Visitor Agreement.
The Passat and Volvo XC get 17/24 mpg with less power, but it's because they are geared shorter.
-juice
Doug
Greg
Eric
The sensors are found at the following locations:
– Sun-load sensor (beside the windshield defroster grille)
– In-vehicle temperature sensor (beside the temperature control
dial.)
– Ambient sensor (at the backside of the front grille)
FWIW, last summer while driving past the local airport the sensor reported the same temperature as the weatherband was reporting for that airport.
I too find it interesting to watch the temperature drop as we drive over the passes here in Colo. It was a cold day of skiing, Sunday, and when we got in the car it was 7 degrees F. No wonder we were cold! As we went up the pass, the temp dropped to 3F close to the top, but I forgot to check it at the top.
Having the VDC sure makes it easy and fun to go over Loveland Pass! I agree with Warren (smokeybaer) that the power has improved at 18kmi. If traffic allows, I just set the cruise on 70 and it has no problem maintaining that up I-70 to the Eisenhower tunnel. Our MPG is also affected by the seasonal formulation of gasoline (and the fact that the ski rack gets left on). Last summer we were getting 26 & 27 hwy (no crossbars), but we're getting around 23 now.
Theo in Colo.
This morning my wife got in the car and drive the 20 mi to her work. The VDC and ABS lights never went out. On the way, she called me. I had her turn off the car when she got there and restart it. The lights went out when she restarted it. We just had the ECU re-programmed last week. The car is almost a year old and has about 18K mi on it.
It was about 0 degrees F out, but the car was parked in the garage all night.
Thanks in advance,
Theo in cold Colo.
-juice
The writer correctly recommended cable chains or Spider Spikes. What I found suprising was the drive time writer recommended putting the traction devices on the rear. Is that correct for the VDC model?
-mike
CAUTION
Tire chains cannot be used on tires listed below because of lack of clearance between the tires and vehicle body.
 P205/55R16 tires for GT models
 P225/60R16 tires for OUTBACK models
 P215/60R16 winter (snow) tires for OUTBACK models
Driving on snowy grades or icy roads may require the use of tire chains, in which case put the chains on the front wheels only. Use only SAE class S type chains that are of the correct size for your tires so as not to damage the vehicle body or suspension.
When driving with tire chains, drive at speeds below 19 mph (30 km/h). When a temporary spare tire is on a front wheel, replace the temporary spare tire with the rear tire on the same side of the vehicle, and then fit chains on the front tires.
There are some companies (SCC and spikes-spider) that make traction devices that need less clearance than normal class "S" chains.
BTW, that statement in the owners manual has caused more upset, heartache and controversy out here in the West as chains are required by law to be carried (not worn) by AWD vehicles in most chain control areas. Normally they close the roads before it get bad enough to put them on.
Speaking of wrenches, that plug is supposed to be a 14mm Allen (9/16") I have yet to find one. Has anyone seen such a beast?
Thanks, Theo in Colo.
http://www.snapon.com
Part Number AWM14C $14.35
That is, can the ac be turned off during manual mode. It seems that the ac turns on briefly when choosing the mode, which can't be good.
Also, we want to tint the rear windows, and I wonder if window tinting may affect the frameless window seal..... Anyone have experience with this?
And, anyone have the Bridgestone Potenza's in snow?
We use Nokian Hakkapaliita's for snow usually, and they are the best. If the stock tires are ok, I would love to save $500.
Thanks....
The Potenza's are not very good in snow in my opinion. Starting and steering are not too bad but stopping is poor. Several times I have had all four wheels locked and slid albeit at a low speed. I learned the hard way that ABS only works if at least one wheel is still spinning.
NOTE
The air conditioner compressor does not operate when the out-side
air temperature is below 32F (0C).
I believe the A/C light only comes on when the compressor may cycle. We don't see the A/C light come on in the winter here, unless we override with the defrost button or the A/C button. The longer we have it, the more we just let it do things automatically.
One thing to know about the auto climate control is that any function (fan speed, air source, A/C, etc.) can be overridden by pressing its associated button, but all other functions remain automatic until their button is pressed.
