Chrysler Town and Country EX/LX/LXi/Limited
Thanks in advance
See my homepage for my littany of problems, also electrical.
You can complain to the US Dept of Transportation thru a link I have supplied. (It is hard to find!)
Please distribute my homepage link as you see fit.
Also, make sure that you have complained to Chrysler.
Suzan
Thanks so much
Clueless in Ohio
Gasolene is mostly carbon and hydrogen molecules. The two main products of combustion are CO2 and H2O which is of course-water! So the water you are getting in your tailpipe is coming from the burning of gasolene in your engine.
As far as your malfunctioning wipers, this was a common issue with that era DC minivans and is I believe related to the multifunction switch in your steering column. Any good mechanic familiar with DC minivans should have seen this before and can fix it.
I wanna know how they rigged it up to work for the time being(meaning for 1 week). I just want to make sure it doesnt happen to me again. The wipers worked after they fixed them, but on a rare occasion when you turn them off, they just stop in the middle of the window and do not go to their resting position. Anyway, wipers are the least of my problems, Im way more concerned about the heat, being that its like the arctic outside. Do you think I can fix it myself or is it too labor intensive?? Anyway, thank you for your help, I really had no where to even start from. Thanks again!!
A little less clueless in Ohio:)
I had our 2001 T&C jumpered this weekend and after we got going --- nothing-- from the speedometer .
What did you findout was fix?
Allan
Meanwhile, a few months ago the front tires had 8/32 inch thickness remaining on the tread while the rear tires had between 4/32 and 5/32 inch tread thickness remaining.
(The tires were not rotated until the van had gone 29,000 miles). Never required a front end alinement either.
Daughter got new tires and a new battery for her 99 GC when it had about 55,000 miles on the odometer and it now has 83,000 miles.
These are just 2 examples of reliable, dependable DC minivans.
Has anyone replaced their T&C alloy wheels with aftermarkets and, if so, with what?
'02 T&C LXI
Any advice on how to replace a burned out bulb in the map light on the overhead console shy of taking it to the dealer? This is a pushable switched light in the front for the driver or passenger. I cannot find instructions on this anywhere. Please help thanks.
Also there is a small red light on the hooded section with the turn signals, other indicator lights that was on before this all happened, normally it just comes on then goes off when starting the car like it was checking something. Checked the manual theres nothing about even having a red dot there and can't find anything about it online. Any ideas? Email me at rjwatt616@adelphia.net if you know what could be going on.
We most likely won't get a Chrysler next (the number of problems are just beyond the norm). Hope this helps. Before you follow the advice in this post though, please make sure that the symptoms match the ones I had described previously; Will turn over but shut down in a couple of seconds. Bang hard on either side of the dash while the key is in the on position, if the digital odo comes to life then it will start. We could do this dash-bang only at the first or second instance of it not starting. If you keep cranking more than 3-4 times then you'll run out of luck, it will completely go dead, it won't turn over and hence the dash-banging trick won't work!
I also read in some other forums Chrysler has offered a 7years/70K warranty on this model? Can anyone confirm?
I have kids in the 3rd row and also always carry a small stroller so I thought this would be something that would give me more organized cargo space since it is 2 tier
Is it worth $250? Yup, every penny.
Best Regards,
Shipo
THANKS!!!!!!!
