Years ago, in Europe, a friend of mine bought a new car (Renault) and found a moldy, half-eaten Baggett between the back seat and the trunk....
Have you lifted up the rear seat? Things can drop below it, just reaching your hand around the seat might not reach everything.
Do you know the history of the car? Hopefully the car didn't come from a flood area. You did mention that the smell started after you bought the car, no hint of an odor when you first got it?
Mrbill
Is the antenna in the glass?
Is there a place to check to see that wires to the antenna are reconnected?
FM reception seems fine.
There is normally one antenna for both AM/FM when it connects to radio. If your vehicle does not have a fender whip, then the AM/FM antenna is etched onto the rear glass or side glass. The current body Accord (with droopy tail light) for sure has rear glass antenna.
Typically, if the vehicle has rear glass antenna, it also has an antenna amplifier module which is normally located near the glass antenna (C pillar, base of rear glass, or upper part of the trunk). The glass antenna pattern is similar to rear glass defroster wire but not connected to it. Just follow the glass antenna wire, you should find the connection to the antenna module. The first suspect is a disconnection between the antenna and the antenna module. On the output side of the antenna module, there is co-ax cable (similar to your shielded Cable TV cable) connecting this module and the radio. This could be disconnected. If the body shop touched the radio somehow, then you may have a disconnection between the radio and this cable (behind the radio). Any of the three connections could be loose.
Things to check:
1. If your radio can receive FM stations 40-50 miles away then your antenna connection is likely OK. Even without connection, your radio can receive local stations (5-10 miles radius)
2. If you have no antenna connection, you will not receive any AM station unless you drive by an AM transmitter. You just hear white noise in entire AM band
3. AM reception is different during day-time and night-time. It's also depending on the locations. You will notice less sensitivity under highway overpass, power line or some metal shielding structure. So find a clear open area and compare your vehicle with others.
jt
you said you replaced the cabin filters, and i suspect you would have seen evidence of mold or mildew on the filters themselves if that were the problem. you've also indicated that there was water draining from the evaporator line and exiting the vehicle with the AC on.
my advice would be to use your nose, to check the flooring material in front and back. don't forget to completely remove and check the floor mats. check for dampness under the matts.
i'd also check the trunk area, specifically the wheel well and the jack compartment.
if you come up empty, i think the suggestion to check under the hood is a good idea. it's possible a dead animal is lodged somewhere among the cables and hoses.
That's a good suggestion. One time I found where a small animal had made a nest on top of the engine in our Nissan. Our daughter bought a new Honda and later found where a mouse had been chewing on someting in the trunk.
Thanks for the help.
Sincerely,
PRG
do not forget to remove your mats and check for smell / dampness. also don't forget to check the trunk, the wheel well and also the access panels on the right and left in the trunk for signs of water.
also make sure your trunk lid rubber seal area is clear of debris and gunk from tail-lite lens to tail-lite lens.
hope it helps.
How easy/hard is it for a NON-Mechanic to change plugs in a 4 cyl.?? AND...should I replace the plug WIRES too....as a mechanic recommended??
My question - should the bolt tighten till it is flush with chrome finisher? I have some threads on the bolt showing and I think I am tight enough but I do not want to lose the finishing tip. Thx.
> Hopefully Honda will goodwill a new one for you.
Yes, Honda is replacing the transmission for me. This improves my opinion of Honda America a bit - I haven't been too happy dealing with them in the past.
> Did your check engine light ever come on during the slippage?
No, no light. The transmission would just start slipping if I drove on the highway for more than about an hour. Heat build-up I suppose. If I let the car cool down, it would be all right for a while. I took it in to the dealer to have it checked, and now it slips after just a couple minutes - just spins like it's in neutral. I wonder if the dealer didn't add to the damage by doing stall-speed tests or something.
I haven't gotten the car back yet, but I will let you know the outcome when I do.
> and got a few eggs thrown at me. I went through a car wash and noticed
> that one of the eggs left an imprint on my side door after it dried off. Kinda
> looks like a swirling scratch thats 3 inches in diameter. It feels like a surface
> scratch that has a small little grooves in the door as you wipe your finger
> across it. I used scratch doctor which didnt work. Anyone have an idea on
> how to fix this? Is this going to be expensive?
Yeah, someone did that to me too, about 7 years ago. The radial pattern is caused by fractures in the clear coat. If they were close enough and threw the egg hard enough it might even make it down to the paint.
If you take it to a body shop, they will probably want to clear coat the entire panel, which is expensive. I have a friend who does body work, and he worked the area with a buffer to lighten the scratches. It still showed if the light hit it just right, but it was 70-80 percent improved.
NO, obsessive-compulsive "neatness" doesn't count, here. Tightening the setscrew firmly enough to prevent twisting or pulling the chrome finisher off is sufficient. My '96 Accord came with a chrome finisher. The set screw protruded about 1/8" - 3/16". Forcing a flush fit of the screw head only risks scratching the chrome finish to set the stage for rust, deforming the tailpipe, or stripping the threads. (Besides, who looks at the stupid thing that closely anyway?)
It's interesting that Honda is always picked on regarding paint issues - it's thin, it chips easily, it's water-based and therefore inferior, are the three I've heard. How does one conclude that the paint is thin or any more or less inferior to the paint used on every other car produced in the U.S.? As far as the chipping goes, many indicate that Accords are more susceptible to it based on the number of chips received, but I think this may have more to do with the shape of the frontal are and the forward-most part of the hood than the durability of the paint.
Or if you know where I could look at a picture? That would be helpful.
Mrbill
The radio lights burned out over the summer, from looking at other forums this seems to be an ongoing problem. Honda should recall the radio component. Luckily I have an extended warranty and only had to pay $50.00
Now, my TCS light stays on all the time.........which from other research seems to be an issue with this car.
Other problems: my brakes had a "silent recall" as well.
I would trade this car in........but Im upside down on it. Ugh
Anyone else have the above problems at all.
