Audi A4 2004 and earlier
18182848687118
  • bamafan2bamafan2 Member Posts: 5
    Can anyone recommend a dealer who is selling 2002 A4s around invoice? I am looking to pick up a 1.8T CVT with minimal options.
    Kevin Worcester
    kworcester@directvinternet.com
  • nyccarguynyccarguy Member Posts: 17,485
    mark...you are right (as usual). I stand corrected and would like to foemally retract my statement about the "porkiness" and "added weight" being cons of the upcoming 2004 S4.
    scirocco22: Good to hear from ya! You've been kind of a ghost for a while! The Amulet Red is a gorgeous color for the A4. They way it contrasts with the grey bottom it really reminds me of an Alfa Romeo Milano. Rest assured that is is a bright red (not as bright as the laser red) and not even close to burgundy as it looks on the website.
    Do you all think the S4 is being delayed because they're trying to get the 4.2L V8 mated to the 6 speed manual transmission?
  • cyberpmgcyberpmg Member Posts: 83
    Thanks for the info! Guess it's something I will have to live with.
    'rocco: I've been able to get into the ClubA4 site with no problems. I would send a note to George about it. Activity over there has been extremely slow since it's been back online.
  • rayainswrayainsw Member Posts: 3,192
    Here is a relatively simple scenario:
    Coming around a corner at a reasonable speed for existing traction conditions, suddenly the road conditions change. Perhaps an unexpected change in surface material or even just the camber of the road. (A slippery substance on the road such as oil, sand, black ice, whatever.)
    The vehicle (previously cornering at some sane lateral G force) will tend now to drift / skid toward the outside of the curve. In a situation like this, the best gripping tire(s) will tend to grip longer. If the fronts break away first, the vehicle will tend to go straight. If the rears break away first, the tail end tends to swing around.
    Now, frightening as it is to see (through your windshield) your vehicle approaching large, solid objects (guardrails, trees, other vehicles, uck!) that can hurt you and your vehicle - this is typically preferable to the extreme instability of a spin. (Not to mention the driver disorientation.)
    If / when the vehicle speed is reduced to a level that will again allow the tires to provide useful braking or lateral acceleration (before contact with said solid objects, one hopes), it is typically better that the car still be pointed in the direction of travel. When control resumes – partially or fully - drivers typically deal better with a vehicle still facing in the general direction of travel.
    Now, your point about Audi Quattro (or my Passat W8 and many other cars) being biased toward understeer is well taken. In steady state cornering, this will typically be true. As braking or acceleration is added to the situation, this can change, however. As a vehicle accelerates or brakes, the effective center of gravity and thus effective weight distribution (one primary, but not the only factor in the understeer / neutral / oversteer dynamic) will change. And any tire contact patch can provide a finite amount of total grip. This will be the sum of lateral acceleration force and any braking or acceleration force. In other words, asking the tire patch to provide acceleration or braking at the same time as it is already trying to provide lateral acceleration (turning) reduces how much of either force the contact patch can simultaneously transmit to the road surface.
    Anyway – point is that I want (and I expect most people could best deal with) a vehicle that will not spin or tend to swap ends, even under the most extreme conditions. Again, if / when the vehicle speed is reduced to a rate allowing control again, I want to be (and the vehicle to be) pointed in the direction I am traveling. I don’t want to be sideways or looking at where I have been. And I want NOT to be rotating. The transition from rotating to not can be rather traumatic as well.
    Just my humble opinions . . .
    Cheers,
    - Ray
    Who is just trying to avoid said contact with said solid objects whenever possible . . .
    2022 X3 M40i
  • scirocco22scirocco22 Member Posts: 721
    Ray-- I'm beginning to see the point you are making. How does ESP effect these scenarios which you and Mark are discussing?
    Paul-- I just got an e-mail from George with a new temporary password so I'll give it a try when I get the chance. Yeah, hopefully things will pick up a bit. I actually liked the old format better. It's too bad it took so long to change servers because the forum lost a lot of momentum by doing so.
    Bradd-- Hi! ...thanx. Yup, I do like Amulet too. Although I'm a fan of metallic and pearl finishes, the Amulet is quite eye-catching.
    You posed an interesting question about mating the manual tranny to the 4.2L ...I was thinking about that too. Isn't it the first application which the 4.2L uses the 6-speed manual? The new AudiWorld article that Peter mentioned does confirm the availability of the 6-speed however ...yay!
    Kevin-- Where are you located? I've been hearing quite a few reports of dealers letting the remaining '02s go for close to invoice. You've got to remember that there's no holdback on Audis so if they can let one go for invoice, they are getting a pretty good incentive from the manufacturer ...a great deal no matter, if you can get one at invoice.
