Audi A6
14041434546136
  • ktcoffeyktcoffey Member Posts: 1
    One day, the passenger window on my '99 A6Q suddenly wouldn't close completely. At the dealer, the service folks replaced a plastic guide piece inside the door (on both front doors actually, lest the other one have the same problem), which seems to have cured the problem.
    In the days following, I noticed several things suggesting that maybe the door panels had not been remounted correctly. First, the door lock "nub" is now further down in the door on the passenger side, in both locked and unlocked positions. Second, the "sill" portion of the panel, just at the bottom of the window, appears higher on the passenger side, which is most obvious next to the B pillar trim. Third, the low speaker in the passenger door, or perhaps the speaker grill or the panel itself, buzzes with music having significant bass, which it never did before. Fourth, the gap between the door panel and the upper dash, around and above the wood strip, is nearly a quarter inch wide on the passenger side and quite nearly touching on the driver side.
    In a subsequent service visit, I requested that the alignment of the door panels be checked. When I picked up the car, I was told that there was no alignment adjustment for the door panels, and that their screw mounting holes were fixed in alignment.
    The door panels are definitely not the way they were. Does anyone else have knowledge of door panel alignment for this model? How do the alignment cues I have noted appear on your like vehicle? Thank you for any assistance.
  • bertram60bertram60 Member Posts: 113
    I was looking at having to do the same. As I had purchased this car, had 43k miles on it and only 10 months of AoA scheduled maintenance, I decided to bail out. The big brake kit is the brembo kit that's used on both the S8 and the 996 Porsche (front only). I love the look and the power, but not the cost (especially since pads and rotors would no longer be covered by AoA either). I just got itchy, mad and impulsive. If I could have found another A8 (short wheelbase) or S8 for the right money I probably would have just flipped into a short term lease on that, but alas, none were available (my dealer's A8L was canvas beige and ecru, not even on my maybe list. S8 was brilliant black with titanium, but had the alcantara inserts in the seats. I could just imagine climbing in all sweaty and dirty and passing that on to the suede forever...oh for a silver or ming blue S8....ahhhhh.
  • dsumberadsumbera Member Posts: 8
    Has anyone run across this? I have noticed that on occasion (and getting more frequent due to the time change) the xenon headlights on my '01 2.7T will be cock-eyed (one up and one down). Have not found a pattern to it yet. Sometimes they will be fine and other times either or both will be shining into the ground. The only way to correct it is to turn off the car, restart the engine and turn the lights back on. This is repeated until the headlights are both up.
    I thought it might have been from putting the car in gear before the headlights had leveled, but I can sit in park and watch them do their thing against the garage wall. Have also on rare occasions had them both start off fine, only to drop while I was driving. When that happens, I can only see about 20' in front of the car. Not a good thing!
    Right now it is more of an anouyance than a dire need. I will be going in next month for my 5k/6month maintenance and will get it looked at.
    Knowing my luck, the mechanic will not be able to get them to do it. Any thoughts would be appreciated.
  • markcincinnatimarkcincinnati Member Posts: 5,343
    My dealer says this is not supposed to happen, and take it into your dealer to have it fixed, my lights self level when I turn the car on and they have thus far, stayed rock steady.
  • timcartimcar Member Posts: 363
    1.I've read that the Alcantara isn't suede, but actually a polyester fabric. (Though it certainly doesn't cost like polyester.) If so, it might not be all that difficult to clean.
    2. I've read numerous reports of cock-eyed Xenon's. As Mark says, there's a problem with the self-leveling system, or the electronics that control them. I've never had the problem. (Knock-on-wood.) The only electrical anomaly I've experienced is to have the stereo display blank monetarily, and go back on. This would happen infrequently for the first few months, but hasn't occurred in about 6 months.
  • kirby2010kirby2010 Member Posts: 136
    The Audi just went over 10,000 miles today. (2.7T, 6-speed). I've had the car 10 months and my only regret is I don't have an opportunity to drive it more. Second service interval this week - all routine stuff. I'm looking forward to a long relationship with this car - unless Audi decides to import the S6 sedan.
    I know some of you read everything that is printed or posted on Audi. Does anyone know if Audi will bring the S6 sedan to the states??
    New AutoWeek says no S6 Sedan, but that Audi is considering briging in the RS6 Sedan! How about a twin turbo V8 with 460hp?
