Let me give you a more detail response. I had to run out in a rush before. I will make it a hypothetical case.
Say a car can make 200hp from 1,000 rpm to 7,000 rpm. From a stop light idling at 1,000 rpm, the car accelerates from the 1st gear until it reaches 7,000rpm. So, you made 200hp already and get up to a certain speed. Note, the power delivery on 1st gear is very fast but the car speed would probably not exceed 30mph.
Then you skip 2nd gear and switch to the 3rd gear. Now the engine is at 1,000rpm and you make 200 more hp by going up to 7,000rpm. The car would probably get up to 70mph and noticeably reaching to 7krpm takes longer. Therefore, the power delivery is much slower than in 1st gear. The car contains total energy of 400hp which made it get up to 50mph.
You repeat the same in 5th gear and driving at 120mph at 7,000rpm. The car now contain total of 600hp to get up to this speed. Every time you change into higher gear, torque on the wheel gets less and less. But the total possible horsepower you can make is 600hp. If you downshift to 3rd gear, you are limiting the car up to only 400hp(600hp-200hp).
Notice how every time you shift up in gear and start at 1,000rpm, the engine does not have it's maximum power developed yet. But in HSD E-CVT and mechanical CVT, the engine can stay at 7,000RPM and the transmission can adjust to accelerate. That way, engine is at max horsepower all the time. CVT can also put the engine in the RPM that is most efficient or most torque. That's why CVT is superior.
Mechanical CVT achieves this by using belt, cones and pulley. But HSD does it electronically. When you want to downshift(want more torque), Atkinson engine can rev up to max horsepower while MG1 generates electricity. That electricity combined with battery will power 50KW MG2 and provide high torque. Notice how HSD is providing both max hp and max torque at the same time. In traditional transmission, it is either torque or horsepower. This translate to faster power delivery. HSD(Prius) can supply power as fast or faster than ICE only car(Camry) with twice the max hp rating. This also applies for hill climbing which is the reason why this discussion started.
Look, for ther short term, new diesel engines provide the best driving experience in small, medium, and large cars. They also work well in SUV (sold only in Europe). We were tricked into marketing gimmicks where more horsepower and bigger SUVs are "safer." Fuel cell cars are examples of domestic car companies use of smoke and mirrors. They are decades away. Hybrids are OK but diesels drive better. If you turn the AC on or drive on the highway, the mileage drops. PLus, I dont like driving in a coffin like Insight or Prius. The Passat TDI is the only mid-sized diesel car in the US. The E-class 320 CDI is the only luxury car sold in the US.
"If you turn the AC on or drive on the highway, the mileage drops."
What is illogical about that? AC uses electricity and driving on highway takes more energy to push through air so, the mpg will drop. Could it be that you got it the other way around?
why exactly are Insights and Prius coffins? Is it just the shape? Cuz there are a bunch of hatchbacks out there with similar looks (at least, similar to Prius). Matrix comes to mind.
Turning the A/C on in a diesel doesn't decrease the mileage? That would make diesel-installed A/C miraculous.
The A/C in the new Prius is electric for less draw on the engine.
I believe he is making reference to the fact the government gave Toyota special safety wavers to get this vehicle on the road. I drove one and thought it was cool. My wife wouldn't get in it even for a test drive. She is used to her Lexus LS400 and my Suburban. I don't think anyone can argue that a Prius or any other small car is not as safe as a larger vehicle. I'm with the other people on the forum that believe we are missing the boat in the USA by not using more diesel vehicles. I would love a small Ranger size diesel vehicle. I refuse to drive a smaller truck or car one with a V6 that only gets 2-3 MPG better than my Suburban V8. My wife's 1990 LS400 with a V8 gets 27MPG consistently. I just rented a brand new Ford Taurus that was smaller and far less comfortable and it only got 25 MPG on the highway. Doesn't look like we have made much progress in the last 14 years.
