Dodge/Plymouth Neon
1222325272832
  • littleblueneonlittleblueneon Member Posts: 1
    I HAVE A 95 DODGE NEON AND I NEED TO KNOW HOW TO WIRE A KEYLESS ENTRY SYSTEM AND HOW MANY RELAYS I NEED FOR IT
  • faroutfarout Member Posts: 1,609
    neo763: I have had three neons; a 96, 2001,and 2004. My 96 now has 175,000 miles on the orignal engine. The 1996 is the only one that has needed motor mounts, several times. The one in the front seems to need replacing about every 80,000 miles.. For some reason this one takes more of a beating from curbs, and rocks, and parking lot stops. They are not cheap as you say, I paid about $125. installed at a local garage in Sept. 04. The mount came from Napa, which you already said. You are not alone. But the Neon keeps going and going.
    My 96 Neon has 175,000 on the orignal engine. I have learned the hard way this engine does not run well on Split Fire plugs, the SOHC is not designed for Platinum plugs. The best plug is the OEM Champion plugs, and change them at 30,000 miles and the spark plug wires at 60,000 to 75,000 miles with Mopar. I tried two other wire sets and they just did not fire as strong and interefered with the radio. The biggest thing is the timming belt at 90,000 miles and replace the water pump with a new one while doing the belt. The 96 also had head gasket problems and if yours worked out as mine did, I had the belt and water pump changed at the same time and my cost was only for the belt and pump. Hope this helps.
    We got our 2004 Neon SXT late July 2004. We have almost 22,000 miles on it now. The only thing done has been reseting the left tire rod was not done correct at the factory, and that was done at less than 1,000 miles. This is our 3rd Neon, we still have a 96 with 175,000 miles on it, and we had a 2001. Of all this 2004 is the best. The four speed is nice,but shifts rather awakwardly at times. We have goten as high as 33 mpg and avrage is 28 mpg. That's quite a bet better than Consumer Reports says! They claim 24 is Neons best, well our 96 still gets 30 plus mpg.
    The only thing I find distracting is the solid black seats and doors, dash and interior. They show dirt real easy. The seats clean up real easy. The car is comfortable even on long trips. The interior is noisy and the engine is also, wind noise is less than the older style. But when on a cell phone it's not as nice as our Jeep Liberty.I kept the "Bad Year Tires" just long enough for a tire shop owner friend to order me a set of Cooper tires.
    The 2005 is suppose to be the last year for the Neon. However that remains to be seen as the replacement looks like a crossover something like a hatch back and a Derango type front end. Time will tell.
    I think Chrysler should fire the idiot that is designing these "low rider" "chopped top" station wagons and this "old Charger". Heck we have had all the station wagons and fastbacks to last a life time! When will Dodge build a sedan that's got lots of back seat foot room, and looks like it belongs to the twenty first century?
  • arcadefreak36arcadefreak36 Member Posts: 49
    Thank you for the update. I purchased Mopar wires on eBay for $22.99 plus $7.99 shipping and picked up the OEM Champion Spark Plugs at Autozone for $8.00 and my Neon runs tops. I called the dealer about the timing belt. I am at 75,000 miles. They told me I could wait but the entire job would go for $800.00, which was a little steep. I called my mechanic and he said he could do the same job for half the price the dealer wanted. I'll be doing this job in the fall when I have the money. Thanks again.
  • micwebmicweb Member Posts: 1,617
    I think the manual calls for a change at 100,000 miles or thereabouts. Check the manual or use the Edmunds maintenance guides, which are great. Unless the car is a manual transmission, the timing belt is probably safe out to about 130,000-160,000 miles (no "popping the clutch" or wild downshifts with automatics). It is a critical replacement, and so the manual recomendation is actually conservative. I wouldn't go past the manual recommendation, but I wouldn't feel a need to do it earlier either as a precaution. The belts have improved a lot over the years, and there is a lot of statistical evidence on belt life for manufacturer's to draw on.
    I recommend shopping dealers since there are wildly different rates for this. Personally I'd rather have the dealer do this, they have all the proper tools, use factory parts, don't have to improvise, have good up to date manuals, and usually trained personnel. They also back up their warranty. One trick that sometimes works well is to ask which mechanic (or two) is good at timing belts and make sure that mechanic is on duty when you take your car in. You don't want someone who does a lot of brake jobs to substitute when the timing belt person is out sick. Or take it in on that person's day off.
