Battery to ignition switch.
Switch to Power distribution centers (2 for most jeep models 1993 thru 2000).
Power distribution center,(in engine compartment), to PCM (Powertrain Control Module).
PCM to Auto Shutdown Relay(A.S.D)((which is bridged with Fuel Pump Relay(F.P.R)(if 1 is defective, then both are defective)
A.S.D relay From the Power Distribution Center fuse F2
Fuel Pump Relay from the P.D.C fuse F15,F03,and F06.
Relays are the "weak link"/ (circuit breakers) to the sensors. Without them sensors would burn out very quickly.
THIS IS where i would start. Where i had left off, both relays feed all sensors from there. IF any sensor(s) are truly, indeed, "BAD", then the OBD would have "sensed" them and alerted you.
I hope this helped you, and good luck m8.
I hope this helps you, and good luck m8.
Anytime that you rebuild the "top end" of a engine, you give the "bottom end" a hand up. Hopefully. Putting rebuilt heads on the engine, has increased your compression rate. Resulting in heavier loads to the crankshaft and bearings,bringing "slop" to the piston(s) travel.
MY "BIG" question is: How long/far did you go, before you realised the head gasket had gone out? Check the spark plugs. I have had several spark plugs improperly gapped lately, must be the holidays .
Make sure that you have no vacuum leaks; especially the throttle body to intake manifold. Check all your hoses. Take a piece of hose and insert in your ear canal. Take the reverse end, and listen for vacuum leaks. (you will hear a "hissing" sound.
I cannot go any further with your question, as you do not give any info about year and model.
With this done, I would go back to sleep, and dream of pulling your next Suv out of the mud.
:surprise:
Without starting the engine, turn the ignition key on,off,on,off, and finally on again. The check engine light will begin to flash.
If any codes are stored in the PCM, then the check engine will flash the the number of the first digit, pause and flash the number of the second digit. Example: code 23 will be two flashes, pause, then flash three times. A long pause will appear between individual codes, if there is more than one stored trouble code.
When all codes are indicated, it will flash a code 55: completion of code display on check engine lamp.
After the system had been repaired, the codes MUST be cleared from the PCM memory using a scan tool. Disconnecting the battery will not do this, and you run the very good possibility of ruining the new sensor(s) that you have just replaced.
Purchasing a OBDll(OBD2) generic scan tool will give you a more detailed trouble code identification number(usually starting with p0, p1 codes narrowing down exactly what your problem is. An OBD2 scan tool can only be used on vehicles with a build date 1996 or newer. These scan tools run about $60.00 - $200.00 depending on the scan tool, and/or availability. Which ever scan tool you decide to purchase, make sure that it comes with the option to reset the trouble codes in the PCM; otherwise, you will have no choice but to go to a dealership to have the codes reset, making the purchase of an OBD2 scan tool moot.
In your situation, I/myself would just go to a dealership, and have them scan the PCM, to find out exactly what needs to be changed. If it is within your power to change these sensors relativly easy, then go for it. If not, bite the bullet and have the professionals do it.
P.S. If you do happen to get the P0,P1 codes for your problem, post them please, and I should be able to give you a online helping hand. Better yet, go buy a Haynes Repair Manual at your local part store for about $20.00. I swear by these manuals.
Go to a lube shop, and have them change your oil, and inspect all nessasary fluids:brake,power steering,cooling,and every thing else that comes with inpection.Also(if needed) have them lube the chassis where applicable.
If the dealership way is not too expensive, then that is the route that I recommend.
i know i would have never figured that one out ,did i get ripped off ???? anyway hope this could help someone else someday they also said for a mere $2200 they could have ripped the front end apart & put all new wires in there i dont think its even worth 2200 at this point
When you install the pump with a new gasket, turning the shaft so that the gear tang mates with the slot on the lower end of the distributor, or oil pump drive. The oil pump should slide easily into place. If it doesn't, pull it off and turn the tang untill it's aligned with the distributor, or oil pump drive.
Have them balance the drive shaft to find out if this is your vibration problem. If this is not the problem, then the front diff is where the problem lies.
I am assuming the radiator fan. Check the cooling fan relay, in the Power Distribution Center that is located in the motor compartment. You can more than likely swap the horn relay with the cooling relay and see if the fan stops. If it does, then replace the relay. If that is not it then, check the temp sensors ( there are two) to see if they are completely plugged in. 1 sensor is for your temperature control for the motor, and the other is for the cooling fan. A typical way to check the electric cooling fan on any vehicle is to take the sensor plug off creating an open circuit, resulting in the fan running continusly. You have an open circuit. Usually when the temp sensor goes out for the cooling fan the fan will not kick in. I'm thinking relay.
You can also do an automatic temperature control on-board diagnostic test. Hold the ac and the recirc buttons down, and turn the left temp control knob 1 click clockwise to do the segment test;when all the bars light up, which they should, release the buttons. Now "00" will appear, and push either a/c or recirc and a stickman will appear(indicating the fault code mode). Record the numbers, and post them, or phone a dealership about them. If a code 25 or 29 appears, the ATC module is faulty itself, and must be replaced before further testing. To clear historical faults, hold the a/c or recirc button down for 3 seconds. The faults have cleared when 2 horizontal bars appear in the display, and do not show up after several ignition cycles.
The service advisor told me that the service is around $150. What's included in the service is a complete flush BUT no filter replacement. When I asked about why not filter, he said that the way the do their flushes, it "cleans" the filter. I've never heard of this before and I wanted to get some info if any of you guys have had the service done or experienced the samething. It just seems a bit weird that the filter wouldn't be replaced.
amigo_john, "Isuzu Trooper" #8070, 30 Jun 2003 6:46 am
2 Days before this happened I was driving his jeep and it stalled at a stop sign, but started right up again. He has not had any problems with it dying before.
Does the alarm have a cut off switch and could this be the problem? How do I reset?
He also just had a stereo installed 3 days prior. I read that new electronics could cause computer problems. Before I start replacing Fuel pumps,sensors etc...Maybe someone could help thanks.
Just a couple of days ago I had a small problem with the cooling system repaired at a shop (i'm on vacation and did not bring any tools) ... the mechanic id a Grand Cherokee fanatic ... he has 4 of them .... he pointed out that the noise I'm trying to eliminate is not coming from the transmission, but from a worn bearing in the AC compressor!!!
When I get home in a couple of days, I'll replace that.
This jeep runs great ... we drove aprox 500Km on a secondary hihgway ... losts of snow and ice .... the jeep not only handled very well, but was very comfortable and used about the same amount of fuel as our 4L YJ.
As for the low coolant warning, if your Jeep is full in both the resevior and the radiator, then it more than likely is the sensor that is located near the fill bottle area. Hope this helps
chandler2
May i suggest that you buy the part from a parts store, or a steering and suspension outlet to save some money. Remember to always use the new nut(if supplied) and cotter pin that comes with the part. If the upper ballstud is diffucult to separate, then removing the 4 bolts that holds the frame rail bracket where the upper ballstud is in, may help you greatly.
Your very welcome
Happpy Holiday TO You And Your Loved Ones
