Visitor Agreement.
Will let you know how it goes, it be a week or 2 b4 I can get to it.
One other thing, do I need to dis-engage the air bag and if so, how is that done? Should I also disconnect the neg battery cable?
I bought a 2004 Accord EX-V6 w/navigation 4 days ago and while everything seems to be fine with the car, I seem to have about 3 separate instances where my engine wouldn't start at the first attempt. I thought it was pretty simple where I just put the key in, turn it and the car should start right?
I would repeat the same procedure again a second time and the car started up without a problem.
Should I be alarmed and take it back to the dealer to check out? or am I just being paranoid?
I had my last car for 13 years and it always started at the first attempt. Is this normal for a Honda? Any help would be greatly appreciated.
I have to take the car in this week, so I guess I'll ask the dealer. There's a rubber piece that came off the back door frame when I opened the door. I'm sure a little glue will do the trick, but I'll let the dealer take care of it.
My confidence in my Honda is going down and I've only had it for five days.
The comments about turning accessories off before starting, or giving it some extra gas are, to put it mildly, poppycock. You should not have to do this on a modern vehicle.
Here's the problem:
Defective fuel pressure regulator.
Have them replace it. TSB search should bring it up.
I agree with you on this one. Because of the position of which my vehicle is parked I go through the passenger side to gain access, but even before I hop over the seats I actually start our 04 V6 Accord from standing outside of the vehicle from the passenger side. What I do is turn the ignition to the on position, in which there is a humming noise, I believe it is the fuel pump. That humming stops after a second or two, then I turn the key to the start position in which it starts immediately. In one of Honda's discussion they stated that the long starting was due to pollution reduction and it was not a defect. If anyone is interested I could forward them the link.
The majority of engine wear occurs when you start your engine. The more you crank, the more wear is done. This is just a fact.
He bigger problem is that it can leave you stranded!
Modern vehicles should start very quickly. That is the way the are designed. Look at any new Toyota, Ford, GM, etc.
Honda has a big goof here, and I'm surprised they did not fix in 2004.
Brigg10
The brakes shook excessively after all three long (500+ miles) highway trips I have taken. About a month ago, the dealer replaced the front pads and rear rotors, and turned the front rotors again. The brakes seem to be fixed now (I guess I will see for sure when I drive to Washington, D.C., next month).
I have driven a 2004 Accord as a loaner from the dealer, and it seemed much quieter than my 2003. I think many of the more common noises have been eliminated with the 2004s. Of course, there is only so much that can be done--the entire interior is held together with cheap plastic clips. My 1989 Accord had none of the rattles/noises that this car does, even at 200k+ miles. The only time I ever heard thermal cracking noises in the 1989 was in sub-zero temperatures (not <40F and >80F like in the 2003). But the 1989 was the last year before a redesign and was built before all manufacturers started cost-cutting. I guess the adage, "They don't build them like they used to.," is quite true.
I don't mind the firmer suspension. I like the fact that they reduced the engine and road noise. But, if the car has a firm suspension and is otherwise quiet, any little noise/rattle sticks out like a sore thumb. If the car is not SOLID, it sounds like a piece of junk.
But this wear is caused by higher RPM running with low oil pressure. Cranking the engine a little longer will not hurt the engine. In fact most engine rebuild manuals recommend cranking an engine WITHOUT spark for a while to make sure the oil circulates throughout the engine. You really don't want the car to be running at high idle right away.
If there were an oil pressure guage in the Accord you would see it take a few seconds for the oil pressure to get to normal. It's like this in all cars. A little extra cranking may do more good than harm in that area.
So far the 03 performs flawlessly. Probably I have not put enough milages on it yet. It has only 5900 miles and 16 months old. And it already had 2 oil changes (done by the dealer).
I think there is a brake design problem with that generation. The rotors are too small. So they get hot and warped easily.
There are no problems with the shoes & drums though.
My car was in for its 30,000 mile service yesterday, and after the tire rotation and wheel balancing that the dealer did as part of the service, I have to say that the car drives as well now as it did the day I picked it up. No more rattles, the interior is holding up very well, and the engine and 5sp manual are a dream. I have a habit of getting rid of my cars every year or so, but this Accord is so satisfying that I really don't have the urge to get something new.
Does anyone know how to take down the glove box of a 04 Accord?
I'm trying to see if the rattle is coming from the pollen filter.
Much appreciated.
Tony
To completely remove the glove box, there are 2 Phillips screws at the bottom that are unscrewed.
1. the transmission seems to have troble shifting down while I am drive at 25 ~ 35 mph....if I let go of the accelerator the rpm seems to be stuck at 2...and stays there till I slow down to about 15 mph - and then a sudden peak (about 2.2) and then goes back to 1....
during this - I feel the car is a bit heavy....this happens too often to neglect
2. there is some very dull, very low rattling noise in the engine - that is only if I go at highway speeds and come to rest...but that noise will go away as soon as I put the car in park and then put it in drive agian -maybe its just me but about 50% of my friends say they don't hear anything...I don't want to be ridiculed by the dealer....
thank you for your input....
If these things question your confidence in the vehicle, you have every right to take a diagnostic ride with a technician. I suggest it. My dealer has always made me feel great about my car, even though they had to explain a couple of the things I thought were wrong were actually quite normal.
Do I just do the reverse to put the glove box back it? Any tips and tricks?
Thanks again.
I am not sure what the problem is, but I am guessing it is too much slop in the window regulator. Perhaps someone here has had this problem and has been able to fix it.(?)
Also, ive notice my valves tapping right after start up. is this an easy and inexpensive fix for a garage to perform or is this part of a large more expensive problem to come?
I'll see if it stays closed again tomorrow morning when it's cold out.
Is there something I can do to resolve this without having to take it back to the dealer?
and save some money over dealer prices.
Hope this helps.
You must love Cats.
blane> under warranty this morning. No questions
blane> asked.
Were you able to demonstrate the problem to the service department? Mine is intermittant and I can see the dealer just looking at me while I try to demonstrate the problem.
Was your dealer already aware of such a problem?
It could be that I just love stealing stuff, but kittens ARE delicious.
Can someone provide the TSB numbers that
1. Recommend to the dealer to replace existing rotors and replace the brake pads with the new ones that don't cause the warping.
2. Recommend to the dealer to put shims of some type on the seat track assembly to keep the seat from shifting.
Thanks for your help
