Visitor Agreement.
1) Should I follow the Owner's Manual or my shop? and
2) What are your feelings about using only the fluids that are now sold at the Honda Dealer with the Honda name attached. i,e, oil, coolant etc.?
First at 47900 miles and every 2 years/12k miles thereafter.
2. First coolant service was at Honda dealer.
The other times were at local shop using Prestone.
I do check the strength of the coolant every year before the winter arrives.
The car still runs great.
For the oil, I see no differences in using Honda name or not. However, I do use the viscosity oil recommended by Honda for my Accord for the last 15 years.
Jeff
Anyway... you shouldn't see a huge difference in the brake pedal travel unless one of two things are happening(in general)....
1>leak in the vacuum assist booster. If there is a leak in the vacuum, you should notice it because you won't have as much braking power along the travel. Most likely not the case.
2> The caliper slide may be sticking. this 'adjusts' the caliper so that braking pressure is being applied to both sides of the rotor. If it is sticking a bit, you may be applying more pressure to one side than the other, and will wear out the rotor faster. The pedal will travel a little more because the piston may(or may not) have to apply more pressure to apply the brake.
OF course, if there is no problem, then don't worry about it, but they should inspect it for free.
Oil gets dirty from engine inefficiency. Honda is respected by everybody in the automotive industry as making some of the finest engines, and their newest engines are very efficient and therefore dirty their oil much less and need fewer oil changes.
Why every 3k miles: engine has a contact point & condenser ignition system and a carburettor (cars up to the 1970s).
Why every 7k or so miles: engine has electronic ignition and fuel injection system managed by a computer (as with all cars today).
mikefm58: There appears to be enough empirical evidence supporting longer drain interval using synth oil with no more engine wear than fossil oil at shorter intervals.
Reasons include, among others, lower volatility (that reduces "coking" and other deposit formation), and better molecular uniformity (for better lubricity) that are inherent in synthetic lubes.
Because synth oil is more expensive, however, one runs a maintenance tab about $2,000 higher over 200k miles of ownership.
Would I use synth oil on a car I'll own for only 75k miles ? Maybe not. For 200k miles ? Maybe, considering that an engine replacement / rebuild would cost upward of $2500.
Others have reasoned that with today's engines and technology, it just might be possible to follow the manufacturer's recommended maintenace schedule and have a car that runs smoothly and is trouble-free in operation.
I can only guess that, because your post about never changing oil and just adding to what is there, came after other posts suggesting it might be possible to wait 7,000 miles between changes (which closely coincides with the interval suggested by Honda for many of its cars), that you were posting in response to those suggesting a longer interval might be appropriate. So tell us, how in your opinion does following the manufacturer's recommendation on oil change intervals imperil our engines?
My service tech told me to come back around Christmas or when my mileage hits at least 3750 because of the break-in oil that Honda uses.
Go figure.
Bottom Line, Change it at regular intervals (5000km's sounds safe and economical and EFFICIENT).
If you wish to do it on a more regular basis, go ahead.
If you wish to do it on a not so regular basis, go ahead.
Bottom line, it's YOUR 30,000 dollars that are in YOUR hands. $29.99/change every few months (more or less) isn't so bad. So what's the big deal?
Just a Canadians opinion
Bought my 2002 Accord Lx 20 months ago in Southern California and moved to Iowa 14 months ago. Current Milage 33k. I do oil change every 4 or 5k and other maintanence required by the manual but ignore the services recommend by the dealer.
Two Problems so far I like to share with you:
1. check engin light comes on while driving.
Taking the words from the manual, I open the gas cap and recap it tight. After 3 trips, the light goes off. But this happened to me three times last week, so I went to the dealer (The only Honda dealer in Des Moinse). Verdict:
replace Sensor 36531-PAA-L4 (USD 256) and Control
M 37820-PAA (USD 612). So it will cost around $900 to solve the problem. Fortunatly, it's covered by the warrenty. But it still make me wondering...
2. key lock. This one is tiny and Very Annoying.
At times when I insert the key and try to start the engine, the key will be locked for 3-5 minutes. Afer that, I can turn the key and start the engine. This happened to me 4 times, 2 in California, 2 in Iowa. Of course, the dealer can not duplicate the problem. So I just hope it will not lock up for one hour or even longer next time.
One of my friends, who drives a 2002 Accord Ex, got the same problem even he has keyless entry which prevent most of the dirt or moiture you may have when open door or trunk.
Your comments are welcome.
As to sythetic oil, I use it in both my vehicles, but I change at the factory recommended times so as not to void warranty. After the warranty is expired and if I don't buy an extended warranty, I will change the synthetic oil once a year or every 25,000 miles. Bought a Subaru 12 years ago and ran it to 248,000 miles on Mobil 1 with that oil change interval. Engine was running great when I sold it(however the body was about rusted away!
Thank you for your advice. I definitly will try it
if next time it lock me for more than 5 minutes.
