Pontiac Grand Prix - 2000-2005
1252628303187
  • immoeimmoe Member Posts: 15
    Hi! New to the Grand Prix town hall but use the 2002 Envoy site. Could someone tell me where the pcv valve is precisely located? It has been a great trouble free car with 24,500 mi.
  • lberry662lberry662 Member Posts: 1
    I purchsed a new 2001 GP GTP 10 months ago. I really love this car, but have had the following problems. My service engine light has come on for four different reasons. First an oxygen sensor had to be replaced. Second time the fuel pump had to be replaced. Third time was a computer component that kept turning the service engine light on. Fourth time is today, my vent valve on the gas tank is leaking pressure and a part had to be ordered and my battery was leaking acid. Thankfully everything was covered under warranty. I was wondering if anyone else out there has had any of these issues.
  • hengheng Member Posts: 411
    had to be replaced shortly after purchase. I get the light after I drive about 350 miles on a tank of gas. It goes off the day after I fill the tank. Not codes stored either. But no other problems in 48K miles.
  • dsm6dsm6 Member Posts: 813
    was replaced, twice. In all, my wife's 99 gp gtp was in 9 times for warranty work. Quite disappointing.
  • rmyers76rmyers76 Member Posts: 34
    Took me a while to find my PCV valve because it is kinda buried on this car.
    Remove the plastic engine cover.
    Look just to the left (passenger side) of the intake manifold. There should be a black circular contraption with a electrical connection on top (two wire lead). There should be two plastic flanges that hold the electrical connector in place. Spread these apart and move the electrical device to the side.
    The top half of the circular housing turns counter clockwise to open. There will be a spring that holds the PCV valve in place. You can then remove the old PCV valve.
    Be careful not to loose the rubber O-ring on the old PCV valve because the replacement valves do not come with a new O-ring. Also, it took me some effort to seat the new PCV valve all the way in place.
    Hope this helps.
  • ottawaguyottawaguy Member Posts: 15
    Anyone know if the power driver and/or passenger seats go lower than manual ones at the lowest setting? I'm a tall guy from the waist up, and am planning on buying a GT, but every one I sit in with the manual seats, I brush my hair on the roof (when no sunroof is in the car...!).
  • montanafanmontanafan Member Posts: 945
    I am also a tall, and in my brother's 2000 GTP with the power driver's seat, I do feel that it goes lower then my other brother's 2000 SE without the seat. Keep looking to make sure. All 2002 GTs & GTPs are standard with them, an dmost SE's also have them.
    Does the GT come without a moonroof? You'll get more head room without it.
  • b4zb4z Member Posts: 3,372
    I am not a gp owner but can give you a generalization about all of the Wbody cars.
    I have owned the intrigue and impala and both have excellent headroom.
    The intrigue is slightly better because the rearview mirror does not block forward vision the way it does on the impala with its raked back windshield and lower windshield header.
    The power seat does not go down, but when you rock the seat back it lowers the cushion.
    I am not comfortable in the cars without the power seat but am extremely comfortable in those with power.
    My understanding is that the impala and gp share the same roof. The regal and intrigue and century share a different roof.
    The impala and gp have about a 1" longer wheelbase than the other wbody cars. This is noticeable in th rear legroom.
    I am 6'8" by the way. I don't own any cars with sunroofs.
    Any of you guys with the 3800 engine have a problem with the upper manifold base leaking?
    I just had mine replaced because it was warped. I wonder if this is a common problem?
    We have a 2K GP GT and I am not overly impressed with the headroom. I am only 6'-0" tall and with the seat at its lowest position there is only a few inches from the top of my head to the headliner.
  • teoteo Member Posts: 2,508
    I think the GP's roof is lower than the Impala's.
  • evandroevandro Member Posts: 1,108
    I put some of the pictures I took at NAIAS here. I didn't try to compete with marketing pictures, but I'm not proud of the photographic quality of my pictures either.
    Anyway, I focused especially on concept models and engines, for I love cut out engines! ;^)
    Enjoy!
  • tpkentpken Member Posts: 1,108
    Nice shots of those Buick interiors. Suicide doors certainly dominate the concept thinking at Buick. I wonder if they'll actually make it into production. I also wonder what Bob Lutz' take is after reviewing these Buick ideas since he has already voiced displeasure over Regal and LeSabre redesigns. The future for Buick looks interesting - hope to see some of these designs make it to the local dealers.
