farout.
Thx.
Any ideas?
Now my radio quit working no electricty getting there and the fuse is new.
Here is an expensive lesson I have experienced. At 90, 000 miles I replaced the timing belt and put on a new water pump. I now have 197,000 miles on it. The timing belt pully broke the timing belt broke as well, the engine stopped. I had it towed to a local shop. The owner said he was sure at 50% he could replace the pullu and the belt and get it going, if the valves were not bent. Itook the chance and I was aware it might not work. Well nearly $400. and the valves are bent. Now whenI fix it, the cost will be more than $600. I was wrong to take such a gambel. So if you have not had you timing belt and water pump changed do so 101K is a belt just about to brake. Hope this helps.
farout
This for all practical reasons is a dangerous idea. Here is why. The engine would fit, but the tranny is a special beefed up stick, brakes are extra heavy duty, the body is strengthened, all the control moduels are different. But say yoy really wanted to put an SRT engine in the safe way it would cost more than you can buy a fairly low mileage SRT for.If your 04 sxt has acceptable mileage in the NADA sell it andthen buy a real honest to goodness safe solid worth something SRT. To give you go on ebay motors and check out all the SRT's. By having a blessing on the way I am assuming you are 30 or less years old perhaps uo to 35, insurance on a SRT just might be really up there.
If you did find an SRT engine and tranny, you would spent real high dollars for it, there are lots of SRT's with needed rebuilding and many would rather get a used engine even for big bucks. Call some different auto salvage places and see how many SRT engines you find, id any.
Sorry to but the brakes on for you, but safety is always the best idea first and formost.
Oh, we had an 04 sxt. Our daughter had an accident, at 30 miles an hour everything worked perfectly. The air bags went off, the engine tucked under the body as designed and she just had some neck pain from the air bag going off. The Neon is designed to protect the driver and passengers, and because of that the vehicle crumbles. In a accident this is a throw away car. The design for safty was good, for rebuilding it costs too much.
farout
Problems too numerous to list without taking up 10 monitor screens of text.
More expensive to keep running than a vintage Ferrari by FAR.
Chrysler bankruptcy was in large part caused by the Neon in my book.
May Chrysler designers and engineers rot in hell! :mad:
The first head gasket leaked at about 40,000 miles, I blew 5 Five! Head gaskets up to 170,000 miles.
I blew a cam seal at about 50,000, it took me like 12 quarts of oil to get 2-3 miles to a supermarket marking lot to call the dealer.
The recall was no big deal, cars get recalled.
The thermostat went around 50,000 miles and I was stranded on the side of the hwy, overheated.
The inner door panel holding pins broke and the (panel) would get caught on the frame and the door wouldn't open.
The clutch felt like it had "gristle" along the cable and I would have it cleaned...to no avail.
CV joints like to just "go"
Rain and winshield fluid whichever would piss into your face if the window was open a little bit.
The girl I was engaged to had a neon as well.....against my advice......the list of problems was just as long.
My spontaneous shopping brother on a whim bought a 2001 sport..his problems were really bad, in fact, he had the balls to drop it off at dodge, told them to "*******" keep it. I hope you all learn Chrysler never will change. and I wish you all luck..
What happened was the belt tensioner broke, which I had repleced, and the timing belt. When they started it up it was clear two valves were bent. So that $ 650. was down the drain. I would consider a engine with low miles, but the low mileage eeeengines are pricy and again the question of trust worthiness is there. Anyone can say they have a low miles engine, that could have 150,000 miles and lie about that the engine has 70,000. That's my issue.
So why am I posting, more just curiosity I suppose, I am in the process of figuring out why my dome/ trunk lights wont work and if there is any way to supplement those with some strip l.e.d.s that I have from Wal-mart ( Idea is to make them work in the same way the dome light would open door and/or the multi-function switch, next question would be what the difference from the regular neon an the ES I ask this mostly because the Haynes manual that I bought the fuse box numbers don't match up from the book to what is on the diagram on my fuse box cover, my Haynes manual covers Dodge & Plymouth Neon 2000-2005, so not sure about that, I know that the Haynes Manual for the '84 Dodge Rampage 2.2 I had up till this year didn't match, but that was because it covered the Dodge Omni Plymouth Horizon and the '87 Dodge Shelby Charger, which the Rampage were modeled around, could this be another problem of Haynes is covering to many years/models and the wiring diagrams are just not accurate do to that or something else entirely.
