Did you ever find out what was causing the traction activation issue? I have the same issue, driving down interstate, traction light came on, reduced engine power?
found it out. the accelerator pedal position sensor had a bad connection. i unpluged it and plugged it back in and truck runs just like new. also got error code p2138 just in case it happens again save ur money and look for loose connections on any wire connection. GOOD LUCK. im glad i had friends in good places.
I had this problem this past spring and the dealer told me he had to reprogram the transmission. It went away and ran great till about 2 weeks ago and the same problems arose. I'll try looking for the pedal position sensor. Where is this sensor located? Wish me luck
the sensor is located on the foot pedal itself. u cant miss it u can see the wires running off of it. if the engine light stays on after its fixed, disconnect the battery and it will reset itself. DO NOT PAY FOR THIS, IT CAN BE DONE WITHOUT BEING HOOKED UP TO MACHINE!!! dealers dont know [non-permissible content removed] are nothing but ripped off artist.
I am having the exact same problem and my delaer cannot find this document. Can you please verify the document number or let me know what dealership you went to so they can call? This is very frustrating.
After repalcing two relays and other BS we have determined that the body control module that the autoride suspension pump is controlled by needs reseting. Is this a dealer only procedure or can I do it myself without going to Mr. GUTWRENCH!
Had to replace front differential. Vehicle was only serviced by GM dealer and I told them on two ocassions there was a noise in the car. After the car was out of warranty the noise got worse. I went to AAMCO and they replaced the front differential and the vehicle is quiter than when the car was brand new, AAmco said there was hardly any oil in the case. GM paid for 75% of my cost and was just told my rear differential is leaking. This vehicle is kept in a garage and there is not one drop of oil on the floor. Could this be a factory goof? Whoever changes your oil insist they check both differentials and the transfer case and have it noted on your work order. Also had a $600.00 transmission repair when just out of warranty
Vehicle was only serviced by GM garage and I complained about noise on two different ocassions
I had a similar problem with my 2004 yukon denali xl. It died 4 times in the first 6 months of owning it. It was in and out of the dealership with all kinds of repairs, reprogramming and replacements in addition to an examination by a special GMC engineer. Even he couldn't determine the cause of the problem. I finally wrote a letter to Rick Wagoner since I was getting nowhere. After that, the dealership conveniently determined that the problem was caused by the aftermarket DVD player that was installed (at their recommended shop). I was so fed up, I turned in the truck and got a 2006 model... guess what, it's starting to do the same thing - but no after market DVD player this time. So frustrating - crap car, no wonder they're going bankrupt!
I had my '07 Lemon law'd after months of grueling battles and mediations with GM and their phoney mediatator. All mediation ended when my vehicle broke down and GM could NOT repair it. It rotted at the dealership for almost 4 months. GM informed me they would repurchase the vehicle under state lemon law. But it was a total farce designed to defraud the public and give only a superficial sense of justice. In reality, they purchased the vehicle from me at a huge discount stating "mileage depreciation charges." Think you then get paid in cash? Think again! You are given the opportunity to purchase another GM crapbox at LIST price. You are not even entitled to any existing discounts or rebates!!!!!!!!!!!! I was outraged. I had to fight with GM just to get them to at least honor and accept my GM Card earnings!!! What a low life operation GM really is. Meanwhile, the replacement vehicle turned out to be another 4 wheel problem. After much deliberation, I bit the bullet, took a huge depreciation loss on the '08 and purchased a FOREIGN car. I am now enjoying a well made, high mpg vehicle that works without problems. . Good luck to all those folks who have been suckered into buying a GM product. They will need that and more.
A few basic things I would try if I am in your situation, if you not already: 1. Does the system respond/operate when you add weight to the rear of the vehicle (i.e. start the engine, open the tailgate and sit in the trunk area for 30 seconds or so, do you hear the compressor running within the 30 seconds at all)? 2. The on board compressor is generally located behind the driver-side rear wheel, if its not running at all, it could be of the position sensor/switch that's out of adjustment, or some kind of electrical issue... I would by-pass the switch and verify that the compressor is operational first (make sure you know what you are doing before apply 12 volts to any lead/connector to avoid any damage)... 3. If the compressor is ON constantly, there may be a leak in the system (i.e. line, shock, or possibly damaged/out-of-adjustment sensor/switch).... If the compressor is running constantly when the ignition is turned on, I would find and remove the fuse to the Autoride system immediately until the problem is fixed to avoid damage to the compressor and shock(s)... Good Luck!
help...2003 denali is falling apart..i love this car..but this is ridiculous! oh, and i paid to have the onstar upgraded and after 3 times at the dealership..it still does not work properly..and the driver's side seat heater does not work...all other seats do...anyone????
