Visitor Agreement.
Many tows to the dealer, just to have it start, I changed Battery, Starter, PCM-(the main computer ) and the dealer wanted to change the BCM-Body Control Module.
My Starting problems have not surfaced, since I replaced the Cluster board. Im telling Everyone with similiar starting problems it's the Cluster Board. I'm Shocked that Chrysler has not caught on this.
In the year we've hadit, we've had to replace 3 tires (all on the front end) because of splitting at the seams. Not covered under warranty.
It has completely died on me twice, for no reason - so dead the power door locks won't work. They charge the battery so I can get to the dealership and then service dept says they can't replicate the problem.
Everytime we fill the tank with gas, it sputters as though its going to die and then recovers miracuulously.
This week, our breaks went from perfectly fine, to shaking when we hit the brakes, then ultimately within 36 hours, grinding, It even made the grinding noise while not braking. I took into the dealership and was told I must "drive with 2 feet". I had an Expedition for 5 years, 70K miles and only one break job. I have an 02 Mazda, 153K miles and 2 brake jobs. I had to pay to replace my rotors, pads - all of it. It just doesn't seem right and I'm about to ttake the dealership to court.
We have lots of little issues as well, like every once in a while the sliding doors won't open automatically or otherwise. Both sets of headphones have broken in the same exact place. Just goes on and on.
Is anyone else havng the same problems?? If so- please let me know!!
1. When we turn on the vehicle the radio, wiper, power windows, and ac/heater do not turn on, but the van runs normal otherwise. Then if we turn it off and back on right away they work.
2. Sometime (more often then not lately) when all the above things are working while driving the radio (radio, CD, tape) will suddenly go to a buzzing noise and will not work again until the van has been off for a least an hour.
3. NOW- tonight my husband saw flashing lights outside our window. When he went out to check it out our light were flashing quickly on our radio was turning on and off. The fuse box was also ticking. The vehicle had been turned off for over an hour and there were not keys in it. We unplugged the battery for now.
HELP!!!
I have a T&C 2001 with similar problem. Did you find a cure?
Mine has a throaty sound at about 2,000 rpm's goes away pretty much above 60 mph.
Any suggestions?
Allan Reed
This one i can only access the T/C setting not the message center information. Is that the case with this model or should i be accessing both? When i hit the C/T it gives me a service requested or needed message and it does it calibration process then i get the compass and temperature readings...when i press the step button...it just gives me my options of any settings i wish to change...am i doing something wrong, is there anything wrong with the sensors.,...or do you just get the C/T or the Message Center...hope this isn't too confusing, any help will be appreciated.
By the way, very nice van, loaded to the hilt and extremely comfortable. Using it for mostly work but wife is slowly taking it away from me.
Actually it has 4 buttons, not including the homelink and the auto doors open ones...
left side is the : Menu : Reset
Right side is the: Step: C/T
when i press the step button it just says perform service and then begins the calibration of the Compass...
I'm thinking the Mini-Trip computer is not with this model...or... :confuse:
Some cars used to (still do?) have a roll over switch that would cut power to the fuel pump in the event of a rollover or other severe accident. Problem is that, on occasion, those switches would open up on a very hard bump (think a deep pothole), disabling the car until it was reset.
I have no idea if the Chrysler minivans have something like this or not.
I have had wheel bearing go out, A/C, radio several times, thief switch bad which took 3 weeks to replace, back rear cover buckled, gear shift was very noisy, lots of air leakage causing you not to be able to hear radio, and several times the electron key has failed (once at Mount Rushmore). I had owned T&C and Dodge carivan before and they were great but stay away from new ones. Too much electronics and poor craftmanship. Just check out all the infor at this site.
We took a trip from Nebraska down to Lousiana, Florida, upto Georgia and then along the east coast up to Connecticut and then on up to Maine and then home through the Alleghany Mountains and across the northern states. During the trip we averaged 25mph over all. At home we average 17-18mpg city driving.
We did have an issue with the car after verbally agreeing to buy it... the switch for the window worked when my friend and I test drove it but the next morning when my husband and I went to let him test drive it and to sign the papers, the power window controls on the front passenger door no longer worked. The dealer repaired it before we finalized the paperwork. The car had 105k miles on it. We took the trip above about a month after purchasing the van. In New London Conneticut on the 3rd of July, the service engine light came on. We finally found a repair shop that was open. They checked the car over and could find nothing wrong, but although they found the error code, it was very generic... a problem with the emissions control system. They changed all the fluids and filters and suggested we take it to a chrysler dealer after the holiday. We went back to the hotel, the temperature cooled off overnight and the Perform Service light went away for several days afterward. When we started up through the mountains, the Perform Service Light came back. We have taken it to 5 different Chrysler dealers and to 3 independent repair shops, none of whom can find anything wrong relating the emissions control system. We don't seem to be having any problems with it otherwise.. just a light no one can figure out why it is on. I am going to have them check the EGR valve and see if that might be the culprit.
We have the power seats for the passengers and I only wish that the passenger seat had the auto-lumbar adjustment as the driver seat but other than that, they were very comfortable on the long trip. We were able to fairly comfortably fit in 2 adults, 2 teens and all their accessories and the 2 service dogs and all our luggage inside the van and even spent a couple of nights when we couldn't find an available hotel room taking 4-6 hour naps in the reclining seats at rest areas. That is with both of the adults having back issues. So yes, this is a comfortable car. I just thought I would right a positive comment about an 8 year old car. It has no rust on it, the only body work was after an accident right after the rain, which we are chalking up to an oil slicked road,wet brakes,partially worn tires and the car in front slamming on their brakes without warning on a hill. Just a bad combination of variables. Definately going for the AWD on the next one. Sometimes I miss grandpa's old Oldsmobile Wagon with Posi-traction. We currently have about 135k on it, and if all we have to do is change out the egr valve, I will be very happy, but am going to definately get it checked out so we don't develop transmission problems like we did on our aerostar when a similar part wore out, though I guess at 327k miles, it probably was time to either sell for parts or replace it.
