Visitor Agreement.
Let her look at a new Kia Sportage hybrid. Edmunds just did a comparo with it, the CR-V and the new 2026 RAV4 and it blew them out of the water.
I like our Kia Sportage PHEV. Our neighbor has the Hyundai Tucson PHEV which is also nice.
I do prefer the Chevy Blazer EV to both of them but it is a bigger vehicle. Depends on what size you are looking for. A compromise between a sedan and an SUV might be the Subaru Outback. Sits up higher but looks more like a station wagon.
And speaking of Costco, they often have coupons for certain auto brands. We got $1000 off the Blazer EV. They also have great deals on rental cars. It’s not just what’s in the warehouse. We also get our prescriptions filled there and eye exams and glasses too.
Some of the engines are definitely a weak spot. But these days GM and even Toyota have been having massive issues with engine failures.
How much does he have invested in parts inventory? Maintenance and gas for the truck? Insurance? All these things to into the pricing of his time.
We're having a problem with our garbage disposal - or, more correctly, the outlet into which its plugged. Only one of the sockets work that's under the sink, and since the disposal is plugged into one and the dishwasher into the other, we can only use one at a time. It's a hassle, but not debilitating. Got a guy coming out tomorrow morning to look into it. Not sure what it will cost, but it will be worth it.
Couple a things to check -
1 - Is there a GFCI reset under there (not on the outlet, but a separate unit)
2 - Double check the breaker it is on - turn it off and back on even if it doesn't look tripped (it may be a GFCI)
3 - If the outlets aren't switched, how do you turn your GD on/off? Air Switch?
4 - You just had a ton of work done in your basement... assuming they worked in the panel, there could have been a loose wire on the neutral bar or breaker and they disrupted it.
This is the device I'm talking about. It is a standalone GFCI button (we have this on our whirlpool tub)
Yes, it takes longer to stop, it takes more distance traveled to react, but reaction time is not a heavy factor (or at least not as heavy as the common conventional wisdom thinks) - and that explains the real world data. Heavier factors could be a combination of the fact bad drivers and/or wild animals may not give you any time to react (another any number multiplied by zero equals zero equation). Or if they do give you time not sufficient time to avoid a wreck even if you were going slower than the speed limit. Making yourself harder to hit by making yourself less available to be hit clearly has weight towards reducing safety risks.
If fast things weren't harder to hit, there's no reason a major-league pitcher would throw 100 MPH fastballs.
Looking at the quantity of crashes in the real-world ignores nothing. It's a valid way to record and analyze real-world data rather than speculate with statistical models based on absurd assumptions and presumptions.
More crashes = bad.
Less crashes = good.
A disposal and dishwasher should not be on the same circuit. It’s highly unlikely that each half of the receptacle is on its own breaker but it is possible to do that and if it is done, I don’t think the code allows it.
The fix for you is a new circuit being installed with its own receptacle. Hold onto your wallet.
You can still be hit by a lighting bolt (reducing time exposure effective here), or by a landing airplane (higher speed might help you not get rear ended here), or some other "act of God" as they say. Animals are not a thing on Interstates near me, but that might be different in other areas without walled off limited access freeways and constant traffic.
Ok I had too many things going on this morning with my earlier response. Yes, the disposal is on a switch, mounted in the cabinet under the sink.
Yes, lots of electrical work has been done. The basement has its own breaker panel in the space under the stairs, and the outside box has a master 30amp breaker clearly labeled.
It seems as if one of the outlets under the sink no longer works. I’ll let you all know what I learn tomorrow after the guy comes out.
So there are 2 outlets under the sink? That makes sense. Though you can have an outlet that is half switched.
P.S. We don't cook much and we definitely don't use the garbage disposal for food waste when avoidable.
If you have a switch under the sink for your disposal, that sounds like the disposal was put in after the house was built otherwise the switch would be on the wall. This usually happens with older homes when a disposal is put in because of the work involved to install a switch on the wall (most folks don’t want to pay for the extra labor involved). But, your house is newer so it’s odd that the switch is under the sink.