    Max-- I've been told the same thing that David heard about the MB Xenons ...that they should last a lifetime. But for some reaon, I kind of have my doubts about that. I'd like to get some kind of confirmation on that.
    Peter-- Thanks for bring the AudiWorld write-up to our attention. Isn't this the first real confirmation about what the S4 will actually be equipped with and how it will look?
    *thumbs up* ...on the 6-speed! But it appears I'm not going to get my voltmeter and oil temperature gauges --I guess I'll just have to add them somewhere myself. Preliminary reports were that the S4 would have "sportier" instrumentation ...oh well.
    btw, the weight and balance issues are discussed in the article.
    http://www.audiworld.com/news/02/new_s4/content.shtml
    --'rocco
    Some S4 enthusiasts aren't as enthusiastic as I appear to be. Read on: http://forums.audiworld.com/s4/msgs/964598.phtml
    ...essentially, it's not competition to the M3. "Never follow?" --"always underperform?" Or as he puts it: "Always follow, never lead"
    --'rocco
    I don't know about the rest of you all, but that new S4 has got me drooling. Those AVUS style wheels (18") look great and the fact that weight hasn't increased much over the Bi-Turbo V6 is a credit to Audi's engineers. 344 horsepower V8...mmmmmmmm! Personally I don't care whether or not the S4 can outrun an M3 (And I LOVE the M3 too) to 60mph. Whether the car hits 60 mph in 4.6 or 5.6 seconds, most of us can't drive that fast anyway.
  • dtwleungnycdtwleungnyc Member Posts: 188
    As it was explained to me with the one used in the MB. Since the light is not ignited by a filament, but by running an electrical current igniting the gases inside the bulb. There's really nothing to burn out. Only time the light will/should fail to work (other than because of an accident) is if/when there's a gas leak or the current is not running thru. Both would deem to be a manufacturing defect. At least this is true for the one used in the MB cars.
  • andys120andys120 Member Posts: 23,669
    Thanks for the input on this color guys. The new S4 photograph on the AudiWorld site is the color I saw, which doesn't look anything like the Amulet Red does @ audiusa.com.
    I really like the bright red, I must have it,whatever they call it!
    I'm impressed by the S4 as well. "I really don't care if it's faster than an M3, cuz it's got Quattro, which the M3 can't touch. I'd feel better having the V8 up front as opposed to the problematic twin-turbo.
    but willing to travel within a few hundred miles to get a good deal.
    Kevin
  • markcincinnatimarkcincinnati Member Posts: 5,343
    Ray, I agree with you.
    However, here are some additional thoughts and some experiences I have had.
    I took the Audi driving experience in Seefeld, Austria now 4 times. They always use A4 quattros. The course is given on a closed field 100% ice all the time.
    The cars are stick shift, sport suspension, ESP ABS+brake assist and are shod with studded snow tires on all four corners.
    We are told that quattros can be made to oversteer -- but it is difficult. They have two rear wheel drive Audi A4's (yes rear wheel drive) and they allowed us to drive them in a circle and try to accelerate to "X" speed. At a point in time, the rear end breaks away and the car is "doing doughnuts" -- classic oversteer.
    The same example was undertaken in the identical car with AWD and virtually the only way to make the rear end give away is to "encourage" it to do so by pulling quickly and sharply on the hand brake.
    Oh, BTW, the ESP is turned off for these "examples" -- cause it is really virtually impossible to make the quattro A4 oversteer with ESP.
    Here is what the instructors say to do:
    enter the early stages of a curve or turn and the Audi will begin to plow -- or understeer. Now, without the help of the hand brake or ESP here is what they say to do. Punch the brake hard enough to cause a "load shift" to the front wheels (now this is counter intuitive since it is important to turn the wheel in the opposite direction that you wish to turn the front end of the car). The reason you do these two things simultaneously is to have more weight push down on the front tires (the ones that are plowing -- understeering) and to temporarily stop the tire from sliding -- because a sliding wheel cannot steer.
    The exercise, after several practice runs, looks like this from inside the car.
    1. enter (left) curve, turn wheel in direction of curve
    2. car continues straight -- condition understeer
    3. curse
    4. punch brake -- like BRUCE LEE (hard and fast) and turn wheel about a half a turn to the right (intellectually and emotionally this seems insane)
    5. car begins to turn left, and driver again begins to turn wheel to the left
    6. car, on its own continues to slow (ever so gradually, but weight has shifted to the front tires) which means that more left lock can be dialed in because the car is moving somewhat slower and there is more downward pressure on the front tire patch which means understeer happens at a higher speed.
