i am having the same problem with my 2000 maxima. Did you ever get it resoved???
my maxima 2000 se standard stalls when i pull it out of gear and into nuetral - but not all the time!
it never does it if i have the Air Conditioning on.
It happens mostly in the morning or when the car has just warmed up.
It seems like the idle is a little low.
It seems that the whatever controls the idle isnt catching it after i pull it out of gear, the rpm drops very low and recovers or just stalls out.
also, i need to find a honest mechanic in the orlando area!
thanks for your help!
Any suggestions? does this sound normal to anyone?
My driver's side window does the same thing, very annoying squeek.
Sorry to sound like such a dolt. I'm one of those who usually takes the car to a mechanic or the dealer for whatever is needed.
Armor All down the window track and that apparently took care of it. Probably best to do it with the window all the way down and apply it to the front side of the window edge and just let it run down.
Does anyone know what this might be?
Thank you, :lemon:
I have been unable to find anything that may be hanging down for the wheel to rub against. Are there any known causes for this?
When I use the key fob remote to open the doors, they often relock themselves a second later. It happens right after the second button push to open all four doors. I don't thonk it happens when I do a single push to open the driver's door. I do think it has happened when a door is slammed closed (after all four are unlocked).
Anyone dealt with this before?
There were three problem code, 1. P0115 Collant Temp Sensor Prob 2. P0325 Knock sensor Problem 3. TCM-ECM coummunication Line Prob. That guy told me the first and second prob was not a big issue, but the third prob he was not very sure. So does anyone here has that problem? How do you deal with it? Thanks a lot
I'll probably change the screen with every other trans fluid change in the future and save the $25 for something else.
