Visitor Agreement.
Oh, I forgot...The Grand Prix also had a leaking right headlight.
I have thought about starting a topic on rental car experiences, both the cars and the companies. Does anybody think that would be a useful topic?
Mr. Vivona
I certainely would be happy to give my input - for example, how Avis attempted to kill me twice in a row by renting cars w/ faulty brakes.
Susan
L8_Apex
Sedans Host
Sidney
Worst case scenario...if you couldn't open the trunk with your key turned clockwise (keep it there) and pushing (forcing ???) the trunk lid up. Or using the services of a experienced locksmith fails...
You might want to have a try of unhooking and remove the rear bench seat to gain access to the trunk and see whats the cause. You'll need a socket set to remove the rear seat.
-C-
If the key won't turn at all, then the linkage may be pinched by the table pushing against the trunk lining. Stopping the car abruptly to shift the table forward slightly may dislodge it. If the key turns but the latch doesn't let go, then the plastic may have become jammed in it. If there is enough extra space in front of the table, maybe the quick stop will slide the table forward and pull the plastic out of the latch.
If all else fails, remove the rear seat to see if you can gain access. You'll have to look for the bolts that hold it in. The seat cushion must be removed first, then the seat back. However, you may find that the wall behind the seat is metal and you can't get access. If that is the case, you might have to drill an access hole large enough for you to send in a long piece of metal to pry the latch. Before doing that, look under the car to see if there are any snap out drain plugs that could give you a way to get to the latch.
Another way to get a tool into the trunk may be through the speaker hole, but they usually are mounted from below, so that may not be possible.
I have written this without actually checking my car. When I do and if I see something else that you can try, I'll let you know.
Mr. Vivona
If there is no wire, you can snake in your own harness through the speaker holes and dress it under the dash using cable ties. Then connect the other ends to your radio.
What I don't know offhand is if the standard radio can take an extra set of speakers in parallel without loading down the amplifier. If they are in series, the amplifier won't be loaded, but the sound will be less.
You could also call Crutchfield and tell them you want to buy dash speakers for your car and want their help in connecting them to the stock radio. They have information on all cars and can give you advice.
Mr. Vivona
table forward to dislodge it downhill, uphill, around-hill and back around-hill NO LUCK. Thank goodness he was carefully not to dent to lid. Tables out, and trunk is in uses again.
Thanks again for all your help.
Sidney
After thinking about it more, I figured that the table was tight in the trunk and was lodged against the lid pushing it up and keeping the latch from releasing, even if the key was turned. By pressing down on the lid, you compressed the weatherstrip allowing the lid to move down about 1/4 of an inch which was enough to take the pressure off the latch.
I did look at my Diamante and if you hadn't been able to open the trunk by any other means, it would probably have meant having to remove the license plate and drill two holes lined up with the latch mount. You would then attempt to unscrew the latch mounting bolts. Once opened, the small holes could be fixed with Bondo and since they would be under the license plate, paint repair wouldn't be an issue.
What I did note is that the Diamante trunk is a very secure vault. It is very well sealed and there are no easy ways to gain access through existing holes. You are quite lucky that you problem was solved easily.
I guess the lesson learned is beware of large things that "just fit" into the trunk.
By the way, did you know an Acura TL has no trunk keyhole. If the remote release quits...
What sort of conditions do you driving eg.stop and go or usually good highway runs; dry road or rainy and muddy roads?
-C-
I have a 97 D. I live in the New England area. During warranty I had warped rotors repaired 5 times, with 2 different Mitsubishi dealers. Always came back. It's back now and I'm off warranty. I dread the fighting that I'll have to go through to get this damn problem fixed.
I have been monitoring this board for over a year just looking for a solution. I am willing to use high performance, after market rotors just to solve this. Haven't seen any yet.
There is definitely something wrong with the rotor /brake design, despite what Vivona writes. If factory dealers can't fix the problem, then it is a manufacturer's problem.
Mitsubishi is hiding behind the dealers.
I visited Mitsubishi design and engineering in Japan about 4 years ago (I sell automotive electronic components). I intend to use my Japanese contacts to find out more about this problem.
