TL-S needs to be there when redesigned ES300 comes
Interestingly enough, if you refer to ConsumerGuide or the recent issue of Kiplinger which compares cars, both list the TL as having MORE headroom than the ES. How can this be? Do these guides actually take measurements themselves or simply use the manufacturer info from brochures? Is there any standard of measuring headroom or other interior dimensions? Is a Lexus inch bigger than an Acura inch?
He loves the car, though, and wouldn't trade it for and ES300, as he feels the TL is much nicer all around.
http://biz.yahoo.com/n/h/hmc.html
Sounds like nobody knows for sure.
If they build it, I will buy it.
Questions: With regard to features like TCS (traction control) and the night driving feature on the rear view mirror.. Can these be left on all the time without causing wear? Is it better to leave them on? Also, will forced entry to the trunk set off the alarm.
Not big issues, but please remember the old saw about...... "no question being dumb".
Thanks.......
http://www.acura-tl.com/2002_TL-S.htm
There is really no reason to turn your TCS off unless you are racing.
Amen -:)
Second comment on the TCS - we have it on our 98 Ford Windstar. I've been surprised a couple of times to have the green "TCS Active" light come on when starting out or turning and the wheels slipped - didn't even realize the road was slick.
I have taken to my dealer and they balanced my wheels twice. I also took it to a third party mechanic and they did a "high-speed" alignment. But to no use.
Does anyone has/had this issue with their TL? If yes, how did they get it fixed?
Can anybody clearly explain to me what does it mean
"...having only the seating surfaces upholstered in leather..."
Does it mean that some other luxiry car seats are made
completely of leather? Is it a big difference from the viewpoint
of comfort?
-Ron
-Nelson
I RECENTLY SPOKE TO ANOTHER OWNER OF A 99 TL WHO HAD JUST LAID OUT ABOUT $275 TO REPLACE ONE BULB. I LIKE THE HID LIGHTS BUT THEY ARE NOT THAT MUCH BETTER THAN A GOOD HALOGEN. CAN THESE SYSTEMS BE CONVERTED TO HALOGEN? ANY IDEA HOW MUCH IT WOULD COST?
THANKS
PEDDLER
Later...AH
Thanks for the comments.
Peddler
Most car makers only install leather trim on seating surfaces. That means usually the sides of the seats, the seat backs, the door inserts are really vinyl.
My low and high 0-60 numbers were 6.14 & 6.42
After averaging the 4 times I came op with a 6.33 0-60.
To get more accurate numbers, I am planning on going to the track in early spring to see what it will do when timed by the tracks equipment in the 1/4 mile. From the seat of the pants feel, it definately seems like it is quite a bit faster than it was with just exhaust on it.
The other noise, that also seems to happen more when it is cold, is a creaking from the drivers seat. Seems to especially happen when I accelerate and sounds like plastic against plastic.
I guess I'm a creature of habit. I'm used to changing oil every 3K mi. Though their not required, I've kept changing the oil @ 3k mi. I have 14k mi on my '00 TL. Now would be the tima for another 3K oil change so do I do it or wait until ~17K?
Thanx!--
As far as efficiency. The halogens on the BMW are accompanied by fogs that add to the pattern width. they both are good.
Any thoughts from others would be welcomed.
Even in any case I think, 3750-4000K is proper mileage for oil change. U may choose to 4750.
Do what dealer reccommends as resale value depends on how u maintain ur vehicle.
Pick up is in two weeks. I'm a happy camper.