  • lintorontolintoronto Member Posts: 8
    Mark:
    I have read with interest your love for cars, particularly Audis, and your obviously profound knowlege about them. I am seriously considering a new A4 3.0 and would rather wait to get a feel for the CVT in the spring. I would welcome your thoughts on the new 2002 A4 3.0, assuming that by now you have had a chance to see, examine and drive the car. Particular reference to the previous A4 2.8 and the A6 2.8 as well as the BMW 3 series would be welcomed; understandably, the CVT has not yet reached our shores. I know that you are always generous with your time in commenting, but I hope this is not too great an imposition. Many thanks for whatever you wish to say.
    I urge you to read the Car and Driver review of the A4 FWD CVT. This is one Audi that I have not yet driven. The last FWD A4 I drove was a 2.8 with a 5spd -- and I thought it was pretty impressive.
    I would not consider a non-quattro Audi of any flavor however. At this point the CVT is only available in FWD Audi's.
    The test report of the CVT in Car and Driver is favorable with a "this is NOT the future of transmissions, opinion." After reading the preliminary reviews of the 6spd Tiptronic, I would assume that the 6spd Tip will be the transmission that will be broadly applied to the performace models from Audi, BMW and Mercedes, etc.
    The manual transmission is perhaps an endangered species in these sport-sedans like Audi's (although hopefully less endangered in A4's).
    For the small (relatively) additional premimium that quattro commands, I would ONLY consider either the 6spd manual A4 3.0 or the 5spd Tip at this time (and I would get the sport supension option, too).
    I do plan to drive a CVT because of my love and curiosity of cars in general and Audis in particular, but at this point I have not driven any FWD 2002 A4's; only the 2.5TD, 1.8T and 3.0 quattro versions (and only with manual transmissions thus far).
    Many thanks, Mark. Your comments are greatly appreciated.
  • morphiemorphie Member Posts: 95
    Greetings, all;
    Happy Thanksgiving.
    Just a brief update on my wife's 2002 A6 Avant 3.0. This replaced her 1999 2.8, and is in addition to a 2.7T.
    The vehicle was just in for a snow tire change over (Michelin Arctic Alpins); I had the first oil change done (2,500 miles). I simply cannot get used to the reccomended 10,000 miles. Call me paranoid. I will probably continue at 7,500 mile intervals.
    As far as mechanicals are concerned, the car has been trouble free; a nice improvement. A front tire needed to be rebalanced; that is the extent of the "warranty" concerns.
    The new 3.0 six continues to impress. While of somewhat lesser performance than the 2.7T, and significantly less than the 4.2, it is a viable option. It is especially impressive in the A4.
    The only minor annoyance: apparently, due to enhancements to the transmission/torque converter, some remapping of the electronics and, I would imagine, the increased performance, accelerating from a stop or "off idle" is a bit abrupt. Not unpleasant, merely noticeable.
    Happy Holidays.
  • noshonosho Member Posts: 119
    Occasionally, the question comes up about mileage.... I just returned from visiting my sister in the Cincinnati area. 635 miles each way with 28.4 MPG from NJ to OH and 29.1 MPG back to NJ. Less traffic today (Saturday) than Wednesday which probably explains the better mileage back (10H39M to OH / 10H13M back to NJ). Fortunately, it was a boring trip....
  • kjanakjana Member Posts: 16
    Greetings:
    I am seriously considering either the 2.7T5A. This may seem like a silly question, but when I drive I frequently rest my elbow on the ledge of the driver's window. The window ledge on the A.6 seems too high for me to rest my elbow comfortably. I am an average size guy. Has anyone noticed this? Is it something you can get used to over time? TIA.
    It is an unusual, but certainly not silly, question.
    I have not noticed this problem. Then again, I probably do not rest my elbow on the "ledge". Have you tried raising the seat height? When combined with the adjustable steering column, you may be able to find a comfortable position.
    Whenever we purchase a new vehicle, especially one we have not owned previously, I request the loan of an identical model for at least a few hours. This permits one to experience the idiosyncrasies that all vehicles possess, as well as utilize the car on familiar roads.
    Isn't there.... The driver door arm "rest" is fairly useless also. I've done some 2600 mile trips and can say you easily get use to the "lack" of a left arm rest.
