The A/C compressor made a high pitch sound. The clutch did not engage. I let it ran for a couple minutes then shuted it off.
The next day when I tried to turn it on again. Nothing happened.
The two fans didn't come on either.
I didn't bother to find out why because it probably costs more than the value of the car.
I am happy the compressor lasted over 170k miles.
any TSB's for those? anyone have any successful fixes? they aren't really too bad, but i tend to be a little crazy about my cars..
thanks!
On the other hand, I also have a paint "bubble" on the hood. They are replacing the hood. So I'm stuck with a Nissan Sentra rental for a week.
The dealer replaced the entire overhead console containing my "droopy" sunglass holder, under warranty. The new Sunglass holder stays where it belongs.
Chucko3, thanks for the genuine advice!
So ... how typical is it for the A/C compressor to go on Hondas, and at what mileage? My car has 101,000 miles. Plus, I live in the Northeast, and don't use the A/C very much. (Mostly to clear up the windshield, to tell the truth). Also, the A/C had not been producing very cold air for some time, so I wonder if it had been ailing for a long time before it completely died?
What else lies in store for me around the corner? (I.e., what can I expect to go next). It's a 1997 Honda.
Proper servicing then might mean your compressor would be still running today.
It's recommended that the AC be turned on occasionally during cold weather too. It helps in keeping things lubed. One more thing,, and it might be too late for this but I was told once that my compressor needed to be replaced on my '86 Dodge by two different mechanics. I tried one more place (AC specialists) and they had me cooling the interior in 1/2 a day for $200. Most mechanics can't know everything and sometimes it pays to go to a specialist.
My 03 EX front emblem was stolen and so I bought another one. However installation isn't simple as it requires removal of some parts. I tried to ask the dealer to install but they suggested to glue it to save $$. However in Toronto here winter is cold and summer is hot. Would any of you recommend using krazy glue to fix it? It's a cheaper solution obviously..
THanks.
At 101k, have you had the timing belt changed yet? That's what you can expect to go next. The timing belt job (all belts & water pump & seals) costs around +/- $500.
What do you think about her reply?
As far as the timing belt: yes, as a matter of fact, that was what I had originally scheduled the service for. They replaced the timing belt (and water pump, which I think they normally do at the same time). It cost $700 for that, though, not $500. And that was with a 10% discount coupon applied to the service.
I had to travel 12 miles further than my buying dealer, but the Honda dealer in Gulfport, Ms was the best price for me. We now have a Honda dealer in my home town. I'll price them next time. I sure miss my dad's rack and pneumatic tools.
I think the service dept.'s job is to replace a broken compressor.
It does not care to find out the cause. Does anyone actually come to the service the dept and tell them my compressor broken because I ran it on low freon? If anyone happens to ask why it went. I guess the answer would be "it's time".
The owner's manual does state "prolong use of undercharge system may damage the compressor".
Have my 89 done 1 1/2 years ago. It cost $400+ .
A different deal cost $75 more. So it's pay to shop around.
I bought the same model car as yours on March 31,2004 and have complained about the same "clunking feel" the last FIVE times I was at the dealer. I went in for a variety of reasons that you'll be able to see in the past posts. The latest and greatest is they changed the brake buster because I had a metallic rubbing feel to the brakes when applied. The problem no longer exist when braking in city driving. However, the same metallic rub exist now that I'm driving on the freeway and have to slow down. That is a scary feeling.
I'm still having intermittent non-start ups which they cannot duplicate and are blaming it on the sensor of my keys, but did not issue me with new keys. In a nut shell, they did nothing about this "major" problem.
Getting back to your problem. The service manager gave me a copy of either a TSB or is it a regular Honda Service Bulletin they receive monthly. The bottom just says March 2004.
"ABS Grunts When Doing a Self-Check
NOTE: This article applies to '98-04 Accords, '96-04 Civics, '97-04CR-V's, '00-04 Insights, '98-04 Odysseys, '03-04 Pilots, and '00-04 S2000s.
Are owners of vehicles with a "compact" ABS complaining of hearing a short grunt or groan when backing or moving the vehicle forward after it's been sitting awhile? It could just be the ABS doing its self-check. A compact ABS has a modulator, a pump, and an accumulator all rolled into one. (Later model vehicles don't even use an accumulator.) The system is designed to do a self-check when the vehicle reaches a speed of at least 7mph either forward or backward after sitting. So the grunt is normal; it doesn't mean there's a problem with the ABS. On some models, you'll even feel a vibration through the brake and accelerator peds when you hear the noise.