My 11 year old Dodge Spirit got +24MPG. That's terrible! gagrice, You are correct that a larger, heavier car is safer than a smaller one. The difference in my view is which works works for my commuter vehicle with only me in it. It doesn't make any sense (to me) to drive...say a large SUV even with an "improved" engine getting...27MPG when I can drive a smaller car with half MSRP and 55-68MPG. I'm not saying that the smaller car is the only car for everyone...I myself keep a Grand Caravan @ 24MPG to haul 4x8 sheets of whatever and family on long trips. But my GC 24MPG is a joke..but not funny at the pumps. It's almost always parked these days. I don't personally care for a diesel car. Thanks Steve
I will try to use a perfected CVT logic to explain impact of power on thrust. Let us assume we have two identical cars (3000 lb., 15% drive train loss, both have a transmission that can hold engine speed at peak power perfectly as the car accelerates, and tested with driver weighing 200 lb., both cars have wheel diameter 25 inch). All considerations are at WOT (wide open throttle) to keep things simple.
The only difference between the two cars is that they produce peak power at different engine speeds. Car A: 200 HP at 2000 rpm (hence 525 lb.-ft at 2000 rpm) Car B: 200 HP at 6000 rpm (hence 175 lb.-ft at 6000 rpm)
Here is a simple formula you could use to calculate the overall drive ratio (ODR) required to maintain certain wheel speed (in mph) at some engine speed (in rpm), when the wheel diameter (in inch).
Now, we have two identical cars, with same power (but different rpm due to torque difference) with same wheel speed. You could approximate “thrust” (in g’s) using this formula.
Two cars with different torque (525 lb.-ft versus 175 lb.-ft) at same wheel speed (50 mph) have same thrust (0.40g) BECAUSE they have the same power (200 HP). Remember power balances thrust and speed, not one way or the other. You can have more speed with same power, but you would have to give up some thrust. Likewise, you can have more thrust from same power, but you would have to give up some speed.
How boring. I don't need the car to find the optimal torque, you can feel it. Shift your car and you won't have a problem. Its a big advantage for other cars over Toyota-Style hybrids. Why do I want it to shift for me? I'm not a baby and maybe I didn't want it to shift right then. CVT is reading us for the totally bland experience. Soon maybe the new cars will drive for us. If all we have to look forward too is a computer robbing us of driving experience, the future is bleak. Give me some rumbling engine, and a stick to contain the beast and I'm happy. Now with gas mileage on par with robo-drive, I'll pick a diesel everyday.
are safer in an impact usually, but they have also been shown to be more likely to be in an accident due to top-heaviness and less ability for routine and emergency handling.
Diesel seems to give more of an advantage in trucks than in cars...
I agree with the little high mileage vehicle being very important. I just don't believe the Hybrid is ready for prime time. You can get 50+ MPG with a VW TDI vehicle and have better crash test ratings. Also when I test drove the first Prius in our part of San Diego it had an 8 year 100,000 mile warranty on everything. Now it is the same as all the rest 3yr 36k. It still has some very expensive equipment that will go out, such as the batteries. I was talking to a guy that owns one at the firestone store and he had to order special tires that cost double what they should. I still want a medium size PU with a diesel. I drove one from Brazil about 4 years ago and it was great. A Ford Ranger crew Cab with a 4 cylinder diesel that average 45 MPG from the tip of South America to Prudhoe Bay Alaska where I work. We are being manipulated by the manufacturers into driving what they want to sell us. Economy is not a factor.
I would have to go along with you on this. Right now the hybrid (Toyota Prius) is a "do it all" machine. There is so much "SEX" about it. (not that anything is wrong with sex) but hey it is the cure for global warming, cure for suvs, the elixir for peace in our time, cure lung disease, cut down oil spills. Shoot even Hollywood types get paid to drive em.
To me when folks like Consumer Reports do their 5 year evaluation and after several recalls etc would be a more reliable judge.