    Or, watching the experts --
    You can enter the curve "too fast" and give a slight tug on the hand brake which induces oversteer, again this is all happening quickly -- turn into the skid a little bit and apply power -- causing a "left handed" power slide -- with the rear end of the car swinging right and the driver twisting the wheel to the right (into the skid) which prevents a 360 and causes the car to "pivot" and actually go left.
    The second scenario is really difficult and I found my self either over or under correcting and either doing a 270 or inducing understeer and hitting the orange cone (what did you think they would put real gaurd rails for us to crash into?).
    The instructors -- all paid by Audi, granted -- are and or were rally drivers -- some for Porsche and other European cars not just Audis. They all said that the quattro system is the best real world system in that it is generally very forgiving (understeer biased) and was difficult to force into oversteer -- but that oversteer was possible with practice.
    Their claim then was that the AWD -- as enabled by quattro and Porsche (and I assume VW) provided the acceleration goodness of RWD, the cushion of safety of FWD (understeer) and the capabilities of oversteering (which are typically associated with RWD cars).
    You walk away believing that yes Audis do have some compromises and that in an ideal world on dry, smooth pavement, RWD with perfect 50-50 weight balance would be "best" -- but since conditions are virtually never ideal that the Audi compromise makes them the best performance car design -- in and on the places real, normal drivers drive most -- the public highways.
    Then they tell you that keeping the ESP on all the time, coupled with brake assist ABS reduces even further both over and under steer tendancies.
    I think that my dealer (not that they are by any means experts) still favor putting the newest best tires on the front wheels and the older tires on the rear -- under "normal" circumstances.
    But, the counter argument is also persuasive.
  • marleybarrmarleybarr Member Posts: 334
    Thanks 'rocco and dtwleungnyc for the info on xenon lights. Sounds like they should last much longer that the standard halogens.
    Andys120 made a comment about the "problematic twin-turbo" engine. Do you believe the current A6 4.2 powerplant is more reliable than the 2.7T engine? Thanks again -Max.
    I've seen reports of a number of failures with the 2.7T. I have no idea how many or of any details. They must be true if they're on the internet (lol).
    I haven't read or heard of any problems with the 4.2
    Andy-- I had the same question as Max ...about the 2.7T engine being "problematic" as I'm considering buying an allroad with that engine. You said you didn't know any of the details but do you know if it had to do with the turbos themselves?
    And that "red A4" you saw the other night, maybe it was a new S4 being tested or something since the A4 no longer comes in a bright red ...wow!, wouldn't that have been something? But yeah, I almost bought a B5 A4 in the old Laser Red. I had never owned a bright red car and after thinking about it for awhile, I thought it would just attract too much attention. That pic of the new S4 in that bright red does look sharp, however!
    Max-- Yeah, I'm sure they'll last longer than halogens but I'm still skeptical that they'd last a lifetime or as one guy said on AudiWorld, that they should be shining bright three million years from now. On the other hand, what David says makes a lot of sense too.
    Kevin-- I haven't recently heard of anybody buying a leftover A4 in the Alabama area but my hunch is that you could get a leftover for pretty close to invoice on models that are traditionally slow movers, specifically 3.0s. But since you want a CVT, I wonder if they'll bargain much on them as they seem to be rather scarce in supply ...especially one that's "stripped" when it comes to options.
    Here in my neck-of-the-woods, we tend to pay the highest prices for Audis than in where else in the country. I'm positive that none of the dealers here would let any new car go at invoice but in your region, I'd be more apt to believe you'd have a better chance.
    It never hurts to inquire and try. At least go to the AoA web site and use the dealer locator to get a list of all the dealerships within the distance you are willing to travel. Then inquire by e-mail whether they have a car that comes close to what you are looking for.
    Let me know how it goes. I have a few other suggestions if you find a car that comes close. And there's always the possibility of locating one somewhere else in the country that may have an abundance of CVTs, making a good deal on one and then having it shipped to you. I'm considering doing that on an allroad but I don't know if you'll be as successful with a "stripped" CVT as you'd have to make out "much" better on the deal than what you could get one for locally compared to what the cost to have it shipped will be.
    --'rocco
  • toast99toast99 Member Posts: 4
    I am planning to purchase a A4 Avant (1.8T 5 speed). I am looking for input on the ride quality of the sports suspension. There are few Avant 5 speeds around here and no sports packages. Of course those 235/45's aren't exactly Minnesota winter driving tires. I am assuming there are viable after market choices (for the suspension)and what have/do you enthusiasts tried/suggest.
    Is it possible that you could order the car you want or does your situation require that you "buy off the lot?"
    I thought most Audi's -- even to this day -- were ordered, not bought off the lot. Of course, I am old (51) and have only purchased one, maybe two Audi's off the lot (out of two dozen that I have owned).