  • cityscapex5cityscapex5 Member Posts: 14
    in depreciation according to Money Magazine. The A6 managed to beat out such stalwarts as the Ford Expiration and Land Rover Discoverey in reducing your initial investment after 4 years.
    Me too! Thought the same thing when I first got my 2.7T. Fortunately, elbows are adjustable. I.e., now that I've gotten used to it, it feels just right.
  • rxkerxke Member Posts: 168
    I just started shopping for a 2002 A6 quattro(Preferred luxury and convenience package and bose)with an MSRP of $41,005 in the NY metro area. Does anyone have recent experience with purchase prices or leases(39 month 12,000 or 15,000 per year) for this car?
    Thanks for any input.
  • wbreauxwbreaux Member Posts: 33
    A few weeks ago we got my wife an '02 A6 quattro, preferred luxury package, convenience package, bose, premium package, rear and side shades, for $41,000 (in Houston). I think msrp was between $42.5 and $43. We love the car. Overall I would rate it almost as highly my '00 E320, and for almost $10k less.
  • habitat1habitat1 Member Posts: 4,282
    ..when you decided to get the A6? I'm just curious as to how you think it compares to a 530i. Thanks.
    My recent experience, with a 2002 A6 3.0, combined with previous Audi's, leads me to conclude that a well equipped vehicle, which is a new model, will be discounted by about $2,000.00, maximum. As the pipeline fills, during the first quarter, deeper discounts will be available. Anything greater than a $3,000.00 discount is considered "aggressive" pricing.
    Of course, souring economic conditions or the demand for specialty models (e.g. "S" types), will alter this generalization.
    Most successful price negotiations are conducted on an amount over dealer invoice. Last year I obtained an '01 A4 and an '01 A6 from Audi of Mendham. A dealer I would strongly recommend. We paid $1,700 over dealer invoice for each. Northern NJ has quite a few Audi dealers. You can shop around. Jack Daniels in Paramus tends to have pretty aggressive pricing.
    A good deal at this time might be anywhere from $1500 to $2500 over dealer invoice depending on model, inventory levels, the dealer, etc. You can get dealer invoice pricing here at Edmunds, add about $2K to that, and that's about what you should have to pay. Monthly payments will vary by financing source, and credit worthiness. Negotiate the price first.
    In answer to the prior posting, neither my wife nor I or crazy about BMWs so we did not seriously consider a 530. This is mainly due to looks and space, for which we think the Audi and E320 are far superior. I know BMW is noted for performance, which would be nice, but is not high on our list. The other cars I would have considered for my wife (assuming I had input) were Jaguar S type (also relatively cramped interior), Maxima / Infiniti equivalent, Volvo S80, or 300M. She looked in detail at the A6 and S80 and loved the Audi.
    My friend had the same question A6 vs BMW 5 -- drove the Bimmer first then the Audi.
    Stopped looking at the Bimmer.
    The people who seriously test drive these cars, generally do not find them appealing to the same "needs" or tastes.
    In this respect, I'll quote my friend, "the BMW was great, I loved it, I would like to have it -- I cannot afford two cars, so I'll take the Audi, which I also loved -- but for different reasons. The two cars just don't do the same things. Would you ask someone to compare an apple to a fish? The are both food items, to be sure; they are both, to my tastes, good -- but they should not be compared. Now comparing an apple to a pear is possible."
    In my opinion, you can compare an Audi A4 quattro to a BMW 3 series AWD or you can compare an A6 quattro to an AWD Volvo or Jaguar or you can compare an A6 quattro to a Mercedes E class with 4Matic, or perhaps even a VW Passat w/4Motion. . .etc.
    I agree with my friend, a 5 series BMW is a very good car -- but it is not comparable directly to an A6 quattro equipped car. Apples and fish.
    I have an '01 A6 2.7T w/6-speed. I have driven the 530 w/auto. (Somewhere in a previous posting I wrote about my views). Two things that struck me about the 530 were the narrow accommodations and the "cheaper" looking interior finish. It seemed like too much plastic. I rode in the passenger seat of the 530 for a bit, too, and was surprised by the manual seat adjustments. I haven't taken either car to the track - in fact I've only made a couple road trips in the Audi. I prefer the Audi because it is a more comfortable car with plenty of performance versus a "performance sedan" with only modest comfort. I haven't tried it yet but if you believe the experts I should be able to leave the 530 in the dust.
