Visitor Agreement.
A real slick design except on the automatics the gear selecter needs to be moved from the park position to provide ample space to insert or remove the cds. Not sure if this has been changed on the newer models.
Vince
Not for the MAC unit found on the VDC. The 6-CD changer used to be under the front passenger seat, IIFC.
Bob
Now we know it's the lawyers that set the limits - nothing significant changed to get that higher rating. The brakes are the same, right?
The Forester also got internal rebound springs. Put me on the list of folks who have no idea what that means! I think they are referring the the inner shock valving, not the coil springs.
-juice
The Baja gets the 2400 lbs rating too, so you might think it has to do with the weight of the vehicle.
But then why does the even lighter new Forester get rated for 2400 lbs? I can't make sense of it all.
Glad to hear the 6CD is appearing on more models, my wife and I both have them and love 'em!
-juice
Bob
The Forester X weighs, what, 3090 lbs? The H6 sedan is lighter than the wagon, but far heavier than the Forester.
-juice
Cheers
Pat
Since it takes only about a cup of fluid to move the coolant from the low to high mark, I believe a lot of the perceived problems could be because of this tolerance. A few people might have a real problem, but I don't believe that there is any general design flaw in the H6 engine.
Even though I have this potential problem, I would still buy the car again. I love the quietness, the ride, the H6 smooth power, and the stereo system. I feel good in it.
Mike
Our fifth, and last Subaru, continues to use coolant, SOA stated to us in a letter that the vehicle is operating 'as intended'.
What more does any potential customer need to know?
-mike
On a totally seperate subject; can anyone comment on the leg room in the front seat of this edition of the Outback. My mother has one of the previous edition, and I had one of the very early ones, and I found them to be very cramped. Good cars but small. TIA
Cheers
Pat
Concerning leg room, I think that is too dependent on your personal size and personal taste in comfort. You just have to go for an extended drive and judge for yourself. Not a problem for me, but I am only 5'7''.
Mike
So the "if it's not on the floor therefore it's in the engine" isn't 100% correct.
-mike
I notice that some of the GT models are coming with an avail "man-u-matic" shifter. Is there any sense, in all this collective wisdom, that it will become avail. on the Outback? If so, and they would add a turbo to the H6 motor, it would be the ideal vehicle for my purposes. (I live a high altitude).
Cheers
Pat
Now if all H6 models were consistently losing fluid, then there would be a design issue. I see no evidence in that due to the few posts with that problem. My problem is sporadic with loss only after extensive trips, which indicates what the other Mike (paison) suggested in my case.
Mike
By contrast, the Edmunds specs for the 2002 Outback wagons--both 6 cyl VDC and 4 cyl Limiteds--indicated maximum tow capacity at 2000 lbs. I know that warranty considerations often enter into the GVW tow limits put on vehicles, but it seems to me that the 6 cyl wagon should probably be rated a bit higher than the Baja and certainly higher than the 4 cyl Limited.
I'm not looking to haul a massive trailer--just a pop up camper at about 2200 lbs--but I'm surprised that towing (an "outdoor" activity after all) sems to be a bit shortchanged on these great vehicles that do a lot of things well.
Any thoughts or real world experiences on these numbers?
Be aware, however, those ratings are only if the trailer has trailer brakes. The unbraked trailer rating for all Subarus is only 1000 pounds. This is mentioned in the owner's manual.
Bob
I'd love to hear about the resolutions but I believe Patti has to respect the privacy of each individual's case file, so I doubt she can share specifics of each case with us.
I think if there are enough cases that Subaru issues a TSB, then we'd here more about it.
If the coolant made its way into the combustion chambers, surely the (very sensitive) CEL would be triggered. So I don't suspect that is occuring.
Shiftronic is a neat feature, but IMO they price the 2.5GT too far above the L/SE model to be worth it. It's about $4500 more for the shiftronic, VTD instead of auto AWD, and heated leather. Those things are nice for $2-3 grand, but not $4500 IMO.
For 2003, the tow ratings for the H6 wagons went up to 2400 lbs. And I don't see a design change, so I imagine yours can handle 2400 lbs just as well as a 2003.
What's funny is H6 sedans are still rated for 2000 lbs, while lighter and H4 equipped Forester can tow more. I don't get it, either.
-juice
Don't forget there have been some suspension upgrades for the '03 models.
Bob
It's still interesting to me that the Baja 4 cyl and the Wagon H6 have the same tow numbers, and since I go by the rule to take 80% of mfg's number, that puts it at about 1900 "safe" lbs, assuming trailer has brakes.
Hey, I wonder if all the models that got the higher tow rating have those struts?
I'd love to be able to make sense of the tow ratings.
-juice
-mike
This was my first Subie but my son has a WRX. He had not checked coolant ever and when we did at 15,000 miles, it was perfect.
Frankly, I lost confidence in the VDC. I was worried that a problem with as much exposure as this one would come to the attention of Consumer Reports which could result in the used vehicle being rated as undesirable and thus dropping in value dramatically. Thus I dumped the vehicle and bought a Camry. Guess what, 10,000 miles on the Camry and not a drop of coolant has been lost.
Yes, I miss the Subie. No, I do not miss having to closely monitor and add coolant frequently.