HTH,
Theo in Colo.
Drained and refilled the coolant, since most of it drained out anyway when I pulled off the plug. There was about a quart in the bottom of the radiator that I drained through the radiator drain.
The whole thing took me about 45 minutes since I had been under there Sunday and knew how to take off the brush guard and knew which plug I was going to try.
Hope this helps someone.
Theo in Colo.
The same thing happened to my wife today Jon and it will be a few days before we can get it in to a dealer. I'm very interested in your situation and the outcome. Please post a follow-up on this board.
KarenS
Owner's Clubs
Ask if they checked and if not, let them have another look.
BTW, your case is very mild, so if so you caught it early. Our 626 was going "chunk-chunk-chunk" in rhythm with road speed, and that's what it was.
-juice
Immediately afterwards I noticed the ABS and VDC light on. Of course VDC is disabled if ABS is. Pulling off at a truck stop I tested the breaking and ABS was definitely disabled. Turning the car off and on reset the fault and everything has been fine since.
Still it seems unusual for the ABS to be knocked out by snow. Never happened on any other vehicles I have driven. Has anyone else had the experience of the ABS being knocked out by plowing through snow? On any vehicle?
-mike
-juice
Dave
For example, I need to transport the bike rack I pick up from the dealer home. Just want to put it in the wagon and then install it this spring. How should I protect the back area?
Should I use a carpet remnant?
Does Subaru or a third party make a full cargo area mat?
How about a canvas tarp? What seems to work best?
Also -- what do folks use for tie downs?
Thanks. -- Joe
I always have a set of bungee cords in the cargo area, and I've used them many times.
-juice
I kind of miss the 60s and 70s wagons that had rubber mats and seat backs and a fold down tailgate.
Steve
-- Joe
Steve
-r
paying for the VDC in various parts of
the country. There doesn't
seem to be a glut of them on the lots in the NW.
I've used one on my MY 2000 OBW and am satisfied. The velcro doesn't stay adhered to the vinyl in the cargo area very well, so I use 3 suction cup clips on the glass on each side and some trick tarp clips (blue plastic devices with a bit of cord attached to a central wedge that traps the fabric) that I picked up at Menards. It would be nice if the cover was cut so you could have the rear seat partially folded, but I don't think they provide that option. Very rugged material that cleans easily and has done a good job so far @ 40,000 miles, bikes, skis, helping a friend move....
HTH - Greg in IN
Revka
Hatchbacks & Station Wagons Boards
the car specialist's reply was: "The Subaru-McIntosh O.E.M. systems will not work with McIntosh Changers. The system has changer controls, but Subaru changed their mind about getting a changer designed for the system. They offer a RF modulator changer that will work (*but has the response of the FM band). Requests for Subaru to get a Mc-Changer or ANY questions about the Subaru system can be addressed to 1-800-subaru3."
I wonder if that will change any time soon? Patti, any info you can share?
Theo in Colo.
-mike
Just my opinion,
Mike
-mike
The premium sound are decent, at least. They are true two-ways with 15-30 watt handling. I'm sure the Mac speakers are much better.
-juice
Theo
This is generally not true anymore for the best car companies. For example, Toyota and its suppliers (mainly Nippondenso) are actual partners in development. Toyota sets performance goals and works with the suppliers to best balance performance, new technologies, and costs. U.S. manufacturers are slowly making this transformation.
In the case of McIntosh and Subaru, I think from all I have read that this was indeed a collaboration between McIntosh and Subaru engineering to match components and car acoustics. In such a case, the cheapest approach would be using existing components modified slightly to meet the goals. From comparing audio specs, it appears that this was what was done utilizing existing Mac components. Hopefully, this is an indication that this is the way Subaru works with all suppliers.
Mike
Dukephoto
teeth.This leads me to ask what is subarus level of commmitment to this model,will there be more production in 2003
Fitzmall.com has 8 VDC wagons in stock, all around $30k with freight included, if you feel like coming down to MD. They have locations in Rockville and Gaithersburg. You could take the train, and then the subway (Metro here) to get to Rockville.
-juice
