Visitor Agreement.
Yes I definitely would not recommend Galant for any new car buyers out there. I thought I was getting a really good sport sedan for 25k but I was disappointed after few months. Anyone else notice these problems with their V6 Galants?
1)When in D and car been running for awhile, when stopped at a light...hissing and buzzing sounds coming from engine compartment. Took it to dealer and they couldn't hear anything abnormal. Car has 34k on it and had 30k service already and these annoying noises still there. Anyone have any opinions on this problem?
2)Got glovebox fixed but some bolt or nut loose underneath driver seat and makes noise whenever I make sharp turn. Also, misc. rattles from front passenger side window, or door, or seatbelt anchor but can't pinpoint where they're coming from???
3)After owning car for several months, wind noise and tire roar seem to get louder and louder. I think Civic cabin or less expensive cars quieter than Galants during freeway speeds.
4)Intelligent tranny not so intelligent.
Overall, car drives solid and performance decent. Also didn't get recall notice for wiring harness...wiring harness for what? I got recall for tranny oil cooler lines and steering nut thing but not wiring harness. Can someone explain what this was for? Mitsu motors not so respected in Japan and Japanese consumers staying away. Weird thing is Mitsu broke sales records in U.S. Good marketing campaign with hip music and commercials but unfortunately they trick public into buyin not so hip cars.
Consumer Reports does have a decent track record in their reporting of car quality, although the Galant DID make their "recommended" list for the first time this year. This car really isn't that bad, but it should be a little better for the price IMO! BTW, has anyone seen the new 2002 Galants?? That new front end looks REALLY, REALLY cheap, a step in the wrong direction IMO!
I have a 2K ES-V6 (built 4/00), and while there is a certain amount of road/tire noise, in my car wind noise is practically non-existent. I'm puzzled by the previous few owners' complaints about it.
I agree, the revised grill/nose on the 02 model is ugly. The car was obviously not designed with that new grill in mind.
cbnearla: Question on battery cable recall. What would be the effect on car if recall wasn't done for this problem? Just tryin to troubleshoot something with my car that has 34k miles on it.
Year: 2000
Make: MITSUBISHI
Model: GALANT
Manufactured From: MAY 1998 To: NOV 1999
Year of Recall: '99
Type of Report: Vehicle
Summary:
Vehicle Description: Passenger vehicles equipped with V6 engines and Federal emission equipment. The battery cable harness can become heat
damaged by the front exhaust manifold which could cause grounded circuits.
This circuit failure could cause any of the following to occur: (1) the engine will not start because the main fuse will blow if the power lead is
grounded; (2) the low oil pressure warning lamp will illuminate if the signal wire is grounded; (3) the airconditioning system will become inoperative if
the lead to the magnetic clutch is grounded; and (4) the turn signal/hazard lamps will become inoperative if the voltage monitor lead is grounded.
Dealers will remove and discard a metal manifold bracket (from Galant models only - Eclipse has no such bracket). Dealers will also inspect the
harness. If the harness wires show no damage, the dealer will install a heat insulator along with heat resistant harness clips. If the harness wires do
show damage, the dealers will install a new harness with preinstalled integral heat protection. Owner notification began February 7, 2000. Owners
who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should
contact Mitsubishi at 1-800-222-0037. Also contact the National Highway Traffic Safety Administration's Auto Safety Hotline at
1-888-DASH-2-DOT (1-888-327-4236).
So far I'm trouble free driving since April and still like driving/styling of the Galant much better than my Camrys. The only Camry I liked driving better was a fairly modified V6 Coupe I had back in 94. This Galant has better quality/materials than my 97 V6 Camry, which was when Toyota really started decontenting/cheapening things. That vehicle was delivered with grease on the carpet, a broken windshield, and broken rear cupholder. Over the first couple years it had several unfixable rattles, bad strut mounts, and 4 recalls. None of that was really anything that effected the drivablility of the car, just annoyances from being built cheaper than the prior models. None of these problems really seem much different that what alot of people here are complaining about, just piddly things for the most part. I have a buddy with a F#rd for a company vehicle and it does bad things like not starting, broken tranny, and a vibration at highway speeds noone can figure out.
The 02 Camry may be a nice car, and may be built better than the prior models (hopefully) but before long there will be 300,000 of them on the road and you'll be passing yourself on every corner. I guess I just got sick of driving something that everybody and their brother has. If they were still built like brick sh$t houses, they'd be worth the extra money, but now they are only marginally more reliable than vehicles that are cheaper.
It began to rattle almost immediately after I bought it. I had it in four or five times and they never fixed it. Now after 45,000 miles my mechanic says one of the front wheel bearing is going. Isn't that a part that should last much longer? He says I should try and get the dealership to pay for it. Has anyone else had this problem? How should I approach the dealership? Also, I received my third recall notice on this model! Ridiculous!
I had 4 recalls on my last Camry, along with rattles. I guess you have to spend $40,000 to get a well built car these days. I drove Camrys for years, but the last one sent us shopping for something more entertaining. If I have to live with niggling annoyances, it might as well be a cool car.