Thanks for your effort by using the formulas and making it so clear. The only way to increase thrust is either increase torque or increase ODR since other numbers are constant. You are right, those two cars can provide the same thrust. The next question is how fast can a drivetrain deliver thrust?
Let's go back to climbing hill genesis. Climbing hill requires extra thrust, agree? Three ways to achieve this goal:
1) Increase torque of the drivetrain 2) Increase ODR(downshift) 3) Do both
In a traditional ICE only car, at full throttle, the engine torque output is static. You can duplicate torque curve by flooring the gas paddle. So, the only way for ICE only car to achieve more thrust is to increase ODR. This means downshift to get more thrust.
Believe it or not, HSD can increase thrust by using #3) Do both. HSD can increase drivetrain troque and increase overall drive ratio(ODR) at the same time! How does it do it? Get a full understanding of Planetary gearset first or you won't understand what I am going to say. First, to increase torque, HSD can tap into battery electric torque instantly. That's the easy part. Second, to increase ODR, MG1(sun gear) will spin backward or acts as a generator. This changes ICE to Driveshaft(wheel) ratio, in another word, increases ODR. Did I mention MG1 is acting as a generator? That electricity will be routed to MG2 to increase more torque as well. Another example of HSD killing two birds with one stone! This is why 76hp Prius can climb hills like a 2.4l 160hp camry.
Dennis
P.S: You may go back and read my previous messages. They might make more sense to you now, why I said, torque is more desire when climbing hill and more speed isn't desire.
For those with wishful thinking and bought into PR bias diesel spin, here are real information from Motor Trend.
"The diesel E320 can get 27 mpg in city driving and 37 mpg on the highway, while the gas-powered E320 gets 19 mpg in the city and 27 mpg on the highway.
However, the E320 CDI cannot be sold in California, Maine, Massachusetts, New York or Vermont, because it violates pollution regulations."
Diesel E320 combined mileage is 32mpg. No where near of Prius. The emission is also night and day.
"and have better crash test ratings" __Honda Civic is 5 star rating. Not sure of Prius. "3yr 36k" (Warranty) __Yes, this and 5yr/70K battery warrany is the standard for HCH. Since I keep all my cars 10 yrs and 160K miles I got the best extended warranty of 7ry/70K B2B and 10yr/150K on the battery. "tires that cost double" __I've not priced the low resistance tires but can also be made with the deal. I've got free tires from the dealer for as long as I own the car.
I'm not out to push an environmental statement, I don't go for the sky is falling global warming hoo-la or the death to us all crowd. I just want to save some $$ bucks at the pump. My last tank average was almost 60MPG: more than 710 miles on 13 gallons of gas driving normally with other traffic in a nice comfortable car. Daily commutes are 58-64MPG day after day. Given these figures it wouldn't make sence to drive daily commutes in a truck that gets only mid 40's MPG and have to put up with the hastles of diesel, or a VW TDI getting only 50MPG. It will be interesting to see in 10 years what will or won't be available in either or both technologies. Thanks Steve
Horsepower is the end all. Unless Prius has better power to weight ratio going uphill compared to Camry, it won't perform as well. Thats the bottom line. Torque won't do anything if there is little or no power.
Diesel E320 combined mileage is 32mpg. No where near of Prius And Prius' doesn't perform anywhere close to the diesel E320. As much as I'm eager to see hybrid technology mature, I try to appreciate things as they are. And new diesels can definitely stand on their own.
In a recent test, diesel hybrid (2.2 liter I-4 i-CTD, 140 HP/250 lb.-ft) returned 92 mpg (mixed driving). Even if this is in imperial gallon, it is still impressive (also given the performance). I wonder how much improvement (fuel economy and emissions) hybridizing this diesel could bring.
