Volvo S80
1121315171848
  • n0v8orn0v8or Member Posts: 169
    Your report that the mirror can move both up and in (but not out or down) implies that both motors function, since 1 motor is used for up / down, and another for in / out (left / right). It is possible that a physical obstruction within the mirror is limiting travel. Did this problem always exist, or did it develop over time?
    You can force the mirror to a new position by pushing firmly at the outer ot lower edge of the glass surface. The mirror will over-ride the geartrain, with a clicking sound. This often happens to me when I clean the glass with Windex. The mirror is designed to do this without damage, in case you try to adjust it with the motors when there is ice trapped in the housing.
    If you can force the mirror to to proper position by hand, see if you now have full range of motion with the motors. If you cannot force it, I think a complete new mirror assembly is required.
    Another possible source of problems is the digital decoder / driver module located within the passenger door ("PDM"). It receives the serial data from the central body computer, decodes it, then operates the mirror, power windows, or door locks.
  • trip7trip7 Member Posts: 5
    I bought a new engine air filter for my S80. Can anyone please advise how to install it. Thanks in advance.
  • vbnmvbnm Member Posts: 21
    my mom has the upgraded system, w/the 4-cd changer, no tape. i was partially mistaken in my previous description: the SPEAKERS are Dynaudio. i read it in a car mag a while back, and the dealer confirmed this when we bought the car. as for the head unit and the amplifier, they probably are Dynaudio as well, but who knows? when BMW or Merc say they use H/K and Bose, are they referring to only the speakers? i have a feeling that the mitsubishi unit to which you're referring might be the basic audio package (which, ironically, has a cd AND tape player, as opposed to teh cd-only upgraded system) that we have in our new, base-line s60 5-cyl. incidentally, it's a great car, with all of volvo's safety, comfort, surefootedness and solidity built-in. but for those seriously considering this smaller model, if you're looking for any amount of peppiness in a car, i strongly advise against the base 5-cyl and to pony up for the light turbo.
  • snjmike1snjmike1 Member Posts: 3
    Thanks, n0v8or, for your advice. And for your reference, Broeux, here is a case resolved well.
    Today the dealership mechanic found the fault in the PDM, replaced the module, downloaded the related software (took the longest time), and fixed the mirror.
    I had shared your comments with the dealership service advisor before the work started.
    He appreciated them, as I did.
    Thank you very much!
    Mike
  • jack130jack130 Member Posts: 9
    I’ve been away from the forum for awhile and just read through a couple of hundred posts. As usual, learned a lot and thank those who comment.
    Although our 2001 S80 T6 is almost one year old I just took it in to Barrier Volvo in Bellevue, WA for 7500 mile service. We were out of the country twice for several weeks and haven’t put many miles on. Actually, we don’t anyway. Cost was $ 126.58 not including the Mobil 1 5W-30 synthetic oil I took in. When I bought the car October 2000 our salesman, who’d been an area manager for one of the lube/oil chains, recommended that if I wanted to use synthetic in the long run I should have a change at 2,500 and 5,000 miles, both with normal POL oil, then start synthetic at 7,500. That’s what we did.
    Our S80 is the third Volvo I’ve taken to Barrier for service (’72 164E and ’87 760 GTA). I’ve always felt I paid a bit of a premium but have had good service over the years since they bought Bel-Kirk Motors in Kirkland, WA. As usual, I felt $ 126.58 was a bit pricey for what they actually do at 7,500 miles.
    We’ve had a few 200 and 300 mile road trips but most driving is around the Seattle metro area. No real problems thus far but do have a "click" which seems to emanate from behind the center of the dash when I go over some bumps and/or turn the wheel rapidly back and forth. I don’t know if this is one of the infamous "clunk-click" problems but it happens so infrequently I may not even bother about it. The service advisor didn’t seem to recognize this as a general problem but offered to look into it any time I want to bring it in for that. I was surprised at his lack of knowledge.
    Anyway, so far so good and we’re satisfied with the vehicle. Cheers.
  • stanny1stanny1 Member Posts: 962
    Sounds like a classic case of needing to perform what's called a "throttle body cleaning". The gum and varnish of gasoline has deposited on the edge of the throttle plate, choking off air flow to the engine. Very common in today's cars. My Volvo dealer recommends a bottle of Techrolene made by Chevron (available at Costco) every few tankfuls to keep the fuel system clean. But at this point, you need a physical cleaning.
