Mazda MPV: Problems & Solutions
1202123252686
  • tboner1965tboner1965 Member Posts: 647
    Need a scanner with the OBD-II cars.
    I have the interface box and software on my laptop to retrieve codes.
    If you really can't wait, then look in the owners manual for all the fuses that deal with PCM (Powertrain Control Module) or something similar. Remove those for a half an hour, then put them back in. The 'puter should lose it's memory. But your stereo will not.
    Otherwise, just disconnect the negative battery cable for 30 minutes, then reconnect. However, you will need to reprogram the sound system.
    Cheers,
    TB
  • maltbmaltb Member Posts: 3,572
    What kind of box do you have and what does that run? Give me a brand name so I can look it up. Thanks.
    I bought it from a guy here in St. Louis. Makes them in his home.
    I got in on a group buy with the Contour Enthusiasts Group.
    Check out his website at http://www.obd-2.com/
    I paid under $100 for the deluxe unit and the software.
    HTH
    TB
    I'm curious what it allows you to do other than just pulling codes. can you make any mods with it?
    I would like to do that fuel economy mod for the next 3 months...
  • jcroftsjcrofts Member Posts: 7
    Thanks TB! I think I'll be patient for a couple more days before I dig into the fuse box since the gas cap was very loose.
  • evaddaveevaddave Member Posts: 156
    We've got it. I've explained the problem to the dealer twice, and they always say it's something with the brakes. Naturally the problem never happens when I'm *at* the dealer--only in stop and go driving. I think TBoner posted the TSB on the problem. I'm going to print that out and take it to the dealer the next time.
    -Dave
  • blacklxblacklx Member Posts: 60
    I know this has been covered before but when do you do the first oil change and what do you use?
    Thanks for repeating the info
  • tango_28tango_28 Member Posts: 35
    Make sure you have filter wrench, because the oil filter is on real tight. You have to remove the plastic skid plate (4 nuts hold it down). Also make sure you oil pan with big openning.
  • noles2000noles2000 Member Posts: 7
    Our VCP plays sound but we are not getting any picture from it. Any ideas? Has anyone else experienced this? Will try cleaning the heads but not sure if it will help. Has been a very dusty, pollen filled spring here in NJ. Not sure if that has anything to do with the VCP picture not working. Also wonder if it's a loose connection? Again, any help or suggestions would be great.
  • rotarykidrotarykid Member Posts: 191
    I had a few problems with my rses. THe first thing to go wrong was that some cables came loose at the interface(located behind the left rear side panel) second, the remote stopped working and had to replace the entire unit on the ceiling.
  • brmudabrmuda Member Posts: 50
    You've probably already done this but, check that you've got the "input mode" (TV, AV1, AV2, AUX) of the monitor (ceiling unit) set to AV1.
    Fortunately (so far), I haven't experienced any probs. Once you identify the problem, PLEASE post so the rest of us will know.
    Thanks and good luck.
    Well, believe it or not, cleaning the heads worked! I used a wide width head cleaner that I purchased at Radio Shack and the picture is back and clear as the day we bought the vehicle.
    I have had the van since February so it's been a bit more than 3 month's. I found it surprising that the heads needed to be cleaned that soon but I guess because it's under a seat in a van where a great deal of dust, etc can collect it is most likely going to have to be done frequently.
    Thanks for your suggestions rotarykid and brmuda. Hope this helps you in the future.
  • unclejunior1unclejunior1 Member Posts: 6
    He folks...
    Wanted to say thanks to everyone for all the info here to help us research our van purchase. Got a new 2000 ES in March and couldn't be happier. I did take it into the dealer for the first oil change and asked to check about the TSB for the bumper upgrade and he didn't know what I was talking about. Could someone point me in the direction where I can get this info to take back to the dealer to see if my van (Built April 2000) needs the upgrade?
    I have noticed some very slight jerkiness in the shifting. Not anything major to worry about--it just seems that it gets held up a little from 3rd to 4th. Question for all you Red Line users--could this be the solution to clear this up?
    Mike
    Winter Garden, FL
  • msgjvhmsgjvh Member Posts: 196
    Noles,
    If your traveling with kids there is no telling what could have gotten in to dirty up them heads. We could run a list from Peanut butter to Sour Worms. I have problems keeping the ones in the house working from year to year. Unfortnuately, the VCP is not as inexpensive as the $58 dollar kids VCR in the playroom. Glad you were able to get it working properly without the fight at the dealer.