    I would want the exact car of "my dreams" at the moment. Hence I order, usually at least 6 months to a year in advance.
    Now, having said that, there are plenty of aftermarket suspension upgrades -- see European Car magazine or go to Audiworld.com and use their excellent search engine to find aftermarket suspension upgrades. And it is possible that A/S high performance tires are available, but my guess is that you need dedicated summer and winter tires -- correct?
    A question for Mark and others with the v8 engine.
    It is just amazing the dif between the air on and off w/ the 2.7T tip setup. With the AC on, it appears to drag the whole car down until about 65mph. Of course, even with the AC on, I can easily cruise at over 100 mph, it just seems like it takes twice as long to get there!
    Do you notice that much dif w/ the v8 on take-off, at an idle, and general all-around driving with the AC running? Thanks-Max.
    I notice NO difference whatsoever with the 4.2 engine. But -- I must say that I was under the impression that the compressor is always on except when you turn off the climate control system altogether. In over 30,000 miles I have never turned it off, I set it at 67 degrees F and let it do its thing year round.
    So, does this mean that the climate control in the 2.7T acutally turns off the compressor
  • lauk0dglauk0dg Member Posts: 563
    My girlfriend has been telling me it feels a lot drier inside my A4 on a humid day even when the exterior is listed as 75F and I have my climate control at 72F. I think Mark's right, the compressor on my A4 stays on when the climate control is working unless you put it in ECON mode. Another proof was that the car feels slightly faster and hence lighter with the climate system off.
    Billy
    Well, maybe not yet -- but as you may know I have ordered a 2003 allroad 2.7T with the 6spd manual -- because I want a manual transmission and the allroad 4.2 is auto only and at this point in time the new S4 isn't for sale, etc etc -- and I did want to stay with a car about the size of my A6 4.2.
    Now I read that the 2.7T -- which is supposed to be the quickest of the US Audi's is sluggish with the a/c ON?
    I can't win -- the 4.2, in my opinion, needs a stick shift -- none available, not even on the S6 avant. No V8 or 2.7T currently available in the A4 body --
    Why can't they just sell us what we want?
    Yes,w/AC on, a big difference in take- off. Even at idle it seems to work harder than w/ system in OFF. Climate control does seem to engage the compressor, heat or AC, and hence slow the vehicle down to some degree.
    Engaging the compressor seems to rob the engine of noticeable "get up and go", and of course increased gasoline usage.
    I don't notice this as much w/ my naturally-aspirated v-6 Toy camry. Maybe this has something to do with the turbo's?
    There was no spoiler lip on the rear but there was a "1.8T" badge. Perhaps Laser Red is back in the A4 spectrum? I sure hope so.
    Sorry I can't be more helpful on this 2.7T motor failure business. I saw some posts about here on TH or at AudiWorld.com (their forum format leaves a lot to be desired IMO).
    I have read plenty of raves about the 2.7T -- I wish that there had been a 2.9T, apparently the 1.8T and the 4.2T and the 2.5TDI will be enough engine (for the US anyway) choices.
    Actually, I plan on a mild chip in my new 2.7T allroad.
    The new S4 looks great, in fact I say too bad it is NOT a turbo -- I think a turbo 2.9 would have been great, then a turbo 4.2 is the RS4 would have been fantastic.
    But, then again, as my friend says: there's no replacement for displacement.
  • sonnyburnettsonnyburnett Member Posts: 1
    Been negotiating to purchase this for a week now, with the South Florida dealers the Collection, Braman, Prestige, and Champion.
    Invoice is $27,048, MSRP is $29,661. Have them down to $28,150. I think it's a decent deal, but wanted some input from the fine folks here before I seal the deal.
    Also, the "Premier Purchase" plan is intriguing. Does anyone have any experience with it as a way of lowering monthly payments/tax implications, etc..
  • dpvwia2dpvwia2 Member Posts: 11
    Quick follow-up to the xenon discussion. Yup, the bulbs themselves should last a long time (barring any defects), but the high voltage converter ($200+) required to run these babies is an extra part that can go bad. Mine new A4 lost one the day after I brought it home; of course, it was quickly replaced; but if it were just a bulb, I could've done it myself.
  • tmcktmck Member Posts: 28
    It finally happened. After 12,600 miles my check engine light came on as I was backing out of the garage. It was also blinking. I drove a few miles and returned to home. Monday morning I called Audi service which is in a town about 85 miles away. They told me not to drive it so I called Audi roadside assistance and a after a few hours and lot of communication, the flatbed truck took my Audi away. About 3 hours later the service mgr called and said they had it fixed. It was a bad ignition coil. When I called initially and told him about the check engine light blinking and the car running rough he suggested it might be the coil as if it has happened to others before me.