How many more people out there have been having the brakes problems like us that have only been watching and posting? Please register and post, it only takes a minute as I have done.
One observation that I have on the brakes is that if the majority of your driving is non-highway, or under 50 mph, you won't feel much of the brake vibration problem. The vibration felt, goes up exponentially as you try to brake from higher speeds. It's dangerous.
I also drive a lot in Europe, on business, where highway speeds are greater than here, brakes used much more. I always wondered why Mitsubishi didn't sell the D in Europe, especially with the GDI engine. I suspect they knew that the brakes wouldn't hold up to European driving standards.
Any help would be welcome.
I also do not get the vibrations you talk about.
As you seem a well travelled man, I'm curious in which highways in Europe did you drive? In what country and between which towns did you experience greater highway speeds than in the US?
What was your car and cruising speed in those highways?
-C-
Maybe I should ask Bohlen and Maury2 to do the reply back to me as their appearance on the discussion group seems to be a "mutually-exclusive" affair.
With that I mean, one doesn't seem to hear much from Bohlen and Maury2 when new characters happen to appear with the same brake problems and wanting to recruit "real" people hopefully to express their disgust at the 'D's brake problems.
Sigh... they try and try don't they?!
-C-
2. You didn't ask about my details, only about driving in Europe.
I have driven in most of the major countries in Europe in rental cars and in client cars. In Germany, of course, there are no speed limits on the Autobahn when conditions are clear. I have driven and ridden at up to 145 mph on German roads. 100 - 110 mph is very common. In France, on tollroads, the speed limit is 140 kph (88 mph). It is common to cruise at 100 mph. In the UK, it common to cruise at 85-90 mph.
3. The only reason I am here is to solve a problem: the brakes.
I have seen a lot of mention on it here, and the dealers I've been to told me there is a problem. The last one used all the recommended equipment, procedures, torque etc. to true the rotors. It fixed the problem for the same temporary period of time. I have watched this happen 5 times on my 97 D. I've been driving for 34 years, lots of different cars, and I've never seen this sort of persistent brake problem before.
The D is fine car except for the brakes. The only other problem I have had was the transmission chip problem.
4. Why are you here on this board? The main reasons people come to these boards is for help on a problem, to research a possible purchase, or other research. If I had no problems, I would not be on this board.
5. Once again, I encourage all owners that have had the brake problem to post here so that we can see the magnitude of the problem and hopefully find a permanent solution together.
and is more comfortable on a long drive than the Diamante, IMHO of course. You should try reading the Diamante topic form the very begining and you'll discover that there have been many others reporting about the bad brakes. Hey, having my brake issues (vibrations) addressed at the dealer TIME AND TIME AGAIN was bad enough but I also had the transmission fail and the AC compressor fail in additon to may other rattles and fit and finish problems. I'm glad for you that you've had no problems, but I can tell you that I've spoken with many who have had problems; not everyone is as lucky as you are. I can also tell you that if I have problems with the TL that I will be posting in that topic but as of now, there is nothing negative to report.
haaah...We've missed you!
Each and everyone of you ;-)
-C-
at no extra cost).
Now, ccancio, you are being extremely offensive to us, "the opposition" of low quality & value represented by Mitsu Diamante. There is no reason to believe that Maury is somebody else...I happen to be on his side too...
This forum is not a true representative sample of all Mitsu opinion. It is not a valid sample for making determinations about mechanical failures of the Mitsu Diamante vehicle. When we share in this forum our comments are purely anecdotal, individual observations about our specific auto. No matter how heartfelt our complaints may be, they do not necessarily mean there is complete mechanical failure for the entire Mitsu line.
Certain mechanical issues have been addressed by Mitsu as a result of numerous claims. These have resulted in Service bulletins. However, a small number of bulletins does not necessarily mean that the vehicles have been free of defects. I'm not sure we know what mechanical issues Mitsu has chosen to recognize. The level of candor by Mitsu service representatives may be as varied as the opinions held in this forum, but it shouldn't be. This forum could result in presentation of information that may point to trends regarding our vehicle. One would hope that Mitsu monitors lists such as this to gain information about their product's performance in the field.
