I used a friend's 2001 Odyssey w/ NAV on a Niagara Falls trip last year and it was pretty good. Is the 2005 better?
I have a new Odyssey with the DVD/Nav system. My question is about the audio system. It seems that the CD player and the XM radio can't be played simultaneously in the front and back. If I'm listening to XM in the front and someone tries to listen to a CD on the headphones, an error comes up on the screen saying that "the system is locked, please pay a different source." Has anyone else seen this? Any ideas? Also I'm confused about XM1 and XM2, I thought that the reason there are two XM sources is so that people in the front can listen to XM1 and people in the rear can listen to XM2 on the headphones. But, when I switch the XM source in the front it also switches the rear. Any thoughts?
Carson
Strange but true!
Carson
Were you finally able to get your problem resolved? I am very very curious to
know as I have just purchased a 2000 Honda Odyssey and I am about to order
a verision 2.2 Nav disc from Honda dealer. After reading your mail, I wanted to
be absolutely sure before I attempt to do anything.
Thanks...
Press on the time while at the shutdown screen.
how does that work for the 2005 touring odessy?
The navigation system alone in my wife's '05 Pilot was a $2000 premium and is about 2 generations behind the one in the Odyssey. It was, relatively speaking, a poor buy. The voice commands do not work particularly well - the system misreads me at half the time.
Bottom line - the R&N package is well worth the money. Besides, from what you say, you want it and you will be driving the vehicle. Tell your husband he can decide such issues on his own vehicle.
http://gpsinformation.us/main/gpsauto.htm
Have you contacted Honda yet reference a European or Germany based DVD for the Navigation system. I plan to ship my '05 Ody in a couple of weeks and Germany based disc would be great. I've had my van for 9 months and we love it. The navigation gets a little laborious at times but its still a great system.
I really like the navi system found in my Acura.
Questions on the Odyssey Navi:
1. How are they different, or are they the same?
2. Some navis don't allow input while the car is moving. I realize this is for safety purposes, but I don't like it. I assume the Odyssey navi allows for input when the car is moving?
the DVD entertainment system. Looks like Honda's options need to have both.
Does anyone have any experience with an aftermarket Navi that's close in
quality to the original? What's the cost? Any waranty consideration that I should
take into account?
Thanks in advance in sharing your experience.
It didn't! It seems that the DVD player in the car is a region 1 player as is the DVD that came with the car.
The DVDs in Europe are region 2 (which can't be read by region 1 players).
What is needed is an all region DVD or a means to convert the US DVD reader to an all regions reader.
Hate to tell you, you probably aren't going to be able to use the Nav system here. U thought about buying a European DVD reader for the car and buying the European DVD, but since the DVD itself is @400 euro ($500,00) it would probably be a $1000+ proposition.
Good luck, of you find a way to make it work..please post it here.
http://www.lowrance.com/Automotive/Products/iWAY500C.asp
I am really impressed with the support and map availability
I found after market NAV which is same tech & look of GPS
chech it out.
http://www.eclipse-web.com/
Also on any destination, you can select a preview on the sienna which actually goes along the entire route on the screen using the scale you selected as if you were driving it. It is nice to see exactly the entire route before you leave. I also don't see this on the odyssey. Again, comments?
Is there any way to notify Alpine or Honda to see if they would add these features?
Pioneer also makes a decent one AVIC-D1.
It all depends on aftermarket head unit trims. There is none currently for the Honda odyssey although a dealer can custom build one at a reasonable price.
The quality is better in both these units than Honda's. Honda comes with a voice recognition as these do not.
Warranty - Just make sure the installers do not cut any of the original wiring. I hear that you can also have the installers bypass these units to have the option of navigating during normal driving.
You should be able to get the pioneer installed for approx 1400 or less. I'm not sure about the ECLIPSE.
Hope this helps!
CHRIS
Does anyone know of a way to re-set the password, or eliminate the password requirement?
Another alternative: did the previous owner give you the radio security code? It ought to be on a sticker somewhere (maybe stuck to the inside of the glove box) or written down. If so, there should also be a Navi code. These are used to reactivate these systems if the battery dies or is disconnected. So if you have these codes, you could disconnect the battery, and it should forget the password, as well as all entries in the address book and previous destinations. Then you give it the security code to reactive the system after reconnecting the battery.
I wish the Navigator had some sort of USB interface so it could be controlled or reset.
Subha
THANK YOU.
OSORIO1
We like to keep feedback here in the Forums, rather than in email -- that way everyone learns from the answers. Also, typing in all caps makes it look like you're shouting, so you might want to take your caps lock off. :-)
I'm planning on purchasing the 2005 update disc (version 2.3) when it comes out in January... What is the actual update procedure? Just put the new disc in and it updates itself? Do you only have to reset the system if you're going "down" in revision level?
Thanks in advance!
-Joshua
Thanks in advance for any help.
Jeff