    I picked up the car last night and in the process looked at some new A4s on the lot. I had not wanted Denim Blue as a color initially but now I think it is Audi's best color for the A4. On the way home I averaged about 32 mpg with the 1.8 and Tip. Not a bad experience at all. Still love my Audi.
    about coil failures at audiworld.com. Apparently you're one of many. I'm not sure if it's peculiar to the 1.8Ts or if they're having
    coil troubles with the v6 motors as well.
    Good luck with your new A4, I'm sure you'll continue to love it.
  • mejjbishopmejjbishop Member Posts: 3
    Does anyone know if the 03 A4 3.0 CVT has the radio controls on the steering wheel?
  • dbugbeedbugbee Member Posts: 18
    Does anyone know if Audi will ever offer CVT
    with their Quattro models?
    They're working on it. Supposedly it is another 2-4 years away.
    I don't think so. It's a feature lacking in A4's, unfortunately.
    (even the new 03 Accords have them)
    Billy
  • srhomsrhom Member Posts: 7
    As I mentioned in an earlier post a few months ago, a coil pack on my 2001 1.8T failed, leaving me without one cylinder (really rough engine, check engine light on). The closest dealer I could get to fortunately was only 4 miles away, and they later told me all four coil packs were replaced plus all four spark plugs, per Audi's direction (all under warranty). I wasn't pleased with the one failure (had the car less than a year, a few thousand miles), but the repair was done in a day and I'm happy all four cylinders are now taken care of (supposedly). Looking down the road I'd like to hang on to my Audi after the original warranty expires, but I'm nervous about a potential whopper of a repair bill that I read about every now and then. Anyone know what's the best extended warranty out there? If Audi made cars as reliable as my 1985 Supra (still going strong), I wouldn't worry about an extended warranty, but I'm nowhere near convinced that that is the case.
    Don't worry, this is not another "which one of these should I get," but just a comparison of a friend of mine. He has a 2002 A4 3.0Q w/ 6 speed and his sister recently purchased a 2002 BMW 325Ci w/ Steptronic. Both cars are equipped with Sport Packages. He drove his sister's car last night and I just wanted to pass his observations & comparisons on to the board.
    He was suprised at how strong the smaller 2.5L I6 was as compared to the 3.0 V6 in his A4. He said with some miles on it and a stick that it could probably run with his 3.0 with no problem. He said the 330i must be like a road rocket and can't imagine how fast an M3 is.
    He likes the interior of his A4 MUCH better. He said the monotonous orange lightling in the BMW is somewhat distracting and discomforting to the eyes. The A4's interior lighting is spectacular. The BMW is a snug fit for him. Now granted he's 5'7" and weighs somewhere around 240lbs, but he's much more comfortable in the A4.
    He said the steering in the BMW was much heavier and more precise than in his Audi (he still thinks the Audi's steering is great though).
    As far as ride quality goes, he said his A4 actually rides rougher. That may have something to do with the fact that his tires have 20K on them and the BMWs tires are obviously brand new.
    So I asked him the obvious question: If you were shopping today, which car would you pick? Hands down he would take his A4 3.0Q 6 speed. He loves the unique look of his Amulet Red, SP equipped A4 as opposed to the ubiquitious 3 series which are all over the place in Connecticut. He says if he was shopping a 325i vs an A4 1.8T, he might have to reconsider. He said if the 1.8T were available with leather and the wood trimmed interior it would be closer, but as of 2002, he'd take the 325i.
  • uwscarguyuwscarguy Member Posts: 40
    I have driven the A4 with the 1.8T. I really didn't like it. Even though the car was equipped w/ Tiptronic I felt that while the low end torque was decent, the car really ran out of steam at highway speeds.
    Granted, the car was a loaner and I was comparing it to my A6 2.7T (I don't want to be unfair since the two Audis are obviously at differing price points), the 6cylinder in the 2.5 BMW is nicer. Advantage to Audi, however, in offering a true sport suspension for Quattro whereas BMW doesn't (or at least didn't in 2001) offer a sport suspension for their iX line.
    IMO, NO OTHER car company comes close to Audi interiors. Whether it's lighting, materials, design, or thoughtful touches, they are masters.
  • tiredofmanualtiredofmanual Member Posts: 338
    The A4 interior was a major factor in my decision to buy an A4. It certainly isn't perfect. Where do you store your sunglasses? I use that spot underneath the armrest, but it isn't ideal. What about cupholders? The A4 cupholders are terrible. Now, I don't allow eating or drinking in my car, but I would like to be able to bring a quick meal back to the office without spilling soda all over my radio. And what if I need to bring back two sodas? Put the second in the armrest and hit it with my elbow every time I shift or turn the wheel?