  • plumber10plumber10 Member Posts: 1
    I HAVE A 2000 2.9 WITH ABOUT 30000MILES. SO FAR THE CAR HAS BEEN VERY GOOD. FEW PROBLEMS. I WANT TO CHANGE THE AIR FILTERS, BOTH CABIN AND ENGINE.
    DOES ANYONE HAVE ANY EXPERIENCE CHANGING THESE FILTERS? ALSO, HAS ANYONE HAD VOLVO DO THE RECOMMENDED 30000 MILE SERVICE? DO YOU REALLY HAVE TO REPLACE SPARK PLUGS AT ONLY 30000 MILES?
  • jpd6jpd6 Member Posts: 1
    I am considering buying a 2001 S80, but I am concerned about the reliability of 1999s and 2000s. Does anyone know if the problems associated with prior-year models have been fixed in the 2001s.
    (such as emissions, software updates, can't get it out of park, engine stalling on the freeway, etc.)
  • gerry14gerry14 Member Posts: 12
    I have a 2001 2.9 with 25,000 miles. I do not understand your reference to emissions and software updates, but I have never experienced difficulty getting the car out of park or stalling... nor any other mechanical problems/failures.
    GP
  • overhilloverhill Member Posts: 2
    I have a 2001 S80 with only 1800 miles, but it has preformed perfectly. The T6 is a lot of fun to drive and everything seems great cosmetically and mechanically. I think most new models tend to have some bugs and maybe Volvo has gotten them worked out in the S80. I'll know for sure as the miles pile up, but at this point I wouldn't hestitate to reccommend it to anyone.
  • bugeyed1bugeyed1 Member Posts: 2
    re: #708
    I have recently changed the cabin air filter. To do this, you need about a #25 TORX driver. Under the glove box, there is a panel with 2 Torx screws. Remove these screws, and then pull the panel out. Note that it hooks into the side panel along the console. Then, there is a white plastic plate under the dash (glove box) that has 4 Torx screws holding in in. These are removed from the bottom of the white panel. A screwdriver will not work because there is not enough clearance between the screws and the floor. (I used an Allen wrench, because I only had a Torx screwdriver) When the screws are removed, the panel and filter will drop down. Pay attention to how the filter comes out, as it is tapered on one end. My dealer wanted about $45 labor to do this. It took me less than 30 minutes.Be prepared to get twisted up under the dash!
    ....but I'm here to announce the new Volvo Owners club now available on Edmunds.com Owner's Club board. Please stop by and introduce yourself in Meet the Members and let me know how I can help build your club.
    I have linked this discussion into that folder, but it will always reside here in Sedans.
    Looking forward to meeting everyone!
    KarenS
    Owner's Clubs
    Three times in the last month, I have returned to my car to find the driver's door unlocked, but when I open the door the alarm siren sounds as if I were breaking into the car. I have never had any problem disarming the system while unlocking with either the key or the remote, so I don't think an accidental button push could create this situation.
    I'm glad the alarm remains set, but I sure don't like the idea that the car is somehow unlocking itself. Any ideas?
    Gerry
  • dfried1dfried1 Member Posts: 6
    gerry14, Could it be that the driver's lock does not respond when you lock the doors using the remote? I ask because I have this as an intermittent problem. Sometimes the lock works, other times it does not but the system is always armed. I discovered this the first time when I returned to the car, noticed the driver's door appeared to be unlocked and was rudely "awakened" as the alarm was immediately triggered when I tried to enter. I have two misgivings: one is to tell the dealer that this happens on a random basis and the second is to wait until it breaks and then have the service department take the door apart! Danny
    Danny: Thanks for the tip. That possibility hadn't occurred to me. I assumed that if the alarm was set the door must have locked to begin with. I'll check the button when I lock up to see if you're right.
    Gerry
  • oak4oak4 Member Posts: 5
    I'm a new owner of a 99 T6 and had to order a owners manual because it was missing. Where is the clock on this car? I have the HU -801 stereo with 4 cd changer. Is this car full of problems ? Any turbo problems? Thanks.
  • kjewelkjewel Member Posts: 19
    Has anybody had any *recent* luck with an AM radio reception fix? T6. It still stinks. Haven't been to dealer in a while. Just checking.