  • rmorin2rmorin2 Member Posts: 110
    I'm a long time BMW owner including 5 and 3 series. Fine cars. I am seriously considering an A6 probably a 4.2 as well as a 540 BMW.
    Styling of the A6 is starting to grow on me. Would appreciate hearing from some A6 4.2 owners.
    A6 Sales are down some 25% Year to Year. Contrast that with BMW 5 Series sales which are about Flat with last year - not bad considering the 5 series is being totally redesigned next year. If dealers are still giving you the runaround - I would also show them the Money Magazine article which states that the A6 depreciates faster than a .Com stock on the Nasdaq http://money.cnn.com/2001/11/29/autos/used_cars/ In fact - it led all cars/SUV's in 4 year depreciation. At least BMW's hold their value quite well. The A6 is a fine car but it does not hold up to a BMW in these areas and you shouldnt have to pay for one as if it did.
  • mariobgoodemariobgoode Member Posts: 114
    I'm on my way to the dealer today, and I chanced upon your suggestion while waiting for my wife to get dressed. Brilliant! Now, let's see if it works: slow sales, holidays coming up, bad press. Should be a winner, huh? I'll keep you posted. Bye. Mario
  • peteri1peteri1 Member Posts: 21
    In Illinois (11/21) I received lease quotes for both the A6 4.2 and the 540i. Audi is calling it at 54% residual at 39 months and BMW at 60% at 36 months.
    I believe BMW may be subsidizing since the model is in its last year of the cycle. The CNN comments apply to the 98 A6 which was the 2.8 derivative, prior to the release of the 2.7T and the 4.2 and, subsequently, the 3.0.
    All cars have seen much more aggressive depreciation since many leasing companies went belly up by fabricating high residuals in 1996-1999.
    The residual a BMW @ 36 months vs the Audi at 39 months -- 60% and 54% -- I wonder what they would be at the same term? These differences do not seem to really clearly favor one over the other.
    Financing arms and institutions have been burned and as noted have changed the depreciation numbers to reflect reality more closely.
    Cars depreciate -- and depreciation rates (real rates) are known after the fact (kind of like the recession "leading and trailing" indicators). BMW 7 series have (historically/generally, but not every single model year) depreciated very rapidly. From time to time, Porches retain their value, but watch out, the Boxster has had its good and bad years, too. Corvettes, etc.
    Cars, for most of us, are RAPIDLY depreciating assets -- sometimes they depreciate so quickly they appear to be more like just plain old expenses. Buy/lease the car that you enjoy -- trying to determine which is "the car for you" (based on depreciation) is like trying to time the stock market -- good luck.
    I still love my A6 4.2 -- but then again I am leasing. I am not worried about trade in value. I know these things (cars) lose value [rapidly]. They, so far, have remained great performers, safe and fun. Jay Leno invests in cars -- I wish I could.
  • gooddesigngooddesign Member Posts: 34
    Several people posted the following comparisons earlier this year. I compiled them and numbered them. The typos are not mine! The list may be outdated for 2002 models.
    Hope this helps someone decide one way or the other. ;-)
    1) If the lights are on (running/headlights) the BMW's windshield washing system automatically gushes the headlights, your hood, and bumper with windshield fluid. What happens when you just want to clean your windshield only at night? You can't unless you turn off the lights completely. When the headlight washer system is activated it sprays windshield washer fluid all over the front of the car, it really makes a mess.
    The Audi- Push the stalk once to spray the windshield, hold the stalk down longer for the headlights.
    Advantage Audi
    2) The Audi's stereo system works without the key being inserted in the ignition. After about 1.5 hours the radio automatically shuts off to prevent the battery from going dead. Advantage Audi.
    3) Audi's interior lights can be programmed to work independently. If you only want the rear interior lights to go on when you open the doors you can do that. The BMW is everything or nothing.
    Advantage Audi.
    4) The Audi has a hook that holds the panel up on the spare tire compartment. That makes using the spare a lot easier. The BMW? You have to hold the panel with one hand while you try to remove the spare tire with the other, good luck. Advantage Audi.
    5) The BMW's Folding rear seats can only be operated from the trunk. The Audi's from within the cabin. What happens when it's pouring rain outside (like today) and your umbrella is in the trunk. You guessed it. In the BMW you would have to get out of your car, get soaked, and open the trunk. In the Audi you just pull the seat lever (lockable), Fold down the rear seat, reach into the trunk and grab your umbrella, All while remaining dry inside your car. Advantage Audi.
