Older Honda Accords
1363364366368369389
  • autoboy16autoboy16 Member Posts: 992
    Just for the record, I also posted this in the 1994-1997 honda accord maintence and repair forum. I just want to put it simple(r) here. Ok heres my problem. I have a 95 v6 accord and these homely rims:image
    I would like these:image
    Is this do able or should I just just keep my same rims. Has anyone tried this? I know its often for people to go from the steel wheel and plastic hubcap to the ones I like. I'm pretty sure they both are 15inch rims.
    My main concern is why would honda put the ones I have (top picture) on the "top of the line" model while the middle of the line model gets the nicer ones.
  • dwinkdwink Member Posts: 14
    I just wanted to clarify, but after reading the specs on both the top of the line 2006 Accord Ex and the top of the line civic ES, it appears the stereo is better in the civic. According to the data I read, the accord has 120 Watts and the Civic has 160 Watts. Why would Honda do that? Can anyone give me feedback on their Radio experience? Thanks.
    Hey, even the Fit has a 200W stereo!
  • mrbill1957mrbill1957 Member Posts: 823
    The 2006 Accord is the 4th year of the current design (other then a slight change in front and back ends). The Civic is a totally new design.
    The buyers of the Civic are typically younger then Accord buyers, so the demand for a higher wattage stereo is probably more important.
    My guess is the stereo will be changing when the Accord hits it's new design.
    Mrbill
  • don57don57 Member Posts: 19
    On my 06 V6 sedan, the navigation system stared asking for a PIN when one was never set. Now the screen comes up, the PIN screen flashes and the whole thing goes blank. Any ideas without having to go back the the dealer? :cry:
  • tallman1tallman1 Member Posts: 1,874
    Did you disconnect the battery or did it go dead?
    You got a card with the PIN on it when you bought the car. Just enter the number and you'll be good to go.
    Ah but wait... there is a PIN setting aside from the anti-theft ID, isn't there? That's odd if you never set it. Does anyone else have access to the car? Someone may have set it w/o you knowing.
    Thanks for the info mrbill1957. I cant understand why for a v-6 top of the line sedan that Honda would go with a stereo that has less Watt then any car in its class its trying to compete with. Does anyone know what the new camry offers?
  • master1master1 Member Posts: 340
    The Camry has many features.
    http://www.toyota.com/camry/index.html?s_van=GM_TN_CAMRY_INDEX
    But don't say TOO much about this because it is the Accord sedan forum only. ;)
    The 6-speed Accord V6 has 180 watts, my EX Auto has 120 watts (I'll admit it isn't as good as the Pioneer 200W unit I installed in my 1996 LX Accord) the Camry has an optional 440 watt JBL stereo. I expect the Accord will up the power in the next model (about 15-18 months away). When the Accord debuted in 2002, 120-180 watts was perfectly sufficient (and still is IMO), but here in America, more is always better, right? LOL
  • blackexv6blackexv6 Member Posts: 503
    The Camry 440 Watt JBL is a joke. The system in my old '03 Accord EXV6 sounded better. Do a search in the '07 Camry forums its been discussed before.
    How does the number of watts relate to the sound quality? ;)
    Kind of like saying one car uses more gas than another, so it is better. :)
    Remember - 5-10 watts of clean power is extremely loud in a car.
  • stickguystickguy Member Posts: 53,590
    No, more power doesn't mean better sound.
    I have my Odyssey in getting new speakers (and an ipod gizmo). I will be taking my '05 in to have the speakers swapped out.
    The stereo shop guy confirmed what I have heard elsewhere. Honda makes (or installs) decent electonc pieces (the headunit, other than the display!), but they use just about the worst/cheapest speakers of any maker.
    Generally, you will get much better bang for the buck with new speakers instead of adding more power. ALthough you can certainly fo both if you want!
    $300 bucks worth of new speakers will probably make a world of difference to the quality of the digital sound from the sat radio or ipod.
