The voice commands controls the NAV unit plus A/C, radio, DVD, XM, etc. One of my favorite feature on it is that you can say "Find nearest ..." (So if you say Find nearest fastfood, then it shows you a list of near by McD, Wendy's, etc). The manual shows about 700 commands (but lots are repeats like Find nearest blah blah though) To me, the voice commands provide very convenient shortcuts while driving but I still perfer entering destinations by the touch screen.
Hope this helps.
Mike
06 EX-L NAV/RES
I also think the POI's are more limited than my old Garmin 2610, but I've not met a factory NAV was better (in terms of POI's). The integration of the Honda NAV is top-notch though. Better than my wifes Lexus IMHO.
That's a file that will give you detail/diagrams I believe. That's where I worked from.
So I assume on a closed highway, it will probably reroute you to the next ramp, and if the road is still closed, you will have to just do another detour again and again until you reach the section of the highway that is open...
:mad:
For example, you embark on a trip to a specific destination address. You begin to follow the systems route but you periodically change the path along the way to match a slightly different and preferred route.
Upon reaching your destination, you add the destination to the address book.
Will the system remember your alterations and take you on your favorite route the next time you target that address or will revert back to mapping a route the system prefers?
I recently purchased a '06 EX-L w/ DVD/NAV.Unfortunately, the Nav does not show a new highway that has been open for about a year where I live (the sys stops where the old highway was and keeps doing a search-like its lost). Does anybody know how to update the system or are there periodic updates where new construction is added to the Nav map or is there a way to manually enter the new highway to the Nav sys? Just curious.
http://www.gnetcanada.com/navvideo-models-gnet_rgb_hondaacura20.asp
Also, I never heard if anyone has traveled with a storage box on top of the van which might cover/block a portion of the GPS antenna and how it effected the NAV's accuracy.
Also, does anybody know how to change time? Time on my NAV is 4 hours off. Is it even possible without a NAV disk?
1. I read that the Map data only covers some major cites and highways/routes in small towns. It also sounds like it depends on the small town to how much data is available. I am moving to TX and saw that South Paudra island is on the list. Is Corpus Christi included in that map data? That is where I will be using it along with driving to San Antonio TX. Anyone use it in those areas?
2. After market Nav systems. I understand that the Nav system costs about 2K. I was looking at the AVIC-N3
In-Dash DVD Multimedia AV Navigation Receiver
Suggested Price: $1,800.00. It can be view at http://www.pioneerelectronics.com/pna/product/detail/0,,2076_3151_295503034,00.h- tml
It has a couple other items that I was interested in, like XM radio, Teles Map data that is update able, and it has an Ipod direct access hook-up. Question is if it is installed by a professional does it void any of the Honda warranties?
As understand it has a better us a speed because the unit needs to be hooked up to the speedometer.
Thanks for all the insight to the Honda ODy w/ Nav and I can't wait to purchase one.
The system does allow you to pick a preferred type of route (e.g., maximize freeways).
Don't forget the factory NAV adds quite a few extra features in addition to just the NAV. You also get: Backup camera, voice activated audio/nav/climate controls, fully functioning XM, and touch-screen audio. The antenna is also color painted to match the exterior and includes the XM antenna all inone.
I hope this helps.
Tom
I believe 4.31 is the latest NAV version on the Ody. Check your CD to see what you have.
There are so many restaurants, gas stations, etc. that are not listed in my area. There is a gas station near my house that was built 6 years ago and the NAV cannot find it. I live in suburban Philadelphia so the coverage should be complete.
Also, I having about 10% success rate with the NAV voice commands. "Find nearest gas station" usually turns the radio off or AC on.
My dvd version is 4.31.
When I pick out the street (misspelling) from the list and then enter the house number, the NAV shows my house about 10 houses up the street.
The wife will be very angry about this b/c she does not want the NAV in the first place.
Whoever have Odyssey or other Honda cars, they better check the house number first before ring the door bell.
It is frustrating when you're looking for something that's been there for many years. I use mine a lot for phone numbers and get frustrated as well at times. It's pretty much par for the course though with any NAV system.
As for voice commands....I've found if the radio is on or the HVAC blowing very hard, it doesn't respond well. You also have to be careful if you have an accent. I personally don't use voice commands...I just don't like talking to inanimate objects. I don't use the voice commands on my cell either.
Tell her to pretend it's not there. No reason she HAS to use it. Problem solved :P
Last week I took the dvd out to check the version for the first time, I saw it has alot scratches already.
Did you use +R or -R dual layer disc?
Thanks for any leads.
jmp
jmp
My mechanic checked all the wires, replaced the one sensor from the nav to the trans twice, and took it to Honda directly when he couldn't figure it out. They checked all the wiring, etc. too, and then said we had to buy the DVD upgrade before they could look any further. I disconnected the unit, removed the DVD, etc. trying to get the unit to reset, but nothing corrected the problem.
Problem is it's a 2000, and after the cost of the trans, I'd rather not pay for the upgrade if I don't have to. The unit worked fine all this time, until the trans repair. Anybody have any ideas?
Thanks, Dave
please help me what can i do. if i will buy canadian CD , how does it will work with my US odyssey.
thank
Stop by a dealer in Canada and ask nicely if they would pop it in the ensure it works before you buy it. If they agree, buy it from them
Good Luck.
i bought 2002 honda odeyssey. but the seller did not give me the Navigation manual. if any body have that manual then please send me the pdf. file for this. i really apritiated.
One section of CA-58 was new (built several years ago) and with my old Garmin V map, it'd show that route as off route and not on the map.
The Ody NAV on the other hand mapped it out clearly.
I've read somewhere that some people with older versions would see this section as off route.
So I guess version 4.31 has a newer database despite the date??
Can someone drove this road before comment?