..."My last tank average was almost 60MPG: more than 710 miles on 13 gallons of gas driving normally with other traffic in a nice comfortable car. Daily commutes are 58-64MPG day after day. Given these figures it wouldn't make sence to drive daily commutes in a truck that gets only mid 40's MPG and have to put up with the hastles of diesel, or a VW TDI getting only 50MPG. It will be interesting to see in 10 years what will or won't be available in either or both technologies. Thanks Steve "
Since you have a gas/hybrid, it will be interesting to see your long term history 100/200/300/400/500 K miles. One other thing I would be interesting in knowing is; other than the normal unscheduled maintenance stuff, what your battery replacements costs will actually be. So the real question is it worth your up front premium (4k) to drive a gas hybrid and down stream battery costs (local rag mentioned 3k).
Actually, you seem to be a very fuel efficiency minded driver. I have heard of Jetta TDI'ers pushing 60-65 mpg. It would be interesting to see what you can do with it, despite your bias. I have driven the Prius for 5 hrs but did not do a full tank refill. Magazine tests report 40-45 mpg. This is a lot less than its 51 highway and 60 city mileage epa.
The thing I really like about the TDI is you really don't have to be very care "fuel efficiency" wise. Yesterday and today, we made two round trips to the exact same destination 162 miles R/T x 2 days, "freeway town and country) 2 hrs each way one day, (obviously heavy COMMUTE bumper to bumper traffic) and this morning 45-50 min . Filled up and got 48 mpg. Loaded with 4 people, with the AC ON!
As you know diesel is more efficient than unleaded gas, app 37%. So a diesel hybrid mating would be "better."
That survey would point out that the diesel PR spin has not reached many Americans. Its not surprising since in this country the only place you see diesels are big, dirty trucks. Most people don't know the new diesels since most Americans don't see them as they are on the other side of the pond. I know many people I work with were clueless about biodiesel and overall they are well informed. Also a friend of mine just got back from England with his rave review of a drive in a new diesel, followed by the shock he can't hardly get one here. Maybe its wishful thinking or the grass is greener syndrome, but it is a shame for whatever reasons it has taken so long to get low sulfer fuel, and new diesels. Gas is good, but we can't expect to be paying under $2 a gallon in the future, much less $3 or $4 in the foreseeable future. Biodiesel today can be found around the $2/gal price as I've seen on other treads. In the near future it will be the only affordable fuel and the only renewable one. Now hybrid technology is great, but battery technology has not evolved very far and has been a bottomless whole for funding. Lets get real about the future and solve the Mid-East dependence. Thats my main concern, then we can sort out the environmental issues, that are far from unsolvable.
___In regards to the latest Honda designed 2.2 L iCDTi Diesel Performance, Fuel economy, longevity, and drivability concerns may have disappeared. With an even smaller 1.0 - 1.3 L in a Civic/Insight (non-Hybrid format), you are probably looking at meeting Euro V emission specs which are every bit as tough as ULEV here in the states. Can anyone possibly not see an advantage to cheaper to purchase and cheaper to own then any hybrid to date?
___The new iCDTi Accord diesel 0 - 62 in 9.2 to 9.3 seconds in a > 3,000 # automobile and meets Euro Spec IV specs. That is anywhere between TLEV and SULEV depending on what is being measured:
___Here is the rundown in terms of CO, HC, NOx, and PM in grams/mile
“I’d defy any passenger not already ‘primed’ to even notice this was a diesel engine.” Top Gear, test drive Dec 2003
“It delivers strong, real-world performance with a new standard of diesel refinement.” “Stunning engine, fine car.” Autocar, 11/03
"It was one of the most harmonious, most complete drives I've had all year. It just gelled" Evo, 11/03
“Seems Honda has got just about everything right first time.” Autocar, 09/03
“Smoothest and most refined in class.” Fleet Week, 7/03
“Superbly quiet and smooth.” “The Accord diesel is one of the most refined around.” What Car? 10/03
“It works, brilliantly. No, it is better than that: it is easily the smoothest, most refined, least dieselly diesel I have driven ” The Independent, 09/03
“This vehicle even behaves like a petrol, making Volkswagen’s laggy PD TDI 130 feel dated.” Auto Express, 08/03
“This feels like the new benchmark for four-cylinder diesel refinement.” Car, 10/03
Sounds like you are happy with the Civic. Does it require Premium Unleaded as the Prius does? I think we are on the same wavelength wanting a decent vehicle with decent mileage. I don't think you can compare the hybrids of today with the diesel trucks that keep slipping into this discussion. The best of them still only get about 22 MPG. That is much better than 13 MPG but when you are looking for 50 plus MPG it will have to be a smaller vehicle, at least for the foreseeable future. I will be interested to see your long term impression of the hybrid civic.