    Just make sure to get very efficient speakers if you aren't pushing a ton of watts.
    Thanks. That did the trick. Even though the battery wasn't disconnected, I couldn't get past the enter PIN screen.
  • yankeryanker Member Posts: 156
    I am 6'2' and have an 03 Accord with leather and of course a sunroof. I have no problem but I do remember to wear a hat in sunny weather. On the other hand i recently got out oa an 07 camry and banged my head. Similar head bangings have occurred with Ford escape, Chrysler 300 and a Buick lacrosse all with sunroofs. Honda Ex is no problem
    Interesting that it would do that without a battery disconnect. Glad that it works for you now though!
  • tinatinatinatina Member Posts: 388
    My new Accord with about 450 miles is making a poppingnoise/rubbing noise/cracking noise from the front suspension area or near the brake pedal @ about 5 mph - when backing up or moving forward. I also hear the noise when making turns at very low speeds. I will bring it in tomorow or Tuesday. Any thoughts or ideas? Maybe something with the suspension being too loose/too tight? Is this the popping noise related to the welds from the 2003s? Thanks.
  • 6mt_jordan6mt_jordan Member Posts: 8
    Does it only do it once per drive?
    I have an 06 EX-V6 with the 6spd manual (coupe) and I know for a fact that the car does an ABS check when you get up to a certain slow speed. It does it once per drive only. It doesn't sound like cracking. It sounds like a "thunk" and is less than half a second in duration. It shouldn't do this more than one time per drive shortly after you start moving. If this is what you're experiencing, it's normal behaviour.
  • ar39ar39 Member Posts: 61
    I've answered this question in the Repairs/Maintenance thread. There's nothing wrong with the brakes or the car.
  • bdymentbdyment Member Posts: 573
    I hope I am wrong but this is exactly the way my 2003 EX V6 sounded. It was the weld problem and it was never fixed correctly by my dealer. Trusting that Honda is now able to correctly fix this annoying problem on 2006 models.
    Thanks for the tip - it sounds like a popping/rubbing/crunching noise. I gave more details on the dedicated problems thread. I brought it in the shop this morning for a look. I suspect that its one of three things:
    1. Suspension bolt not on tight enough - As the car is warmed the problem becomes apparent. It is not apparent at a speed above 10 MPH, or when the vehicle is cold. The problem is easily when coasting at a speed of about 5 MPH either on flat surface or coasting up a hill. I believe I read this on the Acura TL thread or on the Accord thread.
    2. The weld problem is from a 2003 TSB, effecting early models. Chances are that Honda has corrected that problem- but who knows.
    3. I think another issue may be the silence tubes over the the springs.
    I will post an update on the problems thread once the dealer informs me of what the problem is. The good thing is that they heard the noise.
  • tomlivtomliv Member Posts: 29
    My Accord EX Sedan (4 cylinder, manual) is needing to go in for its 15,000 mile service. I had oil and filter changes at 5,000 and 10,000 miles along with a number of dealer inspections (brakes, tie rod ends, driveshaft boots, suspension components, etc.) at the 10,000 mile service. The 10,000 mile service cost me $90.
    For the 15,000 mile service ($245), they want to repeat the 10,000 mile service along with a couple additional items. I don't buy them re-checking all the things they did at 10,000 miles only 5,000 miles later, so I think that's a "no go." As I see it, I'll get another oil and filter change, and the question is about the additional items which I'd like some feedback on.
    One is to replace the air cleaner element. As I drive in New England and can fall under the "severe" schedule, that's a 15,000 mile item, so that's reasonable. Another item is replacing the cabin dust & pollen filter - reasonable per the manual as I drive in a relatively urban area.
    But how about replacing the differential fluids, inspecting the PCV valve operation, pressure testing the cooling system, inspecting the suspension mounting bolts, and checking the shocks for leakage and proper operation? Added dealer fluff?