I have a 2003 Yukon XL Denali purchased used in March 2006 with 58000 miles. We have routinely battled with the non-start issue. We've tried bigger batteries, shutting all accessories off etc. We can't figure it out. There is something randomly draining the battery. We actually went all summer without the problem and now it has started up again. My guess is something to do with the rear glass closure. But the repair shops figure there is no way to truly trace it as it is random and there are so many electrical switches and accessories. If someone has found the fix, it would be great to get any help.
It seems that electronics are a problem with this year/model or maybe with the denalis in general. I noticed recently when I turn the car off and take the keys out and shut the door(as in completely exit the vehicle including locking the doors) the radio stays on. I have to open the car doors up again and then close it up. That has been doing the trick. Or else, a better option is just turning the radio off when I turn the engine off. In any case, it is a pain in the neck. In thepast month I have had several issues come up. The raidio staying on, the driver seat switch seems to be reversed. To move the seat forward, you have to push back and visa-versa. Also, the door ajar message comes on randomly when the door is closed and then it locks and unlocks the doors. I have a feeling this is all probably related to some electrical short. I am just hesitant about getting it looked at for fear of the cost. Oh and my speedometer is stuck up on like 140mph. Which is strange. Last but not least the hydraulics seem to be resetting themselves often.
The speedometer thing happened after the last battery install. Try removing the positive lead to the battery. It resets some of the electronics.
The fix for the speedometer was starting and switching off the engine many times and each time the spedo dropped a bit until finally reaching zero again.
There is a dealer recall on instruments that is open for my 2003. If your truck is 2003, you can take it to the dealer to fix the odometer on GM's dime.
General Motors is providing owners with a special coverage that extends the warranty on the instrument panel cluster (..a condition where one or more of the instrument panel gauge needles may stick, flutter or become inoperative. This may cause inaccurate readings including the speedometer and fuel gauge.) Coverage within 7 years of orig. service date or 70K miles.
I figured it out this week. Firestone replaced my previous (dead) battery with a 700 CCA battery. For three months I had to jump start this hulk every Monday morning. Took it back to Firestone and they said they could'nt find anything wrong. Chevy dealership lied to me that they couldn't replicate the problem. In fact GMC dealership also told me the same lie. It turns out that the truck needs an 800 CCA battery. I bought one and the truck has been good ever since.
The auto shops do not stock these batteries so they just give you the 700 CCA, what the heck. I only found this out after doing a little research on interstate batteries.
I had the same problem with my 04 and it was something that was recalled so check that out at your dealership they fixed mine and its been good for over a year now.
In 2005 I bought a 2005 yukon denali and a 100,000 mile extended warranty. Now in 2009 I find out I bought a 90,000 mile warranty. I went back to the dealership and was told GMC had no 100,000 mile warranty. Has anyone else had this problem? I know I bought a 100,000 mile warranty because I was there when I bought it. Can someone help me out with this problem?
I had a 100,000 mile extended warranty that I bought for my 03 denali. It was through GM but it was 3 years or 100,000 whichever came first. I purchasaed it when the new car warranty expired. The three years came first. They sent me a small booklet with the information. I think it had a card with the warranty number on it that I kept in my glove box.
I wish I could be more specific, but when it expired last November I threw it away. Good luck. Hope you get this resolved.
I believe the 100K is including the original 36K. I purchased a Continental plan which extended the period 7 years (from purchase date -10 years total) and 100K TOTAL, whichever comes first. Take a look at the contract.
Recently I sent my IPC in to a repair shop for the stepper motor replacement / Calibration / Update . The vehicle was running perfectly when I parked it & removed the cluster. Upon re-installing the cluster, the battery was dead and the vehicle would not start. After charging the battery, I tried to start my Yukon again to no avail. After some troubleshooting, the fuel rail had no pressure, ie. the fuel pump was apparently inhibited
Anyone have any ideas why it chose now to quit? I find it unlikely the fuel pump went out at this precise time.
After reading many of the posts on this site, I don't know if I'm blessed, lucky, or just an unusual case. I own a 2004 Yukon XL 4.8L loaded with all the bells and whistles but not quite the Denali. I had reservations about the AWD and the fact that a service contract for the Denali was twice as much as my truck. Anyway, five years, 130,000 miles and the only repair I've done is the instrument cluster. I still have the original front brake pads, although I've had a replacement set in the garage for over two years. I refuse to replace them til the pad gets too thin. I just wanted everyone to know that my Yukon has been great, I love driving it, and will continue to drive til the wheels fall off.
Did you ever find an answer to your problem. I have the same issue and can't seem to find out why. I know the liftgate lock worked up to a certain point but it quit working and am trying to find out why.
I had this same problem and finally corrected it by replacing both front wheel speed sensors ( about 2 hours labor ) you have to remove the brakes and rotors to access the sensor. The parts cost $ 54.00 each at Ourisman Chevrolet, Bowie, Md.
