Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
Dropped off car at BMW dealership for oil/filter change. After that, drive door cannot be unlocked (actuator seems broken). Dealer says they couldn't have possibility caused it because door panel wasn't touched. Prior to that no problem with the locking mechanism. :mad:
Is it possible for someone to open the door via latch that would have caused this?
If on purpose, depress down the lock button while trying to unlock would break it?
For now I can manually unlock the door from outside with the metal key inside the remote.
I wasn't sure about the specifics, but I also thought that no current model BMW's used timing belts.
Best regards
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
When you use the remote, do you hear the actuator working?
Will the driver's side lock release of you manually try to open the passenger side door or the trunk?
thank you very much!
Best regards, Lehrer1
I'm assuming that you intend to keep the car for a while, so I'd follow this schedule:
Oil and Filter- Every 8,000-9,000 miles, using a BMW filter and either BMW 5W-30 Synthetic, Castrol Syntec 0W-30, or Mobil 1 0W-40
MT oil or ATF- every 50,000 miles using BMW proprietary fluids
Brake Fluid Change- Every two years using a DOT 4 fluid; ATE Super Blue, BMW DOT 4, and Castrol LMA are good choices
Coolant- Every 3-4 years; BMW coolant only
You shouldn't need brakes for 90,000-100,000 miles at least
Tires should last 40,000-50,000 miles
I had written earlier in regards to a ?llower, front control arm bushings repair on my 2005 BMW 325ci and you had suggested taking it to an indie shop for the repair. I wondered if you could tell me what an indie shop is and how I would be able to locate one?
Actually, Michele, Indie means "independent" and it is a mechanic repair shop that is not affiliated with BMW directly but specializes in BMWs and possibly other imported brands. At a good indie shop, the work is just as good as at a BMW dealership, and is usually about 30-60% of the price, depending on what needs to be done. An example is Autobahn Automotive (BMW) in Natick, MA, if you happen to be in the area. Try the yellow pages under "Automotive BMW", or the modern version, the internet, under "'your town' BMW service".
Hope this helps.
bimrs.org
Yeah, wish we had an indie shop around here, the closest one is 4 hours away.
i'd like to disable the smart key while I go surfing, leave the key fob in the car, and just take the small metal key to keep in my shorts while I'm in the ocean.
My old 2008 prius had a button under the steering wheel which would proximity sensor for unlocking the doors.
Is this possible with the BMW key?
2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
M3 makes me smile just hearing the sound of the engine.
As I am new to BMW, can anyone please tell me what all should I check for before purchasing this vehicle?
Also, any thoughts on how much I can pay for this vehicle? The dealer is asking for $25k.
I have been an Acura driver for the past few years, and decided to move to BMW right after I drove my friend's vehicle. I could not wait, and sold my Acura to purchase a BMW. I guess I enjoyed the drive of a BMW too much.
My questions are (1) is it beneficial to get the maintenance cost paid upfront even if the car is not being used much? (2) is the $2000 charge worth it? (3) is my dealer fleeing me now?
1) Not being used much? How many miles do you drive per year?
2) Somewhere around $1800 would be the price I would shoot for, if buying the plan.
3) Not sure.... why won't he honor the quoted price? There is always another used BMW coming down the road... Hundreds come off lease every week. Don't worry about this one getting away... Tell him you want the original deal.
regards,
kyfdx
Oil and filter change
Check fluids
Adjusted wiper blade
Scope inspection? They put a camera in the engine looking for abnormal wear?
I still have 5-6 mm left on the tires before the wear bars.
how much would this service normally run, this was under warranty?
You had an Oil Service performed- but BMW does not call for a boroscope inspection at an Oil Service, an Inspection I, or an Inspection II. Like shipo, I don't understand why it was done.
In any event, my BMW charges @$80 for an Oil Service on my 2004 X3 2.5; the cost for an E90 would be about the same.
Well, I haven't tried shutting it down and pumping the brakes, but the reserve canisters in my other cars don't lose vacuum that fast. I wondered if it was a BMW thing or if I had a problem that could potentially escalate. So far it sounds like no one has had a catastrophic failure that was foreshadowed by this symptom. Thanks, all.
I have a 1995 3 Series with 121,000 miles and a 2004 X3 with 99,000 miles- both are running fine and neither car has ever had a "professional" fuel system cleaning.
Otherwise, just say no to their extras.....
So...
I would amend my prior advice by stating that BMW proprietary fuel system cleaning procedure wouldn't hurt anything- but it is still totally unnecessary unless the car is exhibiting the symptoms listed in the flyer.