  • sardonic_ninnysardonic_ninny Member Posts: 25
    i'd def go with the PCV valve
    It returns unburned gases into the intake manifold and it lowers emissions and increases gas mileage
    I just remember i've gone through like thirty of them since my sixteenth birthday.
    They're fairly cheap If i remember, and they love to stop working
    You are supposed to replace the valve and filter every 30 to 50 thousand miles. But It can be neccesary much earlier so its worth checking out
    I dont think checking the shocks is really neccesary.
    People get nervous cause they own new cars, but think about a car with 150 thousand miles on it, you'll drive another 15 thousand on it and your dang shocks wont be messed up.
    The pressure testing thing is a good idea too though In my opinion
    Do the services your owners manual indicates.
    Why do you think you are in the 'severe service' schedule?
    Do you use the car as a taxi? A police car? A funeral car?
    New England - I would think extreme cold would be the only concern - If you drive it less than 5 miles and do not get it warmed up well and then shut it down - Then maybe it would be severe service. But your nice, mild summers sure do not constitute severe service.
    I would think you most probably have a normal service schedule.
    Now I do think 7,500 to 10,000 miles between oil changes is somewhat excessive, but I would consider 4,000 - 6,000 miles do-able. If you drive 3 miles to work 5 days a week in winter, you are seeing temps below freezing for days and days - I would change the oil every 3 months and 3,000 miles.
    99% of all autos on the road fit the 'regular schedule' for maintenance.
    What's the last car you've heard of that an average family owned and had an engine failure before 75,000 miles? Bad rings, main bearing failure, burned valves, tranny overhaul? Now if Junior drove it on the weekends, loaned it to a 'buddy' to go get more beer for the party, and the buddy drove it 10 blocks to the convenience store in D1 with the accellator floored - then there might me a problem with a car.
    Otherwise, just what kind of transmission and engine failures are you personally aware of? If you know of one, it most probably is one of the engines/transmissions with true 'design' problems - one with a high percentage of failures for the specific engine or transmission. And a 'severe service schedule' isn't going to help these, their failure is 'designed in'.
  • chevymalibuchevymalibu Member Posts: 129
    I've owned 7 cars that I bought new and never have taken in for these services (one dodge, two grand am's, three camry's and an 2004 accord ex). I change my oils at 2500-3000 miles. I changed the accord's air filter at 25K and it still could have gone further as it wasn't that dirty (in SC/NC). It's easy to do yourself and costs maybe 13-15 bucks to buy. Your car shouldn't have a differential case. I asked my honda dealer about that and he said it's all housed in the trans and has one fluid. I did change one drop of the trans fluid at 25K and another at 31K (car has 35K now on it). Your car is basically new. I'd forget the PVC valve, pressure testing the cooling system (if your car doesn't overheat, isn't leaking fluid etc... why worry), I doubt the shocks will be leaking. One of my 1994 camry's had a bad strut in the front at 190'sK and I changed both out. They last a very long time. yes, added dealer fluff. I'm not an auto mechanic but know my way around a car and can do "most" of the normal stuff. As for the cabin filter, I just looked at my mom's in her 1998 camry and it was almost spotless and very white. I doubt yours is dirty unless you drive on dirt roads 100% of the time. I'm not cheap either. Just don't seee going to the dealer for extra stuff I don't need. That's my opinion. good luck with your decision.
    I bought a gallon of antifreeze from honda when I got my car in 2004 due to the warranty. It expires in less than 1K miles. I haven't changed that (although it's supposed to be 5 yrs/100K but I don't go by honda's or toyota's extended mile suggested changes). I know that honda claims to have "special" fluids (mainly the trans fluid) as the antifreeze doesn't have silicates, borates, and phosphates to ruin the seals. I know prestone makes the extended life (not 2 yr variety) that is free of these compounds and is safe for aluminum engines and imports. I don't want to pay $15 or so for a gallon of 50/50 at honda and want to use prestone for 1/2 the price. Has anyone changed their fluid and used prestone??? thanks. I've also used prestone in my two 1994 camrys instead of that pink stuff and I lost one water pump at 165K or so which is normal. Thanks for your comments.