Hopefully the list is a source of help for those who are having problems/concerns. The list has some able contributors that are technically oriented and willing to help. Mr. Vivona comes to mind as a positive contributor. I have read his advice and checked it with other sources. I have found him to be reliable and helpful. More importantly, he and others like him have avoided the distraction of personal attacks.
I hope this list will continue to offer all contributors a chance to share opinion, observations, and questions without feeling like one is venturing onto scorched earth.
Maclf
Anyway, my intention in writing this message is to share with everybody my experience in fixing the problem. I replaced the front brakes with Powerslot rotor and Axxis pads. I have about 25,000 miles on the new parts and the brake still functions properly. You can find these parts at any perfromance shop. The rotor cost me $95.00 each, and the pads cost $45.00 for the set at a local store. You may find better deal through mail order. (I believe the Diamante shares front brake rotors and pads with the Eclipse.)
Personally, I do not believe over-torqueing the lug nuts can cause any problem because the compressive load producing by tighten the nut is minimal in compare to the yield strength of the brake rotor. However, everybody is entitled to his/her opinion. I am not trying to discount anyone's idea bur rather having my input. I strongly believe that Mitsubishi representative just want to give us the run-around like when they tried to explain to me the power steering hose problem . (This is a recall and they could not even fix it with the new parts installed.)
I torque the lug nuts (after replacing the new brake parts) the same way I have worked on any other cars and still did not cause the brake to pulsate.
I wish everyone well and hope Mitsubishi will realize consumer's approval is just as important as any marketing strategy.
Houston7
You guys make your "D" brake problems sound so much more serious than the current Firestone and Ford recall and the 1993-95 BMW V8 sulphur problem where the whole engine had to be replaced.
Is there anybody out there who died yet from the "D"'s brakes failing or anything else for that matter?
...If so please feel free to register your input in this discussion group ;-)
-C-
You can measure radial runout of a tire by jacking the tire off the ground, then placing a fixed pointer just touching the center area of the tread (not in a groove) so that the pointer just touches the tire when the highest part rotates by. Then rotate the tire until the gap between the pointer and tire is the largest and measure the gap with a feeler gauge. I like to see it less than .040.
Remember a tire can have low radial runout and still vibrate if the sidewalls have stiffness variances around the circumference. That's what the Hunter balancer can check out.
Since I am not experiencing the brake problem with my Diamante, it is hard to determine what is happening to the cars of those that do have a problem. If any of you brake posters are experienced in mechanical repair, particularly brake repair, and want to help find the cause of the brake problem, I would like to hear from you. I will provide some easy things to measure and monitor to see what is happening. But I want someone that will be willing to stay with the diagnostic project and make all the measurements and report the results. The cost for the measuring tools around $20.
Anyone interested?
As far as safety is concerned, my 92 D did not have antilocks, and with a full load of 4 passengers breaking on wet roads from highway speeds it was dangerous because of alternate front wheel brake fluctuation and resultant front end instability.
Did you know that there was a NHTSA recall on D's manufactured from AUG 91 to Dec 93 ( Mfg recall #96V143002) to replace the front break hoses and I was never notified of it by Mitsubishi or the dealers even though I owned the car for 2 years after the recall?
The goal of most contributors on this site is to provide factual data to get problems fixed and not to merely provide opinionated commentary. If you have factual solutions feel free to post them.
Your comment that I am affiliated with any other person on the site is just plain wrong. If you went back through the site you would find my prior posts on the brake problem way before the appearance of the 2 individuals you mentioned. You would also find that I praised the vehicle on just about every other aspect except the front brakes.
>provide factual data to get problems fixed and >not to merely provide opinionated commentary.
That's interesting- show me a discussion group on the 'net that does NOT have its basis on "...opinionated commentary." Everybody has opinions including yourself and you post them in this discussion group. An example of opinion is the quote I took from your last post.
Regurgitated opinions/posts tests some peoples patience here including mine. When I see those posts queried and/or challenged and the original poster doesn't reply in a fair amount of time (say... 3 days!!!) one would fairly judge that that post was made by a "Troll" or somebody who posts to incite needless debate on bogus info.
