Visitor Agreement.
Thanks in advance
Alnero
I bought a Honda Accord 2002, certified with 35800 kmiles in Jun 05. After 3months, I noticed that Power steering fluid was leaked ( just a few drops on my garage floor). I did not feel that my car was misaligned. I took it to the the dealer. They said that my car needs rod and pinion to be replaced. The part is $475.00 ( saw on paper). I don't know how much was the labor. It is still in warranty, So; I did not pay anything.
I bought a certified 2002 Honda Accord with 35800 k miles with automatic tranmission. When I placed the car in reverse, it sounded " clank". I replaced the tranmission fluid with fluid from dealer. It went away.
I'm a 22yo female and recent college grad, and my 94 Honda Accord AT is giving me so many problems. First off it was flooded in my apartment complex and the water went up to the top of the hubcaps. I had to replace both the engine and tranny computers on the passenger floor side. I changed the tranny fluid quite frequently since water was in it, and a month and a half later my tranny started acted up. When it was in drive (D4) it would not accelerate but yet acted like it was in neutral or something. Pretty soon it wouldn't move at all in D4, D3 or anything, although I was giving it gas (it just kept reving high like it coudn't switch gears). I had to get it towed because I didn't trust driving it. Oh and a few days after the computers were changed I noticed that my car would hesitate to move when I gave it gas (it would rev up) after it was at a stoplight. But anyway I bought another tranny but it was a used 96 (the guy told me that it was the the same for a 94 and 95), but after that tranny was put in and I drove it home, the speedometer doesn't work, the D4 light blinks, the check engine light is on, and it doesn't go into 4th or 5th gear (it clicks when I speed up and the RPMs go up). I found this out after I left the shop on a Saturday so I couldn't go back to ask the mechanic. I'm scheduled to go back on Monday to get the piece that controls the speedometer. The mechanic actually warned me that the piece for the 96 Accord didn't match, so until I come back to get it put it the D4 light is going to flash and the speedometer won't work. Do I have a bad tranny or the wrong tranny? Or is this piece causing all of the problems? Please help.
Christine
BUT: The ONLY significant problem I have had with this car, in the 6 years I've owned it, is ABS-related.
Exactly 4 years ago, with 60K on the Odometer, the ABS Module went dead. Cost me $1,200 to replace it. 3 months ago one of the rear speed sensors went bad, cost me $300 to replace.
Now the ABS light comes on again few seconds after I start driving, and stays on (though couple days ago it didn't show up for one ride...). The reservoir is full, not leaking. And, btw, I never noticed any "griding" noises mentioned here before...
The dealeship claims it's the Acumulator Module, and wants some $1,500 to repalce it... So these modules are supposed to last only 4 years??? This is NUTS.
The customer service agent who gave me the printed test results, was a bit surprised NOT to see any ERROR CODE NUMBERS on the sheet. And for whatever reason -- they did NOT charge me for testing the car... I tend to suspect that the same sensor they repalced 3 months ago -- is actually the culprit, and they KNOW it... Can't trust no one...
What's the story with the ABS on this model? Is this normal?
I have an EX Accord 95 I4 without any problems until I replaced the engine at almost 200K miles. At the time I bought this Accord I4 I liked to save some thousand bucks over the V6. Now all my other 4 Accord are V6 EX including a 05 Accord hybrid and enjoy it very much. The ABS on my little oldie 95 EX is so fine, no issue so far. Good luck BigMama.
Then at about 50k miles, the noise reappeared, and it started doing it regardless of the position of the seat. I haven't figured out what the problem is, so I can't be of much assistance. If you find out the source of the noise, I would appreciate hearing what it is.
Had several incidents where ABS saved me frm a crash, especially in the winter.
The first Camry I leased had no ABS, which was very uneasy for me, especially one time (again, during winter time) when it caused me to lose control and slid into a ditch...
But then for $1,500 I'd rather forget about the ABS. It's just that my 16 yrs old daughter is the one to inherit the car...