UPDATE - Replaced body control computer - did not solve the problem. Now I just remove the fuse to keep battery from running down and put fuse in when I need to activate auto ride for trailering. Cannot figure this one out. Dealer said suspension control computer was bad. NOT SO. NEED AN EXTRA ONE?
I have a 2003 Yukon XL Denali with 72 months or 100,057miles which ever comes first. I thought I bought the Major Guard for 2200.00 but was sent the Value Guard contract, 72 mos. or 60,000 miles but my card and coverage agreement reads 72 and 100,057? Either way GMC sucks out whenever they can and yes they do sell 100,000 optional service contract plan. Not 100.000 mile warranty "wording"
Well well well I have a Random Misfire so far I have done tune up wires fuel injector cleaning,throttle body and intake.Once you drive above 50 MPH and stay above that for about 10 Min check engine flashes then stays on scan it and the same code What am I missing hear.
I have a similar problem with my 2004 Denali, vibration in the steering wheel between 1500 - 2000 rpm and 50-55 mph. Had the vehicle at the dealership twice and they still cannot figure out the problem. Just changed the rims to 22 inch, still the same problem. They were hoping this would have solved the problem. Now I'm in a battle with them because they have not clue what to do.
Some times bad wheel bearing can be one of the cause to wheel vibration; but, in this case have you checked the steering/ball joints first to see if any is worn (have the joints been regularly lubricated)? One other possibility is the wheel alignment, assuming your wheels are balanced, and all joints are solid...
I just purchased a '02 Denali XL & it has this noise in the front drivers side that sounds like a rearend bearing noise! Has anyone had this problem with the Denali XL & what was done to fix it??
I have a 2004 Yukon XL Denali. The front air works great as I just had it fixed. The rear still blows warm air with rear ac on high. Not operator error. Checked and double checked settings. Wondered if maybe vent door not opening or something. Any help would be appreciated. Thanks in advance.
The noise you're hearing is probably from the front differential. I drove mine about 50,000 miles before I got worried it would finally break at about 100,000 miles. The repair was expensive. I think they said it was the pinion gears.
I JUST FOUND YOUR MESSAGE - WILL TAKE BACK & ASK DEALER TOMORROW - WENT YESTERDAY & THEY TOLD ME IT WAS STEERING SENSOR - $250 LATER - ASKED WIFE HOW IT DROVE ON WAY HOME ? SHE SAID IT DID THE SAME THING - WHAT THE HECK ! WILL GET BACK & LET YOU KNOW OUTCOME - THANKS !
:shades: I have a 2004 Denali XL with 110,000 miles. The vehicle is a beast, I towed my 2nd vehicle a 1999 Town and Country from the mid-west to the east coast thru the mountains with absolutely no problems at all(the 6.0L is a monster). The following is what I had to have repaired while it was still under warranty, the driver seat motor(replaced), DVD player(replaced), steering gear(replaced) at about 20,000 miles and now once again when making left turns the steering gear squeals and there is a vibration in the steering wheel. Overall I am happy with the truck, but need advice on the steering gear. The thing is a 04 and is still turning heads around town.
Went to vacuum carpet in Yukon last night and found drivers side floor soaking wet. I lifted up the carpet to dry out and seen a plug missing from floor so Im hoping this is the culprit. Read somewhere there are drain holes that plug up. Does anyone know where they are?
I have a 168K miles on my Yukon. The vehicle came with a ride stabilizing feature. I have never replaced anything on the suspension. This being my wifes car I do not drive it much, but when I had it loaded with family I noticed for the first time the car not riding level(no comments please). When I use to start the car most of the time there seemed to be a compressor that turned on to level the vehicle, I can not remember the last time I heard this. Any recommendations? I am sure GM will want to replace everything, is there a better fix?
There are a few places you can check: 1. if you have a Sun roof, there is a drain hole at each side front corner, you can only see them from the top/outside when you have the glass opened. 2. In-let vents in the front, below the windshield, quite frequently leafs clog the drain holes in these openings, cause water overflow in to the cabin area... I would use a garden hose water with amount of water at a time at each area to try and isolate the source of the leak. Good Luck!
The compressor should be located in either left or right rear tire area. The electrical connector from the compressor to the voltage source should be mounted behind the rear bumper (close to the Spare tire). You are correct, the compressor turns ON for the first few seconds after you switched the ignition to ON, then as the ride height reached to a specific level the compressor will stop/OFF. You may want to check the fuse under the dash and also if any relay/more fuse in the engine compartment relay/fuse box (check your owner's manual for location). Good Luck!
i have a 2003 yukon base and i have had the same thing, its the steering shaft, its needs to be adjusted. It happens all the time even after you fix it you hit a big bump and its does it again. u could prob replace it but i dont know how much.
I feel bad for everyone that purchased this truck and have had so many problems. This is Professional Grade???
OW
Good Luck!
The last time it happened the dealer pointed to a seat switch that was stuck on. They reall have no clue, however.
OW
OW
OW
OW
HELP!