  • jg28jg28 Member Posts: 257
    I bought this about six months ago and it's in fine condition. It's not working on my Oldsmobile Intrigue, so I have to put the factory sway back in on the front. Anyone want the next level one?
  • d2000one1d2000one1 Member Posts: 47
    A friend of mine has a 2001 GPGT and he had a problem with his Service Engine Light coming. He took his car back to the dealership and they reset it several times and then they reprogrammed the transmission. The Service Engine Light kept coming on. He took it to another dealership and they replaced the gas tank. This apparently solved the problem because it hasn't occurred in the 3 months since the tank was replaced. The service person stated that this is a common think.
  • streetracerstreetracer Member Posts: 134
    I have a GTP coupe, and can almost always distinguish between GT and GTP - even at a relative long distance without seeing the badge. I of course confirm upon getting closer.
    However, I am not really sure how they are different.
    What are the differences if any between them?
  • smily1smily1 Member Posts: 104
    How much are you asking for it? You might get a better response posting in the Club GP Message Forum under classifieds.
    http://www.clubgp.com/forum/
    It is front, yes?
    GT = Normally aspirated 200HP 3800 V6 engine (L36)
    GTP = Supercharged 240HP 3800 V6 engine (L67)
    I am sure there are other cosmetic/trim/packaging differences. GTP has badges on lower front doors as well as the GT models.
    I also believe both models use the Magnasteer steering system while the SE models use a conventional hydraulic power steering system.
  • ruskiruski Member Posts: 1,566
    GT looks absolutely the same as GTP. The only difference is the badge on the front doors.
    yes, it is front. I dunno. I'm willing to entertain any offer. I think it's worth at least $50. I'm not a GP forum member.
    Suicide doors (what an awful designation!) are kind of interesting, very airy. But I'm afraid that not many of those will make it. The elegant Bengal has already been axed for its production cost...
    Thanks for passing by.
  • envoysleenvoysle Member Posts: 20
    Well, after being the owner of a GMC Envoy SLE (crashed last week, no injury) and not wanting a SUV again, I was looking at the 4 doors Grand Prix GTP 2002.
    Does anybody here has something good or bad to say about this car ?
    I was the owner of a GrandAM GT just before the Envoy, and I liked this car very much. I'm hoping that the GTP will be better.
    Thanks for the input.
  • dindakdindak Member Posts: 6,632
    I had a Grand Prix SE and had zero problems through the lease. My buddy has a '00 GT and loves it. It's a good car all around but I don't know about the GTP, I would assume it's fine as I've heard nothing bad about it.
  • stormdavystormdavy Member Posts: 80
    One thing (other than new spoiler) I noticed on a brand new wine colored GP (Possibly a GTP, if so, the new badge is different: The P is diagonally below and to the right of the G-- you could maybe 'see' a T in the negative space between them), is that there are these raised ridges (seams) in the roof that overall give the car a higher profile from the side, but probably are functional-- diverting rainwater from the windows?
    Have to say, for an 'old' design (7? 8 years?), the Grand Prix has amazing 'legs'-- still a head-turner, especially higher trim levels.
  • yurakmyurakm Member Posts: 1,345
    GP are bigger cars than GA, and more comfortable. They are also more powerful, trim for trim, with GTP being very powerful.
    I would suggest to consider also a Buick Regal. Regal GS is practically the same car as GP GTP. The same engine, transmission, and most of other parts.
    We bought a 2000 GS 1.5 years ago, and like the car very much. Very comfortable, rather fast and have a reasonably good steering.
    Regals are built in Canada, GP in Kansas. According to many sources, Regals are more reliable. Better assembly, less initial defects.
    Additionally, with current incentives, Buick is a bit less expensive. $1000 difference or so. At least it was so a month ago, when I last looked for Connecticut prices.
    Regal is a kind of invisible car: nobody notices it, including the highway police... Personally, I like the style more than Pontiac, but it depends on taste.
    On the other hand, the nice head up displays are not available with Buick.
    The cars differs also in some other details, like foldable / fixed side mirrors, seats adjusted in 6 / 8 directions, etc.