"Horsepower is the end all. Unless Prius has better power to weight ratio going uphill compared to Camry, it won't perform as well"
I also favor more horsepower. But power delivery rate(thrust with time) is also important. So, you should also look at thrust to weight ratio across a range of speed. Prius has better thrust/weight ratio than 2.4l camry from about 30mph to 50mph. Camry has better thrust/weight ratio from about 70mph to 100mph. If you are climbing hills at around 40mph, Prius might do a better job. If you climb hills at 70 or 80mph then, Camry will have the advantage. I hope that explains where power delivery rate shines and more horsepower shines.
Traditional ICE only cars are bloated with horsepower. The reason is to achieve faster power output rate. Again, if a hybrid drive train double the power delivery rate, we will have to redefine how much horsepower we actually need to achieve the most difficult driving tasks with higher power output rate.
I am also curious how a hybrid diesel would synergize. I mean, the two are pretty similar in power output. High torque at low rpm but low horsepower. The cause of diesel low hp is due to low achievable RPM. For electric, low hp is due to low torque at high RPM. Maybe there is a design can unite the two natures and create a synergy effect like current gas electric HSD.
I read about Toyota traded HSD license with diesel patents from Ford. I am sure Toyota is toying around with diesel electric for cars. There are Toyota diesel electric trucks in Japan. I believe they are serial hybrid design. Maybe, those Ford diesel patents might give us some clue.
How does it perform from 30-50mph? 60-80mph? 1/4 mile time? If it is so refine, would it match that of gas engine cars? Just curious.
Those diesel emission numbers are impressive. They really need to work on NOx though. For reference, in 1997, the classic Prius was first to comfortably meet EURO IV, J-ULEV and AT-PZEV emission regulations at the same time. 2004 Prius beats it by far.
I'm not sure I could have typed that with a straight face. C'mon, who in the world wants to compare an E-class benz with a Prius?? We're talking a big heavy luxury car that can average 32mpg and perform on-par with vehicles that average 10mpg less. When they can get the prius to accelerate from 0-60 in 6.5 seconds (or any other performance range you want) and still get 40,50,60mpg then we can start comparing the two. Even without all-wheel drive, the E-320 CRD is very close to replacing my A6 4.2 that's lucky to eek out 20mpg.
Not sure what you mean by that, but your assumptions regarding horsepower are bad. And no matter waht you want to calculate (power to ratio, g's (that I already did to show you how it relates to horsepower) etc., power rules. Peak power? No, but mean power developed across the board. More power, better performance, that is the bottom line.
"Hmmm... Solar power cars could be as popular as Diesel by 2010."
And apparently we'll also have nuclear powered cars by 2010, too? I can't put any faith in research that shows a nuclear powered vehicle will be on the road in less than 6 years. Do 14% of people actually think that solar power will "most likely" propel vehicles in 2010? wow. Who did they survey?
Emissions are not night and day. There is 1 component preventing them from being sold in eco-states and that is sulphur. US diesel fuel needs to catch up with Europe in sulphur content and that will happen in 2006.
Plus you're comparing the mpg of a powerful Mercedes with a Prius. apples vs. oranges. Try comparing hybrid to diesel when the 2 cars have similar performance. I could make the same analogy comparing a Prius to a moped. Makes the Prius seem like a gas guzzler.
