Visitor Agreement.
I agree with paisan, though, SoA does not automatically get involved. In fact, I bet the dealer doesn't even want that to happen, 'cause it puts more pressure on them.
I bet some of the seals and/or gaskets are bad.
I have the Phase I 2.5l engine, and for the record the coolant level has never dropped. I've flushed the system once, and have 47k miles right now.
-juice
My favorite was the dohc, solid lifter, a work of art, stupid me had to come down with a case of piston envy.
Let them know. Have patience and they'll make things right. That's always been my experience.
Ken
Report it to SoA. It's to the benefit of those whom (unknown to us here) maybe experiencing what your car has.
And submit to them those test result you have.
-Dave
$30,718 (according to the dealer list price is $32,920). Any options would be added at invoice price.
I haven't seen the actual invoice price of the VDC, but he did give me the prices on the options I am considering.
Popular Equipment Group(cargo bin, rubber floor mats)- $100.00.
Rough Road Group(hood deflector, rear diff protector, and rear window dust deflector) - $147.00
Cargo Area Convenience Group (net and cargo area spot light) - $65.00
Auto-dimming mirror/Compass installed - $119.00
What do you think?
- John
Try fitzmall.com, and then ask them if they'll match the price.
-juice
Have you tried pricing the car out using Edmund's TMV calculator? I've found it to be pretty accurate for my area.
Ken
Thanks for the input. Edmunds did not have the 2003 OB prices last time I checked.
- John
Sorry for the long post
LUCK TO ALL---JACK
-mike
PS: He started in April IIRC @ SOA.
Dennis (bluesubie) might know better.
-Dave
Just a W.A.G. - Shannon
Your thinking is the same as the dealer from which we purchased the vehicle, they replaced a cooler with had both leaking coolant and oil fittings.
While I agreeded that the water side would remain pressurized (for a relatively short while) after the oil side is back to atmospheric , I suggested that if this were the pathway there would have to be oil in the coolant which there is not-it couldn't possibly be a one way street. Furthermore, the water side would have to remain at high pressure for a very long time, while the lube side was not under normal mechanical pressurization, if it were pushing coolant through a pin hole / small crack in the block or heads, or through a porous portion of the casting; which I am convinced is the situation. Additionally the differential in fluid density makes this thought process even more problematic, in my opinion of course.
Unfortunately I was correct, at 1000 miles after the fix another, the third, oil sample was tested for coolant and, the level is the same as it always has been.
The $30,000 VDC has been back at the dealers since Wednesday, I believe it is now 8 business days in shop and no progress has been made.
What is alarming is that Subaru, through the dealer, implied that there may be a minimum 'acceptable' level of glycol in the oil of H6 engines.
Lemonrider, how familiar is this starting to sound????
After reading your posts last week I checked my 2001 LLBean Friday afternoon before driving home from work and several times over the weekend. All were cold engines. The level was the same each time - halfway between FULL and ADD. That's after 26,200 miles...
I did smell coolant once during those 26,200+ miles - this past May when I was stuck in traffic on I95 in CT for 2 hours with the AC on. I considered that a normal coolant expansion overflow - exactly what the tank is there for.
So, no problem here. Sorry to say, I've had flawless performance so far (except for the replacement of front rotors/pads - covered by Subaru).
Good luck with your problem.
Ralph
bit
Bill
Bit, I hope I am wrong but I believe the problem to be very widespread with at least the first year owners.
I've seen prices for VDC dip to close to $28k here in the DC area, at fitzmall.com. The '03s will add a 6CD changer, plus chrome rings around the dials in the dash, and new wheels/bumper/grille.
Robert had a good idea - maybe Bill can post his manufacture date too.
-juice
Patty arranged for the regional Subaru to get involved which he did by instructing the dealer to pressure test the system overnight and look for leaks. There were no leaks observed so I was told by the dealer to keep my eye on the coolant but everything is fine.
I have never owned a car that required so much coolant attention to be within factory limits. I wonder how many drivers in America would have over heated engines if they were required to check their coolant and refill the entire coolant overflow tank monthly.
If I had known that Subaru's were such high maintenance vehicles, I certainly would not have purchased one.
