Visitor Agreement.
Go figure...
pressure you want............
BUT, I highly recommend that you get them back up
to recommended pressure. Running them 4-6 pounds too
low will produce premature wear and cause handling
problems, especially in collision avoidance maneuvers.
berbel
me if appropriate but.........graphite pearl and
white diamond pearl are simply the paint colors.
They are applied OVER the base coat which rests
on the car's metal. After the color application,
a CLEARCOAT is applied to help preserve the integrity of the color coat. I believe all modern
automobiles are clearcoated prior to delivery.
berbel
Usually, nothing happens but we do get a lot of cars with stripped oil plug threads.
For the price of a lousy crush washer, I wouldn't mess with it.
It's also possible that the 18 year old in the lube pit can overtighten and strip the plug even with a new washer.
Leland hit it on the head with his post 6339. It's
kinda like a woman putting clear nail polish over
the color she just did her nails with.
berbel
Is this going to be a lemon? Otherwise, the car is great. Is Honda slipping? If anyone has had this problem fixed, let me know how it was done, at priorityone@neteze.com
There is a major difference between a car that has been "wrecked" as you put it, and a car that may have had some minor body work done.
Most cars that are a few years old have had somthing done...touch up, a dent fixed etc.
You might want to ask the dealer to put it up on a rack and give it a good looking over.
Are the rest of you doing the 7,500 mile mainenance at your Honda dealer?
I think you are being very over charged!
Willis3, my understanding of your message is that the dealer doesn't understand what you are questioning. You have 2 year old oil in the crankcase gathering moisture & eventually sludge. Change your oil every 6 months, even if you don't meet the mileage minimum. The rest of maintenance schedule you can follow per the book.
For example, if you go to Honda for their ExpressChange Service, they are suppose to perform the following in addition to replacing your oil filter with a Honda Genuine Oil Filter
Check operation of your vehicle's horn, windshield wipers and parking brake
Check operation of high and low beam headlights, tail and brake lights, parking and backup lights, turn signals and hazards
Check your brake fluid level
Check fluid levels (and fill where needed) for your vehicle's battery, power steering, transmission, clutch (if applicable) and windshield washer fluids
Check coolant level and fill if necessary
Inspect wiper blades
Inspect external drive belts and radiator hoses for excess wear
Check clutch pedal for free play (if applicable)
Inspect tire wear patterns
Check tire pressure
Inspect condition of your Honda's suspension and CV boots
Inspect condition of the exhaust system
Check for fluid leaks
The 7,500 Service Maintenance calls for the following items:
Replace engine oil, filter and drain plug washer with Genuine Honda Parts.
Inspect and rotate tires.
Inspect wiper blades.
Check/adjust fluid levels.
Road test.
Inspect front brake pads.
Inspect CV boots for damage.
The only services they are providing that is not included with the ExpressChange service is rotating tires, inspecting the front pads and doing a road test. It's hard for me to see these three things costing $43. (Local Honda Dealer charges $26.95 for ExpressChange)
Did you follow the maintenace schedule as set forth by Honda exactly to the letter?
Follow the "severe" schedule only if you drive in one or more of these conditions most of the time:
Trips of less than 5 miles (less than 10 in freezing weather)
Extremely hot weather (over 90 degrees F)
Extensive idling or stop-and-go driving
Trailer towing, driving with a car-top carrier, or driving in the mountains
Muddy, dusty, or de-iced roads
Following the "severe conditions" guidelines won't help your Honda unless you really do drive under those conditions. Many vehicle owners waste time, money, and oil on unnecessary oil changes, for example. The quality of engine oil and filters has steadily improved to keep pace with the requirements of new engines.
You should DEFINITELY get higher than 25 on the highway, unless you end up in rush-hour that forces you to slow down and speed up frequently.
Grand High Poobah
The Fraternal Order of Procrastinators
Miles on Odometer Before Trip: 3000
Total Trip length: 750 Miles
The trip to my destination consited of driving at 80-95mph(30mph headwind) for 60% of the drive and suburban city driving for the other 40%. Auto Climate control on the whole way. Full Load in the car
Avg MPG = 30
The trip back home consisted of 90% driving at 65-85 mph, and 10% suburban city driving. Auto Climate control on the whole way. Fuller Load in the car
Avg MPG = 33
The ability of this car to cruise effortlessly at above avg highway speeds is very satisfying. Road noise is limited. Wind noise was only a minor issue with the headwind.
My dealer will also car wash the vehicle at no extra charge if it needs a bath. To date, both car & dealer have been perfect, except for the ignition switch recall.
I check most of the same items you check, but I also pay the dealer to do the same. For example, at my 30K visit they advised my 4 year battery worked fine, but at a lower voltage (11.8v). I no doubt could have ran the battery longer til it died, but didn't see the need in waiting to strand myself, or worse, my wife, so I paid to have the battery replaced. I'm confident my dealer ain't screwing me. If I felt otherwise I'd do the maintenance myself. Not lazy here, but dealer is 3 blocks from home & I feel for me its money well spent.
When I take it to the dealer, I tell him the exact items I want done, not things like 15K service, but things like oil/filter chg, rotate tires, etc. But again, that's only when I can't do those myself.
As you can see yourself, there's overlap with your dealer's express change service and Honda's 7500 mile service. But the dealer has to stay in business and one hour's labor is about 70 bucks. You are protecting your warranty by the dealer doing the service, not a bad investment.
To the person that got 23/24, do you accelerate 'hard' (over 3000RPM)? I have not had my new car over 3000RPM yet. Next spring when the weather is warmer and the car is broken in I will see what the top end RPMs are like.
