Try to test it out. Drive till you hit the 1/3 mark, then fill it up and see how many gallons it takes?
BC
I dont think there are re-design issues with the 2003. Everyone always thinks there will be, but Honda has had 4 design changes since 1987 i believe, so i think they know what their doing.
It is possible that a specific Honda's quality may be directly related to where the vehicle was assembled. If its Japan, i suspect less issues. No offense to the people in Ohio, but i still think the Japanese worker's attention to detail and quality control is better than Americans.
Enough people have had this problem to alert Honda-course they are super secretive about their problems but tend to solve them rather than ignore them-some other manufacturer's have let well known problems continue for years.
Greetings from sunny Miami.
I have an '02 EXL V6 and the lights were terribly aimed when purchased. They hit the ground 20-30 ft. out and died, especially on the driver side.
I had a Honda technician show me how to adjust them. There is a toothed nut in the back of each lamp assembly that you turn to adjust. The lights are actually pretty bright and illuminate fairly well (except for the sides) once aimed properly (be careful not to do it too much as that will blind oncoming drivers....if they're flashing you, the adjustment was too much). A flat head screw driver will adjust the nut...it works counterintuitive to the way you would think to turn it, though. Once adjusted, you get a nice beam that throws pretty well in front of you. Doesn't help the sides, though. No adjustment fixes that on these lights, which is why I added a set of Hella fogs in the lower grill opening. They supplement the regular beams very nicely (they look nice, too....gives the front a unique look). Good luck.
2. Check alignment
if 1 & 2 are within specs and you still feel like the steering is pulling, I would like to remind that this year Honda has made the accord "sportier" than ever before by providing firmer suspension. One of the drawbacks of bieng sportier is that it will track the road more than a regular "buick" sedan. So you must get used to it. I say this because I did not know this when I got my Protege ES. I had upgraded from a used corolla.
The Protege owing to its firmer suspension and sway bars, will follow the road more than eagerly and I always thought that the alignment was wrong. 3 years later, I am enjoying the car and the pulling problem is not even felt by me.
Does anyone else have this problem??
I can't see why any noise from braking is normal, unless the pads are gone.(?)
Finally got both my actuators and had a couple or so hours to work on my car yester' evening.
Replaced my Front Right Door lock actuator.
Must admit, wasn't that easy getting the outer door lock rod off, but once I figured that out, everything else worked like a charm.
Tested the door, works great. Couldn't complete replacing the rear door actuator, got kinda dark..(different assembly too on door) hopefully it clears enough (rain) for me to work on it today. Its times like this I wish I had a car garage <;-)
** Hey, even disassembled that messed up actuator and found out what was wrong with it.. Popped out spring that broke off its plastic enclosed casing ***
=> Hope this won't happen with the remaining good one or the replaced ones. Also hope its some useful info for those having similar probs. Definitely saved me some chiching $$$ doing the job myself. Thanks spud41 for his input, came in v. handy
- Tony -
Bottom line-if you see the tanker truck offloading fuel-get your gas some place else. A load of water could ruin your whole week.
Keep trying to find out what is causing your poor mileage.
How long is your commute anyway?In order for anyone t for anyone to achieve the 30+ mpg levels you have to extend your trip to atleast 1 hour of non stop, which means no traffic at all, traveling.
For the V6 accords, overall you wont get bettter then 24 city or 33 highway. If anyone does, please let me know their miracle cure is.
Don't be shocked at the minimal number of "problems" that you've read about here. Don't forget, when you read things on a "problems" board, you don't get any input from the vast majority of owners who have never had a problem.
If you are looking forward to owning an air filter that you have to oil, wash the oil from, clean up any related mess from, and be a slave to, then I reccommend that you install a K & N filter. There are many good reasons that NO automobile manufacturers have installed oil-bath air filters for the past quarter century. Paper-type air filters are just better at doing their job.
Any helpful information would be appreciated.
The battery is going on 4 years old, but the speed with which the engine cranks doesn't lead me to believe this is the cause. But I'm open to a plausible explanation if someone believes this could be the cause.
On a side not, this car is amazing coming from the previous owner of an '88 buick regal where the only working gauge was the speedo. That car went to 220K miles on the original 2.8L V6 though
1)Solved my own problem by resetting the E.C.U holding both battery cables together for 10 seconds
2)Thank you glen. It was the transmission control module. Replaced it, problem fixed.
3)Trouble with down shifting? Turned out to be the TPS (Throttle Positioning Sensor).
4)Check all your fuses and electrical connections on the transmission - some transimissions go into "limp home" mode when the electronics fail or lose power. You then have Reverse and 2nd only.
5)If the symptom is trouble with shifting gears, then that's the (TPS)Throttle Position Sensor. To be sure, have it tested for the ECM(computer)Code. If you get a reading of 7, then its the TPS...code 17 is for VSS.
6)Finally figured out the thermostat was sticking open not allowing engine to properly heat up. Replaced thermostat and trans started working fine!
Thanks again everyone, hate to say it, but I really like this car....:) Now I have to decide on whether to throw in an LSD tranny, H22a, and use/not use oil additives... just kiddin'. Have a good one everybody.