    I test drove a Buick Regal GS, and here in Montreal, it would cost me 1000$ more to own a GS over a full equip GTP. I know that the 1000$ give you both driver/passenger heated/power seats, a bit better leather seatings, CD & Tape Moonson radio (GTP only has CD with Bose system), no HUD display and I think that's about it. It is a very fine car, but the look....
    I like a car that say something, I realy like design. The GrandPrix fits my taste better. I'm glad to learn that it seem to be a problem free car (well, i hope that mine will be!).
    I will miss the tape deck, i used it for my MP3 player. I'll have to buy one of those crapy FM transmiter.
    Thanks for all the opinions, I now have to make a choice. The GTP needing 92oct gaz is a big problem with the rising price of fuel.... :( Oh well... I just hope it drink less than the Envoy !
  • graphicguygraphicguy Member Posts: 14,167
    I owned two GP GTPs. Both were excellent cars.
    The GTP is as fast (give or take a tick or two of the stop watch, which is unnoticeable) as any sports sedan I drove for anything close to its price (up to about $35K). Handled well on dry, wet and snow conditions. Good brakes. Nice, firm (but comfortable) ride. All the bells and whistles you could want (except for "on-screen" navigation, but you can get a GTP with On-Star). Build quality was as good as (actually better) than my wife's '99 Toyota Avalon. I never experienced any squeaks or rattles. The car was always very solid feeling.
    Best auto transmission I've ever encountered. It seemed to intuitively know which gear you wanted.
    My first GTP was totalled by a kid who ran a red light going about 45 MPH. I walked away from the accident. The kid who ran the red light (in an Acura) was in the hospital for over a week. I was so impressed that I went out and bought another GTP with the insurance money.
    Now, the downside. Some complain about the plastic inside the car. That never bothered me because I found everything to be very functional and ergonomically designed. It wasn't a quiet car, but I didn't expect it to be. I've certainly been in vehicles which were much louder (and cost quite a bit more).
    Gas mileage in town isn't great (about 16-17 MPG) and it takes premium gas. Highway mileage was about 27 MPG. I used to get about 20 MPG in mixed driving.
    As you pointed out, the car is a "looker". I don't know what the 2002 GTPs are going for pricewise, but with the GM rebates and the ability to buy one at close to invoice, I would think it's a steal.
    Go for it.
    Thanks to all of you for your comments. I'm now waiting for my 4 doors Pontiac GrandPrix GTP Galaxy Silver Metallic with everything inside and out (roof top, Bose, leather seats, chromed wheels).
    Now I only have to wait.... One week they said...
    I'll be back!
    Congrats. Like graphicguy this is my 2nd GTP also. Had a 97 2 door until we had a baby. It took a while but now we have a 99 4 door. Just as good the second time around.
    Getting my the HP of my GP closer to 300...kind of turned into an unlikely hobby for my wife and I. LOL
    Congrats....you're going to love it.
    I get this sneaky suspision that my next car will be an '04 GP G-FORCE (maybe an Infiniti G35). From everything I've read, the recent GP show car is pretty close to what the production unit will be.
    Just curious, there's an outside chance I may be getting an SUV for my next vehicle. The Envoy was high on my list. Pros? Cons?
  • pinettedpinetted Member Posts: 104
    Graphicguy, you may want to read the review on Edmunds home page before you decide on an SUV. That is if you decide on an SUV.
    Well, I loved that truck very much. I had it for less than 3 month before the crash. It was not the SLT trim, no leather/heating seats, no automatic climate control (wich seem to be more or less working from what I read), no moving mirrors when going reverse (wich seem to be a problem to). Take a look at the Trailblazer,Envoy,Bravada forum to read more about the triplets.
    More room than in a Blazer or Jimmy. Better look with a nice finished touch all around. Lots of stuff for the price. Good handling on DRY road. Lots and lots of power from the engine, that I6 is better than lots of V8 out there and cost less to run. Mine was working great with no problem, noise or anything like that.
    Why am I going back to a car ? Because my false feeling of security in a SUV was broke with my accident. A small pile of snow got me to do rollovers and to land on the top of the truck, all this at less than 50mhp. Think hard before buying a SUV.
    Thanks for your input on the Envoy, TrailBlazer, Bravada input.