    MSGJVH
  • robinandrewsrobinandrews Member Posts: 2
    Hi. I'm new. Please be kind, although that seems to go without saying on this board! We bought our 2000 ES in March - about 850 miles on it. We LOVE it - except it seems to be getting only 14 - 14.5 mpg in town. Our old, larger engine Voyager got 18. At over $2 per gallon in our area, this is getting expensive real fast! I can almost see the fuel indicator moving when I drive. Is this normal MPV behavior? Any ideas? Thank you.
    Robin,
    Your MPG will vary with the fuel you use. Try to avoid fuel with additives. You may also have to alter your driving habits to suit the MPV. It really likes a light foot. My wife gets 23-25 but we drive mostly highway. One other thing you may want be take notice of, make sure you have the OD button engaged all the time. Generally, it should automatically engage. You will can tell because the dash light will say OD off when the button is pushed. Make sure you do not see the light!.
    Good Luck.
    MSGJVH
    Thank you, msgjvh. I'm working on my lighter foot!
    Robin
  • gagpgagp Member Posts: 32
    Remember those rust spots on my windows' frames (Msg #968)? Will have them get painted for free (covered by Mazda).
    I still have though, this annoying «clickin'» sound coming from, what seems to me like left, front end. «Sounds» like something loose... Any idea ?
    Silver (and still happy) Driver
  • auerbachauerbach Member Posts: 110
    Has anyone noticed this?
    I installed the rear bumper step plate about 10 months ago. Followed the directions to a "T". About a week ago I noticed two scratches or "rubbing" at the bottom left and right corners of the hatch. It seems as if the edges of the step plate are curling up slightly and rubbing against the hatch door.
    I'm not sure what to do about this since I installed it - I doubt the dealer would fix it. I'm considering filing the bumper plate down just a bit to make sure it clears the hatch.
    Anyone have any other suggestions???
  • javadocjavadoc Member Posts: 1,167
    That's what I'd be doing, getting the Dremmel out and having some fun on that step plate! :-) Is the tape holding the plate down not working in that corner anymore maybe?
    --java
    I would recommend you tear that one off, clean the bumper and install an new one that you can get off of EBAY. Maybe that one was just defective. I have had ours on for over a year and have not had any problems.
  • kawazarkawazar Member Posts: 6
    Gagp,
    I have a 2000 LX that has 8000 miles on it and I just noticed the clicking noise. It sounds like it may be coming from my right side. like a bad wheel bearing. It only happens when I have the wheel turned to the right when I enter the garage. I have not had time to schedule it at the dealership. I will post when I find out what it is.
  • vtac1vtac1 Member Posts: 18
    I can't believe dealers are still saying they don't know whats causing popping sound.Their is a TSB out on the problem,they are told to change inner tie rods and some bushings.If a dealer tells you different he is full of crap.The problem was found over a year ago,and was resolved about 6 months ago.You might try----alldata.com---and see if they have the Tech.Service Bulletin number.Don't wait till it gets cool,the noise can goaway,gets worse with heat.Trust me,the info I have given is accurate.Good luck
  • superbondosuperbondo Member Posts: 29
    It seems our Mazda dealers are quite incompetent when it comes to attending to our needs. Either they don't know about recall, repair info or they don't do it right. After the 4th time fixing my pulling issue, now the van pulls to the right instead of to the left. Sigh!!
    Anyway, you can find the clicking info and bulletin number at post 978. I have 2000 LX too. Last time I parked my van next to a "normal" one I notice not only the left side leans lower (dealer replaced springs but still leans) but also the whole rear sags (less ground clearance).
  • dianaa1dianaa1 Member Posts: 3
    We had to replace all four Yokohama tires this week on our 2000LX. Our van has 33,600 km on it. The dealer told us that the two front tires were dangerously worn on the inside and needed to be replaced. The back two tires are in rough shape as well. The dealership did not offer us any compensation because tires are not covered by the Mazda warranty. They were not going to give us a break on any of the costs of replacing the tires. We followed the service schedules in our owner's manual faithfully. The dealership rotated the tires exactly once, at 24,000 km instead of 12,000 as the Yokohama brochure states. We brought the car in for servicing 3 times, every 12,000 km. Apparently, more frequent rotations prevents excessive wear.
    I found out that the original Yoko's have a treadwear rating of 200 - which gives them an expected lifespan of 50,000 km (35,000 miles). The Yokohama rep I spoke to was willing to cut a deal on new Yokohama tires - we would get 50% off 80% of the list price of the tires, which might save us $20 per tire... We decided that we did not want more shoddy tires, and bought four Pirelli Cinturato 3000's, which have a 135,000 km limited treadwear warranty. Pirelli claims that they are great in snow and rain, which we need in here in Toronto.