    And believe it or not, it helps to show up early with a box of donuts for the crew.
    Thanks again for the update. I remember putting 103,000 miles on my 95 automatic SOHC Neon and traded it and never changed the timing belt before it was traded. I plan on keeping my 99 for 3 more years. I don't hardball her and 85% of my miles are highway. I've had her since August of 2004 and she had 45,000 miles on her. I figure by January I'll need to change the timing belt.
    You and I agree as to having the dealer do the job. Too often local small shops or even large ones are a general, attempting to do it all shop. When shops maybe do two belst a year, they may have a less hourly rate but when they take twice as long and get a cut rate timing belt, what is the savings there? I personally have the water pump replaced whit a new one while everthing is easily to get at. For struts, tires, and generally noncritical things I might use a general shop. At the Dodge/Jeep dealer, an oil change is $22.00 and a tire rotation and balance is $46.00, and that is a better price than most shops arround here.
    I have repeatedly said these dealers get griped at, and seldom get praise. I too bring something to say thanks, and let the service manager know I am please. This is a key to great service, and helps when you really do have a problem!
  • shymerm8shymerm8 Member Posts: 7
    I am new to this site but I just wanted to let you know tellie the 2000 neons are pieces of crap. We have one we bought it at 35,000 miles and it is in the shop every three months no joke. 2 months after owning it the speed sensor went out and when I took it in they said there was recalled part the break hose that was recalled several months before we drove the car off the lot. Since then we have had our cam sensor go out it lets the car know if it is on or off. Two window motors go out since they are power and a door go out power too. Then our battery so it was replaced but the dealer broke something so we were iding from 0-20 without our foot on the gas. So they fixed that problem they made. We has the timing belt and another one replaced and found out we were charged for these so called belts but they were not put on. So we stopped going the original dealer because the car already breaks down it does not need help.Then we replaced the brakes and found out our rotar had been eaten because one side of the pad was braking and not the other. So that's not a big deal because that is matance. But then we had our freeze plugs replaced because our car kept overheating and I could smell the coolant when I got out my car. My car has stared overheating again, 3 months after 600.00 worth of work for the freeze plugs done. So it broke down right on schedule I guess you could say. So we took it in and they told us it was not our radiator because they flushed it and tested it so it is good. They did say it was our radiator cap so a new one was put on. Problem is 2 weeks out of the shop and it is still over heating and needs new motor mounts at 84,000 the upper and lower ones and a new power steering pump. Which is quite funny because our pump has always sounded like that since we drove it off the lot and now we need a new one. It however is very noisy. No one knows why the car is overheating and now they are telling us it is our termastat what next our gasket ??? or the trans ??? Our car is a piece of carp and I wanted to let you know your not alone and warn people not to buy these cars.My best friend bought one too the same year and her trans went out @ 50,000 and now is going out again @ 80,000. So I am not alone in the fact that these cars are pieces of junk. I will never buy another dodge if my life depended on it. I'm so upset with mine I just want to scream. :lemon:
    oh i forgot to mention our cars feels like it wants to stall sometimes too. This has been going on the past 6 months we thought it might be a fuel thing so we used a fuel clearer. However it is still acting up it goes a little then it shakes and then drives a littke more and shakes it feels like it is trying to shut off like when the cam sensor went out the first time. Which is quite scary when your on the freeway and your car wants to shut off because it is not getting a signal that it is not on. This was the case when the sensor went out. It's like there is little power when my foot is on the gas and then a bust then a little and then a bust. That is best way to describe it So does anyone know what problems this is and why the stupid car is overheating ? :cry:
  • rick20rick20 Member Posts: 1
    yes i have the same proplem with my 2000 neon did you solve this proplem could you let me know i think it could be a short or could be the relay thank you
  • purplerosepurplerose Member Posts: 3
    Okay I have a Dodge Neon that is also a 00 and it is doing the same thing. And I have noticed the same thing concerning the weather conditions. Example in the mornings when there is dew, rainy days, cold days it is worse. I took it to get the brakes done today and talked to the guy at the garage about it and he said it sounds like there is rusty S pin in the door panel (p/s door) since that is the only door that acts up with the auto lock system. If I get any answers on this I will let you know and if you do if you could please let me know that would be great. Thanks
  • theatregirltheatregirl Member Posts: 1
    Hi!