  • broeuxbroeux Member Posts: 46
    newms:
    Regarding the DSTC message light you received - is "check DSTC for maintenance" the exact message?
    Or was it possibly "DSTC service required?"
    If the latter, have the brake booster checked.
    At Club S80 International, this issue was documented on the 'Problem or Issue Discussion" board, under ELECTRICAL/ELECTRONIC; and added to the 'Reported Issues and Solutions' record being maintained in FILES (in the 'S80 Technical Information folder):
    9/6/01
    "The problem was traced to a defective BRAKE BOOSTER--the faulty booster causes the BRAKE PEDAL PRESSURE SENSOR to set a fault code (in VADIS) because it cannot determine pedal travel, thus triggering the DSTC warning light. The brake booster was replaced."
    Broeux
    http://clubs.lycos.com/live/Directory/CommunityHome.asp?CG=68aali2dfna1380n004cf293tg
  • jllorensjllorens Member Posts: 2
    This is my first posting and I am looking for some feedback. I have replaced two headlight assemblies on my '00 S80 2.9 in the past few months. The first time I assumed a rock had hit it. The replacement had some condensation problems and the dealer replaced it. This occurred on the passenger side. This past week-end my wife noticed the driver side assembly had cracked and broken. I'm the only one that drives the car and this time I never heard any popping or sound of a hit while I was driving. My dealer informs me that he has replaced several headlight asemblies on S80s. I have emailed Volvo and am wondering if there is a defect in the lenses. Has anyone else experienced this problem or am I just the victim of bad luck. The only other problem I have had with my car is a squeaky glove box that is only quiet when the glove box is locked. The dealer tried several times to adjust it, to no avail. I just got tired of asking him to adjust it and now just keep it locked. I have been a Volvo owner since 1970. My wife drives an 850 and does not want to give it up. I love the S80 but want make sure that I'm not spending money on a design problem.
    Every S80 board includes numerous threads on the topic of cracked or broken headlamp lenses. Looking over the S70 and 850 boards, the subject rarely comes up. This suggests that the higher incidence of broken lenses in S80s is more than just bad luck. If some object has stuck the lens, it should have left a mark. If a crack extends all the way to the edge of the glass, and there is no obvious point of initial impact, the possibility of a stress crack does exist. Stress cracks can begin to form at manufacturing defects, or points of damage inflicted during assembly at the factory. There can be months of thermal cycles before the crack begins to propagate across the lens. The same thing sometimes happens with windshields and sunroof panels, which are stressed as the body flexes.
    There have been numerous reports of squeaky glove boxes on S60 Owner's Boards. One cause has been traced to the switch that operates the light when you open the box. The recommended "fix" is to pack the space within the return spring with a thick grease. I would expect that the S80 uses the same glove box switch as the S60.
    Thanks for the info. I'm still waiting to hear from Volvo customer service. The service manager and body shop manager looked at the assembly and both agreed that they could not definitely determine that the damage was from a rock or other projectile. There was no obvious point of impact.
  • jerrybergerjerryberger Member Posts: 3
    Just purchased a new 2001 T6. Got an unbelievable deal... $5,500 below invoice plus even some more thrown in!! The salesman was extreamly professional, provided great service and follow up, and even called to see how I was enjoying the car. And I am!. While I was initially looking at a 5 series, there really is no reason to pay 5 - 8 K more. I expect the service facility is equally as good.
    Question: Where do I access Volvo Service Bulitens?
    Jerry: Join us at Club S80 International (Lycos Clubs) and you'll find lots of information on the S80. In "FILES" you will see a folder for "RECALLS & TECHNICAL SERVICE BULLETINS" which also includes some TechNet notes. Check it out and tell us more about your T6.
    Broeux
    Thanks for the referral to Club S80 Int'l. Some new questions arise after the first weekend of ownership...
    1) There is a seatbelt warning light on the rear view mirror that illuminates when you start the engine and then after a moment the light goes out. Should the warning light go on again if an occupant unbuckles his seat belt while driving?
    2) Is there a way to cause the doors to automatically lock when the vehicle is in motion?
    3) Is there an accessory boot that can keep the brake dust from building so quickly on the (arrakis) wheels?
    Jerry,
    You can view the index of Volvo technical publications at
    https://www.volvotechinfo.com
    Select "Owner & independent services", then "service", then enter your model name and year.
