Visitor Agreement.
If the dealer checked for excessive current draw and was not able to find any, then the battery should not be going dead (unless the battery is bad, but you state it's already been replaced).
I'm interested in knowing what the dealer's next step is,,,
2) I would start with replacing the driver's front, then retest.
3) After removing the door panel and inner plastic, disconnect the the outer door handle rod from the latch. Next, disconnect the inner rod handle and lock rod from where they connect to the latch (be careful not to damage the plastic clips that hold them on, the outer door handle rod can be very hard to remove from the clip). Next, remove the 10mm bolt (from the left lower part of the door panel) that holds the rear window run channel in place. The rear channel can now be moved out of the way. Unplug the electrical connector, then remove the three screws that hold the latch in place. After you remove the latch, the actuator can be separated from the latch by removing a couple of small screws. I hope this helps!!
That "metallic clicking" that you are concerned about is totally normal on most vehicles. It's just sheet metal components of your exhaust system (catalitic converter, muffler, pipes) cooling down after having been running at maximum temperature while driving. It's the same sort of thing that you hear when the heat is coming up or going down during the heating season in your home if you have finned baseboard radiators.
Enough of this.. I have a question. Does anyone know how to turn off the "maint req" (maintenance required light? I do all my own oil changes/brakes ect...
My sister is having the exact same problem in her 2003 Accord EX (with about 2300 miles now). She notices it when she idles and has the window open, and she says it's very strong. The service dept. told her that it was common in a number of new car makes (although it clearly is not universal to all makes, from what we hear, it seems to be common in Accords). It's some chemical in the catalytic converter that burns off over the first 10K miles and then is gone, they say. Will let you know how it plays out. She's not happy about this, although she likes everything else about the car.
=> Thanks Spud41 for your response.
The front actuator was replaced and tested but have 2 other messed up actuators (rear left, front right). I disconnected the front right and could only hear the buzzing sound from the rear left actuator so far (doesn't unlock or lock anymore automatically, nor does the front left).
Anyways, junk yard guy hasn't fallen through per the actuators I need, will check during the week. Haven't found anything yet on the web(gotta check some more, I guess)... Anyone got a site, pass it on pls. will appreciate.
=> Will try your instructions on removing once I get the part. Sounds like it will work. Will update once I get those items (hopefully).!!! Thanks again Spud41!!
Bob
To gregoryc1, is Honda the engine manufacturer that looks for reasons to go to court to test its warranty in every state? If not, then that fact really has no relevance to this discussion, other than to scare people. Besides which, litigation is horrendously expensive, and you never know when a jury will burn you. Doesn't appear to be a sound business practice to me.
I've said it before, but I will say it again. I really do not think that Honda will risk its reputation for quality, durability and reliability in this country by publishing a maintenance schedule that is incompatible with the long life of its vehicles and engines. If the engines in the Civic from 2001 onward, and now the Accord from 2003 onward (I don't have personal knowledge of the maintenance intervals for other Honda models) start self-destructing 5 or 6 years out, then Honda will have a very serious problem on its hands for its two volume leaders.
I am going to venture a guess that Honda would not allow its reputation as an automobile manufacturer and more importantly an engine manufacturer, to be ruined in that manner.
So while there isn't a problem in changing oil every 3,000 miles, I don't think we can conclude that the engine will be full of sludge in 40,000 miles following the maintenance schedule recommended by the manufacturer of the automobile.
I've followed all manufacturers' maintenance schedules closely, not arbitrarily changing oil at 3,000 miles because the oil companies say so. I've never added top cylinder lubricants, or other such snake oil, specifically because every one of the owner's manuals I've ever read specifically advised against it.
I have never had a sludge problem. I have never had an internal engine problem. I have never had to repair or replace rings, pistons, valves, bushings, etc. If I've ever had a rough idle it was usually because I needed to adjust a carburetter or to adjust or replace points, plugs, caps or wires. Oh yes, there was that one time that I bought some fuel with water in it, but some dry gas and refilling the tank solved that roughness in short order.
I've never wasted my money on additives, and I recommend that nobody else do it either.
well, i just think that if my fog lights aren't lighting up, then the case should be that the backgrond lighting of the switch doesn't light up either, since there is no connection whatsoever, but it does light up, but there is just no electrocity going to the fog lights since that little green light wouldn't light up.
it's already dark outside so i can't work on the car anymore, i'll check everything from start to finish again tomorrow but i'd like to have some advice on where i shoud look into, thanks a lot !!!
I have disagreed with him concerning the Escape as I had a very bad experience with a rental and ever since then he has bashed me for it
I did not get the impression that the sludge was caused by lack of an additive in the gasoline, in an amount so minor that it wouldn't even change the color of the water like adding 4 ounces of orange juice to 10 gallons of water...