Also, I noticed my rear left door is misaligned. Its jetting out a bit. (about half a centimetre or a little less)
Oh yea...I noticed my tires are brown and I try to wash them with soup and it just gets browner. Is there any good tire wash? I live in Canada...any product that sells in Canada thats good?
a damaged radiator with my '98 4cyl. Accord. Everything seemed to be running fine too, except I had been experiencing cooling problems for about two weeks before I rushed it to the shop. No engine damage, car still running fine and not burning oil.
Thanks for the reply. Well, you lucked out because your car was still under the manufacturer's warranty. Whereas my car is at 60K+ so the dealer told me that I would have to foot the whole bill. The part is $700.00 on cost not including labor!!! So, I had to find another way to replace the part. But, I would like to hear others who may have this problem. I hear that usually you don't replace this part until maybe 100K??? But, I hope you had both sides inspected because you never know. With all the potholes in the cities generally, it is easy to damage this part. Maybe it is well worth to look at SUV's...hahahahaha. (Higher clearance).
Sounds like the window is loose in its channel. For the tires, three items: 1/4 cup of powder laundry detergent in two cups of hot water, a stiff bristle brush, and lots of elbow grease.
Wondering the location of the fuel relay sensor?
Did anybody here experienced the same brake problem that i have?
Did the Service advisor from the dealership tricked me that my brakes were OK eventhough it has a problem making noise and they just dont want to fix it for free since it was still under warranty then and waited for my warranty to expire before telling me?
Is the $200 bucks they are charging is fair just to fix the rear brakes?
The squeeking sound can be a signal of your brakes getting worn out (which can be easilly checked) or just nothing... Many brakes squeek with no real reason. Washing them with a hose can sometimes help...
As much as I read here, and know from my own experience, it's better to service your brake at an independent shop and ask for CERAMIC BRAKES. They last much longer. Honda (for whatever reason) does not use Ceramic brakes, and that's why they wear out so much faster.
What I don't understand is, how come you REAR brakes are worn out so much more than your FRONT... Usually it's the opposit (unless you already replaced your front pads in the past).
Again, check it with an independent reputable mechanic.
This is not the case. Honda DOES use ceramic brake pads. Check out: Http://www.automotivedigest.com/WhitePapers/Akebono_Ceramic_Friction_Tech.pdf.
Is it normal for the rear pads to wear out before the front, definitely not. If they are, there is probably a problem with the braking system. The car should be brought in to a shop that specializes in barking problems and has a good success record. This is probably not most Midas or some Honda dealerships. Not that you can't find some of the aforementioned doing good work, but if it is an unusual problem you may need a mechanic that is a good problem solver.
I've read here that the thickness of the pads on the rear is less than the front. It was the first time I had the experience in the many cars I've owned.
I have a 1992 accord LX/5speed. The car vibrates when I stop at the traffic light or start the a/c. The idle rpm of the engine drops to 400-500. It would be great if someone can let me know how to increase the idle rpm of the engine.
Thanks in advance
Mitra
The front pads and rear pads are different sizes. One possibility could be that different suppliers were used for the front and rear pads. It is possible that one manufacturers pads wear faster then the others, causing the unusual rears wearing faster then the fronts.
Another possibility is there is a design defect in the brake system itself.
Unless the dealer/Honda has a solution, which I have not seen any posted here yet (TSB), I would shop around and see what other shops would charge to replace the pads.
Assuming the rotors are OK, replacing just the pads is usually an easy job. $50-$70 should buy good aftermarket ceramic pads, and i would think 45 min should be enough time to replace them.
Some of the larger brake shops like to machine the rotors and replace the calipers every time they do a brake job, which drive the costs up. They may offer a good warranty, but to cover themselves, they want to replace/machine everything. If the car was older, rotors are scored, and the calipers are original, then they may need replacing, but if the only problem is the pads, then make sure that they are just replacing them, and not doing everything else.
Mrbill
RD
RD
You still may have low oil pressure even though you have replaced the pump.
If the engine has considerable bearing wear, the oil can leak out around the bearings faster then the pump can handle. If the engine "rattles" alot when you first start it up in the morning, it would be another sign of worn rod/main bearings.
Mrbill
I would show the dealer a print of the owner's link advisory to ease the process.