    We tried to get an independant tire store to do an alignment before we put on the new tires, like the nice lady at Canadian Motor Vehicle Plan agency told us to do, to see if there were alignment problems which led to the premature wear on the tires. The independant store did not have the alignment specs yet, because most vehicles apparently don't need alignments within the first two years.
    We had to go to another Mazda dealership to get the alignment (we were a little upset with the first dealership). Turns out that there was a significant alignment problem. The tires were probably incorrectly balanced as well. In addition, Mazda changed the tire specs midway through the production of the vehicle from 92S to 94S. We're going to talk to the District rep to see if we can get some money back for the new tires. We spent almost $600 Canadian for the alignment and the tires. This has shaken our faith in Mazda. Putting such shoddy tires on an otherwise great van is saving money in a stupid way. The alignment problem was probably a factory defect, although we did not get the pulling some people mentioned. We'll keep you posted on whether Mazda or Yokohama help us out in any way.
  • plusoneplusone Member Posts: 3
    I let the Xpress Lube in Sterling, VA do an oil change on my 2000 MPV. Two and a half days later I'm driving to work and in rapid order I get the oil idiot light, a squirting sound and then a clanking sound from the engine. The engine cuts out and I coast to a stop on the nearest off ramp from the road I am on.
    I called AAA and got towed to a reliable Good year repair place I have dealt with before that's not far from where the car stops. The guy says the gasket on the oil filter is blown and no oil in the engine. And plenty of oil all over the underside of the engine and the bottom of the bumper. He adds oil and a new filter. He calls me and says I should take the van to a Mazda dealer ASAP-he doesn't know this particular engine very well. I drove it a mile and started to hear the clanking sound. Left it in the parking lot of the hotel we were staying in (in process of moving to Martinsburg, WV)and called AAA again to tow it in the morning to Mazda dealer in Hagerstown, MD (nearest Mazda dealer).
    After they check it out they say the rods are bad and engine has to be replaced. $5,000.00!!! I called press Lube and they say it's a design flaw in 2.5 six cylinder-also shared by Contour/Mystique/Escape/Tribute. Something about an oil pressure relief valve sticking.
    Long story short-Xpress Lube say it's a known design issue and Mazda should cover it under warranty and Mazda says there is no recall, tech bulletin or anything else that indicates a known issue. The service manager at the Mazda dealer says (off the record) that he's heard of a handful of other cases like this where the same problem existed and created the same result.
    I even tried going up a level in Mazda service and the District Service Advisor basically didnt want to hear anything after "Xpress Lube did an oil change on it".
    So now Xpress Lube says they wont pay and Mazda says it's not covered under warranty. I had to go $5600.00 out of pocket to get a 1 year old vehicle back on the road. I have to go to court to try to get my money back. I have spoken to 5 different lawyers who tell me the same thing-I'm not likely to get all my money back, if any. I have to find an "expert", they tell me, who will testify what damaged the engine. I cant find 1 expert who will commit to saying what caused the damage so what the hell do I do now?
    Signed-cashless in WV
    "I let the Xpress Lube in Sterling, VA do an oil change on my 2000 MPV"
    I have heard of this happening before, but every time it seems to be with a Jiffy-Xpress-Penzoil-Econolube type outfit. Have they ever changed your filter before?
    Has anyone heard of this happening with the factory filter? I am very curious to see what comes of your dealings.
    Every time I've heard of this (only a few times) it's been after one of these jiffy/express/Q-lube places have changed the oil. I believe this has to do with the Fram/Penzoil/etc crappy filters these places use. Please, everyone, use the Ford Motorcraft filters supplied by the dealerships.
    This is such a sad story, and I feel for you plusone. Who do you go after? I'd say that the Xpress-lube place is at fault if they cannot produce documentation that this situation is known by Mazda, but you could go after the manufacturer of the filter itself. It looks like a tough battle, so good luck. Hopefully you still have the engine AND suspect filter, right?
    --javadoc
    Yes, maltb, I took it to them a few months earlier and the oil filter seal leaked immediately. I took it right back to them and they said the seal was bad and replaced seal, filter and oil. Then it was fine. I had taken the van to them once before with no problem. We had also taken our 96 Mazda Protege to them several times with no problem as well.
    I think we are on the same track today.