    Actually, I don't need an SUV. A friend of mine just got a TrailBlazer. After riding in it, I have to admit, that the engine is the best thing about the GM SUVs. I really want something that I can haul big stuff with. As a side biz, I buy, refinish and resell antique furniture. I do this with another friend of mine who has a Suburban. What I need is an old beat-up pick-up truck. That wouldn't sit well with my neighbors as it would be parked in my driveway. I probably shouldn't even be looking at a $35K-$40K SUV for that duty anyway. I've been kind of seduced by the SUV phoenomona.
    Anyway, I'll just continue to use my "bud's" Suburban for that duty (what a beast it is).
    Back to the GTP. What's been missing from most sports sedans of recent vintage is the torque of the V8s of my youth. The 3800 engine has that in spades. Adding the supercharger to that engine just adds to an already good performer. The engine is stout and very reliable. It runs smooth and has a nice "snarl" to it when pushed. Great for highway and in town stoplight wars. "Cut and thrust" driving is really fun in the GTP. Massive power is available from any speed up to any (sane) speed.
    A lot has been said about build quality of American cars vs their Japanese based counterparts. I have to say, after owning an Accord, (2) BMWs, a Camry and an Avalon, my GTPs gave nothing up to them. From personal experience, GM cars are still suffering from the perceptions from the cars they built 10-15 years ago. They are building some of the best built cars I've driven recently (well, maybe not the Cavalier). Things like the thickness of the metal they use (knock on a body panel of a Japanese brand and then knock on the body panels of one of the "big 3" cars) and the thickness of the paint and you'll notice a big difference (my wife's $32K+ Avalon paint seems to chip off with the least provocation).
    After being biased against American marks for many years, I'm back to being impressed with the cars that GM is building.
    I agree. There is a perception by many that American cars are not reliable. Many people also read Consumer Reports and see that it's mostly Japanese models that are recommended. What they don't realize is that American cars are only marginally less reliable/well built and often cost thousands less than the recommended models. Further, American cars are much cheaper to service. Take it all in to consideration and you see where the vale lies.
    I have had my Intrigue for over two years and aside from a faulty temperature gauge, it's been perfect.
    seems to be hit or miss. Some model are good, some are not so good. Actually, my wife's GTP has been in for 9 (!) different warranty repairs, ranging from a fuel pump to an alternator to rebuilding the transmission.
    my GTP was reliable during the 3 years of the lease. And considering how much fun it is to drive, I drove it quite hard. Also drove it from NY to FL. No problems.
    Now I am leasing a refined version of GTP - Acura TL-S. Transmission broke at 6,100 miles and needed to be replaced. And my case is not isolated. There is a good number of people on www.acura-tl.com and www.acura-cl.com forums with the tranny problem.
    How is this possible? I was brainwashed to believe that Hondas were super-reliable!
    The two most recent "American" marks I've owned, the GTP and 300M have been pretty near bulletproof. I drove both very hard. No resultant warranty claims on either. Both tight and rattle free.
    I had about 40K miles on the GTP when, through a sad set of circumstances (uncle's passing away), I inherited the 300M. Not needing another car, I put both the GTP and 300M up for sale. GTP sold first, so I kept the 300M (which is also a sterling car). Wish I could have kept both.
    The GTP ran better than the day I drove it off the lot. The guy who bought it from me lives a couple of miles away. I run into him from time-to-time. He's got a little over 60K miles on it and it still looks and drives "new". The only noticeable wear is on the drivers seat. It's not really "wear" per se, but the leather has small "butt creases". The guy I sold it to is a big man...about 260lbs. I told him to quit "plopping" his big frame in the seats so hard. He also just put another set of tires on it. Aside from oil and filter changes, that's it. He said he'd replace the engine belt at 75K as preventative maintenance. I changed the oil every 3K-5K miles. He said he changes it whenever the "oil life monitor" comes on (about every 7K miles). It doens't burn or leak any fluids at all between changes. The coolant is supposed to last 100K miles, but he changed it last Fall.
    I drive a lot and have over 60K miles on the 300M (two years old). I usually trade every 3-4 years, whenever I hit 100K miles. The GP G-Force will be at the very top of my shopping list next year. I was really impressed by the Infiniti G35 at the recent, local auto show. I liked its look both outside and in and the supposed performance I've been reading about. I'll test drive it and may put it on my shopping list, also.
    You guys have talked me out of the SUV "thing".
