Dodge Intrepid Problems
I HAVE A 97 RAM THAT HAD A TRANNY PROBLEM,THEY TOO TOLD ME THAT I HADNT CHANGED THE FLUID, I TOLD THEM I DID IT MYSELF THEY DIDNT BELIEVE ME OF COURSE........ AGAIN I FEEL FOR YOU. SIGNED FELLOW DODGE OWNER [not for long]
Thanks for your help!
mak17f@mizzou.edu
Calling Chrysler for help will only add to the aggravation, again the five star program to follow.
1. Obtain service record
2. give the dealer one final chance to perform
3. see the lawyer
4. pick up the vehicle when ready
5. **trade said vehicle for a more reliable product.
** suggestions re replacement, buy a product produced by Toyota, Honda, VW, Ford, GM, Hyundai, Mazda, or for that matter Anything but Chrysler
I have just passed 30K miles on my '98 and have had very good performance from my vehicle. I have kept up with the services recommended by the leasing company.
I just had a very good experience with a dealership in the Atlanta area that fixed the following problems with my vehicle:
1) The trunk would not open either with the key fob or pressing the interior button (it worked with the key, of course). The dealership determined a faulty "BCM" and replaced it under warranty.
2) I experienced a "whining" sound from my engine during acceleration and highway speeds. Dealership replaced the "idler pulley," also under warranty. My service advisor said that he has seen this issue a number of times, but I have not seen it in this forum.
3) I had also experienced some vibrations during braking. The dealer performed a brake service, replacing the pads.
4) The dealership also replaced a sun visor clip under warranty. My service advisor said he has seen this problem a number of times as well.
An oil change and all services cost my leasing/management company only $162.
I hope I have met the intent of this forum and that maybe I can help other owners with my comments.
Best new car I have owned !
EK
The R/T does run better after a few thousand miles. I have about 4,600 miles, and it quicker at lower RPM's than before. I have only two minor issues to have the dealer address on my next visit - the left rear door molding at the base of the window is loose in back corner, and I am getting the low rpm (< 1,000 rpm) growl from the serpentine belt when it is cold for the first few accelerations after starting.
I'm 34 and single, all my friends love the car so far. Check out the 300m forum for performance ideas.
Anybody have any problems with the 2000 or 2001 models? And how similar are these models. The 2001's are the only ones I have ever checked out. I did drive an SE with the 2.7 liter engine, and I felt it lacked power. I also drove an ES with the 3.2L engine and it was much better than the 2.7L. Then I drove the R/T with the 3.5L, WOW! It was the best of the three I test drove. I am hoping that DC has overcome some of the noise issues and the tranny problems. Would appreciate any input. PS. I also own a 98 Grand Voyager 57K, so far so good.Only minor repairs have been required.
-Andre
I got my car used in 1999, and it had 27,900 miles on it. I did not get the extended warranty.
I had little wierd problems like my driver's side window jumped the track and the whole thing got replaced. Window and assembly, because you can't buy the connecting parts. That was relatively minor, the body shop got me for ~$240
Now it is winter here in the great northeast and my car started acting wierd. Found out that when your tranny restricts you to Park, Revese, Neutral and Second gear it is a bad output sensor. Well that's all fine and good, got that fixed. $150.
NOW. A week later, the car put itself in PARK while I was Moving!! I was stuck on broadway with no way to push the car, as it would not change gears at all. The Chrylser Dealership where I took it told me that it would need a new transmission. price? $2000 but not a cent more.
Being a programmer, you probably think I make a lot of money, but not really. I am a Middle class white collar professional, who isn't rich yet. I am going to have to borrow the money from my parents to pay. I am also going to have to sell the car to be able to pay them back in a reasonable amount of time. I am paying $368 permonth for CarPayment, and about $200 for insurance.
I am getting rid of it, and buying a VERY used Honda. A honda with 100k is considered by many in the used car market to be low mileage.
Hate to pee on your respective parades.
--Kevin
THANX!