    My last car was a Focus, and it had acceptable cupholders. I didn't get the smoker's package, so instead of an ashtray my car had a felt-lined tray that fit a pair of sunglasses perfectly.
    If you want to see the direction Ford is heading with its interiors, check out the concept for the C-Max (the first vehicle to be made off of the next-generation Focus platform). VW/Audi is going to be getting some competition!
  • bimmerpilotbimmerpilot Member Posts: 17
    From my monikor I'm obviously a BMW guy but I've liked the A4 since it came out. I've driven a few and almost bought a couple. The thing that has kept me in BMWs regard the out of warranty experience with Bimmers. First off, I generally like to buy clean low mileage used cars from the original owner. I've often taken BMWs from a year or so of the factory warranty out to over 150K miles. They are fairly easy to work on, don't break very often and membership in the BMWCCA gets anyone 25% off factory parts. Also, BMW's straight six motors have been amazing.
    Our problem is that we live in snow country and my wife really wants an 5 spd A4 Avant. Aside from my normal purchasing habits I like the look of the old body better on the A4s. Around here it seems like all the used A4s being sold are out of warranty. Many of them right out of warranty. Is Audi ownership that bad? I'd like to know how fequently these cars need work. How is longevity on the motors? Of the 4 and 6 cyl. which will last longer? Is there a Audi club that compares to BMWCCA? Would you own an A4 with no warranty?
    To be honest with you, and this is just my humble opinion. The only car on the current market that I would keep way past warranty are the corolla and civic. Anything else, I don't feel so comfortable. With Audi, the biggest concern you will have after warranty is the turbo, if you get the 1.8T or the 2.7T, and then the transmission and drive train. Those will concern me the most. Not because they are not well designed, but just the nature of the beast itself. Hopefully others could comment further.
  • JBaumgartJBaumgart Member Posts: 890
    Our '98.5 2.8Q is out of warranty, at about 53,000 miles. It's held up really well, and except for one tiny scratch on the side (which I haven't gotten around to having repaired yet) it still looks brand new, inside and out. The only major repair (about $600) was when the front suspension (control arms or bushings (?), I forget) had to be replaced, which I guess is not unusual on these cars. I understand this is because Audi does not make them serviceable (cannot be greased) and eventually they just start to squeak.
    I agree with dtwleungnyc about the transmission and drive train being the main worries, but this would be true on all cars, it's just that the more expensive European brands cost you more when something does break. But based on our ownership experience so far, I feel pretty comfortable owning this car past warranty, as I know that it's been extremely well maintained, and still has a real solid feel all around. Most longer-term cars that I've owned previously have felt a lot more "broken in" than the A4 does at this stage. It's still very tight with no rattles. My experience aside, I have to admit that I wouldn't feel very comfortable owning any Audi, BMW, Mercedes, etc past warranty if I were broke and living from paycheck to paycheck...these cars are not for everybody and without a warranty in effect you obviously need to have some money put aside in case the unexpected happens. I disagree with some here about this, but I still think that assuming proper maintenance it's cheaper owning cars over a longer period of time than buying/leasing every three or so years and making sure your car is always under warranty. This is considering all expenses, including interest, depreciation, taxes and insurance. If you can set aside the equivalent of six or so new car lease payments, you should have enough cash to take care of most problems that might come up. My own philosophy has been to buy my cars with cash, which I've done with our last five vehicles, starting with a '90 SHO, a '91 Eclipse GSX, a '94 Grand Cherokee, the '98 A4, and our '01 allroad. All of the first three were driven well past warranty, and I've never incurred a repair that cost more than six payments worth (a little lucky, maybe). It's a little ironic, but my most expensive repair ever (in today's dollars) involved my very first car, a '67 BMW 1600 (precursor to the 2002) which at about 110,000 miles needed a valve job - cost more than what I PAID for the car when I bought it at 70,000 miles!
    P.S. I also agree with you about the older A4's styling - it's a very classic look. I don't dislike the new styling, but it didn't get me excited like the original did.
    Gene-- Yes, buying clean low milege used cars from the original owners is definitely the "smart" way to go when it comes to making the most financial sense. I also agree with Joel in that keeping and meticulously maintaining a car over a long period of time as opposed to leasing or trading a car in every three years, is IMHO definitely going to cost less in the long run. But some just want the luxury of having a new car every three years and this is fine too if one can financially afford it. When I was younger, my goal was to keep a car at least 100k miles but hardly ever reached that goal in any car I owned ...it seemed that I just got itchy for a new car when I put on somewhere around 60k miles on it. Now that I'm older and more financially able to justify the extravagance, I'll probably start to turn cars over at even a more rapid pace.