I did get the impression that Toyota is flim-flamming the customers, just like Honda does, just like Ford does, just like GM does, etc....
I am convinced Toyota knows what causes the problem in part of the cases; the others may be lack of oil changes by customers at 3-5 K schedules as were needed for short trips in colder weather -- hard duty.
For the record, all of my maintenance on both my wife's 2002 and my 2003 Accord is done at our dealership at the interval specified in the manual. Gregoryc1, I believe that this was posted by you at the cartracker's site:
"If the Toyota manual states that oil change intervals fall between 5,000 and 7,500 miles, depending on the use of the vehicle, then the engine should be able to perform properly with that type of preventive maintenance. Now having said that, it is the owners responsibility to have records of that service, and the best way to have records is to use the dealer for oil changes for the following reasons: ----1.) They are responsible for the quality and type of oil installed in the vehicle.---2.) They are responsible for the quality and type of oil filter element that is being installed in the vehicle. If a problem arises, you as the owner are out of the loop. It is their oil and filter, you have changed it at the proper intervals, and the dealer has the records. If you have to go to court, you have the documentation to win the case. ----Just my opinion. ---Greg "
I believe that your post quoted above related mainly to an owner's liability and/or responsibility in being able to prove that recommended maintenance was performed. But I am curious about the first part of this post, in which you state that (to paraphrase) following the manufacturer's recommendations should ensure that the vehicle will perform properly. This was in relation to Toyotas, would your statement hold true for Hondas? And what would be the endpoint (mileage-wise) where following the manufacturer's preventative maintenance recommendations would no longer guarantee proper performance?
And please let me state, I too mean no personal attack in any manner. But I do stand by my statement that the questionable practices of the engine manufacturer you mentioned in your post of #5013 do not relate to Honda unless there is some evidence that Honda engages in the same practices. To a certain degree, I think comparisons of experiences and practices among manufacturers is necessary and helpful. But I don't think that we can go that far.
Is there any way to make the roof open all the way. Right now it only opens to about 75% of the available space?
"and thats all I got to say about that" Forest Gump
Which interval is correct?
Andy
1. From his numerous posts on TH, it is apparent the man knows what he's talking about.
2. He works in the industry, so he is intrinsically involved in the maintenance of engines.
3. He has professional and personal anecdotal evidence to back it up.
Gregory1 says, "But on the other side of the issue, don't take the point of view that these products do not accomplish anything..." and I have to agree with Gregory1only on one minor detail only:. The additives are a _transfer device_: they transfer Greg's money to the dealership, by adding on to Greg's bill each oil change..., grin....
One of my grad school roomies has worked for a major engine oil related company. I'm writing to him to ask about the additives. His specialty was organic chem. I'll post any comments he has...
I've had occasion to demand that the price of such unwanted snake oil be removed from my bills once or twice. It was. They know when they've been found out. But, it's surely worth doing if people don't know enough to complain.
The snake oil crowd is having a real marketing problem-their adherents are leaving the scene-the biological imperative we all face and new people are not coming into the market. I still really liked some of the teflon additive products ads-read about one of the guys in that business-he had over 20 years of launching snake oil products in his career-he was from the south-wonder if he wore white belts and shoes-like the eevangelical preachers i used to marvel at when living in the south. If you want to see some really slick selling-go to a tent revival meeting some time-wow these guys could sell snake oil to an engineer.
my pristine 95 EX wagon and they didn't work either? The switch lighted up and everything. However, when I installed the wiring harness on the engine side, I decided the replacement screws for grounding the harness weren't needed and simply used the existing screws, Big mistake. Evidently, they are a certain alloy NOT good for
grounding electricity. After litteraly checking everything, I finally decided to use the screws supplied in the kit and "Voila". They work perfectly. Just a suggestion in case you made my mistake.
Car: 02 Accord EX-V6
I recently had an accident which caused some damage to the front passenger sides as a result of which the front passenger side suspension, door, wheel, etc had to be replaced. Also, the ABS sensor had to be replaced.
I now have the car after the work has been done. The car looks new (it is almost) but I feel that I have to apply a lot of pressure to see the brakes respond. The body shop guy tells me that they didn't bleed the brakes or any thing like that, just disconnected the calipers from the rotors and put them back.
While work was being on the car I have been driving a 03 Altima (Rental) whose brakes are great (stops on a dime).
My question is this, is there something wrong with my brakes or is it that I haven't yet adjusted to the car after body work has been done (its 48hrs since I got the car back) ? But I clearly see that I have to apply a lot of extra force to have the brakes respond.
Your replies would be greatly appreciated..,
When they are putting the calippers back and adjusting the pedals, if they forget to put new brake fluid (the same amount that they took out) into Master Cylinder compartment air will go into system. Same thing happens if you are not quick enough to fill the compartment. Just get brake system flush or get them bled again.