The problem in your case lies with the steering bushing located behind the engine on the firewall. It's a really complicated set-up. Mechanic said that it was similar to Mercedes. I do not know the proper terminology but I watched the mechanic replace the bushing in my car. They look like two mini doughnuts with metal bushings inside. What happens is that the metal part of the bushing fails and the rubber cracks causing the car to veer left upon acceleration. I might add, the Dodge dealer had not a clue of how to repair this. I have a 3.5 ES fully loaded. They said that it was normal torque steer. These guys (Dodge techs.) really need help. My Intrepid goes through a tranny every 5-10k miles. I purchased it with 36k miles and it now has 88k. I have had it in for tranny service 14 times and had total rebuilds or replacements 4 of those times. NEVER WILL I EVER OWN ANOTHER DODGE. When I call Dodge customer service in Auburn Hills, MI and question them directly about the integrity of the trans. they quote, " This conversation is becoming unproductive and the call will be terminated." Doesn't matter how many times I call the response is always verbatum. It's no wonder they're in trouble. My email is greggfl@wans.net if you care to contact me directly.
I FOUND OUT THAT ON AN INCLINE, WHEN YOU TAKE YOUR FOOT OFF THE BRAKE, THE CAR ROLLS BACK LIKE YOUR WERE IN NEUTRAL. I HAD NEVER EXPERIENCED AN AUTOMATIC TRANSMISSION THAT DID THAT AND WHEN I TOLD THE SERVICE MANAGER...HE SAID IS NORMAL FOR THAT TO HAPPEN ON NEWER DODGE MODELS TO AVOID MORE STRESS ON THE TRANSMISSION WHEN LETTING YOUR FOOT OFF THE BRAKE. I WAS SPECULATIVE...BUT WENT AHEAD AND HAD THE WINDOW FIXED ANYWAY.
WELL....I GOT THE CAR BACK, FIXED WINDOW AND ALL. I LATER HAD A FRIEND IN THE CAR AND WANTED TO SHOW HIM HOW THE CAR ROLLS BACK AND GET HIS OPINION ON IT. AND WHAT DO YOU KNOW...THE CAR THEN STOOD SILL ON THE SAME HILL THAT I OBSERVED THE PROBLEM. MY FRIEND LAUGHED AT ME AND TOLD ME THAT I'M IMAGINING THINGS!!!! CAN ANYONE COMMENT ON THIS ONE?????
If you are worried your DC tranny will eventually fall apart, well, that's a different story.
One thing you can do, which is only a temporary fix...as the drain plug starts to leak, buy a plastic washer and put it on first. I had to do that with a 1969 Dodge Dart. If it's stripped too badly though, it won't help.
BTW, I've been changing my oil myself, and haven't had any problems...yet ;-) 40,000 miles and counting!
-Andre
In addition to the tranny, I have replaced a fuel pump, an oxygen sensor and most recently the intake manifold. Has anyone had any luck with Chrysler with some kind of restitution?? I love the way the car drive and looks, but I have spent $2500.00 over the past three years and I'm afraid I will end up shelling out even more. Any suggestions?? Thanks.
In summary, the fluid used is critical, and it sounds like many service departments get it wrong as well, which will kill the tranny. Notice on these boards how many replacements go out shortly thereafter?
http://www.allpar.com/fix/trans.html
BTW, mine has gone 40,000 miles now in 15 months with no tranny or engine problems (knock on wood!)
-Andre
Still good info on self-diagnosing your transmission.
Any tips... we'd Like to keep the Car running for some time still.
The next day the car was dead at lunch time. Had it towed to a local Chrysler dealership. They replaced the battery called and said the car was done. Went to pick it up that night and it was dead again. They ended up taking the car apart and found again the fusable link was melted. Also the main body harness wiring and instrument cluster harness melted together. The left rear interior "C" pillar molding melted and the rear defrost power wire was burnt. The cause was the main power wire for the rear defroster was stuck between the "C" pillar molding clip and the body cauing the wire to short, melting the main body and dash harnesses in several places.
Problem is absolutely no one will take responsibility. Called AAA and they won't cover it because the "failure was attributed to the "C" pillar clip pushed into the harness" and that is not a covered part. Called Chrylser customer service and they won't cover it because the dealership it's at said the wiring was "tampered with" (a phrase the dealership denys saying).
