Thus far, I've had no problems.
Did you suggest that people look at the exhaust for black chunks of the transmission??
Naw...I've got to go back and re read your post!
Right??
Thanks for the info. It hasn't happened to me but I'll watch for it.
isell,
Now, now, you know what he meant! Actually, the black paint chips falling off is a Honda "Feature". Drive just in front of a Solara while going over some good potholes to "enhance" the paint surface of the Toy Solara.
Now, I know what dc sports was talking about.
Hardly a big deal....but..a quick spray with a heat resistant should fix things up.
Soon after I purchased it, I started to use Dextron III trans. fluid. I noticed nothing irregular about the Dextron's performance, but was curious as to the posts regarding maintaining Honda trans. using their fluid and the Honda fluid being superior to others. Let me say that in my opinion it is. Today I used it and I noticed immediately a smoother running and shifting automobile. The downshifts are not noticeable anymore, before they were. The shift from 3 to 4 is smooth as glass. I will never use anything other than the Honda ATF-Z1 tranny. fluid from now on.
P.S. There's no "t" in Dexron.
With regards to Dexron being compared to Honda ATF-Z1, the owners manual refers to the Dexron II as the replacement fluid.
That being said, it is recommended by the manufacturer. When I use that fluid, Dexron III due to II not available any more, compared to the Honda fluid, based on the performance results, the Honda fluid is far superior in that case.
Hardly a reason not to buy a 90-93.
The oil seal problem, again, affect very few cars but they can pop out. Honda is fixing these for free.
Both great cars, take your pick!
What can I do to improve performance.? I realize this is no v-6 but I can't have every granny
on the road kicking dust in my face. Will this performance improve.
does it feel that way when you first put it in reverse too? thats what my truck did when it had a vacuum leak.
I'm totally new at this, so I'm not sure what to do. Is this covered under comp or collision? How much does the repair for something like this usually run? Should I repair it right away or can it develop into a bigger problem if I leave it alone (e.g., rust)? Should I take it to the dealer or go find a body shop? If anyone out there has any advice for me, I'd appreciate it.
- Tom
Yes, this should be covered under your comp/collision, but you may have a deductible of either $250 or $500, so you won't get that. It looks like about a $600 repair since they will have to paint the entire door (to wrap the paint around an edge...you can't blend paints like in the old days). So it looks like you will be out the deductible amount.
You don't have to get it fixed right now, since any rust would be superficial, if at all, but since it is a new car, it would be nice to have it done. Also, damage like this lowers your resale or trade-in value if you don't repair it.
paint is always better. If the door must be repainted the paint should match well since the car is new. I would say that it will cost anywhere between $500-$800 to fix but comprehensive should cover it as long as you pay your deductible. Good luck to you and curse the jerk who obviously doesn't care about other people's property.
I recently had my timing belt replaced on my 90 Accord (197,000 miles). Since I've gotten the car back I've noticed a very subtle engine noise.. which seems to be most prominent at about 2000 rpm's... The noise sounds like either something requires lubrication or possibly that the belt requires additional tension.. I believe there are 2 internal belts including the timing belt that were changed...
Any ideas..??? I thought I had read that there was some type of external tension adjuster for the Accord.. does any one know if this is true.. and if so .. is it something simple to adjust ??
Other than the noise.. the car is running fine with the new belts... thanks...
I have read some posts here about the shudder problem. Auburn63 has been a help here I see.
I have a 95 EX with the 4cyl. VTEC. 138,000 miles. I just changed the oil and had the timing servicing done last month.
I have just noticed (last week or two) a slight hesitation occuring around 40mph. It is hard to describe. Kind of a rough feel. Like it is not getting enough fuel or air. I did replace the air filter. It will go away as I accelerate. Does not seem to happen at higher speeds. I really don't think it is searching for a gear, like tranny slippage. Does this sound like a fuel mixture related problem?
I noticed some talk of the EGR assembly. Could this be a solution?
Does this sound like a transmission problem?
I hate going to the dealer and other shops due to pressure to have all kinds of work done. I just got the car and do not need more repair bills. So I am trying to diagnose before getting into something.
myers11
If anyone has experienced this and been able to come up with the solution, please reply! This is becoming an expensive problem!
If the noise you hear is like a knocking /rapping sound then one of the belts may be to loose.
If the noise is more of a whine then the belts maybe to tight and although there is an external adjuster they dont work as well as they should so be carefull if you are going to try this your self.
myers11,
If your vibration happens in around the 1800 rpm mark on slight accel then you probably do have an EGR problem. We have just recently started seeing the 94-97 generation accords having this problem so it is possible.
maggiet5,
I have seen a few main relays cause your problem as well as bad distributors. Do you hear any noises like squeaking or chirpping? If so these would lead me towards the distributor if not then maybe it would be worth the gamble to put in a main fuel relay and try that. Nothing else is all that common that I can think of. Good luck
Replacing the distributor and igniter (I was advised to take care of the latter too since it relates to the former) repair took a few hours. Honda parts were used.
