1995 Accord EX VTEC 4, 139,000miles.
I have diagnosed that an acceleration problem I have is a bad EGR valve. I have it disconnected and it runs fine. The Check Engine light finally came on.
My question is this. What would it hurt to just leave the EGR disconnected? Honestly. I really don't want to spend another $175 just for the part. That is the dealer price. Can't get it from another source here.
I disconnected the vacuum hose and capped the EGR nipple. The car runs fine. Should I just leave it this way? I have replaced the timing belt, and had a major tune-up in the last 4 months. I am tired of dumping money in this thing.
Chris
My sister currently owns a 1999 Honda Accord LX sedan 4-speed auto. The car currently has a chronic problem of front brake pad premature wear. The first time she had to have her Honda dealer change the pads was at 16K miles back in October 2000. Almost 9 months and 7,000 miles later, her front pads are completely worn out again!. She took the car back last week and the tech confirmed that the front pads were gone again! She had them resurface the rotors and replace the pads for another $150.00. Her service advisor told her that current generation Honda Accords and Oddessey Minivans are NOTORIOUS for premature wear of the front brakes....(I can relate to this as I had similar brake problems on my 1997 Acura 2.5TL). Needless to say, my sister is extremely dissapointed at the quality of the current Honda Accord. She has had 4 Accords before her current one and the '99 has been so far the most 'problematic' of them all. Also last week her engine's oxygen sensor had to be replaced under warranty as well. The car has been babied, Honda serviced only, since she bought it in Jan of '99. And no, she doesn't drive with her foot on the brake pedal, carry heavy weights or tow a trailer with her car.
Has other current generation Honda Accord owners experienced these nagging problems???
My sisters next car will probably be a Toyota.
What's up with the all 'almighty' Honda quality???
I strongly disagree that these cars have endemic problems with pad life. Something is very wrong with your sister's experience. And, we have had no failures of any kind [nothing but routine oil changes] with either car. That doesn't help you, but it suggests your experience might not be average, either.
If your problem that you are having is a miss fire or studder around 1800 rpm's on light accel then you problem may be the EGR ports in the manifold. We see more of these than we do bad valves.There is a mostly labor procedure to clean them out.
Brakes,
We see most fronts lasting from 30k-60k and rear pads from 25k-45, rear shoes seem to last forever.However most of the time it comes down to the driver and there braking habbits. I have replaced fronts at 15k(rare but I have)but I have also replaced a first set of fronts pads at 90k so as you can see there can be a big differance in drivers.
I can do the EGR removal and clean it no problem.
I just had it in for 37,500 and they said the brakes look great.
How come the rear pads wear out so much faster? I will admit, I was spoiled. My 91 EX 5sp required new front pads at 112K and I never touched the rears. I realize the auto will probably use pads more often, but this fast on the rears?
First time Honda owner. I bought the 2001 Accord V6 fully loaded on April 30 with the leather (put 1300 miles on it so far). I had the car in the dealership this weekend to check the compressor on the air conditioned, and everything was A k. I love the car, but today I noticed that the side air bag indicator was turning on and off in the morning. Has anyone had this happen to them? Also, my sun roof seems to be rattling anyone have this happen to them too?
Thanks in advance for your input guys.
Angelouda
The rears wear out as they do for differant reasons. One is as has been said is due to their thickness when they are new.They are about half as thick as the fronts and alot smaller in overall size. Others could be from emergency brake cables that are not fully releasing, sticky caliper pins or slides.30k is about normal for rear disc to be close enough for replacement but a little soon to be hitting the sensors and making noise. Most of the time brakes get replaced on the early side due to it being so hard to guess how long it will be before they hit the sensors or totaly wear out.
Airbag
If you have something on the passenger seat,something hanging of the backside or the seat gets wet the sensors can cause the light to go on. If the leather was installed by an outside company then the seat may need to be re-initialized into the system. Good luck
Ang
I'm just about positive that a passenger was your 'problem'. My mother is about 4'10" tall and the side airbag light is constantly going on and off when she sits in the passenger seat. When just about anyone else sits there, the light stays off.
LOOK IN THE BOOK. Use the maintenance schedule in the manual as as guide...you'll find which of these items are within a reasonable envelope, and which are just silly. Of the things you have listed, the valve cover gasket falls in the silly bucket...most of the rest I would describe as "not unreasonable".
Actually the sound was coming from the rubber seal around the front windshield, not the sunroof. There is actually a TSB on this. I was at the dealer today, they told me this is common on only the 2001 Accords for some reason. The dealer had a glass company come replace the rubber seal with one which was thicker--the sound is gone!