I'm only defending truth and a fair comparison here. I think there's room for both. Kudos to people who drive the Prius. I can't. I need AWD where I live. I care about what a car looks like (and IMHO, the Prius is butt-ugly). I need a practical car, which means (in part) that I have to be able to do the work on it myself.
"C'mon, who in the world wants to compare an E-class benz with a Prius??
Exactly. Someone posted a review of E320 which compare mpg to Prius and claimed that diesel E320 can get the same fuel economy as Prius. First I pointed out that E320 is twice expensive. That response was to show the real mpg numbers. Please read previous messages to get the whole picture.
"I'm not sure I could have typed that with a straight face. C'mon, who in the world wants to compare an E-class benz with a Prius?? We're talking a big heavy luxury car that can average 32mpg and perform on-par with vehicles that average 10mpg less."
And, furthermore, even toyota says that most users can't expect to get the EPA figures, and several reviewers have gotten significantly better than the E320's EPA numbers, so much so that observed mileage has been the same. I just think that's awfully impressive.
"Even without all-wheel drive, the E-320 CRD is very close to replacing my A6 4.2 that's lucky to eek out 20mpg. "
"Are you suggesting 1997 Prius met AT-PZEV status first?"
No, I'll highlight the important part that you missed. In 1997, the classic Prius was first to comfortably meet EURO IV, J-ULEV and AT-PZEV emission regulations at the same time. HCH might be the fist to meet AT-PZEV but might or might not meet Japanese and Europe emission standards.
"And, furthermore, even toyota says that most users can't expect to get the EPA figures, and several reviewers have gotten significantly better than the E320's EPA numbers, so much so that observed mileage has been the same."
There are Prius drivers with light foot on gas got about 80MPG. Also, it is not fair to compare Prius winter mpg to warmer spring E320 CDI mpg. E320 diesel's combined 32mpg isn't impressive if you look at RX400h combined 34.5mpg. HSD will have superior response and mid range power delivery than diesel. Only if they make a diesel hybrid that boosts passing power......
My question about who was surveyed was rhetorical. It's irrelevant. The point to the comment was that I can't BELIEVE that ANY % of people actually think that we'd have a nuclear car in 6 years. wow. Talk about out of touch. That is so ludicrous that I don't even know how to react. 2% of 1000 people, that's 20 people. scary. It's clear that this is not a smart bunch (even though it's probably representative of the general public).
Plus the question can be taken a number of different ways.
"What will most likely power vehicles in 2010?" can mean: 1. Based on 2010 car sales, cars with which fuel will sell the most? 2. Which fuels will be available to power vehicles? 3. Of the cars on the road in 2010, which fuel will be the most prominent?
>> fair to compare Prius winter mpg to warmer spring E320 CDI mpg. E320 diesel's combined 32mpg isn't impressive if you look at RX400h combined 34.5mpg<<
I believe that the E320 review listed real world mileage, whereas the RX400h is a hypothetical release of EPA by Toyota. I bet the RX gets less than the E320 under normal useage.
ruking: "it will be interesting to see your long term history" __I keep my all my cars 10 years, at that time I'll have about 160km. I had the same concerns so I bought the highest warranty of 7yr/70K b2b & 10yr/150k battery. Battery technology $$ generally go down. I paid about 3.5K over its sister Civic EX, which is not nearly as nice. "I have driven the Prius" __I've not driven one either. Toyota didn't have one. Rick Reese an Insight gamer has one and gets around 80MPG. Admitted this is not the "norm" and neither is my HCH MPG. Only a few folks play this game. "It would be interesting to see what you can do with it" (diesel) __Thanks. Give any gamer an accruate clear to read FCD and you'll see great results no matter what fuel. (Gas, diesel, nuclear, anti-matter etc) Wayne, Rick and others are good enough not to require FCD. I still need one.
gagrice: "Does it require Premium Unleaded as the Prius does?" __HCH burns regular (not)leaded 87 octane fuel. I'd HATE to pump in those extra $$. "I will be interested to see your long term impression of the hybrid civic." ___Me too! So far I rate it 9 out of 10 "stars".