Auburn63: thank you for your timely and helpful response!
Anyone know how to re-program a keyless enrtry remote?
Thanks in advance,
Rich
I hope that the distributor works out for you as 90-93 did have problems with them, however the diagnosis procedure that he did would also be a known way of verifying that the main fuel relay is bad. The fuel pumps themselves very rarely go bad but the main relay(main fuel relay)goes bad often in those years. It will cause no spark and no power to the fuel pump or just one symptom or the other due to the fact that it controls power to the computer.But hopefully yours was the distributor and you have no further problems..Good luck.
mwcarlso,
On the rear motor mount there is a vacuum actuator maybe the linkage for that has fallen off. Those rear engine mounts have been a constant source of vibration once they get some time and mileage on them.Other than that items such as aftermarket radiators not sitting correct in there position.If all it takes is 800rpms to feel better then bump up the idle as it will not hurt anything as long as you stay below 950 rpms.Sometimes vibrations are just there due to the age of the car and parts in it. Good luck.
I have a 2000 Accord EX-V6 coupe which I purchased in June '00. It is my first Honda (my previous car was a '91 Grand Am) and am very pleased with it so far. The only thing that bugs me about it is the transmission.
Being new to Honda, I'm not sure if I have a tranny problem or a normal Honda tranny. The transmission in my Grand Am seemed a lot smoother, you could hardly feel the shifts. In my Accord, the shifts seem harsh at times. Mostly this happens at lower speeds.
I've heard a lot about tranny probs in the 2000 Accord. Should I take the car to my dealer and have them look at it for my peace of mind, or, should I not worry about it because Honda's tranny's aren't as smooth as GM's? Most every review that I read about the Accord praises its transmission. Maybe I'm just too picky, I don't know.
Any comments on this topic will be appreciated.
There has been a lot of arm-waving and fretting online from owners of V6s over the batch of failed parts that plagued a small group of cars produced early in the '00 model year. The symptoms had to do with a loud, unmistakeable clunking noise when the car was put in reverse, and was traced to a group of bad parts from a particular supplier in Japan. There also were a few complaints about lockup torque converters not working properly. Beyond that, I am unaware of any reason for the paranoia that seems to be out there about V6 automatics. My '01 is young yet, but is trouble-free and a wonderful car to drive. Smooth as any GM ? Nope...but you could not bribe me to trade this car for anything in GM's lineup, at any price.
Auburn: Can you help put this continuing rumor to rest?
The one thing that almost all first time Honda owners complain about is the shift quality of the trans. This has been that way since I started with Honda back in 83. They tend to shift on the positive side which is a bit harsh but good for the long life of the trans.However if you feel like your trans is not right there is no harm in having it looked at but I do not think there will be anything wrong with it. I have seen alot more complaints on here about transmissions than I do at work and I see very few transmissions that are bad. So I think you just probably need to get used to yours.Good luck
I was wondering if anyone had any thoughts on the following - apologies in advance for not being more specific.
I've got a 2000 DX Manual with about 13K miles. Lately, I've noticed that the clutch has gotten really picky - meaning I need to really baby it and give it extra gas, especially starting from a stop in first. Otherwise, the engine studders a little and the car jerks a bit as I start to move forward. It's less noticable shifting into higher gears although I have noticed that it's a little picky going into higher gears as well, even if I've accelerated to higher than necessary RPMs (3000+).
The clutch has 13K relatively 'kind' miles on it and I wouldn't expect it to be wearing out. Plus, it doesn't feel like the clutch plate is slipping exactly, just that it has gotten much more difficult to smoothly re-engage the clutch after shifting into each gear. The car is absolutely no fun to drive anymore.
Any help would be appreciated,
BTW - with the car obviously under warranty, I will be bringing this to the dealers attention. It's just that I've had trouble with somewhat vague problems like this one in the past.
The leakage seems occurs on the bottom of transmissiom housing between the gap of two half housings, at least it appears so.
Could it be the gasket between the 2 half housings is defective?
Thanks for any of your input?
Sounds as if the flywheel may have some areas that are untrue. Usally this is caused by heating up the flywheel. The other possibility may be the clutch plate springs either way you may be able to get the dealer to cover it since you have low miles. Clutch's are kind of like brakes and are considered a wearable item therefore are not covered usally. However you should be ok but don't wait too long to bring iit in and have it checked.Good luck
gye,
I haven't seen any yet but I doubt that it would be the case half, although anything is possible. What have they done in the other attempts? Have they done a front trans seal yet? Or even a shift shaft seal? They have been the problems in the past.