    I don't know if I would totally agree with David's comment that the only two cars worth taking a chance on keeping past the warranty period would be a Civic or a Corolla. I think many Japanese cars would be worth taking a chance on keeping over a long period of time ...including Nissans and Subarus. I know many --and I mean many-- people who have kept Nissans and Subarus as well as Toyotas and Hondas for well over 150k miles and/or ten or more years with none or very little maintenance expenses incurred other than routine scheduled services. I have a close friend who bought a new Datsun 200sx and rarely had it serviced. She didn't pay any attention to even changing oil regularly but kept that car for over 15 years putting over 250,000 miles on it with virtually no major repairs. I still shake my head over that! I don't want to turn this into another Japanese reliability debate so I'll drop the subject for now. *chuckles*
    As far as Audi owners having a club similar to the BMW CCA, I believe the former Quattro Club of America which now is called Audi Car Club of North America, is the equivalent to Audi owners as the BMW CCA is to BMW owners. They do offer member discounts on parts, etc. but I'm not familiar as to the details. I think Mark is a member. Maybe he can respond. In the meantime, you can peruse their web site: http://www.quattroclubusa.org/
    And yes!, there are many of us who prefer the old B5 platform A4 over the new B6. For me, the original A4 Avant is one of the cleanest and most beautifully designed wagons ever made! Although I must admit, I am considering trading in my Subaru Forester for a new '03 A4 Avant ...or an allroad if I can talk myself into it. :P
    --'rocco
    The reason I mentioned the corolla and civic only is due to this. These two cars has fewer gadgets that could go wrong when compared to other cars on the market. I am sure there are other cars on the market that could go 10+years or 100K+ miles without too much major problems, but if I have to put my own money down, for a long term car with the least likely problems, it will probably be the corolla and civic. FWIW, my mother in law is still driving her 88 dodge aries K, other than the AC not working, the car is still running fine. Go figure.
    David-- ah yes, I understand what you are saying. "KISS" obviously comes to mind when talking about the longevity of anything mechanical ...or even some electronic components.
    I like the fact that more manufacturers are starting to use LED brake (and tail lights) for example. Longevity of LEDs will far surpass that of the traditional filament bulb not to mention the added performance of the lights illuminating faster.
    But how many of us want a car with few "gadgets" in this day and age? ...after all, gadgets are what makes a car desireable to most of us. Sure, we can do without, say, a heated steering wheel but I'm sure it really makes it nice on those cold days. I'm sure cars will continue to have more gadgets either as standard equipment or options as time goes on. Remember when A/C was considered a luxury item? (ooops, now I'm admitting how old I am). Now it's standard on most cars.
    Speaking of A/C, the only vehicle I've owned that didn't need major A/C repairs or total replacement was my Toyota 4Runner. It's A/C was still blowing strong 16 years after purchasing it new. It never even needed a recharge during that time and I even used it extensively during the winter.
    So anyway, I didn't mean to imply that only Japanese cars could go years and many miles past their warranty periods without major repairs. I'm sure that many domestic and European car owners could attest to the same results. It's just my opinion that a larger percentage of Japanese car owners will give glowing testaments pertaining to reliability than those who own domestic or European cars. No flames please. *smiles*
    --'rocco
    My extended coverage ran out @ 75k and the only expense has been replacing an electric fan motor
    (appx $230). I have confidence in this car ('98
    Avant Quattro 2.8 w Tip) and plan on keeping it past 100k.
    I am concerned about the possibility of expensive repairs if something should fail on the trans or drivetrain but I think if I keep on top of maintainence I'll get my money's worth out of this great car (bought used CPO).
    The newer styling didn't grab me off the bat like the old did (I still remember the first A4 I saw) but I'm anxious to try the new one, the styling is growing on me. Audis make everything else on the road look old fashioned.
  • shehzadshehzad Member Posts: 52
    I just went to an vw dealership today and saw a 2002 A4 for sale that was offered at an excellent price. It looked fantastic but it had one problem--that the dealer also disclosed. He mentioned that it had been "bought back" from the original owner by Audi due to an ignition problem and then fixed and was now being resold through the vw dealership b/c they bought it from an audi/vw/porsche auction. Any thoughts on how much I should pay for it. IT's a 1.8t ming blue, cold weather package, sunroof, homelink, tiptronic, 16inch alloys--he's very firm at his asking price of 26700, and it has 9000 or so miles on it. It was one of the first manufactured 2002's--made in september 2001---and it's still covered by audi's warranty--it's just that, as much as i like the car, I can't help but wonder if I'm buying a problem car. Any thoughts? Thanks-Shehzad
    I'd be cautious - it would make me wonder why Audi didn't keep it and sell it as an "Audi Assured" car. Maybe there were other problems that have not been disclosed, and the problems couldn't be fixed by a simple ignition replacement? For Audi to agree to buy it back I would think that there were some serious issues that could not be easily resolved to the original owner's satisfaction. I don't think the price is attractive enough to justify taking the risk. On the other hand maybe there's a good explanation and the problem(s) are gone, but before I took the plunge I would want some assurances, like maybe a good reference from the Audi dealer which decided to dump it at auction.