Even after all that stuff you wrote, you still haven't answered the question on what area do you live in the US and in what conditions you usually drive in (...snow etc)! Its hard for people like me (who have no problems with my "D") to comprehend posts like yours if you don't explain your environment. Is this break problem isolated on the East coast of the US, or maybe just snow prone areas ?
After sending all your notes regarding the problem to Mitsubishi, did they reply back and if so what did they say?
-C-
Powerslot - Can you give me more information on what part number you used for the Powerslot rotors?
I called Powerslot this morning after reading your post. Powerslot told me over the phone that they only have rotors up to the '96 D, none for the '97 and newer.
Can you help me out a little more. I am very willing to buy better rotors on my own than the junk that Mitsubishi appears to be putting on. I have had 2 sets of factory front rotors on my car. They always warp after 6 to 8K miles, when new, and after being turned on all the latest equipment.
Anyone know? Has Mitsubishi changed the front rotors, or any other front brake components in the '99 or '00 Diamantes?
The Diamante is imported from Australia where it is called the Verada. Looking at the current Verada gives a hint of what they may export for a Diamante in the future. Though the 2001 model remains unchanged, there is supposed to be a facelift in 2002 or 2003.
So...what does the new Verada look like? Visit the Mitusbishi Australia site and see:
http://www.mitsubishi-motors.com.au/verada_sedan/index.asp?page=vehiclespec&typeid=9&modelid=15
times on the front brakes of my '92 Diamante until I heard about the new(er) Raybestos QS (Quiet Stop) Ceramic brake pads. I called and they had just released a version for my application. I contacted Brake Masters here in Scottsdale, AZ and they ordered them and swapped them out for the existing ones under warranty - the difference which was about
$70. I have not had ANY problems since and
my D now stops quicker and I have almost no dusting anymore.
They are more $$$ than normal brake pads but they
are supposed to last longer and be much more
resistant to heating up (important in Az!!!)
The only production cars I know of that now
have them OEM is Porche.
If you are interested either check out the Raybestos site or check with a repair shop.
I'm not sure if any other companies have
released ceramics ones yet (I think some
shops have put there house brand name on them)
as Raybestos claims to have pionered them.
Hope this helps some!!!
Scott McRae
Some facts gleaned from these boards:
There appear to be more than 22 people who have posted about repeated front rotor warping problems, and the inability of Mitsubishi and authorized dealers to fix it. The factory and dealers continue to blame everyone but themselves and take responsibility, despite it being the overwhelming problem of topics posted here. This is statistically significant, as the number of people posting here is small, despite the number of posts. And some, I suspect, are just MMA plants trying to gently shift the blame everywhere else to postpone dealing with the problem, or hoping it will go away.
Also, re: the suggestion to write to the President of MMA - one poster shared his experience about doing that, it got him nowhere, just more runaround.
I searched through sample discussion threads here on Edmunds and found only one other model that has the same level of complaints about warping rotors: the Oldsmobile Alero 99. Please take a look at it by typing "rotors" in search topic, also look at the separate "Alero" topic to see the what happened and how it was fixed. GM, to it's credit, moved quickly to solve the problem. They changed the rotor design immediately, and upgraded the front rotors and pads on all cars with the problem, no questions asked, no blame on poor driving habits, no blame on poor mechanics!
If only Mitsubishi could be as honest.
Also, there are far more Aleros sold in the US than there are Diamantes, and yet our boards have a higher level of complaints on the rotors than the Alero. From this, I suspect the Diamante problem is more severe.
> will go away.
And conversely you could be a Toyota or Acura/Honda plant trying to destroy Mitsubishi for market dominance, but I guess any good conspiracy theorist will never really know huh?
The more you write the more you sound like our old buddy Bohlen!
Talking about Bohlen... usually when he sees a poster supporting his 'D' brake rotor view he would jump at a chance to joun at the fun and gloat.
Where are you Bohlen, past experience would have thought you'd eat this up!!!
By the way at 8,000 miles, my 1999 'D' runs so sweet.
See 'Ya
-C-
>"THE HOST" is obviously devoid of any sense of
>humor since most of my messages contain a great
>deal of just that.