    FYI, I haven't been to see UPS yet, I'll try tomorrow.
    Yes. javadoc, I snatched the engine away from the Mazda dealer as quickly as I could and a friend has it stored for me at his farm. I also have both the filter that blew and the one the Goodyear repair place put on. Both have been expanded by great pressure. I also have a brand new filter of each type for comparison.
    Ah, I think we are.
    Plusone: Also, I haven't seen/heard of any TSB about this filter problem from my friend at the service center. Doesn't mean there isn't one tho. I'm just thinking that little filter could be worth its weight in gold.
    Not worried about the package. I'm too busy enjoying the midnight sun! :-)
    --java
    Sheeshhh,
    I don't know what to think. On one hand if you change your own oil you know what you are installing and how tight, but then you are assuming all responsibility. On the other if they change it you may have someplace to turn but at what cost and aggravation? I have done the last two changes. The last filter I installed was a K&N. I was really impressed with its quality. The thing is made like they use on race cars. I know its expensive but it certainly didn't cost $5,000.
    I think I will continue to do my own and ensuring that puppy is on very tight. One thing those shops don't see are the owners manual. I believe in the manual it tells you to tighten it another full turn vs the normal 1/4 turn with a wrench even! So why would Mazda put that in the manual if they didn't know about a pressure problem? In the future everyone would be wise to make sure the shop tech knows to tighten the filter per the owners manual.
    As for me its K&N from now on and forever!
    MSGJVH
    And I've not heard about any pressure relief valve sticking.
    I have heard about oil starvation in long sweeping RH curves with the engine at 6K RPMs.
    But I doubt many of us MPV'ers will see that scenario.
    I wonder if "Iffy Lube" put the right filter on. Heck, they may only have the earlier MPV's listed and so they slap on the filter for one of those thinking it is the same thing.
    I'd check the part number on the filter then see if it cross lists to the Motorcraft FL820S unit.
    If not, then "IFFY LUBE" probably porked the pooch on this one.
    On the other hand, there are occasional bad filters.
    I'll stick with the Motorcraft filters. Saving $2 on a filter is not worth the aggrivation of these type of situations.
    Cheers,
    TB
    Sitting at 97xx miles on the MPV anticipating the next oil change at 10K.
    OBTW, I had the Contour SVT up to 145MPH indicated this weekend, just for fun. No oil starvation problems.
    do you know the filter brand/number that the lube place used on your van? I'm getting very curious.
    Msgjvh: Just out of curiousity, is the new K&N filter a replaceable-element type (ala Wix filters) or did it just seem of extremily high quality. I've enjoyed the quality of their air filters for years, and didn't check out their oil filters.
    --javadoc
    No Java it was a remove and replace. No elements (too bad). But it was good quality. It also has the 1" nut on the end of the filter with the hole for safety wiring. I needed to buy a new wrench so I could be sure to tighten it properly and remove it during the next change. The old "end of the filter cap" wrench won't work on the race type filters.
    It will cost you about $10 bucks us. But after reading the previous post its well worth it. Maybe I can buy a case at a reduced price!
    MSGJVH
    BTW, when will we see a K&N air filter on the shelves?
    You are right the Yoko tires on my 2000LX are of cheap quality. And if they are unevenly worn definitely the alignment is the culprit here even though you don't have pulling. Last time at the dealership I talked to a lady who had a green 2000DX with the Yoko tires. She was mad and said the dealer stripped the bolt during the last oil change and also have braking problem but did not elaborate. She said she liked the last 97 MPV but grew to hate this one.
    I asked how many miles on the van because the Yoko tires are getting bald. Only 15000 miles!!!
  • alexv1nalexv1n Member Posts: 248
    Now after reading all those Yoko woes I'm glad I went with 16" tires. I wasn't sure if they were worth the extra money and I bought them because of "improved handling" as one of MPV reviews suggested. However I'm glad now. I have 21,000 km and I can't say I see any wear on those Dunlops...
    I have used the Mobil 1 oil filter on my 2000 MPV which has 8000 miles on it now. I have used it 3 times and have never had a problem but like the K&N it will run about $10.
    Ladies and Gentlemen, check this out...
    http://contour.org/cgi/ultimatebb.cgi?ubb=get_topic&f=1&t=007363
    TB
  • glenmcglenmc Member Posts: 7
    Hello all, just a note about popping noises from the front of the van. We noticed that ALWAYS when reversing at low speed, we would get a pop or click noise when stopping - then, ALWAYS a pop or click the first time the brakes were applied when going forward after reversing. Had this for about 2-3 weeks, dealer fixed it - told me there was a new TSB for a front disc "spacer" plate. Don't know the TSB number or date - dealer put on the spacers and it's not doing it anymore.