However, the problem is probably limited to a small percentage of the early H6 engines thus it is not a big deal to Subaru. However 100% of my experience is with this vehicle so it is more important to me.
My honest suggestion for those with the problem is to sell the problem vehicle before Consumer Reports finds out and the car is rated unacceptable as a used car. The value will really drop then.
I wish everyone well but I am bailing out.
Jim
-juice
Patti
As was Patti's recommendation to you, I have a case file going with SOA. They have set an appointment next week with my dealer and a regional SOA tech rep. I hope you do the same; the more similar cases, the better our chance of deciphering the problem.
Mike
If you were having to add coolant at every oil change, that would be a different story.
-juice
I appreciate SOA getting involved; I am hoping for a simple logical explanation. There has never been any hint of overheating or any other performance issues.
Mike
bit
I was not sure if the quantity (a little over a pint in 18 months was really enough to worry about). However since it dropped about a half-inch since I marked it about 225 miles ago, I am wondering if it is accelerating. I need to have more data to be sure.
The half-inch drop happened over about a two week period with 16-miles to work each way, and not driving every day. I have not yet taken a long single trip. A half-inch could be temperature expansion. Although, I always check it when it is cool.
For the past year, I was not very good about checking my fluid thinking that a new car would have no leaks.
No other problems with the car though. Also, the oil does not appear milky which I have seen in another car in which I had a head gasket leak. (Toyota Tercel). At any rate, I will get a sample and have it analyzed. If not from the dealer then from another source
I will keep you all posted, but as I said it will take time because I do not drive it every day.
If other H-6 drivers do not have ay coolant loss then something is wrong with the cars who are losing fluid. I have not had this problem before in a new car. I wonder if any of the 4-cylinder cars have the loss.
Bill
You guys seem to be really on the ball, so hopefully we can all help find a resolution, or at least an explanation, for the problem.
Bill (the other Bill, mfsb): you need what I call a "baseline", so fill it up now, and check the level after at least one drive where the engine has operated at a normal temp for a few miles. Then mark it with a grease pencil, and track it from that point on.
-juice
BTW, my LLBean was manufactured 1/12/01 and delivered 2/1/01.
In looking under the car the exhaust pipe does not go out far enough. Most other cars the pipe will just clear the bumper so that the gases won't get trapped
I am 62, the target age for this car, and I should not have to play with the seat every time I drive the car. Unless Subaru improves their cabin for big drivers, I will have to pick another make.
As far as the sleepiness goes, I bet the Bean is a lot more comfy. ;-)
-juice
I got a bright red Escort as the rental car for my wife to drive. Everybody needs to rent such a car sometime just to appreciate their Sooby. I will be wearing earplugs this afternoon when my wife gets back from running errands.
As for me, I have a renewed appreciation for my WRX. I think I had gotten used to its power and quietness. It was fun punching the Escort, listening to the muffler roar, the transmission downshift, and no noticeable change in speed.
Mike
-juice
-mike
I was pleased with the SOA involvment. The rep had taken the time to to review the Edmunds posts and seemed to be engaged in the potential problem. Personally, I am comfortable with my situation.
An interesting observation on my rental escort. I checked its coolant level. It was at the low mark. It took 32 oz to take the reservoir back to the full mark. The OB only takes about 8 oz to fill. This suggests that Sooby's have a lot less room for coolant variation.
Mike
Generally, Subaru's tolerances are very tight, so that makes sense. That can be good (quality, gap tolerances) or bad (fault tolerance).
-juice
Once SoA is involved in your case, you're in good hands. Even if they can't find anything this time, you'll have it on record so it will be easy to take any future follow up action if necessary.
Ken
"it is Subaru of America, Inc's opinion that your vehicle is operating as designed and no repairs or adjustments were necessary to correct any non-conformity".
Enough said.
I notice the H-6 wagons now are rated to tow 2400 pounds, like the Baja and Forester 5-speeds. H-6 sedans and H-4 Outbacks remain rated at 2000 pounds.
(Juice, check out the second spread of specs, that pertain to the H-6 models).
Bob
Patti
Bob
Aren't springs supposedly to rebound any way?
-Dave
