Just plain water? There's about 3 1/2 gallons capacity in a full system. A gallon of water added would dilute the coolant mix ratio down quite a bit, which will lower the boiling point, and if you've added plain water in the past, even more so.
I keep a jug with premixed 50/50 DexCool and distilled water for occasional topping off. In 3 1/2 years, haven't had to add more than 6 to 8 oz a year to keep at the full mark.
to those that suggest I try to replace the bulb, is there a micro bulb I can but from radio Shack and try to fix it myself? Do I need a soldering gun? I want that fixed it drives me batty to see the light not working
Might have just been the fan kicking in for more cooling and it took a minute for it to cool down and register on the gauge. Especially if it stabilized at 210°.
If you've been adding in some Dexcool with the water, it's probably OK. You could check it with an antifreeze tester (or antifreeze refractometer if you want to get fancy!)
A friend of mine had a Taurus with an overheating problem. All signs were the water pump was OK - no leak, no noise- but turned out the impeller was loose on the shaft, not turning or pumping enough. They replaced the fan clutch, thermostat, and radiator before they figured that one out.
No problems with coolant level, etc. As a side note, the new fan clutch and PCM programming have helped the AC, if not the coolant temp. That is also a reason I am beginning to think it is not an "air" problem, but a flow problem of some sort. If air has been increased enough to improve AC and the coolant does not run any lower then I am thinking the problem is elsewhere. Going in again next week.
Wxman
You might also find out from dealer who repairs their speedometers. This repair place might have a bulb.
Just throwing out some options.
Just available from Prothane - front and rear urethane bushings for the stock bars - front 7-1184-BL and rear 7-1185-BL. Now you can tighten up your stock suspension with front and rear urethane bushings for about $25.
The receipt reads:
Correction: Replace Outside Temp Sensor
Part #: 000 015047946
Good Luck!
I had to reprogram my remote once because I dropped the car off for a module replacement and I did not give them my remote. When I picked up the car, the dealer told me I could re-program the remote and I think they gave me the instruciton sheet.
john
Over the weekend, we decided to take a little camping trip.
We pulled our 4400 lb. camper and, once again, experienced the transmission refusing to do the 2-3 upshift from after about 20 miles of driving onward.
This happens after it downshifts from 3rd into 2nd to climb an overpass, for instance. Then it won't shift back up into 3rd on the downside of the overpass unless I let off the throttle enough so that it slows down about 5 mph, at which point it has to downshift to speed back up. If I don't baby the throttle, the engine just screams along at 4500-5000 rpm in second gear even as I lightly lift the gas to try to get it to upshift. Instead of upshifting, it just slows down but remains in 2nd gear. So I let off the gas a little more and it finally upshifts. This all happens on level ground with no wind, and even on the downslope of an overpass, and only after about 15-20 miles. If I don't release the gas enough for a 5mph slowdown, it will drive for miles in 2nd gear. For the first 15-20 miles, it runs great and shift normally.
I also noticed that if I exit the highway and stop during this, I get the cooling fan roar when I take off again. Are the two symptoms related maybe?
I asked the dealer to look into this last summer, but no resolution.
Anyone here have the same towing problem?
Dean
Should last a lot longer as well.
thanks- Tiger10.
Also, does anyone have an est. price on getting the stabilizer end links replaced at GMC dealer, mine are fairly loose and clunking when hit a bump.
The fronts list for about $70 ea, rears about $67 ea, plus about 1.5 hr labor to do all 4 so I would est about $400. Or go to a parts store, buy the Moog replacements with grease fittings for about $20-25 ea and do it yourself. If you can handle a master cylinder job, can do this too.
Does the 4400lbs include your gear? water (if you fill the holding tank on the camper)? How about people and cargo in the TB? all affect towing capacity.
Max towing is 5100lbs for a 4x4 with the 3.42 rear gear (standard)
Your pretty close to that max weight.
Add some wind and maybe a poor wheel bearing or stuck trailer brake on the camper making it tow a bit harder and it will really heat up the tranny fluid fast.
--jay
Second question regards my boss' 02 Trailblazer. Her rotors seem to warp at 5k intervals. The Chevy dealer tells her it is her "driving style", but this is one of many GM trucks she's owned, and the first one that seems to use rotors on a regular basis. Is there a chronic problem with these trucks' brake rotors? Is there a TSB relating to that problem?
TIA
My 02 TB has 69K miles and I have the original brakes and rotors and have zero rotar warping problems. In fact, this SUV's brakes are better and higher quality and lasting longer than a Durango and Grand Cherokee I used to own. The brakes calipers are powerful using double pistons for strong stopping power. It is likely a "driving style" issue, but it could be defective brake system. If you speed and brake hard, then the life of the brake system can be significantly impacted. However, 5,000 miles is too soon in my opinion unless she is a crazy driver. I would make sure the dealer "replaces" the front rotars next time, do not allow them to "turn" them, and then monitor the situation. My wife's Lexus RX 300 had new brakes and rotars at 16K miles because Lexus used hard pads that were damaging the rotars. It was all covered under warranty. - In other words, every vehicle, including the "perfect" Lexus has issues. But, I am not aware of the Envoy, TB, or Bravada having braking issues. Anyone else on the forum that differs?
-gmfan
You said "I've never been very impressed with the brakes on this truck (compared to other SUV's I've owned)," - What other SUV's have better brakes?