    I also drive a 2000 Neon LX that does the exact same thing. When I am driving, the car constantly thinks the door is open and the light goes on and off. The doors also constantly lock and unlock, and this is all very annoying! To complicate matters, the passenger rear door lock makes this horrible sound when it locks. It drives me crazy.
    Anyway, I have a temporary solution. Please excuse my lack of technical car language; I have a degree in theatre and know nothing about cars. There is a "button" on the car that gets pushed in when the door closes. If you are in the driver's seat looking at the door, there is a "hole" on the left side in the middle that has a little latch in it. Push the latch up and close the door. This should help force the "button" into the car so that the car won't think the door is open. Also, this sounds cheesy, but if you cover the "button" with a piece or several pieces of duct tape, this also helps a great deal. Closing the door HARD also helps. I know this doesn't offer a long-term solution, but maybe it can help restore your sanity until you can have your car professionally looked at. I know I plan to have this done immediately after I stop being poor! :)
    Spark Plug Wires!!!! On a dry day, spray them with water using a spray bottle. If you see sparks then your wires are junk. Change them and your car will run the way it's supposed to be. :D
  • rick15rick15 Member Posts: 1
    The used Neon I recently bought just turned over 102,000 miles and the service engine light is on. I am sure it is something to do with the oxygen sensor or something along those lines, right? What do I need to do to fix this problem the correct way and reset the light? Thanks
    Rick
    Rick,
    Put your key in the ignition and turn it 5 times like you were going to start it 5 times but don't let it start. The check engine light will do a series of flashes and those flashes can be found in the repair manual as to what is wrong with your car. The O2 sensor is cheap money. I believe I paid $150 at the dealer to get mine done on my 95 when I had it. Also, Autozone can check your engine light problem for free. Once the O2 sensor is replaced, the check engine light should go out. If it annoys you then remove your negative cable on your battery for 5 minutes and put it back on and you will find your check engine light out. This is a temporary solution until you get the new sensor. :D -Rick
  • travisj95neontravisj95neon Member Posts: 1
    on the starting problem , i have a 95 plymouth neon and i am having the same problem but mine is because of the wire that runs from the internal fuse box to the positive battery terminal has a bad conection. try replacing it or rigging it to fit better.i also have the fuel gauge problem as well as a speedometer. i could use some help too
    Sounds a lot like a head gasket. Neons were famous for blown head gaskets from 1995 to 1999 but perhaps your Neon got an old one dur to a late build on the engine. It's worth a look anyway.
    Well said, I totally understood what you said without car technical terms lol. I am going to have to look into that door thing cause like you I am about insane due to the noise it makes. Today was a horrible day for the noise too :mad: I was ready to jump out of the car lol with it still in drive and just let it go. Thanks for the tip I will be trying that :)
  • johnniebjohnnieb Member Posts: 1
    I just completed wiring up the push button start on my drag Neon and decided to crank it up for the first time. The engine turns over and has fuel but I have no spark. The whole key ignition is gone but I still have a few wires. Does anyone know what wire or wires were getting power for spark when the key ignition was turned on? :confuse:
  • adamel111adamel111 Member Posts: 2
    I was driving my girlfriends 1997 neon on the highway when the spark plug on the 4th cylinder blew. I had it taken to a shop to be repaired. The shop told me that the porcelain part exploded and the other end was still threaded in the socket. He replaced all the plugs and installed a new ignition wire system. He couldn't find any pieces of the exploded spark plug and thinks they may be in the cylinder.
    I have driven the car on the highway 3 separate times now and it seems to drive ok although there was a little engine noise but that seems to have gone away now. The problem now is that the car does not start well. I have to press the gas pedal a bit when starting the car or it stalls. this was not a problem before. I expect there are still pieces of the spark plug in the cylinder. could they be blocking the fuel coming into the cylinder and causing the stalling problem? What other hazards are there about not knowing where the exploded parts of the spark plug are? the car has 119,000 miles so i don't think she wants to invest much money into the vehicle.
    any input is welcome.
    I can't imagine that the porcelain part of the plug is in your cylinder. Double check the plugs, gaps on them and also check your wires. Make sure they are all connected. It is possible that your coil pack is gone because of the explosion. Cheap fix if you search eBay for a coil pack. I installed new plugs, new wires, and new air filter and not knowing that one of the wires :cry: was broken internally and after replacing them with factory (Mopar) wires, the car runs tops. Also, make sure your plugs are Champions. :D
    The shop installed all new plugs and wires (ended up being about a $100). The plugs are champions. I haven't checked the gaps and wires since they were just installed by a shop.