Unless you are going for a brake job, leave the brake fluid alone except to top it off. The differential fluid is a different story. There is no way of determining the condition of that until you actually get to it. Since you are halfway there, you might as well do it. That shouldn't cost more than $20 to replace.
As for the coolant, have it checked with a hydrometer first. If it needs to be replaced, go for the flush job which will remove some of the deposits that build up inside the engine and radiator.
I just got my front pads on Accord 98 46k by a Dealer. Fluid Flush $75, Rotor Job $145 and break pads $55.
1. What is the cost comparison for Rotor Job v/s Rotor Replacement, which one is advisable.
2. How do the prices compare for the jobs I got
done, are they normal ?
Sridhar
I just found this site and been reading a lot of your messages. Thanks for all wonderful info and experiences you posted here!
Anyway, I have an Accord 2000 SE with 11000 miles on it. The malfunction indicator light has been on since yesterday. I have scheduled with a dealer to take a look at it. Talked to tech quickly about the cause. they told me that 90% is the fuel cap problem. Manual states that if fuel caps loose will have to take 3 trips to clear it. It is true that I had just filled my gas the day before the light got on. But I didnot find the cap loose at all.
I just wonder anybody here has accord se 2000 and experienced the same problem.
Will let you know what the dealer find out about this problem when I bring it in next week.
BTW, how do you make a search on this discussion thread ? Manually browsing all the messages to look for related problem is almost impossible and painful.
same thing but it's most noticable around 50mph.
It's driving me crazy because it doesn't do it all the time. At night or if it's humid outside, it doesn't do it. Also, if I fold in the right side mirror, it's not as loud. I'm taking it back to the dealer next week.
The Moon roof height need fine alignment because of the passenger side is slightly higher than drive side. Can anybody inform me that how diffcault to alignment be done. Is it simple adjustment be done by Car owner? other than turn Car in to the dealer for all day that adjustment be performed?.
Everyone's helpful information will be appreciated.
I swear to myself I will make sure to tight the cap more than 3 clicks from now on.
Engine seemed to have lost some punch on occation before that. did a complete tune-up 3 weeks prior, no code on the ecm! i think it might be the idle air control (IAC) on the FI.
Any ideas?
http://www.batauto.com/honda.html
I have a little problem with my 96 Honda Accord LX (127,000miles). It's burning too much oil! The problem related to the oil leak, at the front of the engine caused by the dislodged seal on the front balancer shaft has been supposedly fixed.
There was no charge for that (merci NHSTA for pointing that to the Honda folks!).
Anyhow I still believe that the problem that I am having is still related to that, but my dealer tells me now that it might be a coil. This would require according to them a half-engine overhaul ($800 + the part if it's indeed the cause!).
I believe that this is a manufacturing defect, and Honda Co. should pay for it
My 87 Chevy Nova doesn't burn that much oil! C'est fou.
Let's all buy Chevy Novas!
Thanks for any suggestion, comment or opinion.
Try to find a good Honda mechanic - dealer would not be the place to take a 12 YO car IMHO.
Luckily ??? - car was totaled in an accident before I had the work done.
The O2 sensor could be a source of your problem but so could several other things.Without being able to drive the car it would be hard to say what could be your problem. Most of the time a failing O2 will cause a check engine light. Engine timing, valve adjustment and fuel injectors are just a few areas where I would start to look at. Tire presure and condition is another when it comes to fuel economy concerns.Somewhere around 32-35 psi is a good all around setting for comfort and economy for most areas of the country.Good luck
mwcarlso
The seals do blow out on your year but not as often as they do in the 94-97. The only thing you need to do is ask, if your seal is leaking to have it replaced and install a seal holder on it.If it is not leaking then you can just install a seal holder and you will be sure it will not blow out. (The seal holder is a metal bracket that holds the seal in).This does not mena that the seal can not form a leak it just means that it will not fall out like the 94-97.I think it is a good idea to replace the cam seal and the balancer seal at timing belt intervals. The crank seal has a metal backing and hardly ever goes bad but could also be replaced at that time if you choose.
Question: Do you know of any after market radio that offers quality AM reception? I'd appreciate any references that you might have.
BTW: My '85 Civic Wagon (1.5L, Jasper reman engine) is running great. The engine cranking 75hp and running real smooth at 65mph (3300-3500 rpm) with the 3-speed automatic. I'm putting the car into the shop soon for a custom paint job. After that, it'll be showroom quality at 250,000 miles.
Thanks for any information that you might be able to provide on the radio.
j.w.
