Visitor Agreement.
A common ploy buy all dealers to try and sell a demo as a new car (because it hasn't been registered), don't fall for it. If you buy it and bring it back a few months later with 5000 miles, see what happens to your trade-in value, now it's a used car having lost 20% or so of what you paid. Even the [non-permissible content removed](made in Kentucky) cars take a big hit the first year.
The wind noise isn't offensive in my car unless the windows are down, definitely coming from those huge mirrors, they could have been made a little more aerodynamically.
North Carolina is one of the states where Toyotas are distributed to local dealerships through South East Toyota located in Atlanta and Jacksonville.
In 2002, SET processed 219,457 cars, trucks, vans and sport utility vehicles at the Port for its 165 Toyota dealerships in Alabama, Florida, Georgia and North and South Carolina as well as Lexus dealerships in the southern region. The JM companies that run this operation are the 13th largest private company in the U.S. with an estimated annual revenue of $7.8billion.
They didn't get that way selling Toyotas at low margin.
I am sure that this company is proud of its operations and accomplishments and feel that what they do for consumers is of value.
Normally, automobile markets can be very competitive when there are competitive distribution systems. But I feel the deal in the SET area is a lot like Microsoft - a benevolent but expensive dictatorship.
Since they monopolize Toyota distribution in these states, they can add stuff to the 'sticker' that wasn't on the cars leaving Toyota manufacturing facilities. They do this and pass the costs on to their dealerships. They pass it on to you.
This breaks the normal 'invoice' plus pricing model that is so effective elsewhere in the U.S.
If you were to compare stickers at your Toy Store with those at a dealership in Boston, you would see that they sometimes "load up" cars with stuff straight out of the 1970's.
My favorite is the infamous
"Toyoguard Protection Group" - which stickers for $619
Exterior Paint Sealant
Toyo Guard Sealant Cleaner
Interior Fabric Protector
Undercoating/Sound Shield
Glass Etch Theft Deterrent
(sounds like it came from the factory right? - SET "installed" at the "port" of Jacksonville or Commerce Ga).
How much fabric is there in that Avalon XLS? And if the paint needed 'sealing' I feel it would be done by Toyota in Kentucky. Can you imagine a company like Toyota with a fetish for perfection delivering cars that require paint sealant. Duh? I think you get the message...
If you check their option lists, they often put on "upgrade wheel packages" and other non-Toyota stuff. All designed with your pocketbook in mind.
My recommendation would be to head north to Virginia and buy a Toyota. You can go to Kay Jennings Toyota ( kjtoyota.com ) just south of D.C. and speak to a very knowledgeable person there named Steve Clifford.
If you really want to shop hard, try Turnersville Auto in Turnersville, NJ just east of Philadelphia. They consistently advertise new Avalons on their internet specials page for Invoice + or - a couple of hundred bucks.
Drive it back to NC and enjoy getting to know one of the best car values on the planet.
Good luck
I do not want to buy a car that I regret in a few months due to cramped leg and head room.
In addition, monitor tread wear. More wear on the outside edges of the tread=tires are too soft. You are more likely to see more wear at the center of the tread pattern, which is "tires are too hard." If this treadwear discrepancy is rapid, my opinion is you are running 'em way too hard. If the differences are slight, your overinflation is probably not too aggressive(IMO).
NOTE: This variation in treadwear gives you an idea of how the contact patch is affected(across the tread) by PSI. Additionally, contact patch is affected front to back with changes in tire pressure. Too high a pressure greatly reduces your contact patch!! This can obviously become a problem. ...which leads to:
Increasing PSI's effects on "performance", include: ***REDUCED braking, as in INCREASED braking distances.*** Though, it can increase MPG and may effect Over/Under steer.
NOTE: When you measure PSI matters too. If you do a lot of short local driving, you are usually on cool tires-measure 'em "cool", or after a short trip. If the car gets plenty of activity, and tires are usually at a higher operating temp, measure at THAT temp.
Anyway, I notice now the ride is not nearly as smooth as it used to be, and after going over a couple speed bumps today, I actually heard the front suspension squeak.
Plus, it feels like the front end bottoms out whenever I go over a pot hole or rough railroad tracks
Is this a sign the car needs new shocks, struts, or something else, and if so, should I go the Toyota route?
All I know is, right now, my wife's Acura MDX is a much better riding vehicle.
-18fan
The "sueak" you mention could be anything, since there are a LOT of parts that MOVE with suspension. There may be a worn bushing in a control arm...if it's worn enough, this could also provide your knocking sound??????
Finally, look at sway bar bushings, for the squeak. Your sway bar "rotates" within two RUBBER bushings at the front of the car. If they are dry or worn, metal on rubber squeaks when it moves! Hope this helps -nomad-
Apparently the Michelin's get rock hard with wear and age.
Pkg GK has a TMV of $2,247. However, Pkg LT has a TMV of $2,056, and contains everything GK has...and then some.
Is there something switched here?