    You can purchase technical bulletins on-line, and pay by credit card. Some are available as Adobe PDF files, so you get instant gratification.
    Seat belt light:
    Mine does not turn back on when a belt is removed.
    Automatic door locking once underway:
    To my knowledge, not offered in the USA yet, even though it would just be a software download. A business acquaintance in another country has this feature on his S80. Perhaps Volvo has concerns about potential lawsuits here.
    Brake dust:
    A chronic Volvo issue. At least one Board contributor claims to have fitted some sort of aftermarket dust shield. There are concerns about a reduction in brake airflow, which might diminish fade resistance. Cleaning the Arrakis wheels has become a weekly ritual. I keep them waxed and use a damp paper towel.
  • 2001volvos802001volvos80 Member Posts: 2
    Hi everyone;
    first time to post a msg here.
    Just got my S80 a week ago, I found the sound system on the doors make vibrating noise when I turn the BASS/TRIBLE to the right, or the sound volume is loud.
    Anyone has such experience?
    Tomorrow I will bring to the dealer to look at.
    thx
    charles
    Charles,
    You can read a report of a similar problem (and how it was fixed) in the technical files library at Club S80 International.
    URL: http://clubs.lycos.com/live/Directory/FileAlbum.asp?CG=68aali2dfna1380n004cf293tg&AID=9153
    Jerry, I had these added because I could not get the full warm weather package with infrared windshield (which interfered with navigation system on 2000 model). The screens do help; my back seat passengers appreciate them. The rear glass screen in easy to install. The side glass screens require removal of door panels. My set cost $200 installed at the factory. I don't know what they cost now. If you are interested in buying the screens, Club S80 International members get great prices on parts and accessories through a participating Volvo dealer doing internet business. The prices there should be significantly less than your local dealer; if you want to install them yourself you could save a lot. Personally, I would not want to take my door panels off, but that's just me.
    Broeux
  • claywaterfillclaywaterfill Member Posts: 534
    Hey guys, my wife loves the S80 but I have a problem. I was reading the new Consumer Reports 2002 New Car Preview and on page 148 they say the predicted reliability is disappointing and rate it "Poor." I noticed that the real world data showed 11 "excellent", 1 "very good" and 2 "average" ratings in the 14 areas they rate in the 2001 S80. The figures drop a little for 2000, but still nothing below "average." I was wondering what real owners say about the car?
  • im_brentwoodim_brentwood Member Posts: 4,883
    Early T6s had exploding trannies.(Late summer 98 production, they were all recalled for it)
    A few whiny check engine lights like most newer Volvos...
    Some odd front suspension bushing issues.. but overall good cars.
    The 00 T-6 we have has been fine (Mom drives it in NJ)
    Bill
    Consumer Reports has not tested one themselves since 1999 when they tested a base model with the 2.9l 6 and 4 spd auto.
    My 2001 2.9 is 14 months old and has 25,000 trouble free miles. I have replaced two headlight lamps and two taillight lamps--covered by warranty. Have occasional problem with driver's door failing to lock on first try with remote. But that's it.
    GP
  • postnobillspostnobills Member Posts: 43
    I have a 99 T6 and have had to replace headlights FOUR times and I also have a problem with the remote periodically not locking one of the doors. What I find most disappointing is that these are well-documented problems from the 99 model year which obviously have not been addressed by Volvo two model years later. Prior to this car the last car on which I had even a single headlight failure was my 1972 Dodge Coronet POS.
    There are many things I like about my S80, but the annoying quality problems have really soured me on recommending this car to anyone.
    I consider having a headlight burn out to be a nuisance not a design defect. Considering the fact that the headlights are on 100% of the time the car is in operation, I don't think the burn out rate is excessive. I actually have about 29,000 miles on my car, but no more than 10,000 can be attributed to highway driving. That means I have driven apprx 19,000 miles at an average speed of 20mph and 10,000 at around 60mph. Altogether my headlights have been burning for over 1,100 hours. I doubt if I have much more than that many hours of headlight use on my '93 ParkAvenue which I have driven 140,000 miles.
    GP
  • godeacsgodeacs Member Posts: 481
    I had a 97 Volvo with 60K miles and NEVER had a headlight burn out (with lights on all the time) Obviously, it is a design defect and I would find it VERY annoying on a $35K+ car.