    New cars which are billed as pristine can be enough of a headache. One which is ostensibly a lemon already smells like nothing but trouble. Look elsewhere.
    With at least one known (kinda major cuz if it happens again, you are going absolutely nowhere) problem, and that the price is not THAT much cheaper than a problem-free used car with 9k miles, I would NOT buy it.
    My $0.02.
    Billy
    it might be worth a chance but @ $26.7 it's way too pricey. You could get a similar CPO for very little more, if any.
    I agree with most of what's been said so far. I have to wonder why the original Audi dealer didn't keep the car for resale. Unless there is a stipulation from the manufacturer or some stragegy on the part of the dealer not to keep a refurbished "lemon" or a buyback to be sold on the orginating dealer's lot, I'd have to believe that this car would be an excellent choice to be resold at the same dealership.
    An "ignition problem" could mean many things. I'd want a full idsclosure on just what the recurring problem was and how it was resolved. For the original owner to demand that the car be bought back and Audi agreeing to do so, there had to be some major problem. I'd want some documentation as to how this problem was resolved ...if it was resolved at all for if it was, the original owner probably would have been satsified and in all likelihood, would have kept the car.
    Here's where I might disagree with the comments of the previous posters: The price itself doesn't really sound all that bad. Using the Edmunds configurator, the MSRP new was $31,220 (assuming it's quattro and you listed all the options correctly). The KBB "Blue Book Private Party Report" configured with the options you gave came to a whopping $30,310! The KBB wholesale came to $26,905. So yes, if it were an absolutely "clean" CPO, then the price you were quoted would appear to be excellent. I'm impressed at how much value is retained on a year old A4! *applauds* I doubt you could find a similar car with that mileage for that price. IMO only.
    --'rocco
  • mikosmikos Member Posts: 6
    I'm shopping VWs and Audi A4. With respects to the A4, anyone have some solid info on just how little over invoice the average dealership will go. I'm interested in 1.8T 5SPD with Sport Suspension and Gray Ext. Invoice is at $24,500.00. I heard that I'll have to go as high as $26,000 to do the deal.. $1500 over just sounds like a lot.
    Secondly, for kicks and grins and if you haven't already.. go drive the VW VR6 6SPD either in the GLI Jetta or the GTI.. Oh my gosh... scary fast! 200HP, 195 Torque! I'm actually considering a fully loaded GTI with climate, leather, heated seats, 6SP, VR6.. pretty much has every bell an whistle. I'm just drawn to the serious heart race the car generates.
    My sensible side says get the A4 for many reasons.. now for the commentary part. In response to A4 3.0Q vs. BMW 325i and the part where the 1.8T is concerned. There are several high-end tuners out there, Wetterauer comes to mind who offer an ECU upgrade for the new 1.8T. HP increases to 205 and Torque to 250! Mind you, you're advised to swap your air filter for a K&N or RAM AIR, and not to full throttle for hours on end... but you'll smoke most of what's out there. The primary complaint that's addressed is the low end torque. If you take care of your wheels.. it's a $500 investment that shouldn't be overlooked.
    Any info on the invoice inquiry is greatly appreciated!
  • jaydolljaydoll Member Posts: 120
    The 1.8 is a great engine but, the 3.0 is better in every which way except the price tag. The 3.0 with the 6 speed will pull from from very low rpm in 1st to well above 4k rpm. Also, with the 6 speed, at a cruising speed of 60mph, yopu are doing a bit over 3k rpm with the 3.0/6 speed. In the 1.8T/5 speed you are reving at 4kpm. Now with regard to the above comments concerning the bmw 2.5/5 speed combo being very close in performance to the Audi/3.0/6 speed, I compared both the 2.5 and 3.0 bmw real wheel drive both with sport package and 5 speeds to the Audi 3.0 /6 speed. I felt that the Audi and bmw 3.0 models were close but keep in mind that the bmw didn't give you all wheel drive, which added weight to the Audi. The 2.5 is a dog engine that felt very slugish and it ran out of steam very quickly. I think that the 1,8T vs. the 2.5 is a much more fair comparison.