Based on this info and the price quoted to take me to 100,000 miles, I decided to trust the Avalon's great quality and go it alone. From past experience, I know that Toyota sometimes extends coverage beyond the stated confines. Hope I have carefree future driving. Thanks for the help.
The Mazda6 group says the only issue with thier new car is the sunglass holder and the heated seat not getting that warm.
The Toyota forums is all over the place with issues.
The Accord forum will note 1 issue while somebody says it's either not true of problem has been resolved.
All I would like to know if possible is what are the main problems with the 2003 Accord and are they either fixable or livable.
BTW Im not here to slam any 1 car just want to select the best for my family.
Thanks in advance.
Happy Holiday to all.
If you are willing to spend around $30,000 then you should also consider the Volvo S60, the Infinti I35/G35, the new 2004 Maxima or a slightly used Lexus ES300.
The Avalon is flawless, it does not require premium petrol, and for all intents and purposes it is a Lexus at a Toyota price (not quite). We call it the Lexus 399.
Question 1) Company may sale 97 Maxima at wholesale so what would be a reasonable offer from me?
Question 2) Thinking about buying an 2003 Avalon XLS with Premium Luxury Package w/ Heated Seat. Local North Georgia dealer will match carsdirect.com at $28,488 is that a good deal?
Question 3) Should I wait to May to see if Avalon has a manufacturer rebate? Do you think there's a high probability with this make/model? Most of Toyota's have rebates except for the Avalon in April.
Question 4) For a full-size near-luxury vehicle is the Avalon XLS the best value for less than $30K in your opinion?
Thanks for your advice in advance.
I didn't rotate the tires but instead when the OEM front tires wore out I replaced the two front only. When the two front tires wore out again, all four were replaced. This way you could get to 100K buying just 8 tires and pay nothing for rotations. If you are driving 40-50K/yr in a northern climate you can also time it so that you
get fresh front rubber at the beginning of winter.
This works because the front tires wear twice as fast as the rears on a FWD car.
Of course this presumes that you like the make/model of the original equipment tires, which is not always the case. It worked for me with a few Tauruses and cab forward Chryslers.
Briefly, paid $29.3K before TTL for a Silver Spruce Metallic 2003 Avalon XLS. I love that color especially with the ivory leather interior. First color choice would have been black but I'm too lazy to keep the thing that clean.
I think I got a decent deal but you can be the judge with the following options included: Moonroof, Sunroof Wind deflector, Cargo/Trunk mats/net, Skid Control, and Premium Luxury Package. According to the dealer, invoice was 29,999. Hard to tell with the Southeastern Toyoto distributor fees that get added but CarsDirect.com did agree with his statement.
The brakes are little rough/grabby when applied so I'm going to have the dealer look at them the first of next week. Anybody else having this problem?
Otherwise, I'm completely satisfied with the purchase considering the luxurious feel the car provides at not-so typical luxury prices.
Thanks for the feedback on the brakes. I plan on having the dealer check it out tomorrow before I take any major trips. I'm glad to hear it's not a systemic problem. At least I hope not.
cusafr
When I found out about this stuff several years ago I was astounded nobody thought of something like this before. I had it put on a new car my wife had bought, and we kept that car 2 years and recently traded it in on a new RAV4 (which we had immediately ClearBra covered as well). It kept that front end absolutely flawless for the 2 years we had it. We use a product called "DriWash N Guard" instead of waxes and such. It can easily be applied with NO deleterious effects on the Clearbra as it has similar Polymer characteristics to the material itself. DriWash N Guard also provides UV A and B blockers in the formula, from what I understand essential to the longevity of the ClearBra material. The dealer supplies you with a 16oz. container of 303 Aerospace Protectant spray with your Clearbra install here in town. He assured me EITHER can be used as long as one is used to protect the material from long term UV damage as that seems to be the ONLY thing that negatively effects it.
He suggested an application at least every 3 months to keep it like new. While my install was a bit expensive due to the coverage I got (entire front bumper, both front fenders, entire hood, A pillers, lower portions of all doors and kick panels, and wrapped the entire rear bumper as well as the top of the trunk hood) a typical install of the front end including the lighting and a taper across the front fenders and hood is around $500. Worth EVERY penny to avoid those damn rock chips and bug splats that abound from trucks and cars alike on the interstates (like I drive on for a living). I can no longer imagine getting a new car without this treatment. The last new car I had was a 2000 Saturn LS2 and the first 2 days on the interstate a semi flung up some rocks that immediately left several large chunks of paint missing in my hood. I was pissed, but that is very typical. Now the only thing I need worry about is the windshield, but at least that whole thing can be replaced for a new one instead of having to get a new paint job. Hope this is at least a partial answer to your list of questions........
So when a Toyota dealer claims Invoice+X you have to add $675 to the invoice price you see on edmunds.
Toyota is the only manufacturer does that.
All other manufacturere's invoice price exactly matched between the invoice price on edmunds and the dealers tell you.