    6) Audi's AWD systems have a real lowered sports suspension. BMW's AWD suspension is jacked up even higher than the normal suspension. Giving it that Riding on stilts look. Advantage Audi.
    7) Audi's rear power window switches are illuminated. BMW Nope. Advantage Audi
    8) Audi has a light on the bottom rear portion of all doors. When the door is open you see the light from a distance. The 5 series has it but the 3 series doesn't.
    9) Minor- the Audi's trunk unlocks with the driver's door. I find myself always having to push the trunk release on the BMW a lot because it only unlocks the trunk when all doors are unlocked. Advantage Tie
    10) Center rear seatbelt- The Audi's center rear seat seatbelt is a shoulder belt with a retracting roll. The BMW has an airline style non-retracting lap belt in the center rear position. This makes a huge difference in installing a child seat in that position (universally considered the safest position for a child seat). Advantage- Audi
    11) Interior lighting fixtures- The Audi has nicely designed interior lighting fixtures while the BMW has what amounts to a bare flashlight bulb in front of a crinkled plastic background. Advantage- Audi
    12) Moonroof switch - Glitches aside, the Audi has a clever dial control that enables you to, with one touch, dial up the amount of "open" you want.
    13) Real aluminium interior trim
    14) Far stronger/better quality door hinges than BMWs high modulous plastic (black piece)
    15) Nice chrome plated trunk hooks.
    16) Includes free trunk net
    17) Includes first aid kit and emerg. triangles headliner handles on driver side and passenger side (missing on BMW coupes) -but BMW's get nice rechargeable flashlight
    17) New Symphony indash CD-changer/cassette unit standard
    18) Thick sport steering wheel as a factory build option
    19) Security alarm standard
    20) The Audi has this mini sun visor above the rear view mirror that blocks the sun in the gap between the rear view mirror and the top of the windshield. Sure, it's a little thing, but it really impressed me in terms of how thorough Audi was in designing that car.
    Hi, y'all. Can somebody help me? I'm in contract with a dealer for an '02 2.7T 6M. Problem is, I wanted the sport package and there is none available in the NY-NJ-CT tri-state area. He has one with 17" wheels, and that's it. No sport suspension, front sport seats, etc. He'll reduce the cost by about 600 bucks. Should I put in an order and get it in March, or settle for what he's got. What do you think? Will appreciate any response. Thank you. Mario
    If you plan on keeping your 2.7T at least 30 months, I'd order one the exact way you wanted it, if I were you.
    I have had an A6 first without the sport package -- a 2000 then with it -- a 2001 (and my 2000 had the 17" wheels). The sport package is worth the wait.
    I probably will keep it for only 39 months (the period of the lease), and then move up to the A8 which was my original dream car. I just need one car to enjoy while Audi is developing the next generation A8. I'm definitely giving it up at the end of the term, or I'll get another one, depending on what's available at that time. The current model and style is getting stale, and I'm kinda hoping they'll spruce it up to keep it fresh and aggressive looking. I appreciate your input, especially since you are the recognized expert on the subject in these parts. Best regards. Mario
    Hard to believe there's no sport package equipped A6 in the tri-state area. I'd want to drive and sit in one before ordering. My 2.7T doesn't have a sport package. Wish it had the suspension, but I don't fit the sports seats. Audi has also changed the suspension between '01 and '02, and I've read reports that both the standard and sport suspensions are a little stiffer than they were. I'd suggest that even if you can't find a 6-speed with sport before ordering that you test drive at least a tip with the sport suspension and seats.
    A friend of mine said "I am often wrong, but never unsure of myself." So I am sure of what I think and sure of its applicability to me -- but that doesn't mean I am right.
    Today, based on what is available in the US, I would acquire a mostly maxed out 2.7T with a 6spd. As much as I love my 4.2, I really miss the manual transmission, in spite of the fact that the 4.2 does feel different than a 2.7 -- for 2002, the 2.7T's chassis has been stiffened, the sound deadening improved, an "improved" sport suspension offered, the cool looking twin tail pipes extended through the lower lip of the rear bumber, the front brakes improved, and a host of other subtle improvements -- and a stir your own transmission.