My bulb that illuminated RPMs on a dashboard burned out at 46k. Dealer won't change it cause you have to take the entire dashboard apart. This sucks. Most of my driving is during day time and I don't drive w/ my headlights on.
I still have not changed my micro-filter for AC. Is it really that important? Someone said here before that it is behind a glove box and it's not easy to change. I don't know exactly where.
I was going to replace my original tires but they have still some tread left so I will drive until it gets really wet outside. (I live in Chicagoland) I will replace Goodyear LS with Yokohama Avid T4. Stock tires are holding amazingly well. It's past their expected mileage of 45k. I wonder how Yokohamas will perform.
Let me know how you like the Yokohamas. I've only got 4K on mine, but I really don't like the noise/handling of the Goodyear LS. Wet traction is impressive though. How did the LS's do in the snow? We get a good bit here also and I was kinda concerned about a 16" digging through the snow. We have an 01 with traction control so that should help some.
I have a friend who has a 2000 galant and his car wont star. The lights flicker and teh horn is weak. After being jumpstarted the car ran but the radio and lights flickered. Is this a recall issue? Alternator maybe?
Just had a tune up and the mechanic could not find one. Let me know
Did not take to the dealer (they charge an arm and a leg)
Everything else is OK
I also spoke with dealer and they said you do not have to replace it..Saves money--Question what does a FULL Tune-Up consist of- all of the services that should be provided. Just for my complete knowledge.
Thxs
aftermarket white(Xenox type)?
What are kind and where did you buy it?
I went to a Toyota dealer and the saleman was an A-hole and told me my 92 V6 Camry was only worth $500 on a cash/invoice deal and they didn't seem to care if I bought one or not. So I went to a Mitsubishi/Audi dealer and was treated like a customer should be and I bought a nicer car (IMHO, and I've had three Camrys) that cost less, especially since they were very happy to take my Camry on trade and give me six times as much for it. You might want to have your caps key checked out, it's not working right either.
Any suggestion will be greatly appreciated.
The last time I had serviced the car in a dealer was at the 15k miles service, for which I had paid $360.
I used to have a Corolla before, so I can say that the Toyota dealers are much better than the Mitsubilshi dealers. So, I regret that I didn't buy I Camry. Sure, it costs more to buy, but considering less maintenance and better resale value, Camry comes out cheaper.
As a car, the Galant is a good vehicle with much better styling than Camry or Accord. But if you add the experience of owning the car, I would say that Mitsubishi sucks!
Indeed, after owning the Glant for 5 years, I finally understand why Galant has low resale value.
Pete
THanks,
Adrianus
I like the car so much that I even added after market wheels despite the fact that it is a lease car (lease ends Nov.2002)
I had a couple of problems the first year but have been pretty much trouble free since. Am even considering buying the vehicle at the end of the lease.
I previously owned a Toyota Avalon and a Honda Accord (both from new) and had more problems with them than with the Galant.
Styling of the Galant is outstanding and aftermarket leather package makes it look very BMW like.
Whether I'm just lucky or some of you guys are just unlucky I don't know. But in the end we all make judgments on our own experiences. Reading some of the problems you guys have had might make me hesitate to buy it at lease end, then again if I haven't had the problems by now maybe I won't.
In the end quality is important and I hope Mitsubishi will be upgrading. I understand the relationship with Daimler Chrysler is supposed to help in that regard.
I am looking for something newer.... would like a decent down payment.
So when is the next time I should do any maint. besides the usual oil change.
I appreciate all the info
The service in Indiana is terrible. On top of those, two of the dealer I contact have never replaced any air purifying filter for the last two years. If you are not aware of air purifying filter from user's manual, they are A/C filters hidden above the glove compartment and need to be replaced every year. Question, how many of you have ever got the replacement done, or done on your own? If so, how? Thanks
Thanks for your input.... By the way, 20,000+ with not one service visit other than oil changes and 3 minor recalls!! Very impressive IMHO!
Someone had an earlier post where he/she stated that even smart people do stupid things like buying a Galant. I did my research before buying my car, but feel like I made a bad choice. I do love the looks and the styling, but have been very disappointed by the number of problems I had with my car and the depreciation factor. If I could go back to June 2000 and take with me the knowledge that I have now, I would not have bought the Galant. But as they say, "hindsight is 20/20!"
I noted your comment on bearing replacement.
I'm having a noticable humming noise at freeway speeds which sounds a little like a bad muffler. Wondering whether that could be a wheel bearing problem you described.. Don't hear the noise at street speeds of 25-45.
Could you describe this problem in a bit of detail so I can perhaps see if that is what I am dealing with.
At beginning, the humming sound is only noticeable around 30-40 MPH when I am driving at constant speed or just leave the gas paddle. Later it is getting worse on all speeds. Hard to know what you are dealing with. High speed a happy engine sound is normal. I will wait if I were you while it is still under warranty.
the look is superb man!!! whoa.
looks like a muscular car. not like a stinkin camry or busy accord except the new altima can beat me in styling.
If ure not altima, don't dare talk to me.
PAt