Subaru can not be expected to change an engine that is within their normal limits. I guess the bottom line is my personal automobile standards were higher than Subaru's. That does not make the car bad or Subaru villains. I probably just need to be careful to stick to makes with very high quality reputations and not experiment.
If your VDC does not lose coolant, do not worry about it and have fun with your Subie. If your Subie does lose coolant, Subaru does not appear to be in any hurry to exceed your expectations and fix it. Good luck.
Jim
-mike
If anyone would like to see the letter SOA sent us please let me know and I will post it if that is acceptable or send it to anyone who is interested.
By the way, the day we we picked up our VDC at the dealer we also got the rental car bill that Subaru refused to pay, $900 USD more or less-we were under the impression that transportation was being provided. And yes, if anyone would like to see the bill, marked paid by us, I'll be happy to post or send that along also.
A factory makes shirts for two outfits. One is named 'Giorgio Armani' and the other 'Flying Horse'. Which is the better quality shirt?
H6 design flaw? Nah, more like design tolerance being applied. Quality of the engine is inferior? Hmmm... engines are machine made and cast. I wonder who makes those machines that makes those engine? I bet Honda, Toyota, and what have you uses the same machine that Subaru uses. ;-)
Never mind me if I don't make sense. I'm just blabbling a thought off.
-Dave
Jim: I hope your Camry was built after July '01, because before that they had sludge issues that make a coolant leak seem like nothing. The new 2.4l engine is okay, it's the old 4 banger and the V6 engines. Check the build date on the door jamb, if it's before 7/01 I'd consider dumping that (if so you have the worst luck in the world), or at least switch to non-sludging synthetic oil and a shorter change interval.
snowbelter's case seems normal. You just don't want it to dip below the "add" level. There will be some fluctuation in the level depending on whether the engine is hot or cold, and above the full mark it'll spill out the overflow valve, won't it?
-juice
Cheers
Pat
In the case where there was coolant in the oil, I'd suspect the seals and/or gaskets, but other cases seem less serious.
-juice
For those without a coolant loss problem, this issue must seem like a weird joke. For those of us with the problem, Subaru's reluctance to do anything, other than pressure test the system and say it is within normal limits, is very frustrating.
The old saying "I never thought about the water until the well went dry" is appropriate. I never thought about engine coolant except to change it every 50,000 (or whatever) miles until this problem cropped up with my Subie.
Are all VDC's bad. Of course not. But on the other hand, they are not all good either.
Jim
That said, it does seem that Robert and Jim have real problems since their's apparently leak continuously. However, their main problem appears to be the lack of a working relationship with SOA in fixing the problem. Based on my personal experiences with the dealer and SOA, I am amazed that it has gotten to that level of animosity.
Mike
-Dave [having another brain f@rt]
snowbelter: could coolant have spilled out the overflow valve, though? A long time ago, when I was new to cars, I overfilled the reservoir, and noticed the coolant spilled over. Not over the top filler neck, mind you, but out some overflow valve. In other words, it wasn't a sealed system.
Just a thought.
-juice
Also, my WRX tank seems to stay right in the middle, but at one time I had topped it off just to compare with the OB, so it has dropped and stabilized to the middle. The SOA field mgr that inspected my OB did make a comment that he had noticed that it seemed that the natural level was halfway on the H6. I am curious if those of you with no problem have the level staying at about halfway between full and add. If so, I am curious if you top it off whether it will seek its level back to halfway. Any experimenters out there?
Mike
-mike
That is my theory at the moment and why I hope some of you will test that theory. I can't because the SOA rep wanted me to wait until it dropped below the add before they checked it again. Tolerances might make my normal close to the add mark; therefore, after my first drop (air pockets?), I started watching closely, everytime it dropped toward the add mark, I topped it up again and repeated the cycle. I wasn't patient enough to just let it stabilize. I think that is also the thoughts of the SOA rep with our current plan.
Mike
Bill: thanks for taking the time and effort to do that. You da man.
Now we have another data point, and an important one, because your slow coolant loss is likely not harmful.
-juice
I'm not sure if it was due to the turns of due to the heavy accerations but that could be helpful to people who have lost some coolant.
-mike
-juice
-mike
Now, how is the transfer of coolant from the radiator into the reservoir controlled? And more interestingly, how is it retrieved from the reservoir? I am certain nothing has changed in the basic design of the cooling system where now they are unpressurized. Is it all in the cap?
Overflow tanks in other cars I have owned did have overflow tubes. One memorable Toyota with a head gasket leak would pump all the coolant onto the ground from the tank overflow tube if parked nose first downhill. The pressure built up in the system would just force everything into the tank, where it simply overflowed. But this action left a mess under the car, and residue of coolant in the engine compartment which was easily recognized by its smell.
Steve
-mike
If the radiator gets hot and the pressure exceeds the cap's specification, it will "vent" out excess coolant into the overflow tank.
When it cools back down, the coolant in the radiator will contract, creating a vaccuum that basically sucks coolant back into the radiator from the overflow tank.
I think this cycle has only a certain tolerance for overflow, and exceeding it may be what makes fluid spill out, and causes the loss of coolant. You may not see it because it'll likely happen when you're out driving, not idling in your driveway.
-juice