    I can only assume further improvements in the breed will arrive for the 2003 model year (A6) which is probably what I will get, but not before I test drive a new generation S4, if such a puppy is available by then. Having had an A8, I can tell you it is (was) a wonderful car, but I want a bit more involvement when I drive, hence my mild regret at getting another 4.2 (which I am sure you know is auto only). The emphasis is on the word mild, BTW.
    Anyway, even the S6, if it is only an automatic, would probably not get my attention, unless the automatic is that new and reportedly marvelous 6 spd tip (which I hear will be the transmission in the next generation -- to make it stateside -- A8, A8L and S8).
    So, my itch to switch (my own gears) is, at this moment in time, my prime motivator, assuming that the car has plenty of "grunt" -- which I am sure you know, the 2.7T has -- especially when equipped with the 6spd manual.
    And darn, I was more convinced to get a 6-speed with the sports package. I forgot to say that they did not have one in the color I wanted, the new crystal blue metallic. They had one in silver, with all the options I wanted, including sports, and I'm now in a quandary if I should wait 3 months or settle for what is available now. I'm not in any hurry, but that car on the lot seems to beckon. I'm reminded of the sirens in Greek mythology, calling to the sailors to come nearer, only to find themselves in disastrous situation. Decisions, decisions, decisions. BTW, the dealer is offering less than 600/month for 39 months, with 1500 and the taxes down.
    Since we are delving into Epic mythology, it would appear that Mario has two choices: lash yourself to the mast, or fill your ears with wax. Neither would seem to be very palatable. Consequently, allow me to suggest an alternative:
    I am a believer in following the dictates of your heart when it comes to emotional purchases. Accordingly, if you want crystal blue, wait for it. As regards silver: I am biased and, therefore, not a reliable source of opinion: we recently took delivery of our first silver A6.
    Of course, we could consult Homer; that, however, would require a seance.
    Good luck with your purchase; we should all be so fortunate to be faced with such a dilemma.
  • tbtc_325tbtc_325 Member Posts: 1
    The frontend and steering wheel of my 2001 2.7T vibrates when I apply the brakes when going over bumps such as railroad tracks or a potholes. On smooth road surfaces the brakes and frontend are perfect. It has been a problem since it was new. It has become most annoying. I have not notified the dealer and would like to know if others have had a similar problem. Thanks for your help
    Nope, never heard this one before. Almost sounds as if it might be your ABS activating due to the difference in friction that occurs to wheels on irregular surfaces. I'd have the dealer look at it.
  • grogsuzgrogsuz Member Posts: 14
    At the 1000 mile mark my '02 4.2 developed a thump from right front of car that sounded much like tire out of balance or running over bots dots.Turns out CV boot somehow was torn (transit maybe?).Dealer never saw this on new quattros because of their reliable track reccord.Anyone else ever experience this?
    Steve, I reread your post, and you might be experiencing something which I also experienced in my '01 2.7T. When I reread "railroad tracks", I recalled experiencing something similar. It sounded and felt like a very large spring resonating. I think I may even have experienced something like it without braking. I don't know what it is, but it almost felt like the whole front suspension resonating. If it's the same thing you've experienced, I think it may be normal and not a cause of concern. It could be associated with the ABS as I suggested in my first post, as ABS often has a spring-like sound associated with it's activation, or something else. I've driven about 7K since it first occurred and have rarely experienced it again and have experienced no difficulty when it occurred or after.
    I've just returned from a very enjoyable road trip to Atlantic City (~700 miles round trip). On the ride back my "check engine" light came on. I had a similar experience in one of the others cars a few months ago. (The one I drive so I don't have to put local miles on my Audi (2.7T, 6M)).
    When the "check engine" light on my other car came on I took the car to the dealer. Turns out the lanyard that held the gas cap was caught between the cap and the filler - preventing a tight seal of the gas cap. Since I had just had the Audi filled (full service only in NJ) I suspected the same problem. I pulled off at the next service area and sure enough the cap was loose. The "check engine" light didn't go out right away but I was comfortable continuing on. We stopped for lunch a while later and after lunch the light was out and remained out.
