Amazon Rivian EV delivery vans at 10:00 am. I wonder if the drivers sitting around waiting for a charge get paid for the down time.
That said, it might make financial sense for a Canadian to sell property in the US and then reap a premium when converted to Loonies. $100,000 US is worth about $144,000 Canadian.
Some were hit with large bills after the hurricanes, insurance rates have gone up a lot or aren't available. People are tired of hurricanes. The Canadian dollar has sunk, it costs $1.43 Cdn to buy a U.S. dollar. When we bought 12 years ago the Cdn dollar was worth 94 cents U.S., today is is just below 70 cents. Our Florida place has doubled in price in 12 years, and if we sell we will cash out in higher value U.S. dollars.
1000 people a day were moving to Florida, they still are but now about 500 a day are leaving.
We have U.S. dividend stocks so the income from that pays for most of our expenses. We are 33 ft above sea level and inland, which offers pretty good protection. I am not quite ready to give up the Florida lifestyle for the winter. It was 72F here today, and 25F back home...with a few inches of snow. Good article....thanx.