Many readers, myself included, did not realise your posts were supposed to be construed as entertainment, but rather we were led to believe that they were serious accusations on the quality of the Mitsubisihi Diamante line.
If this is so it would be hard to demarcate in your posts when factual data ends and sophomoric humour begins. In essence this revelation puts your entire posting history in dispute
( ...mon ami!)
-C-
L8_Apex
Sedans Host
Finally after many hours on the 'net and visiting many a car audio store, I have finally ended up with:
Pioneer CDX-P1250 12 disk CD changer, $179 from http://www.MillionBuy.com.
I could not easily source an adaptor for this to connect to the stock Mits/Pioneer head unit. The part number was supposed to be MITPIL from Periphials Electronics, but the local car audio shops in California couldn't contact them.
Another outfit quoted me $70 just for the connector so because of this I opted to buy a new Pioneer head unit KEH-P690 ($141 @Ebay, List Price $250 ). This will make it possible for me to connect my new 12 disk CD changer via Pioneer's "IP bus". I couldn't connect it via the old DIN connector in the stock Mitsubishi.
The KEH-P690 is the high end head unit with a casette rather than a cd player. I can connect the stock single CD player as an auxilliary so I won't be left with a gaping hole.
I will use Mr. Vivona's helpful guide in disassembling the old stock radio and see how it goes.
Mr Vivona as you obviously have already tried it, are all the audio wiring clearly marked and labeled and are the wiring easily accessable with some lenght to play with? is the wiring permanently connected ( which I then would have to cut?) or does it use plug type connectors?
I will also have to lay the new IP bus cable from the dash and route it to the trunk. Have you tried this, any tips like upliftingthe carpet?
I will give it a go this weekend!
Many Thanks,
-C-
While you are in the dash, you may want to open the A/C control unit and unsolder the beeper that makes a beep each time you make an A/C adjustment. I found the beep a bit annoying for a sleeping passenger. The beeper is a small cylindrical component mounted on the controller PC board. If you are not skilled in PC board unsoldering, then try applying silicone glue into the sound hole on the beeper. That should at least make it a little quieter.
If you don't want two CD players, you can replace the stock one with a bin. I would get a replacement one for a 92-96 Diamante from the dealer parts department (about $40). It has a nice smooth action door on it. The 97-00 bin doesn't have a door. To get the older bin to fit, you will have to shave about 1/8" off the front edge. I had the original bin in my 99 and changed it out for the older style and I like having the door on it instead of the open bin.
Mr. Vivona
Sometime ago you posted about buying a Garmin 3+ GPS unit. May I ask you opinions on it. I am considering a GPS unit, but I can't decide between the Garmin eMap, 3+ and StreetPilot.
Your thoughts will be greatly appreciated.
You need to decide based on price and intended use. The street pilot has a bigger screen, but it is also not a pocket device and costs a lot more. The III+ is also more costly than the eMap.
I would recommend you visiting the excellent GPS review site http://joe.mehaffey.com/ You will find a link to "Low Cost GPS Hardware and Moving Map Software Reviews" that will tell you everything you ever wanted to know about mapping GPS receivers. Narrow your choices and visit a store that will let you demo a few models to see what you like the most.
At the clearance price of $150 I paid for the basic eMap (not the $299 Deluxe model which includes the memory chip and data cable) I found the eMap met all my needs. If price and size was no object, the Color StreetPilot would be nice.
My last post was removed because I questioned Ccancio's mental capabilities in a manner not acceptable to terms of service of these boards. I chided him for not reading my posts carefully. I was not, and am not, bashing the Diamante.
I was, am, and will continue to look for solutions to the warped rotors that have occurred on my 97 D. Please look over my last posts here: #71, 74, 94,95.
Despite Vivona's many offers of help, I do not think his approach is the correct one, letting Mitsubishi off the hook. And besides, I don't know Vivona from a hole in the wall, or what his agenda is.
This I do know: Road & Track, a far more knowledgeable, and KNOWN source is much more credible than an unknown Vivona. Road & Track is accountable for their words. Vivona is not.
As for Ccancio, his role seems to be to divert attention away from issues anyway that he can. Just study his posts.