    Any guess as to why the car is having difficulty starting and stalls? If the porcelain exploded into small enough pieces couldn't it get into the cylinder?
    The porcelain on the sparkplug is all above the threaded part that goes into the cylinder. Most likely there was a defect in the porcelain, it got hot, and popped. The engine itself has "explosions" all the time - the combustion - much stronger than the ceramic popping. Unless the mechanic let the pieces fall into the chamber, nothing is in there - assuming the "pipe" that covers the spark plug below the valve cover wasn't punctured. It all depends on how your mechanic removed the plug. Did he "vacuum" it first? Did he have to replace the tube over the plug up to the valve cover?
    Thank you for the heads up. I will keep the gasket thing in mind. I was pretty mad though when my car was over heating and they said it was my radiator and so they checked it and said it was al right after all. So they flushed the radiator thinking their might be a clog some where. Then when I went to pick up my car I got a nice radiator flush bill and no solution to my problem other than it might be my gasket and those are expensive the guy said. So yeah took it to another place they said it was my radiator cap and wanted to charge me 45 dollars worth of labor to put the cap on. I mean how hard is it to put one on ?? I'm not that retarded so I put a new one on myself and it kept overheating. So then we went back to the place 2 weeks later to tell them the car was still overheating and we put a new cap on because they said that was my problem and told them that they should take the car back and retest it for free. The guy was a total jerk and said they could not because they were not the ones that put it on so it could have been put on wrong I laughed and walked out and told them I would never do business with them again. So any ways so I picked up a thermostat because my friend that works on dodges said that might be my problem. So I had a family friend who works on cars install a thermostat and my upper and lower motor mounts for $ 115.00 and the dealership wanted to charge us 425.00 for the same stuff lol. The car is working good again so far no overheating our thermostat was yucky so I'm sure that was the problem. However it went to two different car places even a chrysler dealer and why could they no see it was my thermostat ??? Now I will see how long it will run without breaking down again I hope not in 3 months like it always does. :confuse:
  • kiltedmadmankiltedmadman Member Posts: 1
    I went to start my car the other day and when I turned the key, I didn't even get a click. The accessories came on and the battery was fully charged, so I checked to make sure the clutch switch wasn't jammed or disconnected. Then I popped the hood and discovered that the in-line 5-amp fuse that lays right on top of the main electrical trunk coming through the firewall was smashed, so I replaced the fuse and whaddya know, it started right up. It ran fine for three days, then last night, it did the same thing as before and I checked the new fuse and it looks fine. Does anyone have any idea about this problem?
  • aite_eternelleaite_eternelle Member Posts: 3
    Don't swear off all dodges just because of the 2000 neon.
    I actually used to own a 2000 neon ES. After 6 months, the battery died. One of my rims bent a few months later. After that, I had a slew of problems, including the O2 sensor and cam sensors going out on it, the power system dying twice(in one year), the lock on the door messing up (where the door wouldn't close at all), etc. etc.
    I traded it in after two years and got a 2003 Dodge Dakota. I NEVER have had problems with my dakota, at all. The only reason I'm looking for another vehicle now is cost (with gas prices and stuff). :(
    You might want to check/replace your spark plugs. Mine did something similar to that, and that's what it was on mine.
  • charizardcharizard Member Posts: 1
    Remove the fuse in the dash that controls the solenoids for the locking doors. This will kill the screaching sound (And your power locks). Usually what happens is the solenoid inside the door (the one with the noise) needs to be replaced. Unfortunately, you have to replace the entire locking mechanism.. about $150 at the Dealer, just for the part. As far as the car thinking the doors are open, that is caused by shutting the door with the seatbelt between the door and the car frame. The seatbelt connector may have damaged the Button as well. In most case, you can change the buttons with replacements from the dealer. This you can do yourself since there is only one screw holding them in, and an electrical connector to connect the wires. This should solve that problem. If your shoulder belt is not retracting fully before you shut the door, or you slam your doors often, the button will be damaged again. You may also try to raise the ding a little using a penny or dime taped to the door jamb. If you have noticed that one door will not lock/unlock the other doors, or set the alarm, then you have a broken sensor on the inside of the door lock. That too is a replaceable part, but once again, its a dealer item.