You can show your customer just how this ABS self-check works by connecting the Honda Diagnostic System (HDS) to the 16P data link connector, and running the ABS function test. (This test cycles the ABS solenoid and runs the ABS pump.) The noise from the test may be louder than the noise made by the actual ABS self-check, but it lets your customer hear the noise and helps you to determine if the noise is ABS-related or coming from another source."
Hope this helps. My Honda has been in the shop for at least 15 out of 40 days and talking about my Honda is becoming a sore topic. I've called to speak with the General Manager about 10 times and have yet to speak with him. I called American Honda and got a case number and received a message from the case manager and never heard back from him either. I sent a registered letter to both the manufacture and dealer and only received a letter from the dealer stating that they are sorry for the inconvenience and offered a free oil change. Wow, big deal. I wonder why they are going out of their way to avoid me now. Because these are the same folks whom had plenty of time and energy to call me day and night when they wanted to me to purchase a vehicle from them.
The fuse looks okay--no sign of damage, or defect. (I'm presuming I'd see it if it had gone bad.)
I'm wondering if during replacement of the rotors a sensor's wire was unplugged which is not telling the electrical system to light the brake lights.
Or am I looking in the wrong place for the problem? Any suggestions?
Sorry to hear about your problems with service-- my car is a couple of weeks old and I'm getting a taste of that as well. Trying to get a deck-lid spoiler installed, and I've had to take it in 3 times already, and they still can't get it right! The first time they ordered the wrong spoiler, next time one edge of spoiler was sticking up off of the surface. Right now there's a screw jiggling and banging around somewhere inside the spoiler... sometimes incompetence never fails.
Does anyone know if it is necessary to get your accessories installed from the dealer where you bought the car from? (Especially now, given that they've already done it a few times?)
Can you figure out why?
ramida
Your theory is incorrect. The problem with the brakes on the 2003 (and probably early 2004) Accord was the front brake pads. After MANY vehicles coming back again and again with warped rotors, Honda changed the material of the front brake pads. The old pad material was causing too much heat buildup and was warping the rotors. They made the new pads available a few months ago. The new 2004s should have the updated pads from the factory.
My rotors warped at 6000 miles--something I have never done in ANY other car. After having the rotors turned 3 times, Honda came out with the fix. I had the pads replaced in March (30k miles) and at 35k miles the brakes are still smooth. As for the grabby brakes, I like the feel of them much better than brakes where you push the pedal halfway to the floor before you start to slow down. It only took a few stops to get used to them.
1. Turn key to ON position (with engine off).
2. Press trip reset button and hold it down.
3. Turn key to START position and start the engine (while continuing to hold the reset button down). Release the key when the engine starts.
4. Continue holding the button for another 10 seconds or so until the light goes off.
When you start pressing the button in step #2, do not release until the light goes out in step #4. This procedure, as the dealer said, takes about 15 seconds total. Also, it will clear whichever trip odometer you have showing when you start the procedure (if this matters to you).
If this is exactly what you did, I am sorry that I cannot be of any help.
It sometimes takes several attempts for whatever reason but it does work if you just keep trying. As said before you can just repeat the steps until it works for you:
1, with key off push and hold trip button
2, keep holding trip and turn key to on position
(lights on dash are on at this point)
3, once maint. light goes out turn key off then release trip button.
4 start car and repeat if light is still on..Good luck
Accord window creak
we use shin et su greese on the seal and this helps the noise. you can get this at the dealer..
No need to start the car while holding down the button.
I live in NC and now that the temperature is regularly in the 90's, the 4 cyl sometimes feels a little overwhelmed with the A/C on (manual transmission). Just turned 19K miles. Some other small annoyances include...
1. Paint seems to scratch/chip easily, especially on the hood.
2. Sunroof rattles in cold weather.
3. One of the driver's seat leather panels seems to be wearing/fading prematurely.
4. Navigation DVD holder occupies a strategic place in the trunk (top center) and limits storage space when hauling larger stuff.
5. Lack of split fold-down rear seat.
Of course these are all greatly outweighed by everything else the car has to offer (luxury, value, ride & handling, economy, reliability to name a few). It is a little disappointing to have the seat shift just when you start having fun in the twisties though... (My '89 MR2 never did that! - now that was a great car)
