Store Bought Waxes Part II (No Zaino Posts)
Meguiars Gold...but any good wax will do the job. It is time consuming, due to the windshield wiper areas, etc., however; it does last a lot longer.
I have to assume that the flat black areas absorb the sun rays faster, and, of course, being black, it attracts faster.I also assume, that, the flat black is used, so as not to get reflection into the drivers eyes.
Hope this helps.
Shine it up TRON
marks from the wood trim in my BMW? I've heard everything from Pledge to Car wax. So far, I've only used water and a soft cloth. I've noticed some small scratches on the wood piece surrounding the shifter...any way to remove or reduce them?
If you want to improve the appearance of the wood trim, you could polish it with a mildly abrasive product like Meguiar's Swirl Remover or #M Perfect it--or some other similar product.
The odor is so strong that flies land on the car's surface to try to feed.
Why can't wax smell like wax?
I used to use vanilla scent when detailing a cusotmers car. But I was always partial to Pina Colada.
I love those smells too. Keeps your mind off what you're doing. ;-))
fastdriver
LOL.... I don't have that problem with the stuff I use. I just savor the smells and the shine.
fastdriver
I am lookin for Meguiar's polish that specifically do not leave stain on the rubber trim. Please let me know the name and the result - I prefer endurance over shine. Thank you
Chris
If I'm thinking the same thing as you, it is not really "staining" but leaving a white residue in the grain of the plastic. It can be extremely difficult to remove. Use 3M Wax and Grease Remover and a toothbrush. You may have to use it several times.
Another idea to keep wax out of trim is to use a 3x5 sponge to apply the wax by hand instead of those round applicators. The edges of the sponge will give you excellent control around trim, glass, etc. Plus a damp sponge allows you to control the amount of wax you apply in a particular area.
Hope this helps. Give us a shout if you need anything else.
Only Quick Wax, and Quick Detailer will not discolor black trim. But, they are not designed for durability.
If anyone has really used the peanut butter trick in the past few days, post your technique and results here. Tell us exactly what kind of car you have and what wax product you are trying to remove. If you've just got to post the brand of PB, well, OK. I couldn't care less, though.
I'm interested in real results, not a rehash of an old detailer's tale that no one has actually attempted since the Nixon administration.
Chris
http://www.nsxsc.com/nsexcitement/waxtest.html
I had one car that didn't have any extra care on the outside finish. It has rubber trim. The first time I waxed it I had a coat on the trim. I removed it with a soft brush and dish soap.
I tried masking to prevent it, but it was fairly tedious to apply and remove. left it's own sticky residue to this abused surface.
Then I found Black Magic Tire and Trim Shine. I now apply it after the car is dry with a paper towel. When it is dry,I simply wax. It works even when I use a buffer. I reapply the Black Magic every 2--3 weeks to preserve the surface.
If any excess gets on the car body, I just wipe it off. I haven't had any problems personally after I switched from a foam applicator to paper towels.
On Autopia, many reccommend putting a coat of carnuba on top of a coat of sealant to add more shine. I did the reverse. I applied the carnuba wax first, and then applied the polymer sealant.
So far, my finish looks fine, but is this a problem?
The wax prevents the polymer from bonding strongly.
As you mentioned, some people do apply both types of protectants to their car. The polymer is applied first because it provides longer lasting protection than a carnauba-based wax. The carnauba wax is placed on top in order to provide a deeper, richer shine. That way you play to the strengths of both types of protectants.
By reversing the order you are going against the advantages of each type of protectant--you are hiding the carnauba-based wax's visual qualities under the polymer--and degrading the ability of the polymer to bond to the surface of your car. Also it is possible that the polymer protectant is removing the carnauba wax to begin with.
You are better off putting down the polymer first, then the carnauba--or else just using one or the other.
MY PROBLEM: Under certain lighting, I can see a layer of haze that covers my hood, roof and trunk of my car...this layer of haze almost looks like I did not wipe off the GM Jet Glaze completely!!...when in fact I did--In direct sunlight, my car's finish is shinny and wet looking with no changes in color!!