  • jules923jules923 Member Posts: 1
    This past Sunday, my husband was driving my 2002 Neon over a new speed bump. Neither of us thought he was driving that fast but, we came down VERY hard on the top of the bump. I even commented at the time, "I hope that didn't crack my oil pan."
    Monday, the car ran fine. However Tuesday afternoon, I noticed the car making and unusual noise intermittently. I sounded like there was paper or plastic caught up in the tires or something. I could not see any thing when I looked and the noise would go away for long periods. About 2 miles from my house the car jerked really hard (at about 50 mph) and then continued on. I got about a block away from home and there was a terrible grinding noise and vibration (it almost sounded and felt like a tire blew out) the I lost forward momentum, but the engine continued to run. Needless to say, the tires were fine...I pretty sure we stripped the gears in the automatic transmission, because it rolls like it's in neutral when it's actually in reverse. We can make forward progress at about 3 mph (thank heaven it happened near the house) :) ! If anyone can verify this assumption w/o actually looking at the vehicle and recommend whether or not this is something we can repair or have a mechanic look at, I would appreciate it!
  • airdyairdy Member Posts: 2
    I've been trying to get info and specs on chrysler neon 1.6se 2001 model that is either manufactured in South Africa or imported? can anyone help? thanks.
  • lacyrclacyrc Member Posts: 1
    I bought a 95' Neon and now am having some problems. Well, one big problem. My car is leaking oil and we think that it might becoming from the rear main seal. When I bought it there was no oil leaking and now there is a butt load. I was wondering if anyone has had the same problem or anything of the sort. The car has 122 thousand miles, and for most cars thats not bad, but when it comes to a Neon this is the first one I have owned and have no idea. I was also wondering if it would be cheaper to just rebuild the motor or replace the seal.
  • greenneongreenneon Member Posts: 1
    I was wondering if you ever got an answer to your starting problem. Or if you were able to find the problem. I have had a relatively good experience with my 1995 Neon until just recently. The car has about 65,000 miles and has required very little maintenance. But lately I have had trouble starting it. Eventually it may start after a little while but then last week I was driving and stepping on the gas with nothing. The car just cut off and would not start for another 15 minutes or so. I have had someone looking at it. Changed some coil. But that is not the problem because it has been acting up again and needed to be towed. Did you find any solution?
  • matosapamatosapa Member Posts: 1
    I'm stuck. I need to replace the radiator on my 1998 Plymouth Neon 2.0L SOCH Automatic Transmission and Air Conditioning. I have been able to remove the right (passenger) side fan but I cannot get the left (driver's side) fan out. if I move it back far enough, the fan motor gets stuck under the engine block. If I manage to pull it up a bit it gets stuck on the battery box. Can somebody help me with the removal and reinstallation of that fan? I need to get that fan out to remove the Automatic Transmission lines so I can pull the radiator.
    I wish I had long skinny arms with 3 more elbow joints! :D
  • thesehandsthesehands Member Posts: 1
    I recently purchased a 2003 Dodge Neon and the alternator has already went out twice. About 2 weeks ago, I was driving it and it shut off and the brakes locked up, causing it to skid out of control. I had the dealership that I bought it at come get it, and they said that they couldnt figure out what was wrong. They have now sent it to a Dodge Dealer.....any ideas on what may have happened?
  • podunk503podunk503 Member Posts: 45
    We have a 2000 neon that has problems with the alarm siren inadvertently activating. We found a tsb for this problem in alldata, took it to the dealer and the tech looked up the info and said that this was not applicable to the USA. We already replaced all the door pins in all four doors because we were having problems with the dome light coming on and dash reading door was open. The tech said that the tsb called for replacing the keyless entry module under the top of the dash and running a series of codes to fix the problem, but insisted that it was not for ones manufactured in the US and not sure if that would fix the problem. Does anyone have advice in this matter? I would enjoy being able to lock the doors again.
  • pamelakaypamelakay Member Posts: 2
    I'd appreciate any help. when we turn on cruise, dash says it is on. When we engage cruise, dash says it is set. Unfortunately, it is not. Most of the time it does not engage at all. Once and awhile it will engage but disengages immediately. Can anyone offer suggestion and how to fix. thanks
    A few of us have been talking about this on here already, same situation. It is the most annoying thing. I took the fuse out of my neon to stop the door from making a horrible sound when it is trying to automatically lock. That worked for the lock but not the door light saying the door is open and not the alarm problem. I can't lock my doors, I took the dome light out but the reading lights still light up when it is acting up. I can not afford to pay the dealer there crazy prices to fix this and have not been able to find a garage who will touch it. If you do find anything out please let this board know. And if I do I will post it as well. I tried the duct tape over the door sensor....didn't work. I tried to figure out how to disarm the alarm and cannot. Good luck with this.