  • qbrozenqbrozen Member Posts: 33,772
    If your dealer wants to change the differential fluid, you need to find a new dealer because your car does not have a differential.
    And there is no way you should be changing the transmission fluid at 15k miles, so don't let them talk you into that, either (you didn't mention it, but they might sell that as "the same as changing the differential fluid").
    NOTHING needs to be done on your car at this point, other than an oil and oil filter change, and a tire rotation if you haven't done that yet. If you feel you want to change the air filter, do it yourself. You can get the filter from any auto parts store. Its gotta be the easiest do it yourself job on a car. I haven't looked into it, but I'm sure you could replace the pollen filter yourself, too. They are usually located under the dash on the passenger's side of the car. I'm sure there is a how-to written up on the internet somewhere.
    As far as any of this "inspecting" stuff, just do it yourself. You can see if anything is leaking, broken, etc. I don't feel a dealer should be charging you for this stuff, anyway. Good grief, why pay someone just to eyeball your car? Its all a ripoff. Any decent machanic gives the car a quick once over when doing the oil change. It shouldn't cost you extra.
    If I were you, I'd tell the dealer you want to do what the book says - nothing more, nothing less.
    I've been using the same Honda dealer in the Boston area for 15 years and that's what I have done. My Accords got the normal service as I do lots of highway driving except for oil changes which I did every 3,750 miles. My wife's Ody get the severe service as she drives about 3 miles each way to the train station. Even in summer, it's considered severe service to drive so little.
  • normkolnormkol Member Posts: 135
    As others have noted, the Accord doesn't have a differential, so that is bogus, and it's too early to change the tranny fluid.
    The air filter and cabin filters are ok. I live in NYC and change my cabin filters every year. You won't believe how dirty they get, and since my wife and son have asthma, it's important for me.
    On my 2000 Accord it's a job, so they probably charge an hour's labor. I have a 2006 Accord, but haven't looked into what's involved yet in changing the cabin filter.
    The checks they mention are fluff, shocks are simply looked at while the car is on the lift. They are probably rotating and balancing the tires, which is normal.
    I normally do these things myself, but my Pilot hit 15k in February, and I don't work outside in the winter. The dealer charged about the same for the 15k service, including new wiper refills. The Pilot does have a differential, that was an extra $70 to chang the fluid.
    The car doesn't have a differential? HUH?
    How can the car turn a corner without squeeling the wheels if it didn't?
    Yes, the car has a differential!!! It's just inside the transmission.
    If you don't believe me, look up the following Honda part 41100-RAY-A01 DIFFERENTIAL
    It's for a 05 V6 Accord
    Mrbill
    I didn't feel like playing the semantics game because it would just serve to confuse the matter. The whole thing is called a transaxle and, yes, technically there is a differential in there. But its not the same differential being referred to in the maintenance manual and its definitely not something you service independently at any scheduled service.
  • catbabecatbabe Member Posts: 9
    It turned out to be the left wheel bearing, front hub, which was replaced. All is now well in Honda land. I can continue enjoying my new car. Kind of disappointed though that the part failed @ 500 miles. Oh well, it could have been a tranny issue a la Toyota. :)
  • whitecloud1whitecloud1 Member Posts: 268
    Thanks for the clarification. I think everyone should remember that the dealer is out to make money. Your owners manual is part of a contract and if you need something fixed under a warrenty of some type, what the dealer had you pay for won't matter one bit to the company (Honda or otherwise) paying for the repair. Get familiar with the manual. The dealer is not your friend, just a businessman. I've had good and some bad experiences. Money you put out today for unnecessary maintenance may be needed tomorrow for something you really need.