But back to my boss' 02 Trail Blazer...Her brakes have gotten used up about 5 or 6 times in the 46k miles she has put on the truck. She tells me she has never had a problem with disk warpage or pad wear on any of the other cars or trucks she's owned, so I tend to believe there might be a problem with the truck, rather than her driving style. She also told me that she is averaging less then 15 mpg, while my wife, with an AWD Bravada, is averaging almost 19 mpg, with driving that includes plenty of mountain climbing. The AWD system alone should create more drag and result in lower mileage, I would think.
Do you think she could have a hydraulic problem that is causing her pads to drag and overheat the rotors? That could also explain the poor mileage, don't you think?
To answer your question- (and please keep in mind most people have varying opinions) I just never liked the brake pedal feel or pedal travel. I've previously owned a Pathfinder and two 4Runners that, in my opinion, had better brake feel.
I currently also have a 2005 4Runner and I like the brakes. Have I done any technical data research comparing SUV braking ? Nope. I just made my statement based on my foot and seat-of-pants feeling of driving the vehicle over the past 3 yrs. Of course, your question '"what other SUV's have better brakes?" could be taken in different ways. Did you mean 'better' as in just comparing overall dry stopping distance, or do you mean "better" as in comparing the braking system components of available SUV's such as rotor size/design, pad composite, applied brake system pressure, single/dual pistion calipers, ABS design used, and wet stopping distance ? I guess all of the above would have to be considered to decide what SUV out there has the "better" brakes! Of course, there are also people who would perhaps feel that their vehicle has 'better' brakes because their semi-metallic pads lasted them for 60k or they never had a warped rotor or evil caliper that froze up! Haha.
Our Envoy has been the classic love/hate relationship; love the looks/design, the ride and comfort and gadgets. Hate the things that have broken, still don't work correctly, software gremlins that come and go with a mind of their own, and parts that prematurely wore out. Would I buy another one? Yeah probably would dang it.
My TB has the 3.73 ratio so I think the rating is up to 5600 or so. There was no wind, but the ambient temp was in the mid 80's, and the road was fairly level (in NW Ohio).
On a hunch (since this happened before), as we were getting ready the day before, I jacked the trailer and all four wheels spun very freely.
Too bad that the tranny acts up like this, since GM originally touted the EXT version as a towing vehicle. It's very stable and comfy pulling my trailer, but this non-shifting drove me crazy.
I know it has one built in, but maybe I need to add an aftermarket tranny cooler?
Thanks for the comments,
Deano
Deano
Question: Why am I being charged for computer updates anyway? Should they be included in "recall" or warranty products? Any updates for a computer would imply changes needed to the original system - i.e. to fix software bugs. If it's just new stuff, I didn't need that they day I drove off with my new vehicle so I don't need it now.
Does anyone have info on being charged for car computer updates? Is this a common practice? Has anyone had it performed and if so, what changes or effects did you notice?
Bill
Would be interested in hearing what others are buying and some opinions
www.tirerack.com
www.discounttiredirect.com
www.samsclub.com
Ultimately, Sam's Club got the nod in my case, with a set of Michelins just like those I was replacing. Why?
* I could get them installed by the same people from whom I'd purchased them.
* The other close competitor, Continental, got bad ratings for winter traction on the tirerack site.
* Installation included balancing, valve stems, lifetime rotation, and a road hazard guarantee for less than 10 bucks/wheel
* The installed price was the least expensive - about $110/wheel.
* We own Wal Mart stock. Always good to do business with the places where you invest.
I would say as long as the cooling fan is engaged and moving enough air to keep temps within proper range and the fan is not far enough off speed to turn on the Service Engine Soon light you're probably OK. The fan clutch has a feedback circuit built in to tell the computer if the fan speed is incorrect.
You would have to address this right away if the fan was not engaged enough, turning too slow and the engine was overheating.
Replacement is so expensive due in part to the amount of disassembly and labor time required to do the job, mainly because GM made the fan shroud as one piece. On a lot of other vehicles, my old '88 S-10 pickup for one, the fan shroud is two pieces, and the top can be easily removed by removing 4 bolts for access to the fan clutch, making the job easy compared to the Trailblazer and its cousins.
who says good things about their '02. Since I bought mine I have had it
in the shop many times. First time was for a squeek coming from the front
end that would happen when I came to a stop. The next one was my rear
air/heat wouldn't work and the dealership replaced that modual. Then one day
I start up the Trailblazer to take the kids to school and my car is vibrating
just sitting there. So much so that I could feel it through the steering wheel.
That was caused by little rocks and sand that had got caught up in between
where my transmission is mounted next to the exhaust. It took the dealership
a week to figure that one out. At the same time they informed me that my 4 wheel drive modual was not working and they replaced that too.
Now, 5 months later I get up in the morning
to take my trailblazer to the mocha stand and there is an oil spot under my
car. Under closer examination I discover its brake fluid. I am lucky that my
Uncle is a mechanic. He's going to take care of this problem for me. Now
that my Trailblazer is not under warrenty I am very scared of the transmission
going out. I have 41,000 miles on it. Never in my car owning years have I worried
about a vehicle with this low of miles having a major problem like that. I have always owned GM cars. My first was a '87 Camaro then a '92 Camaro after that
was a ' 97 Prizm and then a 2000 Blazer. I was extatic when Chevy came out with
the Trailblazer in '02. As soon as they were available where I live I went out and bought mine. All my other cars had 80,000+ miles on them when I let them go and NEVER had a major issue EVER....now I am plagued with them. It makes me
extremely sad that GM has really dropped the ball with the Trailblazer.
In searching previous messages on this topic, I read that a few people had had leaking batteries because of the side terminal posts. Is this peculiar to Delco brand, or a problem with any brand of sidepost battery.?