    I have an 01 S80 with 4200 miles. So far, I have replaced 1 headlamp and 2 tail lamp bulbs. The H7 headlamp capsule only lasted 200 miles. A rear fog light bulb was also replaced, but only because it was physically broken (glass separated from the base) when the car was delivered. One front directional signal is intermittent, but that is because the socket makes poor contact. A replacement socket has been on order since June.
    I experienced similar poor service life with the OEM bulbs on my previous Volvo (1998 S70). Six months was typical for headlight capsules, and that was with the DRL turned Off. Once I switched to capsules NOT purchased from the dealer, operating life more than doubled (and they were half the price). The S70 also required regular socket replacements.
    While a bulb failure in no way compares to say, a transmission failure, it is a nuisance to quickly change the bulb before receiving a $50 police citation, particularly so in winter. To make an appointment with the dealer for replacement takes more than a week, and all you get is another poor quality bulb. I just change them myself.
    These lamp problems are long standing and widespread. One would think Volvo would have addressed them by now. Evidently, they consider short lamp life an asset, because it creates profit opportunities for dealers.
  • t6tolert6toler Member Posts: 19
    Charles, I was having a similar problem with my S80 T6 where when the stereo volume was not particularly high both front doors would rattle. Had it checked out at my dealer and the tech found "connector at tweeters noisy" and he "added electrical tape to connector" and I have not had any rattle since. I am guessing it was the lower speakers on the doors, not the upper speakers.
    Incidentally, I have my own problem that the dealer/tech couldn't resolve. With the ignition on and the car idling, the light intensity of the front reading lights changes and flickers. The rate of flicker is strangely not constant, but rather intermittent and without a smooth transitional frequency. Air Conditioning on or off makes no difference but the dash lights and the main cabin lights (the center light button on the roof console) do not show the same flicker problem. Showed tech at last service and he confirmed that the flicker was present and checked two other 2001s on the lot and apparently they have the same condition. Spoke with my service manager (Liz, she is awesome and holds her own amongst the guys at the dealership) and she said they are contacting "FTS," which is like a district service rep, and will get back to me. Anyone else have this annoying flicker?
    PS. I am at 5700 miles today.
    Benjamin, soon after I got my T6 (November 2000) I too noticed the random flickering. Shortly afterwards, the problem disappeared. Swedish gremlins? Apart from replacing light bulbs (3 headlight and 3 brake light)the only problem is the lock on the driver's door which doesn't always lock on the first try with the remote. The system however always arms as it should. Otherwise, after one year and 30,000km the car has been excellent. Danny
  • jbstljbstl Member Posts: 5
    Am thinking of buying my 1st Volvo '99 2.9
    low miles, (less than 30K).
    any problems to be on the lookout for? during test
    drive, heard a rattle in the dash, sounded like
    a loose screw rattling around.. any ideas...
    seems that most of the early '99 problems were on the T6, is that true...
  • shaunsshauns Member Posts: 24
    The air conditioner on my '99 2.9 seems to still think it's summer. It will often blow full cold from the "head" outlets when set to moderate (70-74) degree temperatures, and the only way we can stop it is to go to full heat or to dial down the fan. Actually, that doesn't stop the cold air, just the fan noise.
    I've taken it in to the dealer and have gotten the usual shrugs. Something about the dashboard, outside, and headliner temperatures are all averaged together to determine how hard it should work to get down to the right temperature.
    It's only just started doing this in the last few months, and I can't attribute the problem to a defrost/defog mode. I've wondered if the heating of the dashboard has anything to do with the problem. And of course, it's inconsistent. half the time it works just fine.
    Anyway - has anybody else experienced this problem and - perchance - been able to fix it?
    Shaun (freezing)
    For now, you can just turn off the compressor with the A/C switch. When you select "defrost" it will automatically come bck on.
    Some participants on another S80 board (Volvospy)reported similar problems. Their dealer connected to the diagnostic computer, which recommended cleaning accumulated dust from the temperature sensor, located behing a small grille on the climate control unit. At least one member used a small keyboard cleaning spray can, and his problem went away. This has not worked for everyone, but worth a try.