    Bolivar ... you're probably right ... I needed to rethink the normal versus severe maintenance. My commute is 7 miles each way, and freezing temps here in the Boston area are 3-4 months out of the year, and I don't use the car as a taxi or delivery vehicle, so I don't "mainly" drive under the severe conditions.
    Everyone else - thanks for the great responses. That's what I love about this forum ... the feedback. From what I hear, all I should/need to get done at this point is an oil change. Tires were rotated at 10,000 miles, so I'll get them done again at 20,000 miles.
    In the dealer's defense, I should say that they had a list of items for the 15,000 mile service and then gave the models and applicable prices underneath. It's possible that the differential fluid item was there for the Pilot, Ridgeline, etc. and wasn't applicable to the Accord. But I'm glad you all told me. I wouldn't have known otherwise!
  • nucmanchhnucmanchh Member Posts: 1
    Is it true that the 2006 EX-L Accord has gone to a metal timing belt?
    The I4 uses a timing chain, the V6 uses a timing belt. The I4 started using a chain in 03.
    Mrbill
  • avianfluavianflu Member Posts: 33
    Anyone here know who make Honda's blue antifreeze or their Auto trans fluid? These evidently are essential fluids.
    Honda Accord (2000) water pumps can last 300+k miles, using Honda's blue antifreeze. With the history of Honda's auto transmissions, I wouldn't want to mess with a lesser tans fluid.
    Members here have already established that Exxon make their 5w20 motor oil.
    Hmmm, I thought that I read here somewhere that Mobile made their motor oil. I have no idea myself.
    I'm wondering when Honda dropped putting the trim level on the back of the Accord. I thought it was there in 05 but I know it isn't on my 06. No more EX or LX... just the V6. Anyone know the reason?
  • vhreb123vhreb123 Member Posts: 83
    Does the Honda manufacturer still give back Honda dealers a $750 incentive after 7/5/06? I was hoping to use it in addition with holdback in negotiating for a lower price. If I can't use the incentive, does anybody know if Honda has a factory to dealer cash back or something similar for every Honda (Accord) sold? :confuse:
  • sandman46sandman46 Member Posts: 1,798
    Noticed that there's no trim level designation on my new '06 Civic LX also. Must be something new for Honda with the 2006 lineup. Not really a bad idea though. The alloy wheels or wheel covers usually are the give away as to which model the car is anyways.
    The Sandman :) (New To The Honda Family)
  • mitchfloridamitchflorida Member Posts: 420
    The freshened Honda Accord retained its position as Consumer Reports top-rated family sedan following a showdown between the Accord and the redesigned Toyota Camry for the August issue. The difference in scores is razor thin, and both vehicles are rated "Excellent" overall.
    Honda and Toyota have consistently set the standard for well- rounded, reliable family sedans with the Accord and the Camry. Along with the Volkswagen Passat, they regularly trade places as CR's top-rated family sedan.
    The Accord was named Consumer Reports' Top Pick in the family sedan category for 2006 in the magazine's Annual April Auto Issue.
    "The top-rated Accord is a refined and comfortable family sedan that offers a slightly sportier edge than its competitors," said David Champion, senior director of Consumer Reports' Auto Test Center in East Haddam, Connecticut.
    For the August issue, Consumer Reports pulled together a group of four family sedans and three large/luxury sedans for testing. CR purchased a V6 Honda Accord EX and three versions of the new Camry-a six-cylinder XLE, a Hybrid, and a four-cylinder LE. CR also purchased for testing a Hyundai Azera, Cadillac DTS, and Buick Lucerne.
    The Accord, Camry XLE, and Camry Hybrid all achieved "Excellent" overall scores in Consumer Reports' tests. The Camry LE received a "Very Good" overall score.
    Among the large sedans, the Hyundai Azera rated "Excellent" overall, coming in second place behind the previously-tested Toyota Avalon. The showing is one of the most impressive for a Hyundai in Consumer Reports testing during recent years. The Buick Lucerne, a replacement for both the LeSabre and Park Avenue, scored "Good" while the Cadillac DTS, an update of the DeVille, garnered a "Very Good" overall score.