I have already buffed and rebuffed the entire car at least 3 times with brand new Cambridge cotton bath towels made in Canada thinking I have finally removed all of the possible glaze residue....However, I can still see the haze now and then!! Moreover, whenever I see this haze, I can run my fingers over the finish and it will remove the hazy film from that part of the finish!!....Sorry for babbling on but any suggestions??...I'm almost ready to wash the car with blue Ivory (made by Dawn and sold up here in Canada) to start from scratch but I don't want to feel that I have wasted all of my effort and 2 days of time!! Thanks!
By the way, anyone else use the GM Jet Glaze or Collinite??
Best way to eliminate it is to lightly spray water on the paint. Wipe it off with a clean towel.
Heck, even rinsing the car with the hose and wiping it down will do the trick.
Finally, some car waxes do not react well with some types of paint. If possible, try another brand of wax to compare. I had this problem a few years ago with Meguiars Medallion and a new Dodge. Put the Medallion on a Ford and no problems. Put Eagle One carnauba paste on the Dodge with no problems. Just one of those things....
It's mostly noticeable on cars with clearcoat paint but can show up anywhere.
In a nutshell the rain water has various chemicals mixed in it from local pollution. When the sun came out it super heated the rain drops and effectively burned a hole in the clearcoat. What is left is a little crater where the rain drops were.
You may want to spend some time researching this issue and possible solutions. The Autopia chat room is a good one. Quite a few online car clubs have frequent discussions. Also check out Car Careonline.com, Meguiars.com, and Eagleone.com for more info.
If it's any consolation, this is a widespread problem. My new Saab has acid rain damage all over the trunk and rubber trim around the windows. Not much I can do except live with it.
Re Polish residue on rubber trim: First, I speculate that you may mean "wax" but, in any event, I believe that most polishes and/or waxes will leave a residue on rubber (plus, those with petroleum distillates may breakdown the rubber over time). The best bet is not to get the polish on the rubber in the first place. Some mask, others just slow down and concentrate when they get near the rubber. See earlier posts, over the last couple weeks, for other ideas.
Polymers (non wax products) tend not to leave an objectionable residue on rubber, but that represents a commitment in a different direction, which is not always wax compatible (though some apply Klasse products, then wax on top of them).
Everyone needs to be more specific when asking questions about this since answers vary. Are we really talking rubber? Tires are rubber. Is there wax on your tires? The seals around the doors are rubber. Do you have wax on them?
Or do you have wax on the strips around the sides of the car and/or bumpers? Run you fingernails on this area. Feel a texture? Look very closely at this area. See any grain or texture? If so then you are prolly talking about plastic not rubber.
If you're still not sure tell us exactly what kind of car you have and maybe some of us can look at one and see for ourselves.
Any type of wax will leave residue in plastic trim. Polymer, carnauba, cheap stuff, expensive stuff. All these products have a carrier in them to allow application. The carrier is what leaves the white residue behind.
The tips I've posted in here over the past year apply to all kinds of products.
-Larry
I haven't used turtle wax in 20 years. But what exactly did turtle wax have to do with bret's post? The only "rubber" trim I've seen on cars is around the door/trunk seals and maybe he body side moulding. everything else tends to be plastic.
I've reread my short post and I really can't see where I was being smug. I didn't mention the miracle product because the title of this topic tells me not to.
I'm waiting to here about your store bought "miracle" wax; so I can stop by Pep Boys or AutoZone and purchase some for my Mazda Protege's. Soooo lets try this again; which wax product is your "Miracle Product"?
Respectfully,
Larry
Indeed, if anything, it was a NEGATIVE comment about the unspoken product, in that one has to be just as careful around textured plastic as one is with carnuba wax. I thought y'all enjoyed negative comments about the mail order stuff. I wasn't intending to be smug. Sorry if you took it that way.
Respectfully,
Larry
Let's get back to the topic and stop the petty bullsh--!!!
TRON