  • kjookjoo Member Posts: 27
    Will their be awd...................
    thanks Bob for the URL for the sound system problem.;
    I took the car to the dealer. They used a electrical tape to insulate the panel which is directly against the metal door, lt looks very cheaply designed. Now it gets better on some frequencies, but makes different noise on other sound frequencies. I looked the fixes, the form is a better matrial than the tape.
    Also I have a click noise from under the driver seat when I make a turn, braking and sudden bake, the dealer said it is a known problem caused by the power seat system, they ordered a piston which is recommended by Volvo to fix the problem.
    Also the car is vibrating badly on idle, the dealer said it is normal.
    My car has less than 700 miles, has gone to the deal three times in less than a month. Waiting for the part to come in for my fourth trip there.
    Regret didn't buy a Acura.
  • gerry18gerry18 Member Posts: 39
    To 2001volvos80. Due to their natural harmonics, in-line 6's are supposed to be the smoothest running engines out there, with the exception of 60 degree V-12's. Although I have no direct experience with the S80 (I recently down-selected to a BMW 530i - tails of woe on this site turned me against the S80), your car vibrating badly at idle just doesn't sound right. Did you notice anything like that when you first drove the car? Do any demonstrators on the lot vibrate like yours at idle? If there is another dealership in your area I'd go for a second opinion.
    I have a 2001 2.9 with approximately 4200 miles. If I do not use the car for several days, the engine idles like a 1 or 2 cylinder diesel for less than 1 minute after startup. I used to have a 1998 S70 that did the same thing.
    Other than that, it is difficult to determine if the engine is running or not when idling. It is the smoothest idling engine I have ever owned. There is no vibration whatsoever.
    I have found that the Volvo dealers in my area try to avoid warrantee work. A quick review of some of the factory service bulletins explains why. Volvo typically only reimburses the dealer for less than half of the actual labor time required.
    Whenever I have had a problem (with either the S70 of S80), response from the dealer after the first visit is always " we cannot duplicate the problem". Once you make a second visit and demonstrate the problem, the response changes to "they all do this" (in other words - it is a normal feature). The final step is to drive one of the cars in dealer inventory, to prove that not all samples have the problem, or, to do some research and find a technical bulletin pertaining to the issue. Only then will the dealer relent and attempt an actual repair. The approach of forcing multiple visits to solve simple (and known) problems is an attempt to discourage you. You should try to bypass a step by immediately asking them to demonstrate to you any car in their inventory with the same "normal" idle.
    just curious, where do you live? Sorry to hear you get that kind of "service"....
    Rhode Island. But I found similar tactics employed by a nearby Massachusetts dealer. I can sympathize with them. Example: Volvo allows 0.6 hours to repair the infamous steering "knock" prevalent on the S60, S80, and new V70. To do it right, it is a 2-3 hour job. So the dealer gets to pay his technician for 3 hours and gets reimbursed by Volvo for less than one. Is it any wonder they are not particularly enthusiastic about performing warrantee work?
    The DRLs are at 90% Intensity IIRC.
    And they can be switched off by the dealer using VADIS.
    The feature you saw is called "HomeSafe Lighting" Its' on all 99+ Volvos..
    They should have showed you that one at delivery!
    Bill
    "HomeSafe" lighting is described in the Owners Manua, but is easy to miss (just one sentence). On my S80, the lights under the mirrors come on as well. I like it better than some of the fully automatic systems, because you can easily choose to activate it or not each time you exit the car.
    I have the factory wiring manual for the 2001 S80. For USA cars, the headlights are operated by a relay and there is no DRL module. The headlights can only be On or Off. There is no change in intensity with different positions of the headlamp switch. Note that the tail lights and marker lights all stay on during the day as well.
    It probably doesn't matter. I doubt if you could see the difference between 90% and 100% (a ratio of 1.1 to 1) in the daytime. Given that the system voltage varies (at least) between 12.8V and 14V, lamp power (for a constant resistance), and therefore intensity, will vary 1.2 to 1 just under different operating conditions.
    I do not have a T6, so can't help much there. WIth a mix of 50%-50% city/highway, I average 21.6 MPG. Lowest/highest I have measured between fuel refills is 18.9 and 27 (200 mile trip). These values are based on odometer and gas pump readings, not the "message center". I use 35 pounds air pressure all around with the 225-50/17 tires. The fact that you say "smooth and powerful" implies that the turbo must be wound up at least once in a while. I have to settle for "smooth and adequate". I would get into trouble with a T6.