    Full tests and ratings of the family and large sedans appear in the August issue of Consumer Reports, which goes on sale July 4. The complete report is also available to subscribers of http://www.ConsumerReports.org.
    Consumer Reports recommends four of the cars in this test group, the Accord EX, and all three trim lines of the Camry-the XLE, Hybrid, and LE. The Azera and Lucerne are new vehicles and so reliability is unknown. Reliability of the DeVille was below average; it remains to be seen what it will be for the DTS. Consumer Reports only recommends vehicles that have performed well in its tests, have at least average predicted reliability based on CR's Annual Car Reliability Survey of its own subscribers, and performed at least adequately if crash-tested or included in a government rollover test.
    The Accord combines sportiness and all-around capability, which helps it maintain its top rating among family sedans. The ride is pleasingly firm and handling is nimble with its standard electronic stability control. Road noise is CR's biggest complaint about this vehicle. The Accord EX ($27,850 Manufacturer's Suggested Retail Price as tested) is powered by a 244-hp, 3.0-liter V6 that is smooth, quick, and relatively frugal, delivering 23 mpg overall in CR's own fuel economy tests. The five-speed automatic is smooth and responsive. The Accord's brakes perform very well.
    The Camry is capable, quiet, and well rounded in all three test versions but is not as exciting to drive as the Accord. Handling is sound, but not sporty; the ride is comfortable. All powertrains are refined and economical; the V6-powered XLE, the top-rated of the three, is very quick, while the Camry Hybrid combines good performance with impressive fuel economy-34 mpg overall. MSRPs for the Camrys varied from $21,080 for the LE to $29,839 for the XLE, and $30,677 for the Hybrid. The brakes on the XLE and LE trim lines perform very well. Braking distances were somewhat longer on the hybrid version.
    bolivar - just a little thing: New England summers are mild if you live in northern Maine. Otherwise, it's 85-100 degrees and muggy.
    IMHO, driving stop and go or short distances in those conditions constitutes severe to me
    And to me as well.
    We took our 2 month old EX 4 cyl to Boston this weekend, 200 miles each way. Going up we got 30 MPG, but that included a couple of days of driving in Boston.
    Coming home, we filled up on the highway and again just before getting home, and showed 35 MPG!
    And the car only has 2000 miles, so it should get better.
    You should get used to 35+ MPG on trips... When driven with minimal downshifting to pass (light on the throttle, 75MPH average, AC on, I averaged 38 MPG on my last run to the beach in my 2006 EX I-4 5Auto with 7500 miles at the time(275 mile-trip or so each way). When I made the same trip in my father's 2005 with about 49,000 miles at the time (same basic car as mine, EX - 5-Auto), I got 39.96 MPG without the A/C on (it was March and cooler then). 40 MPG in an Accord is AWESOME! If driven prudently, you'll see these same type of numbers over time. On these trips, I rarely pass 80MPH, and do my best to keep the car from downshifting in order to keep RPMs down.
  • gee35coupegee35coupe Member Posts: 3,387
    Even at 80 mph speeds in an Accord. We have owned 3 of this generation and all of them were world-class gas sippers. Now my TSX, not so much.
    With my 2nd tankful, I'm getting about 32 mpg's in the city. I know it will only go up over time till it's fully broken in. Awesome!
    The Sandman :):):)
  • mdtamdta Member Posts: 27
    There is something wrong with my car. I never get more than 30 mpg.
    Wow... I've never been below 30 in my new Accord and rarely have been below 29 in the '95.
    You can't rev into the 3,000RPM + range or you'll eat up your fuel savings quickly. The trick is keeping the car at a steady speed with low RPMS. Merging keeping RPMs below 3k is possible, and cost-effective over time.