1. Per mile scheduled maintenance costs is right around .01 cents per mile. (Oil filter changes, air filter, brakes,fuel filter, brake fluid, tires, cabin filter and timing belt change allowance)
2. Fuel costs are whatever the price of gal of fuel/ 45-60 mph.
3. In my case, I am right around .06 cents per mile total operating costs.
My projected time to hit 100 k miles or 160 km is 3.5 3.8 years.
Thanks. Oil, oil filter and tires are covered by the dealer for as long as I own the vehicle. HCH has a real-to-God chain, not belt. Not sure what my average CPM would be. I do know that I won't be getting any speeding tickets bumping up insurance! :-) Steve
For sure, the comparison will be with the Civic. I compared the Prius against the Corolla and even with the less mpg, the Corolla was more cost effective.
My VW TDI has leather interior, heated seats, sunroof, Electronic Stability Program, Audio system with separate amp. for the same price as a Honda Civic Hybrid. Mileage is similar to HCH. Fuel cost is $0.37 less per gallon for diesel compared to gasoline. Diesel makes more sense to me than hybrid at this time when comparing cost and available features and performance.
Actually here (Northern Indiana) Diesel is 49 cents less per gallon of Regular unleaded. ($1.59 Diesel; $2.08 Regular; $2.28 Premium) So, if it is true that the Prius needs Premium Unleaded, then I am paying 69 cents less per gallon than the Prius owners. Sure, I only get 45mpg in mixed driving, but 69 cents!!
Just paid $2.03 per gallon to top off my '04 Prius. As I was pumping I noticed diesel at 1.79/gallon! I can't see why VW isn't selling more TDI's in parts of the country that allow it. Anyone know why? Can it be that people are leary of VW reliability? I had two Audis in the past few years and never had any problems. Perhaps people really have a negative perception of diesels? Whatever the reason, the TDI is a wonderful choice. I also like the fact that VW lets you buy ESP for less than $300! All Asian/American car manufacturers should follow suit and let consumers buy this safety option without having to spend a ton of money.
I think most people simply aren't aware of it. Nine out of ten people on the street don't know VW even has a diesel, and many of the ones who do associate it with the old, slow, smoky, noisy cars.
I suppose the question is, why isn't VW promoting it more?
I agree about ESP. I wouldn't get a car without it. You might not use it for 20 years, then it'll save your life.
The base jetta/golf aren't particularly cheap, but they are full-featured ( abs, heated mirrors, side airbags, etc) , have superb safety, and drive like much more expensive vehicles.
Simple, diesel does not have much passing power since diesel fuel burn slower than gasoline. Gas electric hybrids offer high torque and even more passing power than gas engine cars.
I'm not sure which diesel vehicles you are comparing to gas engine vehicles. I can tell you for a fact that our new Ford 6.0 diesel 1 ton trucks blow the socks off of our gas powered trucks. And use 1/3 less fuel in the process. That is from a dead stop or passing 50-70 mph. They also far outpull the gas engines. our company will never buy another gas engine truck. Just no reason to...
Based on what I've seen, they're selling quite well. VW just plain doesn't ship very many here. I think they only build about 10% TDI's for the US market and that's it. Maybe it has to do with manufacturing and the european demand for them. The TDI motors come from germany.
My neighbors have been looking for a wagon and it look like they're going to have to place an order. No dealers within 200 miles have any in stock.
You got any numbers to prove these performance specs you're always using? I've not read a single review of a hybrid that stated it had really strong passing power. Adequate is the word I've most read. The one I drove didn't stand out as a barn-burner either. Granted my TDI has a slight power boost which anyone with $200 can get as well. Any $200 mods available for the Prius that will knock a couple seconds off the performance and not change mpg?
