Mystery car pix
1146314641466146814691479
  • bhill2bhill2 Member Posts: 2,639
    60 ford fairlane front and center.
    And a second one just left of center about 4 rows up (direct sightline over the roof of the 57 Olds wagon.
  • explorerx4explorerx4 Member Posts: 21,117
    A 61 Ford paerked behind the Cadillac. 2 more 60 Fords, one light, one dark, near the building in the background.
    A 59 Ford a couple of rows further away from the 61 Ford.
  • ab348ab348 Member Posts: 20,713
    Your friendly L.A. Area Ford dealer seemed to be doing very well back then!
    Another 1960 Ford under the middle of the up-in-the-air thing. Low line model.
  • fintailfintail Member Posts: 58,876
    Being at an airport, I wonder if the lowline cars are rentals. The 61 Galaxie beside the Olds wagon might be an exception, but I notice it is on blackwalls.
    I cannot make out anything near the building in the background. The picture resolution just isn’t there.
    Found what seems to be a better-resolution photo of the same Theme Building shot. Let’s see what we can see off in the distance:
    I wonder what's in front of the nearmost 60 Ford. Karmann-Ghia?
    In the background near the building, at right beside/behind a squarebird, is a 60 Ford wagon. By the proportions it may be a 2 door Ranch Wagon.
    Might be. My first inclination was an early Falcon b/c of the white steering wheel but it looks too small. Could be as you say.
    I'll note the Corsair flat top (probably a 60) next to the early 50's Plymouth.
  • andys120andys120 Member Posts: 23,689
  • sdasda Member Posts: 7,738
    59 62 convertible. I dislike when the wipers are not parked all the way down. The wiper transmission on the 59 and 60s was prone to wear and became slack.
    Maybe a rerun? Apparently Netherlands, I suspect 1968 or very close, zooms fine, a bit of diversity here:
  • stickguystickguy Member Posts: 54,320
    front left an Opel Kadette. black Corvair in the center 1 back on it's right a Bedford van.
  • tmarttmart Member Posts: 2,427
    Several VW Bugs and Vans.
    The blue Mercedes in the right lane is a Universal. Almost unknown in the US, may be more common in Europe.
    Yes, looks like a Universal based on a first series (190 badged) W110. Around 2500 units total were built for 190 badged cars, diesel and gasoline cars combined. A handful made it to the US, but they were rare even in Europe and are probably the most sought after fintail.
    Van diagonal behind the Corvair may be a Ford Transit.
    Car in front of it is unexpected.
    A couple of BMC Austin/Morris 1100 ADO16 models close to each other.
    I notice the white ADO16 appears to be on a UK plate with an E or F suffix, denoting 1967-68.
    There is a Trabant ahead of a Ford uk Transit van
    Mix of ADO 16 's
    Brit one is an Austin Mk 2 and is a 2-door while the dark green one is a Morris and is an early 4 door
    In some countries in Europe the ADO 16 was locally badged as a Morris or Austin Glider
    certainly in Denmark but probably in Benelux too.
    The car in the gap behind the Continental Tyres VW van is a Citroen AMI
    @magnette,
    Thanks for filling in some of the gaps.
    Ami...
    Good job, mon ami... :)
    Hope this works
    I’ll take the 55 Thunderbird and Fairlane and the 53 Ford.
    edited June 2025
    Christine 3rd from the right!
    Guessing an Oldsmobile dealer.
    That's the New Frontier Hotel and Casino in Las Vegas, opened in 1955.
    Looks like a red and white 57 Plymouth sedan towards the R at New Frontier.
    Skytrain under construction in Vancouver - I think this is Commercial Dr, early 80s I suppose, zooms enough to pick out several:
  • roadburnerroadburner Member Posts: 18,613
    Saab 99, Pontiac Ventura, Toyota Tercel, Mustang II and Maverick POS Edition (weren't they all?).
    Looks like a Mustang POS Edition behind the Maverick.
  • Lostwrench3Lostwrench3 Member Posts: 846
    Electric bus overhead lines.
    You just about got em all!
    Looks like a white bullnose Ford pickup facing away near the stairs, with quite older model with a canopy beside it.
    Looks pretty warm here, should be able to zoom enough to ID them all:
  • xwesxxwesx Member Posts: 18,015
    A Willys Wagon in the middle there, though I'm not sure how to zero in on the exact year. I'm really not too certain that I would have wanted to be that close to an enormous geyser of lava, though!
    62 Ford Country Sedan
    I make the white wagon as a Ford Fairlane, I'll say a 67.
    I don't think their hard hats will be of much help of things suddenly go sideways. :o
    I suspect they must be some distance away and the perspective is making it look much closer than it is.
    I think the white wagon is a full sizer, likely a 66-67 Country Sedan, but a Ford no doubt.
    I suspect the lava fountain is further away than it looks too - just hope you don't end up downwind.
    Spanish Banks, Vancouver, source says 1977 but I suspect maybe a year or two later (maybe a rerun too) zooms nicely with a bit to see:
    Firebired obviously. maybe a 77? facelift Vega with a "racing" stripe. and far right a maroon SAAB 99 next to a gen 1 Honda.
    A grey VW Bug next to the mentioned Vega.
    914.. Of course, I can't spot a 916, either
    The 914 / 916 was not really marketed here as they didn't offer RHD so we saw comparatively few of them.
    Fiat had the same problem with their X19
    edited June 2025
    Quite the variety in this shot!
    I want to say that the two conversion vans side by side are both GM, mid-70s, but cannot quite tell details on either. There seems to be an older, finned vehicle (dark color) beyond that, but getting hard to see at that distance. I'm thinking perhaps a 59 for timeline, as it seems like large fins and a sloped roof (compared to the bubble tops of the earlier years). Another Camaro, maybe 1974, in front of the vans, and perhaps a Ford LTD next to that, with, perhaps a Cadillac or Buick behind the box van / wannabe motorhome.
    I wonder what the blue car at front left of frame is. Looks familiar, but I cannot put a model to it.
    I'm going to take the Civic that's four cars down on the right. Not sure of the two Japanese models after the Firebird, though