We then called the dealership we purchased it from because we were told the wire was routed incorrectly. Since we had had the car in 5 times just after purchase because of the sun roof not working. If they had removed the headliner to repair this then it was very likely they removed the pillar trim molding. That dealership said they would not have taken down the headliner to work on the sunroof for any reason other than replacing the module. Our problem was when closing the window it would drag the cover first and would not allow the window to close. On the 5th time in the shop they found that the rails were broken and they replaced them. (We have since had our mechanic call several dealerships and all said they would have to take down the headliner for this repair.)
We called our insurance policy, since customer service had said it was "tampered with" but they won't cover it because they feel the problem was caused by Chrysler.
I'm looking for some help. It's now 2/24 and we've been out of a car for almost a month. The cost of the repairs is $3100.00 and we just don't have that amount. While everyone agrees it is not our problem everyone is pointing at someone else while I'm without the vehicle.
Questions -- Can anyone confirm that in order to repair the sunroof the dealership would have had to remove the headliner?
Has anyone ever encountered the same or similar problem and how did you go about the repairs?
ANY SUGGESTIONS?
I do have an anoying problem with the transmission.
If I start the car and let it idle it will stay in 3rd gear about 80% of the time . I have to shut the car off and restart it,
then it is ok. If I race the engine to 1000-1500 rpms for a second or two I feel the gas pedal "loosen up" and the transmission is always fine. I have changed the transmission fluid and filter using all chrysler parts 7176+ and filter.
I don't know why cause my old oil with 145k on it was red and no burnt smell. it was original never been changed. I'm curious whats going on with my transmission and also the check engine light keeps coming on even though car runs fine. plenty of power. I have changed spark plugs and gapped them at .050 Bosch plantinum and changed pcv valve and air filter. Occasionally the car runs a little rough at a stop light. I still have the original A\C in good working shape if you can believe that! All brakes are original too lots of pad left, all highway miles. If anyone has an idea whats going on with my transmission at an idle and check engine light I sure whould like to
hear from you. Thanks Forest. e-mail is mmscorp@banet.net
Bought my 94 Intrepid used at 50,000. The tranny went at about 78,000....was about 75 miles from home and limped all the way back in "limp mode". Went to AAMCO...*stay away, overprice and the service and product stink.* Had the 1 year warranty, everything was running great. It's a beautiful car... the big engine, roomy, leather... everything! Well 17 months later the tranny went again. Out of warranty of coarse! Went back to AAMCO because they were willing to do the work at 1/2 the price they charged me the first time. LOL...what a deal, eh? NOT! 1st tranny - $1700 2nd tranny - $900. The second tranny was put in Dec 15, 2000. I had to return three times because it wasn't shifting into gears right....when backing up wouldn't go into gear at all once I'd put it in drive. They replaced a wiring connection cable once...the other time they said they couldn't find anything wrong. Well Feb 16, 2001 while going down the Pike at 65 MPH the car lurches forward with this horrendous sound and then comes to an almost complete stop, smoke billows out from underneith...IN THE FAST LANE! Thank GOD there were no tailgaters following me closely! I limped over three lanes and had it towed back to AAMCO...this time a different AAMCO. Figuring...well maybe I can finally get someone to do a good job. BOY...what a nightmare this has been. I'm told everything was melted, burnt and Tranny THREE to be installed. They have had my car three weeks this Friday...suppose to be getting it back tomorrow. Ya...RIGHT!?!?!? Anyways...I wouldn't touch another INTREPID if you gave it to me. I'd stay as far away as possible from AAMCO as possible!!
Don't get me wrong...I loved the car..the looks, the ROOM, the speed....but they can keep it as far as I'm concerned. Intrepids are NOTORIOUS for tranny problems...had I been a informed consumer when I bought this car I wouldn't have touched it three years ago. So...now I'm looking at the Nissan Maxima...good reliable car, GREAT engine...sporty..cute. Just thought I'd share my story with you all.
I'm hoping they were just frozen or something...like maybe we had a freezing rain during the night or some case like that. Still, I've heard alot of cases of window motors failing prematurely...and at 41,000 miles, I don't know how "premature" that would be any more!
-Andre
Now after driving the car since June, the drivers side window fell off its track, the battery cable has corroded and the front end of the car is making lots of noise. Now I know why Dodges depreciate so quickly.
I wish my company would allow Hondas or Toyotas as company cars.....
Please think twice before purchasing a used 98 intrepid.