But I do think it's a design flaw. Sometimes it did drive me mad because 10 minutes ago you drove this car smoothly and 10 minutes later you could not turn the key to start the engine. Imagine this in the snow storm in Feburary of Iowa.
There appears to be some defect that causes the sensors to get clogged and thus the engine light comes on (this is really the emissions warning light).
Do not drive around for an extended period of time with this light on as this may cause damage to the car. I was able to make the check engine light go off after adding a bottle of Chevron Techroline Fuel Injection cleaner to a full tank of gas (any concentrated fuel injection system detergent may do the trick) the last time the light went on.
As surprisingly, we haven't heard anything about sludged up '01-'04 model year Civics, because there too, the maintenance interval is 5k/10k for severe/normal driving. And in the 23k miles that I put on my '01 Civic EX - with oil changes at the recommended 10k and 20k mile services only - I had no sludge issue. Maybe I didn't keep it long enough, but I thought that the sludge didn't take long to form.
I personally tend to change mine every 6mo/5k miles... Every time I change it, looks relatively clean, but then again, IMO... probably a good 70% of the cars out there fall under the 'severe' schedule anyway... stop and go traffic, extended idling.... etc.
how about a situation where someone fails to follow the honda recomended break-in procedure (not changing the oringinal oil until the first scheduled oil change, per the manual) and the engine fails. would you warrant the engine?
Sludge is caused by engine hot spots breaking down oil, stop-and-go driving breaking down oil, and engines breaking down oil, causing deposits of gunk.
Honda says "change oil at xxxx for severe duty." That's what I'll follow.
I'm at 109K and all is still going well, so my only "warranty" is good maintenance.
I've read some here say that the noise happens when rolling and engaging drive. I'd suggest holding the brake until the tranny engages and then proceed. Also wait until full stop in reverse before engaging drive.
Bad rattle in dash around CD player
Squeaking/creaking noise when driver's side window is all the way up.
Loud buzzing vibration from lid of trunk on bumpy roads.
Creaking of front passenger's side door.
And, the bane of so many Hondas, the clunking brake problem, which I also had on my previous car, a CR-V, and which they always claim can't be fixed.
I love driving this car, but the constant barrage of squeaks and rattles in a car that isn't even a year old is ruining the pleasure. And frankly, I don't see how I could ever sell the car to an individual, because I don't know who would buy it. The car is simply not solidly built, and it's distressing to rent low-end American cars when I travel and be relieved to be driving something quiet for a change. Is it worth writing to the parent company about it? I realize none of the problems are mechanical and therefore I don't have much recourse, but this is my third Honda, and it will definitely be my last, at this rate. When I bought the car I was reading these boards and I remember some Acura buyers complaining of similar problems. Where is their quality control?
It feels like I'm driving my mom's 83 caprice wagon. Shouldn't the throttle response be instant?
My 2003 EX-V6 sedan fits the VIN number.
I don't hear any brake noise when braking. So I just wait until the problem shows up before bring it in.
The car only has 4k+ miles and 11 months old.
This discussion's title will soon change to "Honda Accord Owners: Problems & Solutions" and it will reside in the Honda Accord Owners Club. However, it will also still be here in M&R. If you are subscribed to this topic now, the change should not affect that.
If you have any questions/concerns, please address them to me in email, karen@edmunds.com.
For the past few months my 95 Accord 4 door has been making what I would call a "thumping" sound from somewhere under the car (the noise may have been occurring longer than that, I just really started noticing it a few months ago).
The noise is obviously timed to the rotation of the wheels. When the car is stopped, there's no noise. When the car accelerates, the frequency of the thumping sound likewise increases. When the car is going fast, the sound kind of becomes continuous, blending in with the background road noise.
Despite this mildly annoying thumping noise, the car seems to run fine otherwise. The ride is not particularly bumpy. It seems to steer okay, and doesn't pull to one side or the other. I've driven several thousand miles since first noticing the noise, without any misadventure.
After having become aware of this noise, I have also noticed other (usually older) cars making a similar "thump, thump, thump" noise as they drive by my house, so my situation is probably not unique.
I've asked friends - all of whom are not much more knowledgeable than myself - what they think the problem could be. Bent wheels, rotors, ball joints, etc, are some of the suggestions, though no one is really certain. I thought there might be something loose under the car that is vibrating when the wheels turn. The muffler coincidentally was replaced a few weeks back, but
the thump noise was present before this and didn't change after the replacement, so I don't think that had anything to do with it.
Since the car is 9 years old, and has 108000 miles on it, (and I'll probably be getting a new one within a couple of years) I don't want to go on an expensive goose chase trying to find and solve a problem that is not really as of yet comprising in any way the basic transportation function of the car.
On the other hand, if something major is developing that will become a big problem down the road, I would like to nip it in the bud if possible.
Any advice is appreciated. Thanks.