  • jkobbjkobb Member Posts: 51
    I was just browsing thru the Neon postings , because I`m pretty caught up on my cars postings . I`ve noticed that in the postings on my car they are mostly favorable , and that a majority love this car . On the Neon it seems to be nothing but problem after problem . And I`ve noticed not just Neons but Chrysler cars in general have a large number of head gasket problems. :(
  • iris1iris1 Member Posts: 1
    I know it has been a while since this post and you may not even be returning to this site any more, but I'll ask any way. Do you know what component that would be that was faulty on the air conditioning? My '98 Neon's air stopped working and it's not the coolant system and it doesn't show up on the computer as an electrical problem. I did read about a part that could be the problem but usually doesn't show up as faulty but lost that info before I could get the car into the mechanic. Any ideas? Thanks
  • jgraceyjgracey Member Posts: 1
    Hey I'm from Canada and I'm thinking of buying a 2000 chrysler neon 4 door with the 3 speed auto transmission. Really like the looks of the car and it drives great considering it's a 3 speed (i've always driven 5 speed manual). Any ways the millage is high at 130,000km (80,000 miles) but the price is right. Any thoughts?
    jimmy
  • hz17k0hz17k0 Member Posts: 1
    Hello, did some one answer you're question? I'm having problems with my keyless entry control, I think it lost it program, do you were I can find the programming instructions?
    To All,
    Has anyone attempted to do a 134A recharge on their Air Conditioners? I know Walmart sells them pretty cheap and didn't want to pay a shop $125.00 to do it when I could do it for 1/3 of the price. Any comments would be great.
    Also, any comments on different spark plus besides the stock Champions would help me out because I believe there are plugs out there that give off a hotter spark. Didn't like the bosch plug. I drive a 99 SOHC.
  • thealliemonstethealliemonste Member Posts: 1
    '96 2 door neon ... Manual Transmission. I'm learning how to drive... a manual and was practicing in the yard (Big yard.. in the country lol) ... and somehow i did something to lock the rear left wheel... any suggestions?
  • bobkatsbobkats Member Posts: 1
    My car had three of the four spark plug wires worn thru and it was running for a short time with only one or two holes firing. This was fixed but after the car will lug seriously when accelerating from a stop sign or a slow down for a turn. The problem is most of the time but the car runs great at highway speeds. Also when the AC is turned on it tends to run very rough and it does not seem to firing right. :sick: Neon
  • 90gs90gs Member Posts: 107
    I'm looking to buy a 98 or 99 Neon R/T and I've heard nothing but good things so far except for the thin head gasket that needs to be replaced with a thicker one... the ones that I'm looking at (just south of the bay area) are going for around $2-3k. Is there something else that I should look for (or look out for) before buying one of these. :)
  • broken1broken1 Member Posts: 1
    In the summer car gets hot,runs hot even when air is not on, overheats when using air conditioner.. Has antifreeze
    replaced thermostat, only one fan comes on. Can someone give me some information on what could possibly be the problem...
  • nbafan101nbafan101 Member Posts: 3
    I was driving my 03 neon and all the sudden the check engine light came on and the car is idleing very very hard cuz i can feel it jerk when im sitting still and when im driving, does anyone have any ideas what it could be?
  • slowkiddslowkidd Member Posts: 1
    I have a 98' Neon and I'm looking for some suggestions on how I could put a cone air filter in and move it up front instead of having it right by the firewall. It makes no sense to have the filter back there! Any tips on putting a cold-air intake in would be greatly appreciated. :shades:
    nbafan101-
    If you have an AutoZone in your area, get your Neon to them. They'll diagnose your "Check Engine" light for free. A little tip on it is to turn your key off and on 5 times and then leave it in the on position and your "Check Engine" light will do a series of flashes. Count the flashes, that's your first number, then count the second set and that's your second number. Let's say it flashes three times and then the second it flashes five times. Your error code will be 35. At the end your check engine light will flash a series of five times, that's your que that its done. If you have an owners manual, great. The codes are in there. If not, AutoZone, Lappens and I believe Pep Boys sells the repair manuals for 15 bucks.
    Hope that helped you out. :)