    As far as the ride is concerned I set the cruise at about 75 when traffic was light and still got passed by a few folks. Seems like the craziest drivers out there are in small Chevy pickups and Ford Tauruses. If you're still on the fence regarding which car to buy a road trip will sell you on the Audi - comfortable, powerful, and a pleasure to drive in the inclement weather which dogged us on the trip south.
    If you live in the northeast and don't have EZ Pass you should get it. For those of you who don't have tolls - EZ Pass is electronic toll collecting that has been adopted by most states in the northeast. A plastic encased device fastens with velcro on the windshield behind the rear view mirror. Lanes at the toll areas are reserved for EZ Pass holders and you can drive through at about 15 mph. The same transponder is compatible with MA, NY, and NJ tolls.
  • wasabi911wasabi911 Member Posts: 53
    My parents are looking to lease a new car, and the Audi A6 is one of the cars they're looking at.
    One of the decision factors is the the end of lease experience, and they are wondering if anyone can tell us their Audi experience. We've heard horror stories about dealers, such as Nissan and even VW, gouging fee and penalties costing thousands of dollars. The only lease experiences they have had were Mercedes, and MB are wonderful in that respect in which they don't charge any penalties for damages on the car that can be covered by a credit card.
    Prior to leasing any vehicle, it would be prudent to familiarize oneself with recent, new federal disclosure laws.
    Fortunately, you do not have to read the actual statutes, merely review summaries of the leasing experience on web sites such as "Edmunds".
    Suffice to say that any lease must disclose both up front and end of lease obligations. I am familiar with Mercedes Credit terms and conditions; I can assure you that they are no more favorable than Audi (VW Credit or a major bank). Since the termination obligations are explicit, it is fair to say that most who encounter lease end problems are charged for excess wear and tear. If one is diligent with maintenance, both mechanical and cosmetic, there should be no financial surprises.
    One final caveat: there is no substitute for an informed consumer; the terms and conditions of the lease must be read and, if there are any questions, clarified prior to signing.
    I've been told by dealers and others that many lessees abuse there leased cars and don't maintain them. If this is true, the lessors must be happy to see the cars I turn in. As Mike said, the lessor is required by law to provide end-of-lease terms in writing. They should also be able to provide a written explanation of what constitutes "excessive wear and tear." It's useful to consider the term "excessive;" Most written policies allow for SOME cosmetic damage.
    Many lessors use third-party companies to inspect end-of-lease autos. So there is some individual subjectivity. If any party were to try to stick me with something for which I'm not legally responsible, I wouldn't pay. Conversely, if I am, I am!
    I just got back from a road trip with our '02 A6 3.0 quattro. On the trip back we went through some of the most severe rain I've ever seen. The car was rock solid at speeds of 60-70mph even in this weather. I was very impressed; it was much steadier than my E320 would have been. I was trying to get a 2 wheel drive A6 because we live in a warm climate but we got the quattro because we didn't want to wait. I'm glad we got the quattro now.
    I've got 2 complaints about the A6 after the trip; the hard steering wheel and narrow trunk. I went to put my golf clubs in for the trip (the A6 is for my wife) and they wouldn't fit! There is 5 to 6 inches on each side of the trunk which is not usable for some reason. I had to take my woods out of the bag, put the bag in, and then maneuver my woods in diaganolly. A major pain that I never would have expected; I've never had a car that clubs wouldn't fit in, not a 300ZX / Saturn etc. I noticed the hardness of the steering wheel for much of the time I drove. I really missed my nice soft E320 steering wheel.
  • anoonananoonan Member Posts: 29
    I'm going to be looking at the '02 A6 and am an avid golfer so fitting golf clubs is key. I just can't believe that they won't fit in the trunk...I do seem to remember the trunk is long and narrow.
    That's funny though, my dad drove the A8 and he said his clubs wouldn't fit either and was a main reason why he didn't go with it. The Audi salesman says that was the first time anyone actually tried to do that!
    When we golf (or some semblance thereof) we do not use the sedan, but employ my wife's Avant. It will carry four (4) bags, with carts, and a Newfoundland. However, not at the same time. Fortunately, the Newfie does not golf.
  • jrosasmcjrosasmc Member Posts: 1,711
    I still can't believe Consumer Reports magazine still gives the Audis a below-average rating for reliability. They gave the company grief over the 5000 fiasco in the mid-80s, and they rated the '89-'94 100s as "Used Cars to Avoid." What next? Audis costing as much as a BMW 7-Series?