FWIW, when I moved into my second hose in 1989 the switch for the disposal was mounted under the sink. I’m pretty sure that house was built in the mid 70’s when disposals were not usually common back then. I built my first house in 1969 and I didn’t want to spend what the builder wanted to install a disposal so I figured I’d do that later when I saved a few bucks. So, a few years later I installed a disposal but I went through the work of putting the switch on the wall. Needless to say, Mrs. j was used to that and really disliked the switch being under the sink and couldn’t wait until I put the switch on the wall in our second house. As it turned out that job wasn’t as bad as I thought it would be but I would have spent whatever time it took to put the switch on the wall. I’m just glad I didn’t have to pay an electrician to do it.
Around here they want both the DW and disposal to be on a GFCI circuit. Either a GFCI breaker or a GFCI receptacle. Just make sure your fridge IS NOT GFCI protected.
You’d think, but we’ve checked all the GFCI outlets and none are blinking and in need of a reset.
Nope, the sink is on an island and there is no wall to mount the switch to - ergo, under the sink.
————————————————That would have been a good place for an air-switch but doing that now could be a little painfully expensive if you have to hire to get that done. But, hey, with all you’ve spent so far, what’s another 4 or 5 hundred bucks?
My house was built in the 1950s and all of the original wiring is ungrounded, so I've installed GFCIs almost everywhere other than the lighting, refrigerator circuit, and microwave circuit (the latter two were added later and are grounded). Code compliant (or at least it was when I did it), and much cheaper than rewiring the entire house.
Fun story: when I bought the house, it had 100 amp service connected to a Federal Pacific "stab lock" breaker panel, which are notorious for catching fire. I refused to spend the night there until it was replaced. I also upgraded to 200 amp service, which is very much overkill given the size of my house (the electrician even discouraged it), but it wasn't that much more than redoing the smaller sized service. Now that I have an EV charger, I'm grateful I made the upgrade, as something pulling 48 amps on a 60 amp breaker plus other normal household loads would definitely strain a smaller service.
I’m happy mine is under the sink, I don’t want another hole in the granite… looks cleaner without it IMO.
There is no way I could live without a disposal. Ours is a 1 HP job that chops up almost everything. If it comes off the table it goes down the disposal. Paper napkins and all. Never once has it jammed. I can’t tell you the last time our kitchen garbage can smelled. Plus, hauling it to the curb weighs a lot less too.
With the very cool garbage pickup service that is... required?... in Ohio, and our short stints there, we have a rather unconventional process for garbage: I have a five-gallon bucket in the kitchen, and I just take it out to the covered bin every night before bed. A quick rinse under the hose and good as new; no garbage bags needed! But, we are the polar opposite of @jmonroe1 in that we do not have a disposal and the only thing that goes down the drain is minimal and incidental to washing dishes that were previously drained, scraped, wiped, or similar.
When we do need bags in the house, such as for the bathroom garbage, we just use plastic shopping bags or other similar recycled bags.
Well, if I ever have to go in there, I’ll tell you.
I did not pay for one in the new house. Never used it in the old house. We have a strainer over the drain to catch stuff and I k ok it off into the carnage Pail. And my wife has a lot more space under the sink to store her collection of stuff we don’t need.
Since we are down the hole... I'll tell a recent story on the GD.
Due to our vacation and other commitments we hadn't been down the shore for 5 weeks. Last Friday morning I drove down and had food delivered (wife was coming back from a trip and was driving down in the afternoon with my Mom and kids). Well... the fridge needed a cleanout of all the jars of pickles, peppers, olives, etc since they were old at this point. I decided to put it all down the disposer and it was at least 10 different jars of things.
It was all going good until one of the jars of olives had pits in them. OMG - that disposer screamed bloody murder for a good two minutes chopping all those pits. It wasn't jamming or anything it was just so loud.
Thankfully I was there by myself. My wife would not have been amused.
Much quicker to just dump them in the garbage!
So I’ve heard, small medium-hard items are good for cleaning any built up from soft foods. Needless to say our disposal “screams” routinely.
We do that all the time. Like I’ve said before, “I didn’t buy a 1 HP disposal to just sit under the sink to take up space and look pretty. When you’ve got it, flaunt it”.
In many areas, they are required by building code.
I don't know the exact space it takes up but I'll guess it's less than 1 cubic foot. still plenty of room for what we store under there which I'm sure is typical for most households. We've never had a problem, space wise.