    Well, yes Honda's have some problems from time to time. I'd much rather have to replace a transmission, though, then to have to replace a transmission, replace a window switch, replace the trunk switch in the glove box, replace two struts, replace an alternator, replace the fuel pump - twice, replace two brake calipers, seal a leaky spoiler, and replace a fuel injector.
    Its irrelevant anyway - this is all anecdotal evidence, small number stats; folks do keep stats on overall performance (eg Consumer Reports, JD Powers, NHTSA), and those stats say that many domestics (not all) still lag behind many imports (not all). It's really a model specific kind of thing - ie, generalizations generally don't work.
    The gp looks to be about average. It is a fun car, with good torque. Too heavy, though, for my tastes. The wife loves the low-end torque, and its bigger than our other car, so she drives around in it with our daughter. She'd like to see Pontiac build the GP G8 (so would I, actually). Heavier, but AWD and V8 powered! Might be too expensive, though, if they did decide to build it.
    My neighbor's Accord's auto tranny blew after 8 month's of ownership. Seems to be a weak point of Hondas. They are good cars, but nothing is problem free.
    I kind of miss the GP we had. After my Intrigue, I may get another GP if they build that G-force.
    Well, It's going to take a bit longer to get my GTP... GM is having a small 4-5 days delay in delivery of their car here (Montreal).
    I hope that I will drive off with it by the end of next week. Or so I wish....
  • scottm9scottm9 Member Posts: 2
    Just bought a dark green 98 GTP. Wow what a car.I had 2000 Taurus SE. Wrecked it on a slick road. Pretty bummed out about it until we got the Gran Prix.It's twice the car the Taurus was. I was just wondering how it handles on icey roads. Trac. control and ABS has to help. It's also nice to not worry about passing other cars! This the first GP I have owned' but probably not the last!
    use common sense on icy roads but GTP does very well. ABS and traction control are very efficient.
    I used to live on top of a hill in Yonkers, NY. When fresh snow would fall, before the snow plows came out, I used to like going for a ride up and down the hill, just to see how GTP would do - never had any problems (but saw some other cars that could not make it up the hill)
    I just put ultra high performance all weather dunlops on my GTP - in stock 16 225 size.
    I just want to say - wow!!!!
    The dry and wet acceleration, cornering, and braking are much improved.
    By by unscientific estimate cornering grip is improved by at least 10% - based on sustainable speed through various turns. The turn in is much improved too, especially through sudden transitions.
    I can only imagine if you put true summer ulta high performance ties on the GTP - maybe in 17 or 18in and 245 size!!!
    I would do it but don't have room for a second set of tires, nevermind rims.
    Off to enjoying my "new" ~.88G GTP - its like having a G FORCE today:)
    and how much($)?
  • looking25looking25 Member Posts: 19
    Has anyone towed with their GTP? Class I hitch I presume because I see the max is 1,000 lbs. Does this damage the supercharger?
    I'm getting a single trailer w/ 2-seater jetski ... approx. 800 lbs ???
    I've never towed with the GTP, but own one and have towed with other vehicles before, so I'll add in my two cents, for what it is worth
    I don't think you have to worry about the supercharger as much as you need to worry about keeping your engine and your tranny cool - especially the tranny. What worries me most about the GTP is the transmission - it seems to be the weak spot. Concerns over reliability of the 4T65E is what has held the power and torque down on the GTP to 240/280 relative to 300+ for both on the original prototype.
    Many who mod the GTP (smaller SC pulley, for example) add an extra tranny cooler and use synthetic ATF. If you plan to tow quite a bit, you might think about doing the same.
    Oh, and I'd bet the suspension (especially rear) will take a beating too if you try to push too close to that 1,000 lb limit.
    Okay, so it seem that GM has problem with delivery. But in the showroom was a very nice 40th Anniversary Limited Edition GTP, and I feel in love with it. So instead of the Silvermist GTP, this dark cherry car will be in my driveway by the end of the day (hopefully). It's fully loaded, nothing is missing. The windows are going to be tinted today.
    I just can't wait! Man, what a car!
    I'll give you feedback on it soon.
    Time to change your moniker there to GTPAnniv or something simliar now!!!
    Congrats on your new ride - hope it turns out to be a dream come true!
    Ken
    dsm6 - thanks for the input, I probably won't risk it. I do have a Pathfinder that I will mainly use, just wanted to know if it was an option down the road. I do notice my tranny slipping every once in a great while when I gun it at low speeds.