I agree, my Cummins has serious passing power. In fact, these diesel trucks don't really come alive until the higher speeds. I can hit the pedal in 6th gear and leave a lot of folks in the dust. Even with a 15,000# trailer flapping along behind me, highway acceleration is way beyond any gasser with even half the weight on. We've got some big hills around here and even the biggest hill I can pull 70mph with a downshift to 5th gear. My Tahoe pulling 5,000# requires 2nd gear and slows to 60mph on the same hills.
My brother has a newer 6.0L Ford and we had a little race between it and my Tahoe. I was about two car lengths on him until about 50mph, then he shot passed me like I was barely moving. He's driving a 1500# heavier vehicle as well.
I think if we were talking normally aspirated diesel motors, usbseawolf2000 might have a point. But once the turbo winds up, these diesels do a mighty fine job.
..."Simple, diesel does not have much passing power since diesel fuel burn slower than gasoline. Gas electric hybrids offer high torque and even more passing power than gas engine cars."... "
Simply, the above quote might be arm chair analysis.
Dennis
Dennis
That's terrible!
Steve
ODR = Engine Speed * Wheel Diameter / (336 * Wheel Speed)
Consider an instantaneous wheel speed of 50 mph for both cars. The ODR at that instant for the two cars will be,
Car A: 2000 * 25 / (336 * 50) = 2.976
Car B: 6000 * 25 / (336 * 50) = 8.928
Thrust = torque (including drive train loss) * ODR * 24 / (total weight * wheel diameter)
Calculating thrust for the two cars, at 50 mph (multiplication of torque by 0.85 to assume 15% drive train loss)
Car A: (525 * 0.85) * 2.976 * 24 / (3200 * 25) = 0.40g
Car B: (175 * 0.85) * 8.928 * 24 / (3200 * 25) = 0.40g
3) Do both
Dennis
According to research from TNS Automotive:
Fuel_______Percent Of Respondents
Gasoline___53%
Hybrid____51%
Electric____26%
Fuel Cells__24%
Hydrogen___21%
Diesel_____16%
Solar______14%
Nuclear____2%
Other______2%
Hmmm... Solar power cars could be as popular as Diesel by 2010. =D
Dennis
Steve
Steve "
Gasoline___53%
Hybrid____51%
Electric____26%
Fuel Cells__24%
Hydrogen___21%
Diesel_____16%
Solar______14%
Nuclear____2%
Other______2%<<
Uh, aren't all the numbers supposed to add up to 100%?
Anyway, let me add mine here. If diesels were available in California, I would be driving one.
TLEV:*3.4****0.125****0.400****0.400
LEV:**3.4****0.075****0.050****0.010
ULEV:*1.7****0.040****0.050****0.010
SULEV:1.0****0.010****0.020****0.010
Euro IV:0.50****0.010****0.250****0.025
Euro V:0.50****0.040****0.080****0.010 possibly?
___And the Accord Diesel beats Euro IV while breaking world records of many types as the Vtec link shows.
___Finally, a few more accolades as stolen from a Vtec member known as BMC:
http://www.vtec.net/forums/one-message?message%5fid=234672&ne- ws%5fitem%5fid=234399
QUOTES FROM THE UK PRESS ABOUT THE ACCORD DIESEL!
Autocar, 11/03
Evo, 11/03
Autocar, 09/03
Fleet Week, 7/03
What Car? 10/03
Auto Express, 08/03
diesel refinement.”
Car, 10/03
___Good Luck
___Wayne R. Gerdes
Dennis
Dennis
P.S: Nevermind, i found your other post.
Dennis
Envy, envy.
dave
Dennis
Well check out the whole article. http://www.motortrend.com/features/news/112_news006/
Dennis
Dennis
Dennis
gagrice:
Steve
dave
Dennis