    TB,
    I would like to think that I made an intelligent educated choice when I picked the K&N, however that wasn't the case. I was looking for the air filter and Kragen had the oil filters next to their stock of air filters. It was just a lucky find, specially after reading your link. I think I will buy some stock in K&N. Does anyone know the symbol?
    Anyways, its K&N from now and forever for me. Plus, I justified a new wrench to the wifey! :) thats always a good thing!
    MSGJVH
    Me again. Posted a couple of weeks ago, when we had 4 new Goodyear Regatta 2 tires put on the van after the local tire shop gave up on Yokohama product. We had scrapped the stock Yokes after our dealer advised it might be a good idea, got 4 new Yoke Avid Tourings for $ 350 warranty adjustment. Tire shop could not balance them to remove a 80-110kmh vibration that came up after the tires were changed. After 3 tries to balance the Yokes, on went the Goodyears at no further cost (even with a higher list price). Still vibration at same speed. Dealer swore it was the tire shop's problem UNTIL they switched new tires and wheels off a brand new 2001 MPV on their lot - same problem. Turns out there is a new TSB on adjusting a rear suspension bushing of some sort, has to be removed and turned 15 degrees in its seat. After 5 days in the shop, got the van back and it STILL vibrates. No idea what to do now, and it still wanders at highway speeds and throws the steering wheel around on bumpy streets in town - after 2 previous alignments. Now what?
    Well, if they have done all that, there may be brake drag caused by the master cylinder pushrod adjustment. This could cause some over 55mph vibration. Of course, this doesn't jive with your around town woes. I would definitely have them check that out anywayand look for any sticking calipers or shoes.
  • songbirdmisongbirdmi Member Posts: 2
    Hello -
    This is my first post on site -
    We recently bought a 2001 Mazda MPV LX, and we
    just love it. Have had it about 2 weeks or so.
    This morning, while driving my daughter to school,
    I was braking to come to a stop, and I heard a
    loud noise which seemed to come from the rear
    passenger side. It sounded like I hit something,
    and scared me half to death. There was nothing
    in the road though. I know it wasn't the anti-lock brakes, this was a totally different sound and feel. I came home and called my
    husband, and he said the same thing had happened
    to him a few days ago. He said he thought he had
    run over something or blew a tire, but when he
    got out to look, everything seemed okay. Has
    anyone experienced this or heard of this kind of
    problem before? We are supposed to drive down
    to Florida in a few weeks, and now we're a little
    nervous.
  • nick73nick73 Member Posts: 4
    In regards to #1127, I had the same thing happen.
    I took my 2000 MPV ES for its first oil change at a local dealership (not where I bought it) and two days later my wife was driving the car --when
    woosh , all the oil blew out at once. Luck had it that she was only 100yrds. from home and stopped quickly. Had it towed to dealer and same story..
    sticky pressure relief valve, they said that they have seen this once before.
    It took 2 weeks in shop to rip engine apart and change oil pump and gaskets.
    Couple months have gone by with no problems..
    except fog lights don't work .. local dealer was small and poor service and response to problem, but good thing is that it was covered under warranty.
    I will be taking it to dealer where I bought it (25 miles away) for all oil changes.
  • stevecanuckstevecanuck Member Posts: 33
    I took my 2000 MPV to MinuteLube two months back for its first non-Mazda dealer oil change. Last week I was looking under the car and found a nasty oil leek that had just started. And, yes, it was from the filter.
    I figured that I could tie this in with the sticking fuel door and dropped by the dealer. The service manager says he sees this a lot with the MinuteLube and other places.
  • rktd123rktd123 Member Posts: 2
    Plus one
    Concerning oil filters, go to http://www.pureoil.com/Etch_Bulletins.htm.
    It provides two articles that could help you in your fight. I have read of this problem before on this and Mazda replaced the engine after first denying that there was a problem with the design.
  • drrocketdrrocket Member Posts: 67
    How would one be assured that they don't or won't have a problem with the oil pressure regulating valve? Is this something that the dealership's service department tech evaluates when performing an oil change?
    Steve, I also have a sticking fuel door. We don't have self-serve so the attendants jsut figure out how ot get it open, I can lift up on the lever while they push or pry. I didn't think much of it but I was thinking that maybe I should mention it. Is this a common problem?
