Made an appointment for my Intrepid week after next. Having the driver's seat recall issue addressed, the door seals replaced, and a speaker buzz examined. Interestingly enough, the service manager said that they didn't "rearrange the door seals" but will only replace them. In addition I'm having the serpentine belt examined for wear. I know that has been an area of concern for some... Service manager suggested that somewhere between 70,000 and 100,000 miles they recommend a replacement.
4.7l or 5.7l equipped?
I kinda like the new Durango, too. No need for an SUV here, but that Hemi sounds tempting!
Thanks for all the feedback on belts....
The mech. said he's doing a bunch of these.
Even getting into rebuilding them .
He said that dodge is referring the 2.7's as their "sludge motors".
I love the car and it's ran great but it started to sound like a diesel in the morning until i revved it up pass 1000rpms(not good).
And,yeah my oil light would come on at a stop light too.
I haven't bothered to look it up in the Intrepid's owner's manual yet, but one day, we were going through the owner's manual of the '03 Regal my Dad recently bought, and it mentioned that it's normal for the light to come on in those situations. I also have an owner's manual to a '76 LeMans (nostalgia...I wanted one of those cars when I was a kid, and still kinda do!), and it even says the same thing!
Still, with the exception of my 'Trep, I've only had one car where the oil light would come on while idling...my '67 Pontiac Catalina. It also has an aftermarket gauge hooked up, so I could tell exactly what it was doing. At idle, once the pressure dropped down to under 18 psi or so, the light would start to flicker. It sounded like it was idling awfully slow to begin with, so I just advanced the timing on the distributor a bit to make it go away. Unfortunately, I don't think you can adjust the idle on a 'Trep so easily!!
Only other time I'd ever have the oil light come on was when it got too low and I made a sudden stop or turn. So that's why I don't fully believe it when they say it's "normal"! Because the only time I've ever seen it is when there's something wrong with the car.
As for my 'Trep, I haven't seen that oil light come on in awhile now. However, I recently moved, and my commute to work is now only about 3 1/2 miles. The heater's just starting to blow warm air by the time I pull into the parking lot at work!
And emale, would you send me an email at pat@edmunds.com - thanks.
But i'm use to cars that it would not really bother waiting longer than 3k.Now i know.
Give me my old 69 torino back please!
Anyway,the mech. called last night and said that it's so bad that he doesn't know how much longer i have w/this motor.He did say this was about as bad as he's seen.And a rebuild thru him is $3400.
I told him to finish putting on the new pump,timing chain tensioner and button it up.
Guess we're out shopping this weekend.:(
And fer what it's worth i have a '95 neon 2.0
with 125k that has been serviced about as much without any oil related probs.
Clicking your name only got me your stats.
I wonder if a used engine out of a junkyard would be much cheaper than a rebuilt one? Last time I was in the junkyard, they had about 15-20 LH cars of '98-01 vintage (it was in '01 that I went). They were all in there as the result of a crash, as opposed to major mechanical failure. Maybe if you could find a low-mileage engine, it might be worth it.
I've also wondered how hard it would be to swap out the 2.7 if it was shot, and drop in a bigger engine like a 3.2 or 3.5?
After that though, I'm debating on whether or not I should take it back to the dealer, or to my local mechanic. I have an extended warranty, which is good to 100K miles, but has a $200 deductible. However, I'm worried that if I take it to the dealer, they're going to try telling me I didn't change the oil (I did all but three changes myself, so I don't really have proof) and that's what's screwing it up.
I trust my mechanic, but then I'm worried that if he finds something that would've been covered under the warranty, I'd end up screwing myself by paying him to do the work.
It does still seem to be running fine, though. No nasty noises or anything. When an engine gets sludged up, does it sound any different?
As for junkyard engines, I was kinda figuring that if the car was still fairly new and in there because of an accident, maybe the engine didn't have enough time to get abused too badly! One little thing I forgot about though, is that cars don't have mechanical odometers anymore. You'd need to have the power on to read the odometer on an Intrepid, and chances are the wrecks in the junkyard aren't going to have power anymore!
The service manager was concerned about this issue--as it hadn't been his experience that the 2.7--in either the Intrepid or Stratus applications--was prone to trouble. In his review of TSB's he found nothing directly related to sludge buildup as an issue or with the oil sending unit. From his personal experience he said that the unit (the 2.7) has been a particularly solid and low maintenance unit. He's not denying the story of trouble--but he suggests that it's not a routine problem.
My friend who manages the rental fleet said that same. In fact, he reports, the Intrepid rentals they use have been particularly good. Now..that said...he did acknowledge that they rarely keep one beyond 30K because they move on to the retail unit--but in that time they are used hard.
The 2.7 in my sister-in-laws Stratus is fast approaching 50,000 miles and has been trouble free.. My brother--and I--have both used synthetics since the first oil change after break in.
The mystery continues...
I've been using Castrol 10W-30 ever since I've owned the car, so that's what I put in this time. I'd be worried switching to a lighter oil after all this time. Anyway, I haven't driven the car enough since I changed the oil (basically just across the street), so I haven't had a chance to see if the oil light still comes on or not.
