i have a p reg accent 3 door and the headlights are stuck on all the time
only way i can turn the off is to pull what looks like a fuse in abox from the fusebox on the pass side of the car above the wheel.
has anyone any idea where the relay is thats controls this or have any ideas how to sort it out
many thanks
mikezttman
Hyundai is getting a good reputation, which means their prices are going to go up. Get yours why you can!
If you want an SUV, we know people with the Santa Fe, and they love it. With 22-25MPG, that would be an excellent one to drive around in. I'm looking into trading in my 1997 Plymouth Voyager (which, by the way, is broken and won't start) for a Santa Fe.
If there's one thing I'd change, it'd be having power windows and locks. I miss that! Otherwise, air is cold, runs good, and it's a pretty smooth ride for a really small car!
We looked at the cheapest car to insure for him and the Accent/ Rio came up as the cheapest one to insure.
The year we looked at are 2002/03 35000 to 45000 miles max, basic model preferably Automatic (his choice )...
Do you recommend this car based on your experience, what to expect ? decent reliability ??
Thanks to you all
If the fuel gauge displays empty all the time as well as the fuel warning light being constantly lit then it's likely to be a fault in the system that detects fuel level in the tank... ie a fault with the ball-cock within the tank, a fault with the resistor within the circuit which moves the fuel gauge etc.... again nothing to worry about... just annoying when you cant see the fuel level displayed.
as long as you remember to keep your car topped up every couple of hundred miles then it should be ok.
a few squeaks now and then from the engine can be expected with general wear and tear of the engine over time. Keep to the scheduled oil changes and various other servicing procedures and you should have a god few years left in your Accent.
If they've not been changed for 15,000 - 60,000 miles (depending on how you drive) then it's probably due a brake pad change. Most likely to be just the front pads that are worn, but may as well check the rear brake shoes as well. May as well also change the brake fluid while you're working on the brake system, should be changed every 2 years or 20,000 miles
Or is it just when the brake pedal is moved...which could mean the lever on the brake pedal may need greasing.
http://www.gates.com/part_locator/index.cfm?location_id=3598
If that's correct, then that means it's likely that at least some valves were pancaked and will need to be replaced.
Was that the original timing belt?
most likely to be one of the following: a vacuum leak, one or more of your fuel injectors leaking or a hole or leak in the car's exhaust.
My problem is that if I go up hills (many here in upstate NY) and keep the accelerator down so it stays in 3rd I get a very Hot smell. The engine does not overheat, it smells more like an hot exhaust pipe smell. It only does it going up the hills, when I crest the hill and the trans. goes into overdrive the smell clears up. Any thoughts on this?
The car did not come with a book. What is the life of the timing belt. On the old 96 we would change it every 60K. How much does the change cost?
As far as the timing belt goes, the manual recommends replacing it every 60,000 miles, which I have done as well. My '99 has an interference motor, which means it will be destroyed if the belt breaks. I am not as sure about the '01. The dealer here in Orange Cty. wanted $350.00 to do the timing belt along with the 3 drive belts as well, which I always do together. My mechanic did them all for $250.00.
If you have proof that it was done at 60,000 then you are good until 120,000.
I hope this helps and good luck.
so im 18, and i just bought myself a Hyundai Accent GSI 1999
I am looking for an economic car, one's that good on gas, ect. i guess i got what i was looking for..
anyways, my question..
When should i have my "economy button" on? Should it be off when im on the highway?
Also..
When should i have my O/D button on? Should it be on when i have my economy button on?
please help me, im absolutly uliterate when it comes to cars....
You will need to know the capacity of the tank to determine your driving range. Edmunds.com lists the tank capacity of the 4 door Accent GL as 11.9 gallons. 2 door models apparently have the same capacity. I'd use 10 (leave yourself a safety margin) times your MPG to calculate your range.
http://www.auto-sfondi-desktop.com/Wallpapers_Hyundai_/Hyundai-Atos/Hyundai-Atos- _640.jpg
Only cost me an extra £100-£135 to change the belts as part of my 50,000 mile service, well worth it if it saves your engine.
have you changed the air filter within the last 2 years (20,000 miles)? If that's clogged up with muck it'll affect your mileage.
Your petrol injectors, they rarely, if ever need changing, but they can get clogged up. try mixing a bottle of petrol injector cleaner in with your next tank of petrol.
Fuel filter, if that's clogged up with grime it'll affect your cars mileage. This filter should be changed every 4 years (40,000 miles). Unless your confident at car maintenance i'd leave this job for your garage, as you have to get rid of the pressure within the fuel lines before removing it, i believe... not done it myself though.
Tracking... if you're wheels aren't aligned up correctly: toeing in / toeing out, it not only increases tyre wear and causes excessive wear on suspension components, but affects your mileage.
Hopefully it'll be one of these, as none of them are too hard / expensive to fix.
Ken
If you would like to find out what it is, maybe try jacking the car up and spinning the wheel round. I've heard of the rotor (part of the brakes) rubbing against things before. If this is the case, you could take the rotor off and put it on the grind stone so that it doesn't rub anymore.
It could also be your C.V. joint(s), but when they go it's usually more of a clicking sound.
I have a 2001 accent 2 door auto w/78800 miles. Sometimes when at a stop or slowly going around a corner the transmission feels like it loses power for a second and then catches. Fluid level is full Any Ideas?
not long ago i thought my shock absorbers had gone as two of my wheels were up under the arches and the other two showed lots of clearance, turned out i was on uneven ground, try parking on some flat tar mac maybe?
if this doesn't help, i'd say the sagging is due to worn suspension parts, mainly the shock absorbers lean on the front driver wing of your car, and apply the same pressure to the passenger side, does the car go down more on the one side? if so then it'll probably be your shock's.
The air con compressor was in need of replacement
One of the sensors in the air con system was faulty
The system was wired up incorrectly
Hope that's of some help.
