Visitor Agreement.
Any suggestions on when to change the Timing Belt on them. Anyone?
A code 15 is registered in memory, which according to the manual indicates a problem with the ignitor. The owner believes this to be a false indicator, because it's his impression that the ignitor either works totally or not at all. Instead, the owner replaced the temperature coolant sensor to no avail.
Any advice? Is it a faulty ignitor or a related component?
Thanks //
1)The distributor sub assymblys were known to go bad in that year. Usally they make a intermitant noise but not always. You can look inside the dist cap and if there is a white substance all over the inside then it is probably bad. You can also take it out of the car and spin it by hand and see if it is stiff.
2)The main fuel relay has been known to cause start up problems as well as the capability of causing the stall and no restart until the relay cools off and makes contact again. The only test for this that works real good is to put in a known good one while the problem is there and see if it helps.
3) The next thing would be the TW(tempature, water sensor)
As for the igniter, that is a possibility because they can be bad at certain tempature ranges and fine at others however we have not replaced too many of them in that year. Once it fails/stalls and won't restart you can check for spark and see if you have it or not as a quick test for that.
The most replaced item for that complaint is the main fuel relay, next the tw sensor unless the distributor is noisy or binding then that would be the first thing.
My guess, with a quiet/clean distributor, would be the main fuel relay....Good luck
Thanks for the input. I bought the car at about 70k miles in '99 and have used Mobil 1 5w30 and OEM filters at about 7.5k change intervals. Are the bearing wear(rod and main) and piston slap problems you've seen oil related? I'm going to 15w40 on the next change (Chevron Delo400) to see if it helps any. I will pull valve cover, adjust valves and check for the rocker arm wear you mentioned soon. If nothing there, then next oil change will pull oil pan (assumig that it can be dropped w/o removing steering rack, half shafts, etc.,-I have not looked at it to see how big a job dropping the oil pan will be). Any advice, directions to appropriate websites, etc. will be appreciated. Thanks again.
Thanks again for your quick response.
basically, i would just like to know how much it would cost to have this scratch repaired, this scratch is not deep but it's about 3 in. wide and .5 in. tall, my friend told me that it would costs about $400 to have it fixed, is that true? any information would be greatly appreciated. my car's only 8 months old, i don't want to be driving around with a scratch for the next few years unless it costs too much for this little unfriendly scar.
See you around.
I too have personally witnessed the difference that running lights can make, especially in the behavior of otherwise careless truck drivers [nothing like the second glance in the mirror before he decides to move his 80000 lbs into your lane]. We just got in the habit of using the low beams all the time on our EX, and letting the system manage the shutdown process, which it does just fine. No new wires, relays, or work under the hood.
UNLESS...the car has been lowered!
thank you
and you don't have to pay for the repair, it's covered under warranty.
hope the information helps. have a good one.
Window ticking noise - have you had extreme temperatures (cold nights and hot days) in where you live lately? I have the same noise in my windows when it is freezing outside and toasty inside my car. Another time I have the noise is when I am driving on the highway and it's windy(I mean you can see the tree branches wavering type of windy)
Thanks for all the help.
my .02..
thnx
Oh yeah, crows can fly!
Seriously, I've seen 300,000 miles on several of these. It depends on a lot of things I suppose.
Your results may vary....
And now the facts. I've got a '98 EX V6 Coupe and its a daily commuter over a wide variety of roads. About every six months, I wonder over the car and re-tighten every loose nut and screw (ah, but not too tight). I also use a rubber protector / sealant on all my rubber strips and mounts. Seems to work for me. My "Moon Roof" doesn't rattle except on uneven dirt roads (which I see every weekend). And although I do hear a bit of a squeak or rattle now and then, I've been able to keep them to a minimum.
The wind noise is more of a pain. And most of that is due to the damn MVX4's. I could say mine was a Monday car, but the truth is that a little bit of preventive maintenance goes a long way. 'Having said that, how can I get rid of the non-tire related wind noise. ITS DRIVING ME CRAZY!
It did use some of the dealer supplied grease on my moon roof gasket. I've also been using Zaino "Perfect Tire Gloss" on the assorted rubber mounts and weather stripping (around doors, etc.). And once in a while, I also use it on my tires.
but then last night when i was at my friend's house i ran out of gas so i refilled at a local Shell station since i couldn't find a Chevron, ever since i refilled the lag has been gone and the car accelerates as smooth as silk, i was really surprised because i always thought Chevron is the best brand, isn't it? then how come an accident switch in gas station cured the lag in power i always thought was a honda characteristic? i mean, why? i'm really confused.
BTW, my car is an ULEV VTEC 4cylinder
I know what you mean and I agree. I suspect the 2003 Accords will be much quieter. The new Pilots are VERY quiet.
I say *for now* because any car, Honda or not, can turn on you. I loved my '91 Saab 900T too, but hated it's chronic problems. So far, my Accord has been good to me with almost 28K miles. I have confidence that this will be the case in the future, but you never know.
Anselmo: I agree about the MXV's. They are very quiet. I just don't like the way they wear out prematurely. The Accord is noisy inside, it's not the tires.
Thanks....
Bottom line - I wish I had bought a Honda extended warranty two years ago. Does anyone here have a good ball-park estimate of what the cost *should* be on a '00 SE w/28K miles? Also, does anyone know what the Honda EW cost for this car two years ago? I'll be calling a few dealers this coming week ....
In any case, you're doing the right thing by building a case history for your tranny just in case the thing dies right after the warranty expires.
Best Regards.