And so far all i've gotten was a message about the motor giving him a fit(what over,i don't know).I even drove by the shop i dropped it off at,but he wasn't there.I know he has a 2nd garage where he has a couple part time mech at night werking.But i don't know where it is and i only have 1 # for him.
Needless to say i'm kinda p#ssed off over no call.And my wife needs that car for werk monday.So i'm hearing crap from her too;)
And yes i was using 10w30 just like i always have.And if that would make that much difference
i would consider that a design flaw.But maybe i'm biased.
What do you think?
The two key issues (in order of importance) are: #1. Frequency of oil change; and #2. Quality of oil filter.
Quality of oil is not really an issue today. All the major brands meet the SAE certifications required by the auto manufacturers for use in their vehicles. Synthetics are not necessary and tend to give owners a false sense of security leading them away from priority number one above. Using synthetic oils in a street car is kind of like the guy who puts premium fuel in his 87 octane rated engine...it makes him feel better but really doesn't do anything for performance.
Frequency of change is critical for an often overlooked factor: contamination. Most modern oils won't breakdown past the point of serviceability in the recommended change cycle. However, oil quickly becomes contaminated with a variety of materials regardless of its make-up. The key to long engine life from a lubrication perspective is keeping those contaminates from building up.
Oil filters do make a difference and I would recommend that DIYer's invest their money here rather than in fancy oils. There are important cost and performance differences in the construction of filters. Of primary concern are the anti-drainback and bypass valves as well as the size and type of filtering media.
The anti-drainback valve essentially protects the top end of your engine from excessive wear during cold start-up. If you hear more than a second or two of "valve clatter" during cold starts, your cheapy filter isn't doing the job and you should investigate filters with better valve design/materials. Believe me, you will hear the difference when you change filter brands. Filtering media ranges from low end cellulose (essentially paper) to high tech synthetic fabrics. One key is media area. The less area (especially in a cellulose filter), the sooner it will become clogged and allow oil to bypass the filter. If you are not changing your oil at 3,000 mile intervals, I would highly recommend using a filter with a large area, synthetic filtering material.
Finally, use the viscosity oil recommended in your owner's manual. The people that make these things know what they are doing. 5W-30 is a great product. It contains only slightly more viscosity additive than 10W-30. Remember, 5W-30 is "thinner" only when cold, when most engine wear occurs. At temperature, 30 is 30.
I dunno why, but for some reason I've always been afraid of 5W-30. I think it's partly because, back when those multi-grade oils first came out, if there was too much of a range in viscosity, they really could start causing problems when that stuff broke down. Most of my cars have also been old battlecruisers that I'd just put straight 30W oil in, and never had a problem with. In fact, the first car I ever had that I put a multigrade in, almost self-destructed immmediately! It was an '82 Cutlass Supreme with a 231 V-6. I bought it used with about 61K miles on it, and had been using straight 30 for about 10K miles. Well, one of my friends was telling me that a multi-grade oil like 10W-30 would be better for it. Well, within less than 1000 miles after changing to 10W-30, it lost all oil pressure!
Maybe I do need to get with the times, though! Would it be safe though, after all this time, to switch from 10W-30 to 5W-30? I'm just wondering, if the car is aging and things are loosening up a bit, if I might actually need to go to a heavier weight?
andre...i doubt it would hurt your car to put 5w30 in it. in fact if i remember right, dodge on the 3.2l and 3.5l recommended 5w30 if temps were gonna be below freezing. otherwise 10w30 was recommended. anyway, lighter at startup is good for a motor since that's where most of the wear/tear occurs...
My only concern now with switching to 5W-30 is that now, with almost 88K miles of my car having 10W-30, I'm worried that it might do something to it. Even if the 10W-30 wasn't that great for it, I'm concerned that maybe the car has gotten "used" to it, as far as gaskets, seals, clearances, etc, and if I put 5W-30 in it, it might not be enough anymore. I'll probably give it a try though, at the next oil change. Since I'm not driving nearly as much now, I'll probably start changing every 2K, instead of 3-3.5K like I had been doing. So I'm guessing my next change will be sometime in January.
Sorry for that title--couldn't resist. Nothing "bad" will happen if you move from conventional oil to synthetic. As I mentioned in a previous discussion--because I am doing excessive highway driving and using synthetics and a high quality filter--I often allow my oil to go from 5000-7500 miles. My last oil change duration was just over 7000 miles--and the oil was fairly clean (and clear) and I NEVER ADDED A DROP in the duration. Hard to believe but true! That being said I am well beyond the break in period (at 75,000 miles). I'll keep you all apprised of how the work being done today progresses..
Quetion: Should I go through with the purchase?
I liked the way the car felt during the test drive. My concerns are with reliability and quality of the car(american car- no offense!). For 9500 it seems like a great deal, but I don't want to buy the car and have it fall apart and start rattling after 1 year. I saw an Intrpid that had paint oxidizing(maroon color), is tis a concern? Any other concerns/ advice? Thanks in advance!
Most of us have discovered that our front ends have damage from flying debris and abrasives--but that's to be expected. Good luck and enjoy--whatever your final choice may be..
