The first suspect for an erratic idle is usually an air leak in the manifold. Lean mixture at idle can cause the symptoms you describe. A dirty air filter would likely richen the air/fuel mixture bogging the engine instead of revving it. Check your vacuum hoses and EGR lines.
I replace the spark plugs, PCV valve, and air filter every 24K miles on my 89LXi.
Spark plugs and PCV valve are cheap and easy to replace.
Just purchased a '98 Accord EX V6 coupe. Seems to be in great shape. 78k miles on it, and it had the tranny replaced at 74k miles by honda under warranty. Just had the oil changed, brake fluid and coolant flushed, and the power steering belt and accessory belts changed. I'd like to have the timing belt/water pump replaced, along with the distributor, spark plugs, air filters, and brakes flushed. Can anyone recommend what else i should do? Anything problems i should look out for?
Plaza Honda in Brooklyn, NY quoted me a price of $750 for the timing belt/water pump job. South Shore Honda quoted me $695. Dont these prices seem quite high?
Can anyone recommend a quality shop in the NYC area? To me, $750 seems like borderline sodomy.
thanks in advance.
From the service manual, check the following fuses:
- Under the hood fuse box: fuses #19(40A), #5(10A), #6(15A), and #7(15A)
- Under the dash fuse box: fuses #6, #7, #8, #9, #11 and #14.
If fuses are OK, then the car has a bad control unit located on the kickpanel, to the left of the dash fuse box. Before you try to replace it, I would make sure the 13-pin connector to the control unit is not loose which is possible for a 16 years old car.
A bad light switch won't open the headlights, not to close them.
Drive the car a few days, check the coolant level in the reservoir again when the engine is cold.
The level should be around MAX.
Took the delivery of my 03EXV6 2 years ago. The coolant level in the reservoir was at the MIN. Filled it to MAX. The level has stayed there since then.
What could make this happen?
We won't know until sombody posts a Used Oil Analysis on their factory-fill oil and I haven't seen one yet.
Personally, I'll hedge my bet by doing my first oil change at about 3,750 miles thus splitting the difference between your advice and the manufacturer's.
I know I never had a oil related problem with my 1982 Tercel that I had when I couldn't afford to buy newer cars. 7500 on the dot oil changes per the manual and the car got traded at 199K. It still ran like a top. Absolutely no problems except brakes that wore out quickly from abuse when I delivered pizza.
Read the Owner's Manual and do what it says.
Case should be closed......Richard
We just got out accord ( '05 4 Cyl EX-L Navi), and noticed that when we have the interior lights, (like the map lights on), and we sit in a parking lot with the engine running, the lights dim a bit (it's noticible) as the engine fan continously cycles on and off. Is this normal?
Also, our MPG from the trip computer really stinks- 13.33 Average MPG over the 169 miles that we have driven it. I'm guessing that this HAS to get better, right?
169 miles is not long enough to determine overall fuel mileage. What type of driving, how long the commute etc. determine what type of fuel economy you will have.
Did they discuss this TSB with you during any of your visits? Just curious.
The Navigation system and DVD map software is made by Alpine.
Looking at the headlight circuit diagram for 89 Accord (I guess the 88 and 89 use the same circuit), the high/low beam control signals are fed to
1. the headlights to turn the light on with low/high beam. This operation works fine. Correct?
2. the 13-pin connector control unit. This unit controls the headlights up or down.
If fuses are OK, I think your car has a bad control unit.
I just bought my 8th top Accord Hybrid with NAVI. The car has not yet been delivered. I have been real happy with Honda's advanced automotive technology. My other V6 EXs are so quiet on the highway and very fast. You are quite right. If ones wants his/ her Honda's engine lasting long he/she should "pamper" his/her Honda day and night like a real baby with "brand-name diapers". At 200K+ miles my other Accord I4's engine ran like new on day one after a major tune up. It was amazing. It is a Honda's engine.
Have a good Holiday Season, folks.
Automatic(original owner). Car has 154,000 miles on it and has had its maintenance done as scheduled. This week while driving on the highway the following happened:
-the engine light came on,
-the "D" started flashing on the dashboard, and
-the speedometer dropped to 0 and did not budge.
It has happened twice this week and the owner's manual does not really say much about the problem. Anybody have any ideas what the problem is?
Thanks in advance for the information/help.
Ray
Fuse #8 connected the left headlight, fuse #9 connected to the right and to the control unit. I bet fuse #9 blown.
The control unit is located on the kick panel, to the left of the dash fuse box. Look for a harness with 13-pin connected to it.
See if you can get it at the dealer for a bit more and return it if it's not the cause.
2. "D" flashing means there is problem with your transmission. Have someone check it before it fails on you.
Get into the dealer quick!
Mine did the same thing at 8000. Luckily I was taking it in for it's second oil change anyway. There was a leak on the back of the engine that did not drip onto to the concrete. I did not know it was there. The factory torque on the cylinder head was too tight and they have to replace it. The service dept said they have had a lot of complaints on the mechanics of the 2004 accord. There are other problems also but get this checked 1st. They found the problem using a dye.
As for the gas mileage. Your 91 Accord had 125 HP and weighed less than the current generation. It also takes the newer K-series engine a few thousand miles to turn in it's best gas mileage. FWIW, I saw an average of 31 MPG on my 04 EXL Auto and the same out of my 04 EXL manual transmission.
Am I being too hard on my Accord? Am I over blowing the issue? Does anyone else have similar issues with oil consumption?
It's time for the timing belt and 90K check-up.
I registered so I could post a reply to this --- my 2000 UK Accord suffered badly from the "ice cracking" sound on the windscreen/windshield (I'm English!).
I traced it to the black plastic strip below the windscreen; there are some round lugs (like a big fat black screw, without any slot) which hold it down. The one on the far left was the culprit for me; take the entire thing out (there are two removable parts, just pull), clean, and reassemble tightly and the noise is gone.
Hope that helps,
-Rich
